Resolved Tiguan 2.0tdi lost ABS coding
Resolved
Fredrick Awuor
Kenya
C?ID=309834
client bought this Tiguan from auction, so previous repair history is not known, any hint towards the right ABS coding is highly appreciated
Wednesday,16,November,2022,13:12:17:40543
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
VIN: WVGZZZ5NZ9W103321   License Plate:  TIGUAN TDI CBA 2ND SCAN
Mileage: 79680km-49510mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 56 62
          72
VIN: WVGZZZ5NZ9W103321   Mileage: 79680km-49510miles
03-ABS Brakes -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 016 H    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000AG  9979
   Revision: 13H01---    Serial number: VWX7Z0I23NV89W
   Coding: 0000175
   Shop #: WSC 20048 959 94411
   VCID: B720C3593344E1439A8-80E2
   VINID: 9E65EAAAA15EA899C10030C20494D7F0DC
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 79684 km
                    Time: 21:10:38
                    RPM: 782 /min
                    Temperature: 20.7°C
                    Voltage: 13.30 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 54.9°C
009754 - Coolant Pump 2
               P261A - 000 - Open circuit
                    Mileage: 79684 km
                    Time: 21:10:40
                    RPM: 782 /min
                    Voltage: 13.38 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 96.3°C
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
               P1116 - 000 - Open Circuit
                    Mileage: 79684 km
                    Time: 21:10:42
                    RPM: 782 /min
                    Voltage: 13.45 V
                    Voltage: 13.45 V
                    Voltage: 13.45 V
                    Voltage: 13.45 V
   Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
   Component: AQ 250 6F           1124
   Revision: 00H76000    Serial number:
   Coding: 0000328
   Shop #: WSC 01324 785 00200
   VCID: F8A200657EDA2E3B532-80AC
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000001639817
   Coding: 0011554
   VCID: B924C5610550F7336CC-80EC
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:15:16
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 243
                    Hex Value: 0x0000
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:15:16
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 165
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:15:16
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:15:16
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: FBA81F694FEC05233E0-80AE
            013 - Check DTC Memory
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
            007 - Short to Ground
   Revision: 00H54000    Serial number: 00000009149977
   Coding: 01880FA300041C0047190000140000000009FF475C400104420000000000
   VCID: B338F749273C0D63A60-80E6
   Subsystem 1 - Part No: 5N2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 171108  012 0203
   Coding: 00038805
   Shop #: WSC 01324
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 250
                    Mileage: 79684 km
                    Voltage: 13.40 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5N0 919 475 A    HW: 5N0 919 475
   Component: PARKHILFE 4K  H07 0020
   Revision: --------    Serial number: 60530831806062
   Coding: 100102
   VCID: B720C3593F44E1439A8-80E2
16347 - Control Module - EEPROM Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Time Indication: 15
                    Temperature: 23.0°C
   Component: J234__201 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPQ5AYSO
   Coding: 0012337
   Shop #: WSC 01324 020 00200
   VCID: BB28DF690F6CC5237E0-80EE
   Subsystem 1 - Serial number: 6333FTS605682998
   Subsystem 2 - Serial number: 6343FTS605512998
   Subsystem 3 - Serial number: 6353ETS6ESJPU5KR
   Subsystem 4 - Serial number: 6363ETS6DBC1V5KR
                    Fault Status: 01101101
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:12:29
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0012002
   Component: E0221           002 0030
   Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0005000    Serial number: VWX7Z0HN3NP0R3
   Coding: 0006104
   Shop #: WSC 01286 386 08256
   VCID: B134FD41DD203F73D4C-80E4
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 211108F2000362
   Coding: 75A27F06001202006003
01304 - Radio
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:13:16
                    Mileage: 79684 km
                    Time: 21:13:12
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T4NZ503
   VCID: FDAC117151F80B13004-80A8
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: CBC88FA95FCC75A3CE0-809E
   Component: IMMO            VDD 2420
00003 - Control Module
            014 - Defective
                    Mileage: 63421 km
                    Time: 00:25:23
   Part No SW: 5N0 959 701 B    HW: 5N0 959 701 B
   Component: Tuer-SG         008 2006
   Coding: 0000692
   VCID: B43AF45522320A5BBFA-80E0
   Part No: 5N0 909 144 C
   Component: EPS_ZFLS Kl. 202    2303
   Revision: 00H15000
   Component:    KSG PQ35 G2  020 0205
   Coding: 81800A0052830C7F3F04840570085FCE90FC00
   Shop #: WSC 00999 444 64523
   VCID: 83586789371C7DE3760-80D6
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
   Part No SW: 5N0 959 702 B    HW: 5N0 959 702 B
   Coding: 0000692
   VCID: B53CC95129481353884-80E0
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000162265
   Coding: 0000057
   VCID: AE0EE63DCC1E208BC9E-80FA
Address 56: Radio
   Part No SW: 5N0 959 703 B    HW: 5N0 959 703 B
   Component: Tuer-SG         007 2001
   Coding: 0000144
   Shop #: WSC 01324 785 1012552
   VCID: B63ECE5D344E184B81E-80E2
   Part No SW: 5N0 959 704 B    HW: 5N0 959 704 B
   Coding: 0000144
End----------(Elapsed Time: 02:03, VBatt start/end: 13.2V/13.3V)-----------
JMR
Romania
C?ID=432218
since we don't know anything about it ..0011554 is suggested to be the right one , but you can try 0011551 or 0011524
Inst there a coding helper for this car in the vcds ?
Fredrick Awuor
Kenya
C?ID=309834
Thank you so much,I will try tomorrow and get back
Sounds good. Support has a copy of this scan via e-mail so if you have any issues please report back and we can dig into it.
Fredrick Awuor
Kenya
C?ID=309834
all coding's accepted, but with control module incorrectly coded error,that does not go away
Scan with coding 0011554
Friday,18,November,2022,13:01:57:40543
VIN: WVGZZZ5NZ9W103321   License Plate: 1ST CODING
Mileage: 79740km-49548mi   Repair Order:
          72
VIN: WVGZZZ5NZ9W103321   Mileage: 79740km-49548miles
10-Park/Steer Assist -- Status: Not registered 0011
   Coding: 0000175
                    Mileage: 79747 km
                    Time: 20:46:34
                    RPM: 782 /min
                    Temperature: 27.9°C
                    Voltage: 13.15 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 71.1°C
                    Mileage: 79747 km
                    Time: 20:46:36
                    RPM: 782 /min
                    Voltage: 13.07 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 94.5°C
                    Mileage: 79747 km
                    Time: 20:46:38
                    RPM: 782 /min
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
   Coding: 0000328
   Coding: 0011554
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:03:09
                    Hex Value: 0x0004
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 243
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:03:09
                    Hex Value: 0x0004
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 165
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:03:09
            010 - Open or Short to Plus
   Coding: 00038805
   Shop #: WSC 01324
                    Fault Status: 01101100
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.25 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.20 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.40 V
   Coding: 100102
            014 - Defective
                    Reset counter: 0
                    Time Indication: 15
                    Temperature: 23.0°C
   Coding: 0012337
                    Reset counter: 38
                    Mileage: 79684 km
                    Time: 21:12:29
   Coding: 0012002
   Coding: 0006104
   Coding: 7D827F06001202006003
01304 - Radio
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 20:54:09
                    Mileage: 79747 km
                    Time: 20:54:05
   Subsystem 1 - Part No: 1K6 919 879
No Faults Found
   Coding: 0000005
            014 - Defective
                    Mileage: 63421 km
                    Time: 00:25:23
   Coding: 0000692
   Revision: 00H15000
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
   Coding: 0000692
   Coding: 0000057
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 03:22, VBatt start/end: 13.1V/13.3V)-----------
Scan with 0011551 coding
Friday,18,November,2022,13:05:14:40543
VIN: WVGZZZ5NZ9W103321   License Plate:  2ND CODING
          72
   Coding: 0000175
                    Mileage: 79747 km
                    Time: 20:46:34
                    RPM: 782 /min
                    Temperature: 27.9°C
                    Voltage: 13.15 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 71.1°C
                    Mileage: 79747 km
                    Time: 20:46:36
                    RPM: 782 /min
                    Voltage: 13.07 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 94.5°C
                    Mileage: 79747 km
                    Time: 20:46:38
                    RPM: 782 /min
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
   Coding: 0000328
   Coding: 0011551
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:08:44
                    Hex Value: 0x0004
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 243
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:08:44
                    Hex Value: 0x0004
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:08:44
                    Hex Value: 0x0004
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 165
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:08:44
   Coding: 00038805
   Shop #: WSC 01324
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.25 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.20 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.40 V
   Coding: 100102
            014 - Defective
                    Reset counter: 0
                    Time Indication: 15
                    Temperature: 23.0°C
   Coding: 0012337
                    Reset counter: 38
                    Mileage: 79684 km
                    Time: 21:12:29
   Coding: 0012002
   Coding: 0006104
01304 - Radio
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 20:54:09
                    Mileage: 79747 km
                    Time: 20:54:05
   Coding: 0000005
            014 - Defective
                    Mileage: 63421 km
                    Time: 00:25:23
   Coding: 0000692
   Revision: 00H15000
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
   Coding: 0000692
   Coding: 0000057
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:40, VBatt start/end: 13.0V/13.2V)-----------
Scan with 0011524 coding
Friday,18,November,2022,13:12:47:40543
VIN: WVGZZZ5NZ9W103321   License Plate:  TIGUAN 3RD CODING
          72
   Coding: 0000175
                    Mileage: 79747 km
                    Time: 20:46:34
                    RPM: 782 /min
                    Temperature: 27.9°C
                    Voltage: 13.15 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 71.1°C
                    Mileage: 79747 km
                    Time: 20:46:36
                    RPM: 782 /min
                    Voltage: 13.07 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 94.5°C
                    Mileage: 79747 km
                    Time: 20:46:38
                    RPM: 782 /min
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
   Coding: 0000328
   Coding: 0011524
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:14:29
                    Hex Value: 0x0004
                    Voltage: 13.00 V
                    Bin. Bits: 00011110
                    Count: 243
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:14:29
                    Hex Value: 0x0004
                    Voltage: 13.00 V
                    Bin. Bits: 00011110
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:14:29
                    Hex Value: 0x0004
                    Voltage: 13.00 V
                    Bin. Bits: 00011110
                    Count: 165
                    Hex Value: 0x0000
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:14:29
   Coding: 00038805
   Shop #: WSC 01324
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.25 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.20 V
                    Reset counter: 254
                    Mileage: 79684 km
                    Voltage: 13.40 V
   Coding: 100102
            014 - Defective
                    Reset counter: 0
                    Time Indication: 15
                    Temperature: 23.0°C
   Coding: 0012337
                    Fault Status: 00101101
                    Reset counter: 38
                    Mileage: 79684 km
                    Time: 21:12:29
   Coding: 0012002
   Coding: 0006104
   Coding: FD827F06001202006003
01304 - Radio
                    Reset counter: 254
                    Mileage: 79747 km
                    Time: 21:15:37
                    Mileage: 79747 km
                    Time: 21:15:32
   Coding: 0000005
            014 - Defective
                    Mileage: 63421 km
                    Time: 00:25:23
   Coding: 0000692
   Revision: 00H15000
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
                    Reset counter: 250
                    Mileage: 79684 km
                    Time: 21:14:01
   Coding: 0000692
   Coding: 0000057
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:47, VBatt start/end: 13.2V/13.1V)
Jef
HQ
Coding: 0012002
The Steering Wheel Electronics (J527) coding looks to be wrong:
0xxxx?x: Board Computer / Cruise Control System (CCS)
0 = w/o Board Computer and w/o Cruise Control System (CCS)
PL24 shows the VIN has having PR code 8T2 for Electronic cruise control system (CCS). Please see if coding the J527 to this value:
0012022
2 = w/o Board Computer and with Cruise Control System (CCS)
Additionally, I have 2 suggestions:
1) Park assist
  • Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
16347 - Control Module - EEPROM Error​
014 - Defective​
  • Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
01044 - Control Module Incorrectly Coded​
  • PR-Code 7X0 Without park distance control
Conclusion; Address 10 is faulty (or claims to be faulty) and it is not installed in the GVL. I'd either unplug it or add address 10 to the CAN GW via the Installation List function. If the parking sensors work properly I'd add rather than remove it.
2) ABS
I believe the coding should be: 0006434
Fredrick Awuor
Kenya
C?ID=309834
1) Park assist
014 - Defective​
2) ABS
thank you so much, car is coming back on Monday next week, I will recode and report back
Fredrick Awuor
Kenya
C?ID=309834
1) Park assist
014 - Defective​
2) ABS
1) Park assist
014 - Defective​
2) ABS
Thank you so much @Dana the coding is accepted and has worked with no errors, I have also recoded J527 as suggested by @Jef, but I have not been able to locate a physical cruise control stalk in this car, and E45 defective error has appeared after the codierung exercise, however the most pressing issue has been resolved, thank you so much again,below is the final scan with @Dana awesome coding
Wednesday,23,November,2022,08:18:49:40543
VIN: WVGZZZ5NZ9W103321   License Plate: CBA TIGUAN AFT CODING AND CLEARING ERRORS
Mileage: 79810km-49591mi   Repair Order:
          72
VIN: WVGZZZ5NZ9W103321   Mileage: 79810km-49591miles
   Coding: 0000175
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
                    Mileage: 79819 km
                    Time: 16:11:56
                    RPM: 782 /min
                    (no units): 0.0
                    (no units): 255.0
                    Bin. Bits: 01000000
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 79819 km
                    Time: 16:11:58
                    RPM: 782 /min
                    Voltage: 13.38 V
                    Lambda: 54.4 %
                    Lambda: -30.0 %
                    Bin. Bits: 00001110
                    Voltage: 3.192 V
                    Mileage: 79819 km
                    Time: 16:11:59
                    RPM: 782 /min
                    Voltage: 13.30 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 93.6°C
                    Mileage: 79819 km
                    Time: 16:12:01
                    RPM: 782 /min
                    Voltage: 13.38 V
                    Voltage: 13.38 V
                    Voltage: 13.38 V
                    Voltage: 13.38 V
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND - Intermittent
                    Mileage: 79819 km
                    Time: 16:15:26
                    Temperature: 56.7°C
                    Temperature: 99.0°C
                    Temperature: 17.1°C
                    Lambda: 29.2 %
                    Lambda: 0.0 %
   Coding: 0000328
   Coding: 0006434
   Coding: 00038805
   Shop #: WSC 01324
                    Reset counter: 7
                    Mileage: 79819 km
                    Voltage: 12.60 V
                    Reset counter: 7
                    Mileage: 79819 km
                    Voltage: 12.60 V
                    Reset counter: 7
                    Mileage: 79819 km
                    Voltage: 13.30 V
   Coding: 100102
            014 - Defective
                    Reset counter: 0
                    Time Indication: 15
                    Temperature: 23.0°C
   Coding: 0012337
                    Reset counter: 47
                    Mileage: 79819 km
                    Time: 16:13:02
   Coding: 0012022
00895 - Cruise Control Switch (E45)
            014 - Defective
   Coding: 0006104
   Coding: FDA27F06001202006003
01304 - Radio
                    Reset counter: 7
                    Mileage: 79819 km
                    Time: 16:14:05
   Coding: 0000005
            014 - Defective
                    Mileage: 63421 km
                    Time: 00:25:23
   Coding: 0000692
   Revision: 00H15000
                    Reset counter: 7
                    Mileage: 79819 km
                    Time: 16:14:36
                    Reset counter: 7
                    Mileage: 79819 km
                    Time: 16:14:36
   Coding: 0000692
   Coding: 0000057
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:39, VBatt start/end: 13.6V/13.2V)-----------
