- Oct 19, 2022
- 10
- 0
- Houston, TX, USA
- C?ID=314389
Hey everyone,
I'm currently rebuilding a wrecked 2018 NA Tiguan (BW2) and while the engine was out I decided to take on the laborious task of wiring the LED headlights the factory way. I pulled up ElsaWIN wiring diagrams and ran each wire where needed. I knew I had to source a new BCM, Range Control Module, and rear height level sensor. Once those modules arrived I got to work.
The old BCM part number:5Q0937087 AR
The new BCM part number:5Q0937087 BG
The new Range Control Module part number: 3Q0907338 E
The new BCM was installed, headlights were hooked up and power was applied the car, the low beams turned on but there was no control over turn signals, high beams, etc. The interior dome lights also did not work, and neither did the heated seats. I scanned the car and it showed some component protection in CAN Gateway (assuming something for either BCM or range control) (or LED headlights??). I then swapped the BCM to the original one and things like dome lights, heated seats, etc began working again, but headlight operation remained the same.
And so I am reaching out for help. I realize that these newer cars no longer accept long coding for retrofits and changes, does anyone have any advice as to how I should proceed? Is my original BCM capable of accepting LED headlight retrofit? Does the new BCM have component protection? Any help would be appreciated.
Please find attached scan - I realize that it's a royal mess and that's because the car is just waking up from "surgery". Please not the Central Electronics module, CAN module, and other related components to the headlights.
Sunday,13,November,2022,17:21:02:12942
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: 3VV2B7AX9JM201421 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 29 2B 3C 42 44 4B 52 5F
6C 75 D6 D7 D8 D9
VIN: 3VV2B7AX9JM201421 Mileage: 95774km-59511miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
29-Left Light -- Status: Not registered 0011
4B-Multifunc. Module -- Status: Not registered 0011
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 K HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0004
Revision: 1DH31000 CVN: 95267501
Coding: 012A00122426010F34000000000000000000000000000000
Shop #: WSC 20149 444 00000
ASAM Dataset: EV_ECM20TFS0115NA907115K 001004
ROD: EV_ECM20TFS0115NA907115K.rod
VCID: 46D65EB2A824C5DB9DF-8012
VINID: 0E698248746825A742001102044A052EA6
17158 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 95774 km
Date: 2022.11.14
Time: 00:13:29
Engine RPM: 0.00 /min
Coolant temperature: 96 °C
Intake air temperature: 36 °C
Voltage terminal 30: 12.480 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
33226 - Please Check Fault Codes in Body Control / Central Electric Module
U1021 00 [036] - -
[Body computer 1/ veh. elec sys CM / cent elec.Read out DTC]
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:09
Engine RPM: 798.50 /min
Normed load value: 17.3 %
Coolant temperature: 69 °C
Intake air temperature: 21 °C
Voltage terminal 30: 13.260 V
Com st X Set3 Val1-Bits 0-7: 0
Com st X Set3 Val2-Bits 0-7: 0
Com st X Set3 Val3-Bits 0-7: 0
Com st X Set3 Val4-Bits 0-7: 0
Com st X Set3 Val5-Bits 0-7: 0
Com st X Set3 Val6-Bits 0-7: 0
Com st X Set3 Val7-Bits 0-7: 1
Com st X Set3 Val7-Bits 0-7: 0
4673 - Implausible Data Received from ABS Control Module
U0415 00 [036] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:16
Engine RPM: 879.00 /min
Normed load value: 11.8 %
Vehicle speed: 255 km/h
Coolant temperature: 94 °C
Intake air temperature: 26 °C
Voltage terminal 30: 13.160 V
selected gear-Bits 0-7: 3
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 0
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DT HW: 09G 927 158
Component: AISIN AQ8 206 3698
CVN: 2408AAFC
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00240
ROD: EV_TCMAQ450031_VW32.rod
VCID: 084A908AE2B013ABAF3-805C
25552 - Implausible Data Received from ABS Control Module
U0415 00 [042] - -
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:09
Engine RPM: 3016.0 /min
Transmission input speed: 2972 /min
Transmission output speed: 531 /min
Engine torque: -4 Nm
ATF temperature: 41 °C
Accelerator pedal position: 3.2 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
25553 - Implausible Data Received from ABS Control Module
U0415 00 [042] - -
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:15
Engine RPM: 993.5 /min
Transmission input speed: 1089 /min
Transmission output speed: 557 /min
Engine torque: 0 Nm
ATF temperature: 43 °C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 51618000000290
Coding: 0BFA6BA454201B6DC57B0302A2C449D0D62AD8A3C045927C10415058C28A4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: 76B6EE729844155BCDF-8022
8 Faults Found:
0045 - Front Left Wheel Speed Sensor
C101A 07 [009] - Mechanical Failure
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:08
0059 - Front Right Wheel Speed Sensor
C101B 07 [009] - Mechanical Failure
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:14
0297 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:05
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:05
8304 - Databus
[FCAN: WWSs_01_alt veraltet bit is set]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:12
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:13:40
32992 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:15
32993 - Control Module for Electric Parking Brake
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:08
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0486231884
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E263652F0F49D1BD5F-806A
133124 - Databus
[Message Klemmen_status_01 missing]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:54
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
Control Module Voltage: 12.812 V
Vehicle speed: insufficient voltage
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: Open
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
U1093 00 [008] - Short to GND
[wakeline Open circuit/short circuit to ground]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:40
Terminal_15_central electric_actual_value: OFF
Terminal_S_central electric_actual_value: OFF
ZAT_pressed: OFF
Control Module Voltage: 12.857 V
Driver door: Open
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
12786207 - Databus
[Message ESP_21 invalid Qbit received]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:08
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Control Module Voltage: 13.276 V
Vehicle speed: 0.0 km/h
Engine RPM: 3025.0 /min
Driver door: closed
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NN 907 044 F HW: 5NN 907 044 F
Component: AC Automat H35 4401
Revision: 20K03000 Serial number: 00000D00185779
Coding: 0002000420011800100500001211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002025
VCID: 4FF87B96475E04932E9-801A
Humidity sensor: exterior:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:09
Outside temperature: 14.5 °C
Engine RPM: 700 /min
Temperature downstream of evaporator: 25.3 °C
Refrigerant pressure: 1.0 bar
System run time-Engine running time: 253 s
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86417071804FG
ROD: EV_BCMBOSCH_018.rod
VCID: 0B40AF86F3C678B3821-805E
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 180614 034 0373
Serial number: 18060522208330
Humidity sensor: interior:
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 71852681
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:14:08
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.4 V
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:14:08
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.4 V
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM0A4Z75
Coding: 8CCCFC00000000005000001AC20800000065
VCID: 055499BED5A20EC3D45-8050
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000009Q2RE
Coding: 303351
Subsystem 2 - Part No SW: ----------- HW: 480 003 006 18
Serial number: 35700000000236CCB03L
Subsystem 3 - Part No SW: ----------- HW: 480 000 207 18
Serial number: 358000000003BA3CE03T
Subsystem 4 - Part No SW: ----------- HW: 480 402 005 18
Component: SideSensor_Dr 004 6149
Serial number: 35100010C2AE1266E3C6
Subsystem 5 - Part No SW: ----------- HW: 480 401 805 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001C5299D271D6EI
Subsystem 6 - Part No SW: ----------- HW: 480 400 506 18
Component: FrontSensor_D 003 6149
Serial number: 3550001C329B6AA285DJ
Subsystem 7 - Part No SW: ----------- HW: 480 400 506 18
Component: FrontSensor_P 003 6149
Serial number: 3560001C729B6AA662AK
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 95774 km
Date: 2022.11.13
Time: 23:49:13
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:24
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 95774 km
Date: 2022.11.13
Time: 23:49:17
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 10051804401354
Coding: 0410
VCID: 074893B6EFAE1CD3A69-8052
Part No SW: 5NA 920 850 B HW: 5NA 920 850 B
Component: KOMBI 380 0310
Coding: 0BA40C1AA388CF0502882B0954000000A0000000
Shop #: WSC 00066 790 00454
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:07
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:51
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 30061800841360
Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
GVL: 01D03C0000000600404C80008002C80000000003000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 382A204AD2D0A32B1F3-806C
Generator:
Subsystem 2 - Part No SW: 5NN 959 442 HW: 5NN 959 442
Serial number: 1251812101600850BH2B
Coding: 280000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 2275545900
7 Faults Found:
131598 - Body Control Module (Central Electric)
U0140 00 [008] - No Communications
[Timeout Knoten 0x0E / 09 - Bodycomputer 1/ Bordnetzsteuergerät / el. ZE]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:56
Terminal 30 power supply: 12.7 V
Terminal 15: OFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 30 power supply: 13.3 V
Terminal 15: On
131736 - No Communications with Undefined Control Module
U1126 00 [009] - -
[Timeout Knoten 0x98]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 15: On
131737 - No Communications with Undefined Control Module
U1126 00 [009] - -
[Timeout Knoten 0x99]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 15: On
66304 - Databus
U1124 00 [009] - Additional Installations Detected
[Mehrverbau CAN]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 15: On
U1101 00 [008] - Active
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 15: On
8526363 - Crash Shut-Down
B189C F0 [009] - Active
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:59:52
Terminal 15: On
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00016.04.18
Coding: 0101
VCID: 4CC26C9AB6483F8B4BB-8018
16656 - Databus
[Bremsensteuergerät - no speed signal]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:07
Address 29: Left Light Labels: None
ASAM Dataset: EV_bñžEV_LCMLeftLCMLe Unknown
ROD: N/A
VCID: 55F489FE65827E43E45-8000
No ASAM data for: "EV_bñžEV_LCMLeftLCMLe" (VW37)
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000179707010
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 33301766CBB640732A1-8066
12665088 - Databus
[Timeout Message Klemmen_Status_01]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:54
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: OFF
Clamp 15: OFF
Clamp 15 Status: invalid
Remote Start: not active
Driver door: For
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 655.33 km/h
UBat internal: 12.1 V
UMotorBridge: 6.6 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition not met
Lock condition vehicle speed: Condition not met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
12665089 - Databus
[Timeout Message ZV_02]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:11:55
ESCL locked: No
ESCL unlocked: Yes
Clamp S: OFF
Clamp 15: OFF
Driver door: For
Clamp Request: No
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
Coco reset: No
Coco supply: On
IMS responded: Yes
Learn mode: Adapted
UMotorBridge: 6.6 V
13637378 - Databus
[Errorvalue ESP_Wegimpulse]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:10
ESCL locked: No
ESCL unlocked: Yes
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Driver door: to
Clamp Request: No
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
Coco reset: No
Coco supply: On
IMS responded: Yes
Positive authentification in current KL15 cycle: Yes
Learn mode: Adapted
Vehicle speed: 0.00 km/h
UBat internal: 12.5 V
UMotorBridge: 6.8 V
Lock condition engine speed: Condition not met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition selector lever position parking: Condition not met
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0483214428
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D24315EFDF28603CC5-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0481529733
Coding: 010111
337760 - Databus
[ESP_10::ESP_QBit_Wegimpuls_VL - Ersatz_Init_oder_Fehlerwert]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:09
337776 - Databus
[ESP_10::ESP_QBit_Wegimpuls_VR - Ersatz_Init_oder_Fehlerwert]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:15
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000386565062
Coding: 003013200000028000000000
Shop #: WSC 57893 001 1048576
VCID: 47C853B6AF2EDCD3669-8012
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000528473
Coding: 011000
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002492197
Coding: 01000010004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 40DA48AA8A00EBEBA73-8014
3164929 - Databus
[Fehlerwert "Radgeschwindigkeiten" in "ESP_19"]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:08
Write only channel
3164800 - Databus
[Fehlerwert "Wegimpulse" in "ESP_10"]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:05:08
Write only channel
5262656 - Steering Angle Sensor
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
Write only channel
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 26111910520422
Coding: 000000070900204600002900020000000000000000000000000000000000
Shop #: WSC 00049 770 00086
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 37282376DFCEAC53169-8062
23 Faults Found:
13705529 - Databus
[BCM_01 data bus missing message]
Reset counter: 194
0016 - Databus
[BCM_05 data bus missing message]
Fault Frequency: 14
Reset counter: 194
Mileage: 95774 km
13705788 - Databus
[Blinkmodi_02 data bus missing message]
Reset counter: 194
13705488 - Databus
[Diagnose_01 data bus missing message]
Reset counter: 194
13705476 - Databus
[ESP_21 data bus missing message]
Fault Frequency: 43
Reset counter: 194
13705486 - Databus
[Klemmen_Status_01 data bus missing message]
Fault Frequency: 34
Reset counter: 194
Mileage: 95774 km
13705477 - Databus
[Kombi_02 data bus missing message]
Reset counter: 194
13705481 - Databus
[Licht_Anf_01 data bus missing message]
Fault Frequency: 35
Reset counter: 194
Mileage: 95774 km
0019 - Databus
[Licht_vorne_01 data bus missing message]
Reset counter: 194
13705478 - Databus
[RLS_01 data bus missing message]
Fault Frequency: 20
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
13705483 - Databus
[SMLS_01 data bus missing message]
Reset counter: 194
13705480 - Databus
[Systeminfo_01 data bus missing message]
Reset counter: 194
13705482 - Databus
[Wischer_01 data bus missing message]
Reset counter: 194
13705475 - Databus
[Motor_14 data bus missing message]
Fault Frequency: 37
Reset counter: 194
Mileage: 95774 km
13706165 - Databus
[Gateway_73 data bus missing message]
Fault Frequency: 64
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:06:41
0020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0010 00 [008] - Malfunction
[Databus comfort faulty]
Reset counter: 194
12600832 - Databus
U1200 00 [137] - Defective
[Databus extended faulty]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
131080 - Databus Front Lights
U1504 00 [008] - No Communications
[Databus AFS no communication]
Reset counter: 194
Mileage: 95774 km
0015 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
[Data bus comfort no communication]
Fault Frequency: 64
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:06:41
12601088 - Extended CAN Bus (SAE Bus C)
U0047 00 [008] - Performance
[Databus extended no communication]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
0035 - Databus for Front Lighting
U12EB 00 [009] - Additional Installations Detected
[CAN_AFS_multiple_plug_LCM_identified]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
66881 - Databus
[LED_L_falsch_codiert received error value]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
66882 - Databus
[LED_R_falsch_codiert received error value]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 011 0032
Serial number: 8038820104093
VCID: 44D244BA9E18F7CB83B-8010
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000557476
Coding: 091000
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02730600BE00000051220001001808001F0500C40120050002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2E06061220946D9B45F-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMV1645182
B11CF 53 [009] - Deactivated
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:26
Voltage terminal 30: 13.2 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 100 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 154
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:07
BAP-BAP_Function_ID: 02
Component: RVC Compact H18 0231
Coding: 0123060120002017300040
Shop #: WSC 37597 004 1048576
VCID: 392C254EE9DABA23E0D-806C
13705995 - Databus
[Undervoltage Gateway_71.ESP_v_Signal]
Reset counter: 194
Mileage: 95774 km
Date: 2022.11.14
Time: 00:07:15
Follow-up
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02230602C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43D047A69B16F0F3BA1-8016
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 005A88AACA802BEBE73-8054
0019 - Headlamp Type
C119F 00 [175] - Implausible
Reset counter: 0
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
0257 - Databus
U1201 00 [104] - No Communications
[can data bus - no communication]
Reset counter: 0
Mileage: 95774 km
Date: 2022.11.14
Time: 00:06:41
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
0017 - invalid data record
B2005 00 [175] - -
[Invalid Dataset]
Reset counter: 0
Mileage: 95774 km
Date: 2022.11.13
Time: 23:48:04
0257 - Databus
Reset counter: 0
Mileage: 95774 km
Date: 2022.11.14
Time: 00:06:41
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
End----------(Elapsed Time: 02:57, VBatt start/end: 12.3V/12.3V)-----------
