Resolved P2723 selonoid E perf/stuck
Resolved
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
I believe this is N233 that needs replacement
Also would this prevent me doing basic setting Dsg 6 speed
Followed the steps verbatim and I here tranny noise like how you supposed to hear but basic setting never turns ON it stays off I let go for 30 min and nothing ! I assume because N233 is open it’s not allowing the basic setting to run its course
Westbury, UK
What vehicle do you have? Posting an Auto-Scan would be helpful.
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
2014 VW CC 2.0T
Wednesday,16,November,2022,10:23:21:01154
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Mileage: 236490km-146948mi   Repair Order:
                Address 02: Auto Trans       Labels: 02E-927-770.clb
Control Module Part Number: 02E 300 058 N    HW: 02E 927 770 AL
  Component and/or Version: GSG DSG AG6     512 3522
           Software Coding: 0000020
            Work Shop Code: WSC 05311 000 00000
                      VCID: 2517FE6E99E14E03B84-8070
19155 - Pressure Control Solenoid 5
            P2723 - 000 - Implausible Signal or Stuck Off - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 236430 km
                    Date: 2017.04.03
                    Time: 21:44:20
18115 - Interference in Mechatronic Module
            P1707 - 007 -  - Intermittent - MIL ON
                    Fault Status: 10100111
                    Fault Frequency: 11
                    Mileage: 236436 km
                    Date: 2017.04.04
                    Time: 00:41:12
            P1707 - 009 -  - Intermittent
                    Fault Status: 00101001
                    Fault Frequency: 0
                    Reset counter: 34
                    Mileage: 236442 km
                    Date: 2017.04.04
                    Time: 15:11:59
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 004 -  - Intermittent
                    Fault Frequency: 0
                    Reset counter: 37
                    Mileage: 236464 km
                    Date: 2017.04.05
                    Time: 20:29:41
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
just posted scan was trying to perform basic setting before replacing the Solenoids I have borg warner replacements sitting on the table fluid etc
but I was researching sometimes a basic setting can cure somethings basically when I turn on car in morning to move everything is fine until i switch to drive and it drives to in first then it will go neutral and then goes into 2nd only limp mode
from the DSG6 I been reading on how it works ...but what I read is that the N233 "5" failing hence only 2nd gear
P2711 code is triggered because of 1st gear disengaging and going into limp mode aka 2nd gear only
my assumption i could be way off
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
FIXED:
N233 wire broke on selonoid
Replaced all selonoids since I was already there
Basic setting was able to be completed
Overall easy as cake
vwztips
C?ID=189
May be having the same issue. Where did you get the solenoids?
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
I got OEM on eBay new, you can find some pullouts on eBay you can also go to junk yard as well I have all spares from a tranny at the junk yard for cheap because it’s hard to find new ones honestly , besides the Chinese ones
Used all hand tools and hardest thing is just removing pan in tight space
What issues you having
Mines started here and there that got worse
This how solenoid look
This what happen to the solenoid which I can or could of just repaired but yea
ZACH85J
Long Beach, CA, USA
C?ID=509684 (NRRT)
Also basic settings won’t complete if solenoid wire broke so you can start with basic setting test to see if it can be done you can also rest tcu by holding the brake over 10 sec if those 2 things don’t work then def a solenoid issue and single out which solenoid it is based on codes and what symptoms are since there’s 2 circuits for the 2 clutches
What are your symptoms ?
