Hi - I'm wanting to reset the service reminder on my Mk7 Golf R so that it only shows me a warning when I get close to the reminder mileage (e.g. maybe 500Kms before).
I'm sure it used to do this, but now when I reset it to the desired interval (5,000 km), it shows the "Oil Change in 5,000 Kms" warning every time I start the car, even if I change the Warning channel to "disabled". (yes, I know 5,000 km is pretty frequent, but it gets a hard life ;-)
It also shows in the Car screen on the infotainment as if it is a fault which is a pain.
I did try changing "IDE00512-ESI: minimum value km-driving distance/inspection" to 4,500 but that seemed to have no effect.
Any help is appreciated...
Monday,14,November,2022,21:25:59:39451
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWZZZAUZEW353373 License Plate: XXXX
Mileage: 59055km-36695mi Repair Order:
VCDS Release 22.10.0: SRI Reset-SRI3.CLB
Control Module Part Number: 5G6 920 870 B Labels: .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI 314 2210, Coding:27AD0808BB80080801087E00040000
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status no warning ---
IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 0 km ---
IDE00511-ESI: time from inspection ESI: Time since Inspection 0 d ---
IDE00515-ESI: oil quality ESI: Oil Quality poor oil quality ---
IDE00517-ESI: soot entry ESI: Soot Quantity 0 km ---
IDE00518-ESI: thermal load ESI: Thermal Load 0 km ---
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 5000 km ---
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 365 d ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection FIX: Maximum Distance to Inspection 30000 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 365 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 0 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 0 d ---
IDE00512-ESI: minimum value km-driving distance/inspection ESI: Minimum Distance to Service 15000 km ---
IDE00513-ESI: maximum value km-driving distance/inspection ESI: Maximum Distance to Inspection 30000 km ---
IDE00514-ESI: maximum value of time between inspections ESI: Maximum Time to Service 730 d ---
IDE00827-ESI: minimum value of time between inspections ESI: Minimum Time to Service 365 d ---
Monday,14,November,2022,21:27:49:39451
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZEW353373 Mileage: 59055km-36695miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0102
Revision: --H13--- CVN: BB15373B
Coding: 091D0032242605032004
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B.rod
VCID: 2D07F56F6D989FD3704-8079
VINID: 9E69EAAAA465A959C31430C70C5556BF9A
Readiness: 0010 0000
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4517
Revision: 03253104 Serial number: TFK01407150115 CVN: 0000141E
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F1B1FA717347D43F28-804B
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6066400000010B
Coding: 01FA93A15425296F037A070741C66980C92A94C0E08296F7004200F8C208
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7BA30B37E36CC163BE0-802F
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120004200100011005000000101000
VCID: 66954A4388EE6C8B71E-8033
Air quality sensor:
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011407101272
Coding: 03001A46C24122F34BA44080B10C07281000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140302 042 0551
Serial number: 140305200301
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M03D18H19M28S17S9
Coding: 06A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140481774
Serial number: 00000000000028779421
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331407601015
Coding: 0031151011
VCID: 3E25C223B0FE144BD9E-806B
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 17021441350079
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76B51A03D84E9C0BC1E-8023
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR04DB6L
VCID: 7F5BFF27F774DD43928-802B
Left seat belt tensioner:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B17031471534
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B17031471583
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 303 14
Serial number: 35767000000A1B092F0X
Subsystem 4 - Part No SW: ----------- HW: 480 001 103 14
Serial number: 35867000000488E80F00
Subsystem 5 - Part No SW: ----------- HW: 480 400 703 14
Serial number: 35165029B14D3E72B23G
Subsystem 6 - Part No SW: ----------- HW: 480 400 703 14
Serial number: 3526502C512F62919188
Subsystem 7 - Part No SW: ----------- HW: 480 401 303 14
Serial number: 3556502B914476B1F15F
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0135
Revision: FF027027 Serial number: 20140311400263
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDBBF27B7F41D43D28-806B
Part No SW: 5G6 920 870 B HW: 5G6 920 870 B
Component: KOMBI 314 2210
Coding: 27AD0808BB80080801087E00040000
VCID: 2E05F263609EE4CB49E-807B
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001723779
Coding: 030100042B085900FF00026E9C0F00010001000000000000000000000000
GVL: 01D43C1000000000400C10000000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001933560046415
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9791872703
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00012.02.14
Coding: 0001
VCID: 46D5AAC3E82E4C8B91E-8013
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 08031403110303
Coding: 003F0220D001048000001000
VCID: 40D9BCDBCA0A62BBAB2-8015
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002154744
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 3537DD0F85C8D713084-8061
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 10031402090480
Coding: 003F0020DE01048000801000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002133561
Coding: 050000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A602000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2T1869482
Coding: 02730008FF0000001111000100080A001F0107D6012001008E
Shop #: WSC 00046 123 12345
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 323DE61374A6C02B2D6-8067
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJU043RR
Subsystem 2 - Part No SW: 5NA 919 866 CD HW: -----------
Component: MRM3 2022/23 --- 1810
2562 - Navigation System
B126C F0 [009] - Navigation Database Faulty
Reset counter: 117
Mileage: 59048 km
Date: 2022.11.13
Time: 14:43:07
Voltage terminal 30: 12.4 V
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140225200044
End----------(Elapsed Time: 01:14, VBatt start/end: 12.2V/12.3V)-----------
