Hi all, long time listener, first time caller. I received 'TPMS Malfunction' in the MMI and now have 03543 - Mechanical Malfunction in Suspension permanently stored in Tire Pressure II. Full autoscan is below. After clearing only the steering wheel (expected, I swapped to a flat bottom!) and 03543 return. All tire pressures are correct. I am aware of a TSB which references this error stored in the ABS module but I'm not sure this is the same. I was thinking about pulling the battery cable then going on a long drive as a next step but I'm wondering what sort of hardware issue might cause this code. Thanks in advance for any suggestions.
Wednesday,16,November,2022,20:26:48:62643
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4543.4
VIN: WAUFGAFB6BN064681 License Plate: NOV2022FULL
Mileage: 188380km-117053mi Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4C 4F 52 53 55 56
5F 62 6C 72 76
VIN: WAUFGAFB6BN064681 Mileage: 188380km-117053miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4F1 910 551 D HW: 4F1 907 551
Component: 3.0l V6 TFSI 0050
Revision: --H07--- Serial number:
Coding: 0105000A190F0120
Shop #: WSC 00642 210 45725
VCID: 2411E7BF72D4B41B37A-8070
Part No SW: 4F9 910 156 A HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0020
Revision: --H05--- Serial number: 4609036
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2A0D098710F0626B0D6-807E
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BG
Component: ESP8 quattro H03 0060
Coding: 0020921
VCID: 6E85C597EC984E4B91E-803A
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401771096
Coding: 0000003
Shop #: WSC 35864 000 1048576
VCID: 2517FABB79EE4D13204-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000077 Serial number: 00000000788341
Coding: 0524326
VCID: 1D67D25B51BE85D3784-8048
Part No SW: 4F0 910 279 AF HW: 4F0 907 279
Component: ILM Fahrer H30 0390
Coding: 0013123
Shop #: WSC 02335 785 00200
VCID: 6D87C29BE19EB553A84-8038
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H11 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
01494 - Bulb for Parking Lamps; Left (M1)
Fault Status: 00101011
Reset counter: 166
Mileage: 187864 km
Date: 2022.10.10
Time: 11:38:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 1577CA7BA58EDD93B04-8040
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 R HW: 4F0 959 655 H
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FA001J6KV
Coding: 303142373035303030314A55304C34463053
Shop #: WSC 02323 785 00200
ROD: EV_Airba10AURB4.rod
VCID: 36352DF7D8C8368B99E-8062
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000005EHX
Serial number: 3574SRB40000D44C8179
Serial number: 3584SRB40000D4A04A9B
Serial number: 3516HRB401S2EE2ASB3F
Serial number: 3526HRB402O2IFG0QC5N
Serial number: 3554NRB4000060250F2Q
Serial number: 3564NRB4000060304DF
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90025110210159
Coding: 0002341
VCID: 270BF0B303E25F03128-8072
Component: E0221 H02 0100
01747 - Sensor for Heated Steering Wheel (Z36)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 136
Mileage: 170752 km
Date: 2021.01.03
Time: 00:18:29
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 H HW: 4F0 920 983 H
Component: KOMBIINSTR. H09 0209
Revision: 00000000 Serial number: FKX20UT1C
Coding: 8BD70A050300CF05020201
Shop #: WSC 02391 823 56573
VCID: 313F1EEB312611B3CCC-8064
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L111240029
Coding: 000303
VCID: 392F26CBE956D9F374C-806C
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002790411488
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002286831
Coding: 00581300004011110000
VCID: 323D11E734202AABB56-8066
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0004000210557
Coding: 011F07204E40410001
VCID: 48C9530FA2BCB07BFB2-801C
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01433616470000
Coding: 4618269
VCID: 35372AFBC94E3D93904-8060
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760031440
Coding: 0623301
VCID: 2313E4A377DAB3234E0-8076
02214 - Tire Pressure Warning
Reset counter: 173
Mileage: 187083 km
Date: 2022.06.26
Time: 10:49:11
Hex Value: 0x00D0
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.00 V
Temperature: 33.0°C
(no units): 116.0
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 136
Mileage: 188381 km
Date: 2022.11.09
Time: 13:04:09
Hex Value: 0x8000
Hex Value: 0x0000
Hex Value: 0x006D
Voltage: 11.30 V
Temperature: 10.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000865753
Coding: 0002014
VCID: 5EE595571C38DECB21E-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0004000217728
VCID: 47CB5033AFA2BF03F28-8012
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
VCID: 211FEEAB6DC6A1335CC-8074
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 M
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 44D1473F9294941B17A-8010
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471BZ0B7559450
Coding: 020007020100000000
VCID: 5DE7925B1D3EC5D3384-8008
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 146
Mileage: 187606 km
Date: 2022.08.23
Time: 08:34:05
Bin. Bits: 00000000 00000001
Part No SW: 4E0 035 664 B HW: 4E0 035 664 A
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 488B 0B7545171
Coding: 010200000002E1EF41000305EF6300030000
VCID: 2313E4A37BDAB3234E0-8076
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466AU0B0431388
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 T
Component: Bedienteil MM H01 0060
Serial number: 00000001781047
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0004000220612
Coding: 010E07204040220001
VCID: 46D55D37A8A8A60B09E-8012
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0821ZF
Coding: 1000304
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0004000220645
Part No SW: 4L0 910 283 B HW: 4L0 919 283 B
Component: Parkhilfe 4-Kan H03 0500
Revision: 00H03000 Serial number: 37231103106968
Coding: 0221206
VCID: 290FF68B15F6697304C-807C
00456 - Control Module for Access and Start Control (J518)
End----------(Elapsed Time: 01:49, VBatt start/end: 14.3V/14.5V)-----------
