2018 Tiguan BW2 Halogen to LED Retrofit
eurospekgarage
Houston, TX, USA
C?ID=314389
Hey everyone,
I'm currently rebuilding a wrecked 2018 NA Tiguan (BW2) and while the engine was out I decided to take on the laborious task of wiring the LED headlights the factory way. I pulled up ElsaWIN wiring diagrams and ran each wire where needed. I knew I had to source a new BCM, Range Control Module, and rear height level sensor. Once those modules arrived I got to work.
The old BCM part number:5Q0937087 AR
The new BCM part number:5Q0937087 BG
The new Range Control Module part number: 3Q0907338 E
The new BCM was installed, headlights were hooked up and power was applied the car, the low beams turned on but there was no control over turn signals, high beams, etc. The interior dome lights also did not work, and neither did the heated seats. I scanned the car and it showed some component protection in CAN Gateway (assuming something for either BCM or range control) (or LED headlights??). I then swapped the BCM to the original one and things like dome lights, heated seats, etc began working again, but headlight operation remained the same.
And so I am reaching out for help. I realize that these newer cars no longer accept long coding for retrofits and changes, does anyone have any advice as to how I should proceed? Is my original BCM capable of accepting LED headlight retrofit? Does the new BCM have component protection? Any help would be appreciated.
Please find attached scan - I realize that it's a royal mess and that's because the car is just waking up from "surgery". Please not the Central Electronics module, CAN module, and other related components to the headlights.
Sunday,13,November,2022,17:21:02:12942
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: 3VV2B7AX9JM201421   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 29 2B 3C 42 44 4B 52 5F
          6C 75 D6 D7 D8 D9
VIN: 3VV2B7AX9JM201421   Mileage: 95774km-59511miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
29-Left Light -- Status: Not registered 0011
4B-Multifunc. Module -- Status: Not registered 0011
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 K    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0004
   Revision: 1DH31000    CVN: 95267501
   Coding: 012A00122426010F34000000000000000000000000000000
   Shop #: WSC 20149 444 00000
   ASAM Dataset: EV_ECM20TFS0115NA907115K 001004
   ROD: EV_ECM20TFS0115NA907115K.rod
   VCID: 46D65EB2A824C5DB9DF-8012
   VINID: 0E698248746825A742001102044A052EA6
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:13:29
                    Engine RPM: 0.00 /min
                    Coolant temperature: 96 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.480 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
33226 - Please Check Fault Codes in Body Control / Central Electric Module
          U1021 00 [036] - -
          [Body computer 1/ veh. elec sys CM / cent elec.Read out DTC]
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:09
                    Engine RPM: 798.50 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 69 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.260 V
                    Com st X Set3 Val1-Bits 0-7: 0
                    Com st X Set3 Val2-Bits 0-7: 0
                    Com st X Set3 Val3-Bits 0-7: 0
                    Com st X Set3 Val4-Bits 0-7: 0
                    Com st X Set3 Val5-Bits 0-7: 0
                    Com st X Set3 Val6-Bits 0-7: 0
                    Com st X Set3 Val7-Bits 0-7: 1
                    Com st X Set3 Val7-Bits 0-7: 0
4673 - Implausible Data Received from ABS Control Module
          U0415 00 [036] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:16
                    Engine RPM: 879.00 /min
                    Normed load value: 11.8 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.160 V
                    selected gear-Bits 0-7: 3
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 0
Readiness: 1110 1101
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3698
   CVN: 2408AAFC
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00240
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 084A908AE2B013ABAF3-805C
25552 - Implausible Data Received from ABS Control Module
          U0415 00 [042] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:09
                    Engine RPM: 3016.0 /min
                    Transmission input speed: 2972 /min
                    Transmission output speed: 531 /min
                    Engine torque: -4 Nm
                    ATF temperature: 41 °C
                    Accelerator pedal position: 3.2 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
25553 - Implausible Data Received from ABS Control Module
          U0415 00 [042] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:15
                    Engine RPM: 993.5 /min
                    Transmission input speed: 1089 /min
                    Transmission output speed: 557 /min
                    Engine torque: 0 Nm
                    ATF temperature: 43 °C
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51618000000290
   Coding: 0BFA6BA454201B6DC57B0302A2C449D0D62AD8A3C045927C10415058C28A4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 76B6EE729844155BCDF-8022
8 Faults Found:
0045 - Front Left Wheel Speed Sensor
          C101A 07 [009] - Mechanical Failure
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:08
0059 - Front Right Wheel Speed Sensor
          C101B 07 [009] - Mechanical Failure
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:14
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:05
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:05
8304 - Databus
          [FCAN: WWSs_01_alt veraltet bit is set]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:12
16417 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:13:40
32992 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:15
32993 - Control Module for Electric Parking Brake
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:08
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0486231884
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E263652F0F49D1BD5F-806A
133124 - Databus
          [Message Klemmen_status_01 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:54
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.812 V
                    Vehicle speed: insufficient voltage
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
          [wakeline Open circuit/short circuit to ground]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:40
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.857 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12786207 - Databus
          [Message ESP_21 invalid Qbit received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:08
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Control Module Voltage: 13.276 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 3025.0 /min
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00185779
   Coding: 0002000420011800100500001211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4FF87B96475E04932E9-801A
   Humidity sensor: exterior:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:09
                    Outside temperature: 14.5 °C
                    Engine RPM: 700 /min
                    Temperature downstream of evaporator: 25.3 °C
                    Refrigerant pressure: 1.0 bar
                    System run time-Engine running time: 253 s
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86417071804FG
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B40AF86F3C678B3821-805E
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180614  034 0373
   Serial number: 18060522208330
   Humidity sensor: interior:
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 71852681
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:14:08
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.4 V
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:14:08
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.4 V
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM0A4Z75
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 055499BED5A20EC3D45-8050
   Serial number: IBH000000000009Q2RE
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 003 006 18
   Serial number: 35700000000236CCB03L
   Subsystem 3 - Part No SW: -----------    HW: 480 000 207 18
   Serial number: 358000000003BA3CE03T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010C2AE1266E3C6
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001C5299D271D6EI
   Subsystem 6 - Part No SW: -----------    HW: 480 400 506 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001C329B6AA285DJ
   Subsystem 7 - Part No SW: -----------    HW: 480 400 506 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001C729B6AA662AK
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:49:13
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:24
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:49:17
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10051804401354
   Coding: 0410
   VCID: 074893B6EFAE1CD3A69-8052
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         380 0310
   Coding: 0BA40C1AA388CF0502882B0954000000A0000000
   Shop #: WSC 00066 790 00454
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:07
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:51
   Component: GW MQB High   518 5323
   Serial number: 30061800841360
   Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
   GVL: 01D03C0000000600404C80008002C80000000003000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 382A204AD2D0A32B1F3-806C
   Generator:
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 1251812101600850BH2B
   Coding: 280000
   Serial number: 2275545900
7 Faults Found:
131598 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
          [Timeout Knoten 0x0E / 09 - Bodycomputer 1/ Bordnetzsteuergerät / el. ZE]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:56
                    Terminal 30 power supply: 12.7 V
                    Terminal 15: OFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 30 power supply: 13.3 V
                    Terminal 15: On
131736 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x98]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 15: On
131737 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x99]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 15: On
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 15: On
          U1101 00 [008] - Active
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [009] - Active
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:59:52
                    Terminal 15: On
   Serial number: HA1-00016.04.18
   Coding: 0101
   VCID: 4CC26C9AB6483F8B4BB-8018
16656 - Databus
          [Bremsensteuergerät - no speed signal]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:07
Address 29: Left Light        Labels: None
   ASAM Dataset: EV_bñžEV_LCMLeftLCMLe Unknown
   ROD: N/A
   VCID: 55F489FE65827E43E45-8000
No ASAM data for: "EV_bñžEV_LCMLeftLCMLe" (VW37)
   Serial number: 18000179707010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33301766CBB640732A1-8066
12665088 - Databus
          [Timeout Message Klemmen_Status_01]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:54
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: Not operated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: OFF
                    Clamp 15: OFF
                    Clamp 15 Status: invalid
                    Remote Start: not active
                    Driver door: For
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c cnd false
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 655.33 km/h
                    UBat internal: 12.1 V
                    UMotorBridge: 6.6 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition not met
                    Lock condition vehicle speed: Condition not met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition not met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition met
                    Lock condition difference distance pulse: Condition not met
12665089 - Databus
          [Timeout Message ZV_02]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:11:55
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    IMS responded: Yes
                    Learn mode: Adapted
                    UMotorBridge: 6.6 V
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:10
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: valid
                    Driver door: to
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: Yes
                    Learn mode: Adapted
                    Vehicle speed: 0.00 km/h
                    UBat internal: 12.5 V
                    UMotorBridge: 6.8 V
                    Lock condition engine speed: Condition not met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition timeout clamp status: Condition met
                    Lock condition selector lever position parking: Condition not met
   Serial number: 0483214428
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D24315EFDF28603CC5-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0481529733
   Coding: 010111
337760 - Databus
          [ESP_10::ESP_QBit_Wegimpuls_VL - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:09
337776 - Databus
          [ESP_10::ESP_QBit_Wegimpuls_VR - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:15
   Serial number: 0000386565062
   Coding: 003013200000028000000000
   Shop #: WSC 57893 001 1048576
   VCID: 47C853B6AF2EDCD3669-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000528473
   Coding: 011000
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
   Revision: 00000000    Serial number: 0002492197
   Coding: 01000010004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40DA48AA8A00EBEBA73-8014
3164929 - Databus
          [Fehlerwert "Radgeschwindigkeiten" in "ESP_19"]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:08
                    Write only channel
3164800 - Databus
          [Fehlerwert "Wegimpulse" in "ESP_10"]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:05:08
                    Write only channel
5262656 - Steering Angle Sensor
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
                    Write only channel
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 26111910520422
   Coding: 000000070900204600002900020000000000000000000000000000000000
   Shop #: WSC 00049 770 00086
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 37282376DFCEAC53169-8062
23 Faults Found:
13705529 - Databus
          [BCM_01 data bus missing message]
                    Reset counter: 194
0016 - Databus
          [BCM_05 data bus missing message]
                    Fault Frequency: 14
                    Reset counter: 194
                    Mileage: 95774 km
13705788 - Databus
          [Blinkmodi_02 data bus missing message]
                    Reset counter: 194
13705488 - Databus
          [Diagnose_01 data bus missing message]
                    Reset counter: 194
13705476 - Databus
          [ESP_21 data bus missing message]
                    Fault Frequency: 43
                    Reset counter: 194
13705486 - Databus
          [Klemmen_Status_01 data bus missing message]
                    Fault Frequency: 34
                    Reset counter: 194
                    Mileage: 95774 km
13705477 - Databus
          [Kombi_02 data bus missing message]
                    Reset counter: 194
13705481 - Databus
          [Licht_Anf_01 data bus missing message]
                    Fault Frequency: 35
                    Reset counter: 194
                    Mileage: 95774 km
0019 - Databus
          [Licht_vorne_01 data bus missing message]
                    Reset counter: 194
13705478 - Databus
          [RLS_01 data bus missing message]
                    Fault Frequency: 20
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
13705483 - Databus
          [SMLS_01 data bus missing message]
                    Reset counter: 194
13705480 - Databus
          [Systeminfo_01 data bus missing message]
                    Reset counter: 194
13705482 - Databus
          [Wischer_01 data bus missing message]
                    Reset counter: 194
13705475 - Databus
          [Motor_14 data bus missing message]
                    Fault Frequency: 37
                    Reset counter: 194
                    Mileage: 95774 km
13706165 - Databus
          [Gateway_73 data bus missing message]
                    Fault Frequency: 64
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:06:41
0020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0010 00 [008] - Malfunction
          [Databus comfort faulty]
                    Reset counter: 194
12600832 - Databus
          U1200 00 [137] - Defective
          [Databus extended faulty]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
131080 - Databus Front Lights
          U1504 00 [008] - No Communications
          [Databus AFS no communication]
                    Reset counter: 194
                    Mileage: 95774 km
0015 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [Data bus comfort no communication]
                    Fault Frequency: 64
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:06:41
12601088 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Databus extended no communication]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
0035 - Databus for Front Lighting
          U12EB 00 [009] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LCM_identified]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
66881 - Databus
          [LED_L_falsch_codiert received error value]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
66882 - Databus
          [LED_R_falsch_codiert received error value]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038820104093
   VCID: 44D244BA9E18F7CB83B-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000557476
   Coding: 091000
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02730600BE00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2E06061220946D9B45F-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMV1645182
          B11CF 53 [009] - Deactivated
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:26
                    Voltage terminal 30: 13.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 100 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:07
                    BAP-BAP_Function_ID: 02
   Coding: 0123060120002017300040
   Shop #: WSC 37597 004 1048576
   VCID: 392C254EE9DABA23E0D-806C
13705995 - Databus
          [Undervoltage Gateway_71.ESP_v_Signal]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:07:15
                    Follow-up
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   VCID: 43D047A69B16F0F3BA1-8016
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 005A88AACA802BEBE73-8054
0019 - Headlamp Type
          C119F 00 [175] - Implausible
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
0257 - Databus
          U1201 00 [104] - No Communications
          [can data bus - no communication]
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:06:41
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
0017 - invalid data record
          B2005 00 [175] - -
          [Invalid Dataset]
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.13
                    Time: 23:48:04
0257 - Databus
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:06:41
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
End----------(Elapsed Time: 02:57, VBatt start/end: 12.3V/12.3V)-----------
downtime
Finland
C?ID=280813
Yes it does. The BCM is CP protected and the symptoms of that are exactly what you observed.
Easiest way is to make adamap from current bcm to csv file. Then install the new one, have the CP removed by someone with proper access, then take an adamap to csv from it and compare the two files with excel, notepad++, beyond compare or similar.
The manually change th bcm channels to match the old ones.
Now depending on from which car the 4B and light power modules D6 and D7 are from, you probably need to flash proper parameter sets to them.
Most of this work you cannot do with VCDS unfortunately
eurospekgarage
Houston, TX, USA
C?ID=314389
Thanks downtime, I appreciate your input. Glad to know that I am on the right path with this. Do you have any recommendations as to which tools will work? VAS or VagCan Pro, etc? Or is there a reputable remote service I could approach for this? Please advise if you can and thanks again!
OEMplusCC
C?ID=160054
So I have not done this retrofit but looked into it as I was thinking to do this on my wifes Tiguan (NAR 2019 SEL not premium obviously).
It is the best to find a donor vehicle, i.e. NAR Tiguan SEL Premium from which you need to get both headlights with headlight modules (modules addresses 29,39,D6,D7), headlight range module (4B) and the suspension level sensor(s).
Then you need to make new wiring harness, or repurpose wiring from the donor vehicle if you want to deal with that. There are sellers on Aliexpress that sell decent harnesses, I would just buy those , but double check their work!
Now that should be all for the parts you need, why do you believe you need to change the BCM (09) ? Just asking... I was under impression that even the BCM from lower trims would support LED headlights. But I might be wrong.
If you dont need to replace BCM and can get used modules from a Tiguan SEL then VCDS is all you need for this retrofit. You will just need to change few adaptations etc. However, if you do need to replace BCM then you will need to deal with CP as downtime already shared. That would make this retrofit more complicated, but still possible.
Again, everything above is just my research of what would I do if I had a donor vehicle. So there are probably things I have not discovered yet.
Good luck!
FYI, here is a full scan of SEL Premium Tiguan with adaptations maps
downtime
Finland
C?ID=280813
I can help you remotely but you’ll need your own VAS dongle for it.
eurospekgarage
Houston, TX, USA
C?ID=314389
Good luck!
Thanks for this, it is hugely helpful!
I agree, this retrofit is no easy task and it may or may not have been easier to swap over the wiring harness. I took the opportunity to take this on since my engine and trans was out of the car. It had major frame damage. I figured while everything was out and I had access under the hood and through the firewall, I might as well go for it. I double and triple verified each wire and traced each connection to known parts of the existing car, so I hope I am correct. But it remains to be seen. Not to mention that I found the LED headlights were CHEAPER than the halogen ones - not sure how or if I got lucky. So i bit the bullet. Regarding the BCM, you might be correct, but the ETKA shows different part numbers for the BCM, so I found a used one. I'd be thrilled if I can use the one meant for the car.
eurospekgarage
Houston, TX, USA
C?ID=314389
It just so happens that one of my local Audi club friends has a VAS5054A cable that he let me borrow. I'm sending you a PM.
OEMplusCC
C?ID=160054
I would definitely just try with the original BCM first. If you ever find another donor vehicle I would love to do this retrofit as well :)
eurospekgarage
Houston, TX, USA
C?ID=314389
Thank you @downtime for helping out! I am on the next step of performing adaptations for the headlights. I have found reference admaps on this site and changed leuchte channels (and any other channels relating to the headlights) according to the reference. So far, my right headlights performs the dance and levels, the left headlight adjustment has not been made at all. Both low beams work, and now both high beams work as well. The turn signals are not operating, however. So there is some progress!
As it stands, I can't seem to communicate to either the left or right headlight, and VCDS is showing that other modules are affected by what's going on inside the CAN, 4B and 09 modules.
Here are the admaps and scan of affected modules so far. Please take a look! I would love some help on figuring out how to get the turn signals to work.
SCAN:
Saturday,19,November,2022,20:10:22:12942
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 29 2B 39 3C 42 44 4B 52
          5F 6C 75 D6 D7 D8 D9
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Cannot be reached 0100
   VCID: 46D65EB2A824C5DB91E-8012
          U1021 00 [036] - -
                    Mileage: 95774 km
                    Date: 2022.11.17
                    Time: 14:07:19
                    Coolant temperature: 15 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.200 V
7654 - Secondary Air Injection System: Bank 1
          P0491 00 [101] - Insufficient Flow
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 05:23:14
                    Engine RPM: 1180.00 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 16 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.340 V
                    Engine status: COENG_RUNNING
   CVN: 2408AAFC
   VCID: 084A908AE2B013ABA32-805C
17 Faults Found:
22624 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    Transmission input speed: 0 /min
                    Engine torque: 0 Nm
                    ATF temperature: 19 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22625 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22629 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22626 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22633 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
25508 - Software Incompatibility with Engine Control Module
          U0301 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
25371 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22632 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [036] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22636 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22638 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22639 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22645 - No Communication with Diagnostic Gateway
          U0146 00 [040] - -
          [Lost Communication With Serial Data Gateway Module "A"]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
28267 - No Communications with Control Module for Electric Steering Column Lock
          U0236 00 [040] - -
                    Reset counter: 154
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22637 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22644 - No Communication with Diagnostic Gateway
          U0146 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
26280 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
25881 - No Communication with Diagnostic Gateway
          U0146 00 [040] - -
                    Reset counter: 154
                    Engine torque: 0 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   VCID: 76B6EE729844155BC1E-8022
16 Faults Found:
8196 - Databus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
8210 - Databus
          [FCAN: Allrad_03 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
8232 - Databus
          [FCAN: Kombi_02 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
8234 - Databus
          [FCAN: Kombi_03 messag is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
8236 - Databus
          [FCAN: Kombi_01 messagei is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:10
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:10
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
8304 - Databus
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.17
                    Time: 14:07:20
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:07
16409 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:15
16410 - Display for Tire Pressure Monitoring
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:15
   Coding: 132C0C0723
   VCID: 3E263652F0F49D1BD9E-806A
7 Faults Found:
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.17
                    Time: 14:06:13
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.284 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12716804 - Databus
          [Message Motor_14 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    ZAT_pressed: OFF
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 12.060 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12717572 - Databus
          [Message VIN_01 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.020 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718086 - Databus
          [Message WFS_01 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.014 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718343 - Databus
          [Message Motor_07 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.026 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718344 - Databus
          [Message Motor_09 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
                    ZAT_pressed: OFF
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718345 - Databus
          [Message Motor_code_01 missing]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
                    ZAT_pressed: OFF
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   VCID: 4FF87B96475E0493228-801A
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:37
                    Outside temperature: 15.5 °C
                    Engine RPM: 0 /min
                    Temperature downstream of evaporator: 39.7 °C
459023 - Databus
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
459523 - Databus
          [Botschaft Dimmung_01 - empfangener Fehlerwert]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
459011 - Databus
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
   Part No SW: 5Q0 937 087 BG    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: C864150720042J
   Shop #: WSC 00066 790 00192
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015C8DAEC18A22E3E4C-8054
20 Faults Found:
534549 - Databus
          [FLA_01 Datenbus fehlende Botschaft]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:00:43
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
                    Outside temperature: 12.5 °C
576516 - Databus
          [LCM rechts - LCM_Feh_LM_R_alt aktiv]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:57:35
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
560661 - Databus
          [LDW_02 Datenbus fehlende Botschaft]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:40:51
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.5 V
541204 - Databus
          [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert]
                    Fault Frequency: 8
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:28:03
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
567062 - Databus
          [LCM links - Tagfahrlicht defekt]
                    Fault Frequency: 12
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:57:36
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
579350 - Databus
          [LCM links - Standlicht defekt]
                    Fault Frequency: 12
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:57:36
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:26:32
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
                    Outside temperature: 14.0 °C
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 02:31:23
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [009] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:32:41
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:33:08
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
7434 - Bulb for High Beam Headlamp Right
          B121A 15 [009] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:32:39
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 21:55:53
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.3 V
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 21:55:46
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.3 V
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 21:55:46
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.3 V
465417 - Control Circuit for Wiper Park Position Heater
          B18D0 14 [009] - Open or Short to Ground
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 21:55:44
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.3 V
                    Outside temperature: 15.0 °C
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 02:52:51
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
526359 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 22:45:39
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.4 V
65802 - Rear Vehicle Height/Level Sensor
          C114E 15 [009] - Open or Short to Plus
          [Geber für Fahrzeugniveau hinten Unterbrechung/Kurzschluss nach Plus]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 02:24:33
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.1 V
65800 - Rear Vehicle Height/Level Sensor
          C114E 29 [009] - Signal Implausible
          [Geber für Fahrzeugniveau hinten unplausibles Signal]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 02:24:34
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.1 V
65806 - Rear Vehicle Height/Level Sensor
          C114E 04 [009] - Internal System Fault
          [Geber für Fahrzeugniveau hinten defekt]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.20
                    Time: 02:24:34
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.1 V
   VCID: 055499BED5A20EC3D84-8050
   Coding: 303351
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:35
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:38
1054976 - Databus
          [NWD: 0x6B7 Kombi_02 Timeout]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
1051904 - Databus
          [NWD: 0x30B Kombi_01Timeout]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
1051136 - Databus
          [NWD: 0x6B4 VIN_01 Timeout]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
1048581 - Databus
          [NWD: 0x5F0 Dimmung_01 error value DI_KL_58xd]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
   Coding: 0410
   VCID: 074893B6EFAE1CD3AA8-8052
8 Faults Found:
          U1014 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 05:23:09
          U1110 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:35
13697024 - Component Protection
          U1100 00 [008] - No Basic Setting
          [Komponentenschutz keine oder falsche Grundeinstellung bzw. Adaption]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:50:37
16776960 - Databus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:32
16776961 - Databus
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:32
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
13639936 - Databus
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.17
                    Time: 14:06:23
   GVL: 01D03C0000000600404C80008002C80000000003000200000000000000000000
   VCID: 382A204AD2D0A32B132-806C
   Generator:
   Coding: 280000
8 Faults Found:
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
          U0235 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
131687 - No Communications with Emergency Call Module
          U10E1 00 [008] - -
          [Timeout Knoten 0x67 / 75 - Notrufmodul]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
          U1126 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
          U1126 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
66304 - Databus
          [Mehrverbau CAN]
                    Fault Frequency: 18
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:32:53
                    Terminal 15: On
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 15:06:15
                    Terminal 15: On
   Coding: 0101
   VCID: 4CC26C9AB6483F8B47A-8018
7 Faults Found:
16654 - Databus
          [Kombi - TO -- Kombi_01]
                    Fault Priority: 8
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:13
17466 - Databus
          [Kombi - TO -- Kombi_02]
                    Fault Priority: 8
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:04
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:08
   ROD: N/A
   VCID: 55F489FE65827E43E84-8000
   VCID: 33301766CBB64073260-8066
12666369 - Databus
          [Timeout Message Motor_14]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:05
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    I2C state esp 10: i2c cnd true
                    Coco reset: No
                    Coco supply: On
                    IMS responded: Yes
                    Learn mode: Adapted
                    UBat internal: 11.3 V
                    UMotorBridge: 6.2 V
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition difference distance pulse: Condition met
12666387 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Clamp S: On
                    Clamp 15: On
                    Driver door: For
                    Clamp Request: No
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    Coco reset: No
                    Coco supply: On
                    IMS responded: Yes
                    Learn mode: Adapted
                    UBat internal: 11.2 V
                    UMotorBridge: 6.2 V
Address 39: Right Light
   Coding: 01011103
   VCID: 3D24315EFDF28603C04-8068
   Coding: 010111
337156 - Databus
          [Kombi ECU Kombi_01 - no signal/no communication]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
   VCID: 47C853B6AF2EDCD36A8-8012
   Coding: 011000
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:32
458794 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
458803 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
589827 - Window Regulator; Rear Driver Side
          B131F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:03
   VCID: 40DA48AA8A00EBEBAB2-8014
7 Faults Found:
3158274 - Databus
          [Ausfall der CAN-Botschaft "Motor_12" des Motor-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
                    Write only channel
3161857 - Databus
          [Ausfall der CAN-Botschaft "VIN_01" des Kombi-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Write only channel
3161864 - Databus
          [Ausfall der CAN-Botschaft "Kombi_01" des Kombi-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Write only channel
3161872 - Databus
          [Ausfall der CAN-Botschaft "Motor_Code_01" des Motor-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:08
                    Write only channel
3161888 - Databus
          [Ausfall der CAN-Botschaft "Motor_11" des Motor-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
                    Write only channel
3161920 - Databus
          [Ausfall der CAN-Botschaft "Motor_14" des Motor-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
                    Write only channel
3161984 - Databus
          [Ausfall der CAN-Botschaft "Motor_20" des Motor-SG (über GW)]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
                    Write only channel
   Coding: 00000005090008D206104F010A0000000000000000000000000000000000
   Shop #: WSC 00046 000 00000
   VCID: 37282376DFCEAC531A8-8062
26 Faults Found:
13705529 - Databus
                    Reset counter: 194
0016 - Databus
                    Reset counter: 194
13705788 - Databus
                    Reset counter: 194
13705488 - Databus
                    Reset counter: 194
13705476 - Databus
                    Reset counter: 194
13705481 - Databus
                    Reset counter: 194
0019 - Databus
                    Reset counter: 194
13705478 - Databus
                    Reset counter: 154
13705483 - Databus
                    Reset counter: 194
13705480 - Databus
                    Reset counter: 194
13705482 - Databus
                    Reset counter: 194
13705472 - Databus
          [ESP_19 data bus missing message]
                    Reset counter: 194
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Fahrwerk_01 data bus missing message]
                    Reset counter: 154
                    Mileage: 95774 km
13705479 - Databus
          [Kamera_FDD_Obj01 data bus missing message]
                    Reset counter: 154
                    Mileage: 95774 km
13705489 - Databus
          [PSD_04 data bus missing message]
                    Reset counter: 154
                    Mileage: 95774 km
0029 - Control Module for Light Activation/Adjustment; Right
          U116F 00 [137] - No Communications
          [KN_LCM_R no communication]
                    Reset counter: 154
                    Mileage: 95774 km
66673 - Control Module for Light Activation/Adjustment; Right
          [LCM_Feh_LM_R no communication]
                    Reset counter: 154
                    Mileage: 95774 km
                    Reset counter: 194
          U12EB 00 [008] - Additional Installations Detected
                    Reset counter: 194
                    Mileage: 95774 km
13706046 - Databus
          [LV_Abblendlicht_li_def received error value]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:27:54
13706047 - Databus
          [LV_Abblendlicht_re_def received error value]
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:31:27
66678 - Databus
          [LCM_Datensatz_Fehler_L received error value]
                    Reset counter: 194
                    Mileage: 95774 km
66882 - Databus
                    Reset counter: 194
                    Mileage: 95774 km
5350720 - Left Matrix High Beam
          C1175 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 194
                    Mileage: 95774 km
5350976 - Right Matrix High Beam
          C1176 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 194
                    Mileage: 95774 km
0032 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 154
                    Mileage: 95774 km
   VCID: 44D244BA9E18F7CB8FA-8010
   Coding: 091000
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:32
458794 - Databus
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
458803 - Databus
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:09
589843 - Window Regulator; Front Passenger Side
          B1320 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:03
   VCID: 2E06061220946D9B49E-807A
18 Faults Found:
          [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:50:46
                    Voltage terminal 30: 12.0 V
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:22:25
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Antenna current: 101 mA
                    SDARS_tuner_status_2-Reception quality: good_signal
6706 - Databus
          [Instrument cluster: no communication]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
                    Voltage terminal 30: 11.9 V
                    Network diagnosis-Status: Enabled
6708 - Databus
          [Engine: no communication]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:13
6714 - Databus
          [VIN: no communication]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6927 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Trip computer setup (0x0F) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6929 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Time/date (0x11) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6930 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6931 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Central unit master (0x13) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6963 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
6967 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
7183 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Trip computer setup (0x0F) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
7185 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Time/date (0x11) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
7186 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
7187 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Central unit master (0x13) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
          U1111 00 [009] - -
                    Reset counter: 154
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:36
                    Voltage terminal 30: 12.1 V
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:59:14
   VCID: 392C254EE9DABA23ECC-806C
   VCID: 43D047A69B16F0F3B60-8016
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 194
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 13:57:06
   VCID: 005A88AACA802BEBEB2-8054
0774 - Light Bulb for Low Beam
          C1198 29 [175] - Signal Implausible
                    Fault Frequency: 12
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:27:53
   ROD: EV_LEDMinMaxRKEBODVW481.rod
          B2005 00 [040] - -
          [Invalid Dataset]
                    Reset counter: 8
                    Mileage: 95774 km
                    Date: 2022.11.14
                    Time: 00:21:32
0257 - Databus
                    Reset counter: 7
                    Fault Frequency: 12
                    Reset counter: 0
                    Mileage: 95774 km
                    Date: 2022.11.19
                    Time: 23:31:26
End----(Elapsed Time: 03:19, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
09 Module:
;SW:5Q0-937-087-BG   HW:5Q0-937-087-BA ---  Cent. Elect.
;Component:BCM PQ37BOSCH 038 0303     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc    20001    EV_BCMBOSCH_020_VW37.rod
;Saturday    19    November    2022    20:27:37:12942
;VCDS Version: Release 22.10.0 (x64)  Data version: 20221026 DS344.0
;VCID: 015C8DAEC18A22E3E4C-8054
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01550-Service position    178.999822 °    2
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    short     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms    10
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    0.3 °    16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.0 %/s    16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 °C    16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 °C    16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 °    16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 °C    16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    80 °    16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h    16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    15 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    320 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage    installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    active     11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv    -2.0 °C    11
IDE04927-ENG141962-Window heater-Waschduesenheizung    installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    0 s    11
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    not active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    not_active     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    not_active     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    not installed     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    not_active     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    not_active     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    No     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    No     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    1 Alarm     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    No     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-Light configuration    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35 52 00 5D 52 00 7F 08 09 7F 00 00 00 00 00 00 35 53 00 5E 52 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler    0    30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    21.00 °C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    20.00 °C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    21.00 °C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    20.00 °C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    36.00 °C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    35.50 °C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    36.00 °C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    35.50 °C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    49.00 °C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    48.00 °C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    49.00 °C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    48.00 °C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Keine_Spannungsanforderung     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.7 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    NOT-DEFINED     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut    installed     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    active     8
IDE07356-Position during interval mode    40.999959 °    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    not active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed     9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    7    19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual    11    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    not active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    not active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    active     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    0%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    30%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    30%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    10%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    not active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Keine_Spannungsanforderung     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    0    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    not active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    not active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    not installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    30%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    30%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    50%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    50%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    50%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    50%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    75%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    75%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    80%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics    not installed     17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    installed     17
IDE10298-Alternating park position 1    19.999980 °    2
IDE10299-Alternating park position 2    34.999965 °    2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    0    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    0    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    0    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    0    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    0    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    0    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    100%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    0%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    0%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    0%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    100%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    0%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    0%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    0%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    100%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    0%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    0%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    0%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    126%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    0%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    0%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    0%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    100%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    0%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    0%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    0%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    100%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    0%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    0%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    0%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    0%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    0    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    0    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    0    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    0    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    0    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    0    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    0    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    0    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    0    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    0    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    0    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    0    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    0    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    0    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    0    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    0    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    0    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    0    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    0    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    0    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    0    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    0    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    0    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    0    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    0    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    0    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    0    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    installed     3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber    active     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    not active     3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit    active     3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    not active     3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    Not available     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    Not available     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    Not available     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    Not available     6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head    Not available     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    Not available     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    Not available     6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module    Not available     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    Not available     6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module    Not available     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    Not available     6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater    Not available     6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater    Not available     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    Not available     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    Not available     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    Not available     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    Not available     6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control    Not available     6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch    Not available     6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    0    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    0    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    0    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    0    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    0    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    0    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    0    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    0    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    0    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    0    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    0    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    0    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    0    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    0    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    0    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    0    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    0    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    0    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    0    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS05055-lower turn position    42.999957 °    2
MAS05056-upper turn position    178.999822 °    2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    2512 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 50     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    not active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    4500 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    6000 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    2000 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    0    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    0    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    0    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    0    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    0    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    0    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    0    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    0    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    0    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    0    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    0    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    0    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    0    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    0    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    0    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    0    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    0    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    0    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    0    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    0    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    0    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    0    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    0    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    0    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    0    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    0    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    0    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    0    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    0    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    0    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    0    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    0    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    0    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    0    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    0    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    0    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    0    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    0    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    0    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    0    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    0    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    0    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    0    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    0    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    0    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    0    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    0    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    0    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    0    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    0    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    0    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    0    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    0    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    0    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    0    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    0    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    0    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    0    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    0    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    0    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    0    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    0    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    0    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    0    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    0    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    0    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    0    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    0    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    0    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    0    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    0    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    0    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    0    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    0    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    0    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    0    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    0    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    0    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    0    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    0    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    0    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    0    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    0    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    0    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    0    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    0    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    0    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    0    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    0    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    0    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    0    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    0    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    0    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    0    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    0    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    0    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    0    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    0    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    0    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    0    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    0    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    0    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    0    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    0    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    0    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    0    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    0    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    0    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    0    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    0    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    0    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    0    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    0    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Keine_Spannungsanforderung     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    1    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    1    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    1    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    1    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    1    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    1    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte     10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    not active     10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    not active     10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    not active     10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active     10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active     10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    not active     10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS    PreCrash_passiv     10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    not active     10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    not active     10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken    not active     10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    not active     10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    not active     10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken    not active     10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    not active     10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    active     10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max    120 min    10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    not active     10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    not active     10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    not active     10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    not active     10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren    active     9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lamps     9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    not active     9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active     9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    active     9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active     9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    limitieren     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    not active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    installed     18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf    5000 ms    18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam     18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic     18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH    Keine_Spannungsanforderung     18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp    Keine_Spannungsanforderung     18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    800 lx    18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    30 lx    18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    No     18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes     18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6    not active     18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    installed     18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam    Keine_Spannungsanforderung     18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    10 seconds     18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    10 seconds     18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    not active     18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    not active     18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s    18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp    Keine_Spannungsanforderung     18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active     18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general    not installed     3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle    not active     3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle    not active     3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246991-digital_key-pa_Two_Keys    not active     3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG122934-erase_error_table    00 00 00     3
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: FLA: Fernlicht ueber AFS     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    not installed     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present     6
ENG141685-Front_wash_function    10    2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Not deactivated     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    300 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    not active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active     6
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    not installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    100.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    100.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    100.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    83.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    67.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    50.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    33    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    17.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    0.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    64.00%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    64.00%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    64.00%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    64.00%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    57.00%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    50.00%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    42.00%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    27.00%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    22.00%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    15.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    0    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    0    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    0    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    not active     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    not active     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    63    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0    16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Warnblinktaster_Suchbeleuchtung     16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    0    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    0    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    0    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    not active     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    not active     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    0    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    0    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    0    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    not active     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    not active     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    not active     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    0    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    0    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    0    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    not active     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    not active     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    not active     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    127    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    48    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    37 - allgemeine LED bis 12W     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    127    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    47    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    37 - allgemeine LED bis 12W     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    0    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    0    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    0    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    not active     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    not active     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    0    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    0    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    0    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    not active     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    not active     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    0    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    0    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    0    16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    not active     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    not active     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    minimize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    13    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    35 - kombinierte LED Blink-Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    Blinken links Hellphase     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Blinken links Dunkelphase     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    minimize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    13    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    35 - kombinierte LED Blink-Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    Blinken rechts Hellphase     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Blinken rechts Dunkelphase     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    127    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    0    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    35    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    32 - allgemeine LED bis 12W     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    only_if_closed     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    0    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    36    16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    32 - allgemeine LED bis 12W     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    only_if_closed     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    127    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    54    16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0    16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    43 - allgemeine LED     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    0    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    32 - allgemeine LED bis 12W     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    127    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    32 - allgemeine LED bis 12W     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    0    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    0    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    not active     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    89    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    36 - LED Kleinleistung     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    0    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    0    16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0    16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    not active     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    not active     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    0    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    0    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    0    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    not active     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    not active     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    not active     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    0    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    0    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    0    16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    not active     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    not active     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    not active     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    127    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    5D     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    52    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    53 - LED LeiMo3G o Open Load     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Versorgungsbedarf der LED-LeiMo3G-Module     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    127    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    5E     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    53    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    53 - LED LeiMo3G o Open Load     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Versorgungsbedarf der LED-LeiMo3G-Module     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    Parking light right     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    0    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    0    16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    0    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    not active     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    not active     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    not active     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    0    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    0    16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    0    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    not active     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    not active     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    not active     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    2-Sensor LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    0 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    not active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    90.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    10.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -127.0 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    -8.00 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    -8.00 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    -8.00 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    -8.00 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    -8.00 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    -8.00 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_1     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    0.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    0.00 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    normal     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Negative     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    0 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    0 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    0 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    0 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    0 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    0 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    2.50%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    0 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    0.00 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    Rear     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    20.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    0.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    -100.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    not installed     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1    2.0 s    7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang    10 s    7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik    active     7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS    Nicht_verbaut     7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark    not active     7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze    100 m    7
ENG246957-ENG246981-Lichttaster-Lichttastermodul    lds     7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config    1    7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle    30 km/h    7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig    active     7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig    active     7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig    not active     7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -5.00%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -5.00%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -5.00%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -5.00%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -5.00%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -5    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -5    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -5    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -5    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    -5    20
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    installed     8
ENG122979-ENG99457-Networking-Head area heater    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG124714-ENG142044-OCU-DWA_push    active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    active     8
ENG124714-ENG246970-OCU-IAA -Nutzer_management    not installed     8
ENG124714-OCU-    installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    Via ZV-Absicherung Light     8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    4    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 1.x)     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    not active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut    No     4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut    No     4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln    No     4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut    No     4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln    No     4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut    No     4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt    No     4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut    No     4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut    No     4
ENG141646-MAS01065-Querschnitts_funktionen-Brand    VW     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Sollspannungsanforderung 13.5     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Left     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Right     5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis    5 km/h    8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max    50 km/h    8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM    1.5 s    8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI    not active     8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash    not installed     8
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    not installed     10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    not active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    0 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    0 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    0 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG    not installed     4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    MFG     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    not active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by convenience operation via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    not active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    not active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    not active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    not active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    not active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    not active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    CAN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel    23400 ms    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    20.0 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    3.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    2    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    10.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    500 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    50    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    100    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    2.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    2.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    6.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    10.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    80.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    10 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    100 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    500 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    20    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    80    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    180    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    300    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN     4
ENG141969-ENG249827-UGDO-Anlernblinken    not active     3
ENG141969-ENG249832-UGDO-Bedienfeld    not installed     3
ENG141969-ENG172987-UGDO-ugdo_transmitter    not installed     3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable    not active     3
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version    Version_1_2     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation    5    8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold    30 s    8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation    180 s    8
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw    0 bit    4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    40    3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    60    3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30    3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    not installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    315MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Einzeltuerentriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    not active     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    not active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    via_CAN     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    Yes     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Contact control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    not active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    not active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    not active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    not active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    not active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    not active     8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    Yes     5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:22
4B Module
;SW:3Q0-907-338-E   HW:3Q0-907-338-E ---  Multifunc. Module
;Component:FCM MQB Low   003 0367     Coding:00000005090008D206104F010A0000000000000000000000000000000000
;EV_MultiModulContiVW48X    3003    EV_MultiModulContiVW48X_003.rod
;Saturday    19    November    2022    20:30:30:12942
;VCDS Version: Release 22.10.0 (x64)  Data version: 20221026 DS344.0
;VCID: 37282376DFCEAC531A8-8062
IDE00001-Production mode    not active     3
IDE00820-Activating and deactivating all development messages    not active     1
IDE02332-Deactivate production mode    0    3
IDE03641-Presentation run dynamic AFS light    active     1
IDE03642-Presentation mode    not active     1
IDE03679-Adaptive light functions    active     1
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE08418-Matrix light: total dimming    0.00%    1
IDE09156-Matrix headlamp: function at standstill    not active     1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1    OFF     12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2    OFF     12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3    OFF     12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4    OFF     12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5    OFF     12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6    OFF     12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7    OFF     12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8    OFF     12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9    OFF     12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10    OFF     12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11    OFF     12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12    OFF     12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13    OFF     12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14    OFF     12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15    OFF     12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16    OFF     12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17    OFF     12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18    OFF     12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19    OFF     12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20    OFF     12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21    OFF     12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22    OFF     12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23    OFF     12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24    OFF     12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25    OFF     12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26    OFF     12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27    OFF     12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28    OFF     12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29    OFF     12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30    OFF     12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31    OFF     12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32    OFF     12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33    OFF     12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34    OFF     12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35    OFF     12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36    OFF     12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37    OFF     12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38    OFF     12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39    OFF     12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40    OFF     12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41    OFF     12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42    OFF     12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43    OFF     12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44    OFF     12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45    OFF     12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46    OFF     12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47    OFF     12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48    OFF     12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49    OFF     12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50    OFF     12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51    OFF     12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52    OFF     12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53    OFF     12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54    OFF     12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55    OFF     12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56    OFF     12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57    OFF     12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58    OFF     12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59    OFF     12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60    OFF     12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61    OFF     12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62    OFF     12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63    OFF     12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64    OFF     12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65    OFF     12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66    OFF     12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67    OFF     12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68    OFF     12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69    OFF     12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70    OFF     12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71    OFF     12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72    OFF     12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73    OFF     12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74    OFF     12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75    OFF     12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76    OFF     12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77    OFF     12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78    OFF     12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79    OFF     12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80    OFF     12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81    OFF     12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82    OFF     12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83    OFF     12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84    OFF     12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85    OFF     12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86    OFF     12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87    OFF     12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88    OFF     12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89    OFF     12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90    OFF     12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1    OFF     12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2    OFF     12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3    OFF     12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4    OFF     12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5    OFF     12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6    OFF     12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7    OFF     12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8    OFF     12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9    OFF     12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10    OFF     12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11    OFF     12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12    OFF     12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13    OFF     12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14    OFF     12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15    OFF     12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16    OFF     12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17    OFF     12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18    OFF     12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19    OFF     12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20    OFF     12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21    OFF     12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22    OFF     12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23    OFF     12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24    OFF     12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25    OFF     12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26    OFF     12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27    OFF     12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28    OFF     12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29    OFF     12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30    OFF     12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31    OFF     12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32    OFF     12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33    OFF     12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34    OFF     12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35    OFF     12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36    OFF     12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37    OFF     12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38    OFF     12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39    OFF     12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40    OFF     12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41    OFF     12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42    OFF     12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43    OFF     12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44    OFF     12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45    OFF     12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46    OFF     12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47    OFF     12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48    OFF     12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49    OFF     12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50    OFF     12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51    OFF     12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52    OFF     12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53    OFF     12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54    OFF     12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55    OFF     12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56    OFF     12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57    OFF     12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58    OFF     12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59    OFF     12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60    OFF     12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61    OFF     12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62    OFF     12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63    OFF     12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64    OFF     12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65    OFF     12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66    OFF     12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67    OFF     12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68    OFF     12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69    OFF     12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70    OFF     12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71    OFF     12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72    OFF     12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73    OFF     12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74    OFF     12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75    OFF     12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76    OFF     12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77    OFF     12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78    OFF     12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79    OFF     12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80    OFF     12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81    OFF     12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82    OFF     12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83    OFF     12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84    OFF     12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85    OFF     12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86    OFF     12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87    OFF     12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88    OFF     12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89    OFF     12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90    OFF     12
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest    30%    12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion    30%    12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest    30%    12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion    30%    12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest    50%    12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion    50%    12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest    50%    12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion    50%    12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest    75%    12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion    75%    12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest    80%    12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion    80%    12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1    OFF     3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2    OFF     3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3    OFF     3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4    OFF     3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5    OFF     3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6    OFF     3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7    OFF     3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8    OFF     3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9    OFF     3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10    OFF     3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11    OFF     3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12    OFF     3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13    OFF     3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14    OFF     3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15    OFF     3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16    OFF     3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17    OFF     3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18    OFF     3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19    OFF     3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20    OFF     3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1    OFF     3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2    OFF     3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3    OFF     3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4    OFF     3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5    OFF     3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6    OFF     3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7    OFF     3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8    OFF     3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9    OFF     3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10    OFF     3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11    OFF     3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12    OFF     3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13    OFF     3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14    OFF     3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15    OFF     3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16    OFF     3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17    OFF     3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18    OFF     3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19    OFF     3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20    OFF     3
IDE13611-Cornering lamp in operation    not active     1
IDE13612-Matrix head lamps: steering angle    9600.00 °    2
ENG124608-Order_Reference_Run_Activation_Effect    No dependency     1
ENG124607-Reference_Run_Activation_Effect    Activation effect disabled     1
ENG103979-Reference_Run_Start_Condition    Engine start     1
Elapsed Time: 00:13
And CAN-19:
;SW:3Q0-907-530-L   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   518 5323     Coding:030500347F085900FB0322481E0F00010001070000000000000000000000
;EV_GatewNF    13023    EV_GatewNF_VW37.rod
;Saturday    19    November    2022    20:48:12:12942
;VCID: 382A204AD2D0A32B132-806C
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys    Deactivating     3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation    Deactivating     3
IDE00002-Transport mode    not active     1
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages    not active     1
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved    0    1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation    12.1 V    2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering    12.1 V    2
IDE01211-Static current measuring mode    not activated     1
IDE01457-Energy management deactivation stage    Mode not active     1
IDE01459-Energy management heat output control status    Mode not active     1
IDE01844-Increase idle speed request    Mode not active     1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time    --     3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation    Mode not active     3
IDE01860-Generator specified voltage value variable    10.6 V    1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics    coded     32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics    coded     32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics    coded     32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side    Not coded     32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module    coded     32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric    coded     32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater    Not coded     32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1    Not coded     32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation    coded     32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics    Not coded     32
IDE01996-SFT00021-Installation list: specified installations-Airbag    coded     32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems    coded     32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster    coded     32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating    Not coded     32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface    1    32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection    Not coded     32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant    Not coded     32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2    Not coded     32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics    coded     32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost    Not coded     32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation    Not coded     32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock    coded     32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2    Not coded     32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics    Not coded     32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side    Not coded     32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance    coded     32
IDE01996-SFT00061-Installation list: specified installations-Special Function    Not coded     32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor    Not coded     32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics    coded     32
IDE01996-SFT00068-Installation list: specified installations-Power steering    coded     32
IDE01996-SFT00071-Installation list: specified installations-Sound System    Not coded     32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module    Not coded     32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module    coded     32
IDE01996-SFT00081-Installation list: specified installations-Electric drive    Not coded     32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics    coded     32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control    coded     32
IDE01996-SFT00086-Installation list: specified installations-Radio    Not coded     32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner    Not coded     32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1    coded     32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder    Not coded     32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS)    Not coded     32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function    Not coded     32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system    coded     32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics    Not coded     32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit    coded     32
IDE01996-SFT00118-Installation list: specified installations-Parking aid    Not coded     32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1    Not coded     32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display    Not coded     32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management    Not coded     32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems    Not coded     32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module    Not coded     32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator    Not coded     32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system    coded     32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics    Not coded     32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics    Not coded     32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management    Not coded     32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door    Not coded     32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door    Not coded     32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise    Not coded     32
IDE01996-SFT00197-Installation list: specified installations-Thermal management    Not coded     32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger    Not coded     32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module    Not coded     32
IDE01996-SFT00204-Installation list: specified installations-Starter generator    Not coded     32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2    Not coded     32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01    Not coded     32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02    Not coded     32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03    Not coded     32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04    Not coded     32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05    Not coded     32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06    Not coded     32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07    Not coded     32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08    Not coded     32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D    Not coded     32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11    Not coded     32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16    Not coded     32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17    Not coded     32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A    Not coded     32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D    Not coded     32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F    Not coded     32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20    Not coded     32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21    Not coded     32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22    Not coded     32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24    Not coded     32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25    Not coded     32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26    Not coded     32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27    Not coded     32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28    Not coded     32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29    Not coded     32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A    Not coded     32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E    Not coded     32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F    Not coded     32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35    Not coded     32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36    Not coded     32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37    Not coded     32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38    Not coded     32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39    Not coded     32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A    Not coded     32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C    Not coded     32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D    Not coded     32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40    Not coded     32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41    Not coded     32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43    Not coded     32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45    Not coded     32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48    Not coded     32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49    Not coded     32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51    Not coded     32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52    Not coded     32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53    Not coded     32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55    Not coded     32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56    Not coded     32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58    Not coded     32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59    Not coded     32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A    Not coded     32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B    Not coded     32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C    Not coded     32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D    Not coded     32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E    Not coded     32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F    Not coded     32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60    Not coded     32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61    Not coded     32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62    Not coded     32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66    Not coded     32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68    Not coded     32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B    Not coded     32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C    Not coded     32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E    Not coded     32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74    Not coded     32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75    Not coded     32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78    Not coded     32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79    Not coded     32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A    Not coded     32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D    Not coded     32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E    Not coded     32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F    Not coded     32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80    Not coded     32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81    Not coded     32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82    Not coded     32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83    Not coded     32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86    Not coded     32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87    Not coded     32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88    Not coded     32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89    Not coded     32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B    Not coded     32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C    Not coded     32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D    Not coded     32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E    Not coded     32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F    Not coded     32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90    Not coded     32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91    Not coded     32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92    Not coded     32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93    Not coded     32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94    Not coded     32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95    Not coded     32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96    Not coded     32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97    Not coded     32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98    coded     32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99    coded     32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A    Not coded     32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B    Not coded     32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D    Not coded     32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E    Not coded     32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F    Not coded     32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0    Not coded     32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1    Not coded     32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2    Not coded     32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3    Not coded     32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5    Not coded     32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6    Not coded     32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7    Not coded     32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8    Not coded     32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA    Not coded     32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB    Not coded     32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC    Not coded     32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD    Not coded     32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF    Not coded     32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0    Not coded     32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1    Not coded     32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2    Not coded     32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3    Not coded     32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4    Not coded     32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5    Not coded     32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6    Not coded     32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7    Not coded     32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8    Not coded     32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9    Not coded     32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA    Not coded     32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB    Not coded     32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC    Not coded     32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD    Not coded     32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE    Not coded     32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF    Not coded     32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0    Not coded     32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1    Not coded     32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2    Not coded     32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3    Not coded     32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4    Not coded     32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5    Not coded     32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6    Not coded     32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7    Not coded     32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8    Not coded     32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9    Not coded     32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA    Not coded     32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB    Not coded     32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC    Not coded     32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD    Not coded     32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE    Not coded     32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF    Not coded     32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0    Not coded     32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1    Not coded     32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2    Not coded     32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3    Not coded     32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4    Not coded     32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5    Not coded     32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6    Not coded     32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7    Not coded     32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8    Not coded     32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9    Not coded     32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA    Not coded     32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB    Not coded     32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC    Not coded     32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD    Not coded     32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE    Not coded     32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF    Not coded     32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0    Not coded     32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1    Not coded     32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2    Not coded     32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3    Not coded     32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4    Not coded     32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5    Not coded     32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6    Not coded     32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7    Not coded     32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8    Not coded     32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9    Not coded     32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA    Not coded     32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB    Not coded     32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC    Not coded     32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED    Not coded     32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE    Not coded     32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF    Not coded     32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0    Not coded     32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1    Not coded     32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2    Not coded     32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3    Not coded     32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4    Not coded     32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5    Not coded     32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6    Not coded     32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7    Not coded     32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8    Not coded     32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9    Not coded     32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA    Not coded     32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB    Not coded     32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC    Not coded     32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD    Not coded     32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE    Not coded     32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF    Not coded     32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity    69 Ah    15
IDE03256-MAS06106-Battery adaptation-Battery technology    EFB     15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer    JCB     15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number    1111111111    15
IDE03903-Production process data 1    00 00     2
IDE04159-Deactivation of start/stop function    Mode not active     1
IDE04186-Battery terminal recognition    connected     1
IDE04330-Transfer of release code for a SWaP function    0    1
IDE04331-Selection of release codes for a SWaP function    FF FF FF FF     4
IDE06530-Distance left for deactivation of static current measuring mode    2    1
IDE06541-Distance left for deactivation of transport mode    50    1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof    activated     4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM    activated     4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start    activated     4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)    activated     4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system    activated     4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system    activated     4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof    activated     4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D    activated     4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill    activated     4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)    activated     4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill    activated     4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C    activated     4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater    activated     4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater    activated     4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater    activated     4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation    activated     4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater    activated     4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light    activated     4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light    not activated     4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission    activated     4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater    activated     4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater    activated     4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater    activated     4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater    activated     4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation    activated     4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection    ECO tips independent of driver profile selection     4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption    activated     4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency    Until temperature threshold: with after-run: with switch     4
IDE07838-Counter for inconsistent states    291    2
IDE08348-Start/stop start voltage limit    7.8 V    1
IDE08624-MKE Check box    activated     1
IDE10735-Number requests autonomous recharging    3    1
IDE10736-Cyclization limitation request battery service    0    1
IDE10748-MAS11262-Range gain-Range gain AC system    activated     3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater    activated     3
IDE10748-MAS11264-Range gain-Range gain window defogger    activated     3
IDE10748-MAS11265-Range gain-Range gain seat heater front    activated     3
IDE10748-MAS11266-Range gain-Range gain front set ventilation    activated     3
IDE10748-MAS11267-Range gain-Range gain rear heater    activated     3
IDE10748-MAS11268-Range gain-Range gain fog light    activated     3
IDE10748-MAS11269-Range gain-Range gain rear fog light    not activated     3
IDE10748-MAS11270-Range gain-Range gain windshield heating    activated     3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater    activated     3
IDE10748-MAS11272-Range gain-Range gain mirror heater    activated     3
IDE10748-MAS11273-Range gain-Range gain rear seat heater    activated     3
IDE10748-MAS11274-Range gain-Range gain rear seat heater    activated     3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system    not activated     3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system    not activated     3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption    not activated     3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain    not activated     3
IDE10748-MAS11279-Range gain-List at engine still stand    activated     3
IDE10748-MAS12689-Range gain-Catalogue range display    activated     3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display    activated     3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting    activated     3
IDE10748-MAS19099-Range gain-Convenience consumption socket    activated     3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption    activated     3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating    activated     3
IDE11689-48V-System: locking    regular operation     1
MAS16372-Security version number    2    2
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch    not installed     3
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button    not active     3
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage    not active     3
SFT271921-MAS06614-Multifunction steering wheel control module-Variant    CCS     3
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor    not installed     3
SFT271921-MAS13892-Multifunction steering wheel control module-Platform    MQB     3
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function    not active     3
SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour    active with terminal 58     3
SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC    automatic     3
SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist    automatic     3
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig    not active     3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset    active     12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation    100    12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation    60000 ms    12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation    10000 ms    12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption    3000 ms    12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption    0 ms    12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation    180000 ms    12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation    1500 ms    12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation    0 ms    12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption    2500 ms    12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports    Mode not active     4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen    Mode not active     4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen    Mode not active     4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC)    Mode not active     4
ENG137075-EM_heating_power_quota_adjustment    1000 W    1
ENG137061-EM_nominal_voltage_limitation_low_beams    12.1 V    1
ENG137064-EM_requirement_cyclic_time_voltage_measurement    0 s    1
ENG137063-EM_requirement_reduction_air_blowers    Mode not active     1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature    -50.0 °C    2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature    -50.0 °C    2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics    activated     32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics    activated     32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics    not activated     32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side    activated     32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module    activated     32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric    activated     32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater    activated     32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1    activated     32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation    activated     32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics    activated     32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag    not activated     32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems    activated     32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster    activated     32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating    activated     32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface    activated     32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection    activated     32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant    activated     32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2    activated     32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics    activated     32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost    activated     32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation    activated     32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock    activated     32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2    activated     32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics    activated     32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side    activated     32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance    activated     32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function    activated     32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor    activated     32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics    activated     32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering    activated     32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System    activated     32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module    activated     32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive    activated     32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics    activated     32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control    activated     32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio    activated     32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner    activated     32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1    activated     32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder    activated     32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS)    activated     32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function    activated     32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system    activated     32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics    activated     32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit    activated     32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid    activated     32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1    activated     32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display    activated     32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management    activated     32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems    activated     32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module    activated     32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator    activated     32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system    activated     32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics    activated     32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics    activated     32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management    activated     32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door    activated     32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door    activated     32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise    activated     32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management    activated     32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger    activated     32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module    activated     32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator    activated     32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2    activated     32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00    activated     32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01    activated     32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02    activated     32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03    activated     32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04    activated     32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05    activated     32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06    activated     32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07    activated     32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08    activated     32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D    activated     32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11    activated     32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16    activated     32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17    activated     32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A    activated     32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D    activated     32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F    activated     32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20    activated     32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21    activated     32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22    activated     32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24    activated     32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25    activated     32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26    activated     32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27    activated     32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28    activated     32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29    activated     32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A    activated     32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E    activated     32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F    activated     32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35    activated     32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36    activated     32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37    activated     32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38    activated     32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39    activated     32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A    activated     32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C    activated     32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D    activated     32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40    activated     32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41    activated     32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43    activated     32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45    activated     32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48    activated     32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49    activated     32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51    activated     32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52    activated     32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53    activated     32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55    activated     32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56    activated     32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58    activated     32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59    activated     32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A    activated     32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B    activated     32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C    activated     32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D    activated     32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E    activated     32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F    activated     32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60    activated     32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61    activated     32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62    activated     32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66    activated     32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68    activated     32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B    activated     32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C    activated     32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E    activated     32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74    activated     32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75    activated     32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78    activated     32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79    activated     32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A    activated     32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D    activated     32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E    activated     32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F    activated     32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80    activated     32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81    activated     32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82    activated     32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83    activated     32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86    activated     32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87    activated     32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88    activated     32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89    activated     32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B    activated     32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C    activated     32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D    activated     32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E    activated     32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F    activated     32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90    activated     32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91    activated     32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92    activated     32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93    activated     32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94    activated     32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95    activated     32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96    activated     32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97    activated     32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98    activated     32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99    activated     32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A    activated     32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B    activated     32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D    activated     32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E    activated     32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F    activated     32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0    activated     32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1    activated     32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2    activated     32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3    activated     32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5    activated     32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6    activated     32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7    activated     32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8    activated     32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA    activated     32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB    activated     32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC    activated     32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD    activated     32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF    activated     32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0    activated     32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1    activated     32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2    activated     32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3    activated     32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4    activated     32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5    activated     32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6    activated     32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7    activated     32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8    activated     32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9    activated     32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA    activated     32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB    activated     32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC    activated     32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD    activated     32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE    activated     32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF    activated     32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0    activated     32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1    activated     32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2    activated     32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3    activated     32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4    activated     32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5    activated     32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6    activated     32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7    activated     32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8    activated     32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9    activated     32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA    activated     32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB    activated     32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC    activated     32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD    activated     32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE    activated     32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF    activated     32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0    activated     32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1    activated     32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2    activated     32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3    activated     32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4    activated     32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5    activated     32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6    activated     32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7    activated     32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8    activated     32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9    activated     32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA    activated     32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB    activated     32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC    activated     32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD    activated     32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE    activated     32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF    activated     32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0    activated     32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1    activated     32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2    activated     32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3    activated     32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4    activated     32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5    activated     32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6    activated     32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7    activated     32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8    activated     32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9    activated     32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA    activated     32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB    activated     32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC    activated     32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED    activated     32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE    activated     32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF    activated     32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0    activated     32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1    activated     32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2    activated     32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3    activated     32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4    activated     32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5    activated     32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6    activated     32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7    activated     32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8    activated     32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9    activated     32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA    activated     32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB    activated     32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC    activated     32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD    activated     32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE    activated     32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF    activated     32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus    Powertrain data bus     2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ    not active     2
ENG152379-MV-EM_adaption_48V_zero_potential    regular operation     1
ENG137850-MVK_Warning    regular operation     1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation    activated     1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate    activated     1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events    100    8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events    20    8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events    10    8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time    120 min    8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events    12 s    8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay    0 s    8
Elapsed Time: 00:26
vastechnics
C?ID=143747
The most important the slave modules are some not to be reached. Very important. The 29 39 and d6 and d7 need to be reached and need good dataset. No good dataset is no good working
  • Agree
