How to disable ACC and use regular cruise control on MK7.5 Golf R?
   #21
downtime
Finland
C?ID=280813
It could be. The bump could have broken the clips so that they’re structural integrity was weakend and it went until this far until it really broke.
I’m looking at the vertical angle which is 2 degrees and that is out of spec.
  • Agree
MK7.5
C?ID=402753
This is the damage that was done to the front bumper in June 2021. I really don't see how this could effect the ACC at all, especially not 15 months later, as the radar is nowhere near where the damage is. The ACC stopped working randomly while driving on the highway in September 2022, there was no collision that caused it to go out. I am going to try changing the values and seeing if that works, I just need info on how to access those channels, because S12345 did not work. At this point, it's really either me fixing it myself or trading it in, because driving a car with no cruise control at all is very inconvenient and the pricing to get it recalibrated at the dealer is just outrageous. Even if the screws do need to be adjusted as well, I can do so. I just need to know how.
downtime
Finland
C?ID=280813
If you want to calibrate it yourself, you need to drive the car against a flat wall or similar so that the car is exactly 120mm away from it and is exactly perpendicularry aligned. Also the surface needs to be exactly flat so it does not cause any deviation in adjustment.
Then run calibration in basic settings and do the reset personalisation settings.
If you need to adjust the radar. Take the VW emblem out and turn the screws. There are three and with those you can adjust vertical angle, horizontal angle and ”twist” angle.
You need a special adjustment tool to turn the screws.
This one
MK7.5
C?ID=402753
Good news. I was able to get help from @AINils for the calibration, and now it’s fully working with no fault codes present. It’s detecting cars and slowing down as it should be! :)
Friday,25,November,2022,06:15:27:43090
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWVA7AU1KW224276   License Plate:
Mileage: 52576km-32669mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU1KW224276   Mileage: 52576km-32669miles
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---    CVN: CFC4C78C
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4EC56429B05DA05B29E-801A
   VINID: 9E69E644746505B9C20840871843012DDE
Readiness: 1110 0101
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07    CVN: 3550919B
   ROD: EV_TCMDQ381061.rod
   VCID: 2411E6818E517A0BAFA-8070
   No subsystems:
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 61059000000609
   Coding: 01FA6BA1502221704779030760C96980D60A84E2C0069677384250D8D6A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 06559C0918ADA81BD1E-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6103279128
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D3451D6B1F5D33B60-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500001211140A
   VCID: 6D87C3A51D1B7B43304-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001915701239
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0B43AD3D03CFD5738E0-805E
   Component: WWS    190523  043 0551
   Serial number:         190529040911
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M06D18H23M45S55
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000008061904220204
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418319168
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC16E214641924B47A-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330047C159FFC728949C810580401600000000000000000004
   VCID: 44D146016E115A0B8FA-8010
   Serial number: 28051941350748
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382922F122D90EEB132-806C
   Serial number: 003GCR0C22G4
   VCID: 47CB510D5F2771136A8-8012
   Serial number: IBH00000000000BKP8VC
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 357000000004F374CD3X
   Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 358000000003A020FC3I
   Subsystem 4 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B2EFDF5B5226P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A6F001345535P
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF001346C853
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF001346746$
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: 2C010EA1E681B24B67A-8078
   Serial number: 06061911603847
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   GVL: 01C63C100000060040CC80008000CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C4A9101D805B09E-803A
   Generator:
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001188330099222
   Coding: 2DFFFF
   Serial number: 4546471505
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00017.05.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000163099011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1FD5C1A3DFA354C-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0518404430
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2733E50DFB2BC3C04-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0518694848
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SDI2875A
   Coding: 003F1320D000040000000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031016617
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213EE116E122CBF7A-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05GS0V
   Coding: 12000000008AAA8A000000000000
   Shop #: WSC 07294 004 104857
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E0504A9D09DC05B49E-807A
   Component: FCM MQB Low   002 0345
   Serial number: 09061910524172
   Coding: 000000050900165206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35372BC535CBF383084-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SDR01781
   Coding: 003F1320DC00040000000000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031198255
   Coding: 091000
   Part No SW: 5NA 035 026 E    HW: 5NA 035 026
   Component: MU-H-NS-US    H55 1418
   Serial number: A851L0KB000501
   Coding: 027310020000000021220002001808001F0507F401200405DE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   VCID: 392F27F519D317E3ECC-806C
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0573408
   Subsystem 2 - Part No SW: V03 959 806 NG    HW: -----------
   Component: NAR 2021  --- 0081
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H11 0610
   Serial number: 05021915K12530
   Coding: 0003070000000201002223548156890084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D94A117A09462BAB2-8014
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190419202209
   VCID: 2F3B19ADD797C953428-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:58, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
