This is the link to the photo.
It is related to UDS adaptation, ABS brakes, new value , channel 1B, IDE 07006 - tire pressure monitoring display: tire selection.
My questions are:
- What is the value i shall put in the New Value cell?
- Are there other adaptations/basic settings/coding i need to do further to activate the indirect TPMS on this car?
- Any steps i need to do after all the adaptations/coding/basic settings (besides driving the car for an hour or more including highway)?
Full Scan below:
Friday,29,July,2022,19:55:27:57643
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: TMBAC6NE6G0083379 License Plate: 3379
Mileage: 88126 Repair Order:
Address 01: Engine Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 HD HW: 04E 907 309 BH
Component and/or Version: R4 1.4l TFS H22 2603
Software Coding: 01250032232419081000
Work Shop Code: WSC 73430 031 00000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001006 (SK37)
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D87C4C6DD1FECD3149-8038
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
10591 - Cylinder 1
P0301 00 [096] - Misfire Detected
10593 - Cylinder 3
P0303 00 [096] - Misfire Detected
10594 - Cylinder 4
P0304 00 [096] - Misfire Detected
10592 - Cylinder 2
P0302 00 [096] - Misfire Detected
Address 02: Auto Trans Labels: 0CW-927-769.clb
Control Module Part Number: 0CW 300 048 L HW: 0AM 927 769 E
Component and/or Version: GSG DQ200G2_M H05 0610
Software Coding: 0014
Work Shop Code: WSC 04940 001 00001
ASAM Dataset: EV_TCMDQ200021 001001 (SK37)
ROD: EV_TCMDQ200021_VW26.rod
VCID: 45D75C66A52FF493BC9-8010
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 3Q0 907 379 T HW: 3Q0 907 379 C
Component and/or Version: ESC H32 0393
Software Coding: 1A076A912428116F007A060741CC245856248800608224F2002100004002
Work Shop Code: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033 (SK37)
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 4BC36A5E834B02E36AD-801E
Address 05: Acc/Start Auth. Labels: 5Q0-959-435.clb
Control Module Part Number: 5Q0 959 435 A HW: 5Q0 959 435
Component and/or Version: VWKESSYMQB 021 0604
Software Coding: 030C0C
Work Shop Code: WSC 73430 790 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011 (SK37)
VCID: 3A2D3F9ADCD18B6BC1B-806E
Address 08: Auto HVAC Labels: 5G0-907-044.clb
Control Module Part Number: 5E0 907 044 Q HW: 5E0 907 044 Q
Component and/or Version: Climatronic H04 1002
Software Coding: 01010004000100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 004131 (SK37)
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 333312BEFBBB7A2302D-8066
262659 - High Pressure Sensor
B10AE 04 [008] - Internal System Fault
Reset counter: 123
Mileage: 75057 km
Date: 2021.10.02
Time: 13:18:32
Outside temperature: 42.5 C
Engine RPM: 900 /min
Temperature downstream of evaporator: 26.0 C
System run time-Terminal 15 on: 0 s
Address 09: Cent. Elect. Labels: 5Q0-937-08X-HV1.clb
Control Module Part Number: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component and/or Version: BCM MQBAB H H24 0175
Software Coding: 0C111A42424722FB47E04000000C07080800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001 (SK37)
ROD: EV_BCMBOSCH_015.rod
VCID: 094F9056C9B750F3981-805C
Address 10: Park/Steer Assist Labels: 5Q0-919-294.clb
Control Module Part Number: 5Q0 919 294 K HW: 5Q0 919 294 A
Component and/or Version: PARKHILFE 8K H03 0054
Software Coding: 0031151051
Work Shop Code: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA18AU3700000 002026 (SK37)
VCID: 43D3427EAB1BCAA392D-8016
Address 15: Airbags Labels: 5Q0-959-655.clb
Control Module Part Number: 3Q0 959 655 AT HW: 3Q0 959 655 AT
Component and/or Version: Airbag VW20 013 0200
Software Coding: 88CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116 (SK37)
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 1079BD32AAED613B5FF-8044
Address 16: Steering wheel Labels: 5Q0-953-549.clb
Control Module Part Number: 5Q0 953 507 HQ HW: 5Q0 953 549 E
Component and/or Version: Lenks. Modul 003 0110
Software Coding: 1410
ASAM Dataset: EV_SMLSKLOMQB 017001 (SK37)
VCID: 0C41A942C6C545DBA37-8058
Address 17: Instruments Labels: 5G0-920-XXX-17.clb-SRI3
Control Module Part Number: 5E0 920 780 B HW: 5E0 920 780 B
Component and/or Version: KOMBI 206 7640
Software Coding: 47A402182880000801082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005 (SK37)
ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
VCID: 2615FBEA38691F8B953-8072
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_BCME_0x23 keine Kommunikation]
Reset counter: 123
Mileage: 75057 km
Date: 2021.10.02
Time: 13:18:36
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1223
Software Coding: 030100042F085700EB00024A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020 (SK37)
ROD: EV_GatewLear_013.rod
VCID: 75B7ECA6B54F2413EC9-8020
Address 2B: Steer. Col. Lock Labels: 5Q0-905-861.clb
Control Module Part Number: 5Q0 905 861 A HW: 5Q0 905 861 A
Component and/or Version: ELV-MQBA H01 0120
Software Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111 (SK37)
ROD: EV_ELVMarquMQB.rod
VCID: 343111A2FEB57D1B1B7-8060
Control Module Part Number: 5Q0 959 760 A HW: 5Q0 959 760 A
Component and/or Version: Sitzmemory H06 0009
Software Coding: 001000000000010001A081808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015 (SK37)
ROD: EV_SeatMemorDriveSide_001.rod
VCID: 3B233A9ED3EBB263DAD-806E
Address 42: Door Elect, Driver Labels: 5QX-959-X93-42.clb
Control Module Part Number: 5Q4 959 593 E HW: 5Q4 959 593 B
Component and/or Version: TSG FS 010 0031
Software Coding: 00150120DE00040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 (SK37)
VCID: 47CB566E9F23E6834E5-8012
Address 44: Steering Assist Labels: 5Q0-909-144.clb
Control Module Part Number: 5Q0 909 144 S HW: 5Q0 909 144 R
Component and/or Version: EPS_MQB_ZFLS 126 1063
Software Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140 (SK37)
VCID: 44D14162AE15CD9BAB7-8010
Address 52: Door Elect, Pass. Labels: 5QX-959-X92-52.clb
Control Module Part Number: 5Q4 959 592 E HW: 5Q4 959 592 B
Component and/or Version: TSG BFS 010 0031
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 (SK37)
VCID: 46D55B6A9829FF8BB53-8012
Address 55: Headlight Range Labels: 7P6-907-357.clb
Control Module Part Number: 7P6 907 357 D HW: 7P6 907 357 A
Component and/or Version: AFS-ECU H07 0090
Software Coding: 03CA00003F000000
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 (SK37)
VCID: 40D94D72BA0DD1BB8FF-8014
Address 5F: Information Electr. Labels: 3V0-035-MIB-STD2.clb
Control Module Part Number: 5Q0 035 840 A HW: 5Q0 035 840 A
Component and/or Version: MU-S--ER H24 0245
Software Coding: 03730100FF00000011110001001000002F0200D40120010002
ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37)
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 2B030ADE238B22E34AD-807E
