client bought this Tiguan from auction, so previous repair history is not known, any hint towards the right ABS coding is highly appreciated
Wednesday,16,November,2022,13:12:17:40543
VCDS Version: 22.10.0.1 (x64) HEX-NET2 CB: 0.4623.4
VIN: WVGZZZ5NZ9W103321 License Plate: TIGUAN TDI CBA 2ND SCAN
Mileage: 79680km-49510mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 56 62
72
VIN: WVGZZZ5NZ9W103321 Mileage: 79680km-49510miles
03-ABS Brakes -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 016 H HW: 03L 906 022 G
Component: R4 2.0l TDI G000AG 9979
Revision: 13H01--- Serial number: VWX7Z0I23NV89W
Coding: 0000175
Shop #: WSC 20048 959 94411
VCID: B720C3593344E1439A8-80E2
VINID: 9E65EAAAA15EA899C10030C20494D7F0DC
049682 - Steering Column Control Module
U0212 - 000 - No Communications
Mileage: 79684 km
Time: 21:10:38
RPM: 782 /min
Temperature: 20.7°C
Voltage: 13.30 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Temperature: 54.9°C
009754 - Coolant Pump 2
P261A - 000 - Open circuit
Mileage: 79684 km
Time: 21:10:40
RPM: 782 /min
Voltage: 13.38 V
Lambda: 79.7 %
Bin. Bits: 10011111
Bin. Bits: 00000000
Temperature: 96.3°C
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Mileage: 79684 km
Time: 21:10:42
RPM: 782 /min
Voltage: 13.45 V
Voltage: 13.45 V
Voltage: 13.45 V
Voltage: 13.45 V
Part No SW: 09G 927 750 FD HW: 09G 927 750 FD
Component: AQ 250 6F 1124
Revision: 00H76000 Serial number:
Coding: 0000328
Shop #: WSC 01324 785 00200
VCID: F8A200657EDA2E3B532-80AC
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000001639817
Coding: 0011554
VCID: B924C5610550F7336CC-80EC
Reset counter: 250
Mileage: 79684 km
Time: 21:15:16
Hex Value: 0x0000
Voltage: 13.25 V
Bin. Bits: 00011110
Count: 243
Hex Value: 0x0000
Reset counter: 250
Mileage: 79684 km
Time: 21:15:16
Hex Value: 0x0000
Voltage: 13.25 V
Bin. Bits: 00011110
Count: 165
Hex Value: 0x0000
03201 - Adaptation Overboost
Reset counter: 250
Mileage: 79684 km
Time: 21:15:16
Reset counter: 250
Mileage: 79684 km
Time: 21:15:16
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 133 1213
Revision: 00133024 Serial number: 00000000000000
VCID: FBA81F694FEC05233E0-80AE
013 - Check DTC Memory
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
007 - Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009149977
Coding: 01880FA300041C0047190000140000000009FF475C400104420000000000
VCID: B338F749273C0D63A60-80E6
Subsystem 1 - Part No: 5N2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 171108 012 0203
Coding: 00038805
Shop #: WSC 01324
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 250
Mileage: 79684 km
Voltage: 13.40 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5N0 919 475 A HW: 5N0 919 475
Component: PARKHILFE 4K H07 0020
Revision: -------- Serial number: 60530831806062
Coding: 100102
VCID: B720C3593F44E1439A8-80E2
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01101110
Reset counter: 0
Time Indication: 15
Temperature: 23.0°C
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__201 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQ5AYSO
Coding: 0012337
Shop #: WSC 01324 020 00200
VCID: BB28DF690F6CC5237E0-80EE
Subsystem 1 - Serial number: 6333FTS605682998
Subsystem 2 - Serial number: 6343FTS605512998
Subsystem 3 - Serial number: 6353ETS6ESJPU5KR
Subsystem 4 - Serial number: 6363ETS6DBC1V5KR
Fault Status: 01101101
Reset counter: 250
Mileage: 79684 km
Time: 21:12:29
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012002
Component: E0221 002 0030
Part No SW: 5N0 920 870 D HW: 5N0 920 870 D
Component: KOMBIINSTRUMENT VDD 2420
Revision: V0005000 Serial number: VWX7Z0HN3NP0R3
Coding: 0006104
Shop #: WSC 01286 386 08256
VCID: B134FD41DD203F73D4C-80E4
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 211108F2000362
Coding: 75A27F06001202006003
01304 - Radio
Reset counter: 250
Mileage: 79684 km
Time: 21:13:16
Mileage: 79684 km
Time: 21:13:12
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T4NZ503
VCID: FDAC117151F80B13004-80A8
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: CBC88FA95FCC75A3CE0-809E
Component: IMMO VDD 2420
00003 - Control Module
014 - Defective
Mileage: 63421 km
Time: 00:25:23
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2006
Coding: 0000692
VCID: B43AF45522320A5BBFA-80E0
Part No: 5N0 909 144 C
Component: EPS_ZFLS Kl. 202 2303
Revision: 00H15000
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 81800A0052830C7F3F04840570085FCE90FC00
Shop #: WSC 00999 444 64523
VCID: 83586789371C7DE3760-80D6
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
Reset counter: 250
Mileage: 79684 km
Time: 21:14:01
Reset counter: 250
Mileage: 79684 km
Time: 21:14:01
Part No SW: 5N0 959 702 B HW: 5N0 959 702 B
Coding: 0000692
VCID: B53CC95129481353884-80E0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H09 Serial number: 00000000162265
Coding: 0000057
VCID: AE0EE63DCC1E208BC9E-80FA
Address 56: Radio
Part No SW: 5N0 959 703 B HW: 5N0 959 703 B
Component: Tuer-SG 007 2001
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: B63ECE5D344E184B81E-80E2
Part No SW: 5N0 959 704 B HW: 5N0 959 704 B
Coding: 0000144
End----------(Elapsed Time: 02:03, VBatt start/end: 13.2V/13.3V)-----------
