How to disable ACC and use regular cruise control on MK7.5 Golf R?
MK7.5
C?ID=402753
Long story short, my ACC stopped working randomly at only 30k miles and the dealer wanted $600 to realign the sensor. I’m not paying it, so I would like to code it to use regular cruise control if possible. Ridiculous driving around in a $40k car and not being able to use cruise control at all.
Friday,12,August,2022,08:15:34:43090
VIN: WVWVA7AU1KW224276   License Plate:
Mileage: 42938km-26680mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU1KW224276   Mileage: 42938km-26680miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---    CVN: CFC4C78C
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4EC56429B05DA05B0D3-801A
   VINID: 9E69E644746505B9C20840871843012DDE
21392 - Control Module for Exhaust Flap
          P14AB 00 [104] - Mechanical Malfunction
                    Fault Frequency: 234
                    Mileage: 38874 km
                    Date: 2022.05.24
                    Time: 09:12:57
                    Engine RPM: 1292.75 /min
                    Vehicle speed: 70 km/h
                    Coolant temperature: 106 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.804 V
                    Engine: operating status: PU
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 622 s
                    MAP_MES_SAE: 26 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.880 V
                    FAC_TPS_1_SAE: 12.500000 %
                    FUP_H_SAE: 6300.0 kPa
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07    CVN: 3550919B
   ROD: EV_TCMDQ381061.rod
   VCID: 2411E6818E517A0B8B7-8070
   No subsystems:
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 61059000000609
   Coding: 01FA6BA1502221704779030760C96980D60A84E2C0069677384250D8D6A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 06559C0918ADA81BF53-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6103279128
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D3451D6B1F5D3392D-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500001211140A
   VCID: 6D87C3A51D1B7B43149-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001915701239
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0B43AD3D03CFD573AAD-805E
   Component: WWS    190523  043 0551
   Serial number:         190529040911
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M06D18H23M45S55
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000008061904220204
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418319168
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4CC16E214641924B637-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330047C159FFC728949C810580401600000000000000000004
   VCID: 44D146016E115A0BAB7-8010
   Serial number: 28051941350748
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382922F122D90EEB37F-806C
   Serial number: 003GCR0C22G4
   VCID: 47CB510D5F2771134E5-8012
   Serial number: IBH00000000000BKP8VC
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 357000000004F374CD3X
   Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 358000000003A020FC3I
   Subsystem 4 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B2EFDF5B5226P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A6F001345535P
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF001346C853
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF001346746$
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: 2C010EA1E681B24B437-8078
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 87
                    Mileage: 38866 km
                    Date: 2022.05.24
                    Time: 09:02:11
   Serial number: 06061911603847
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   GVL: 01C63C100000060040CC80008000CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C4A9101D805B2D3-803A
   Generator:
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001188330099222
   Coding: 2DFFFF
   Serial number: 4546471505
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00017.05.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 87
                    Mileage: 42918 km
                    Date: 2022.08.11
                    Time: 12:51:19
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000163099011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1FD5C1A3DFA3701-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Reset counter: 84
                    Mileage: 42852 km
                    Date: 2022.08.10
                    Time: 20:09:29
   Serial number: 0518404430
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2733E50DFB2BC3E49-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0518694848
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SDI2875A
   Coding: 001F1320D000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031016617
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213EE116E122CBD37-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05GS0V
   Coding: 12000000008AAA8A000000000000
   Shop #: WSC 07294 004 104857
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E0504A9D09DC05B6D3-807A
0512 - Rear Right Treble Speaker
          B1068 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 88
                    Mileage: 42045 km
                    Date: 2022.07.28
                    Time: 12:52:10
                    Voltage terminal 30: 12.3 V
0517 - Rear Left Treble Speaker
          B1066 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 88
                    Mileage: 42045 km
                    Date: 2022.07.28
                    Time: 12:52:10
0564 - Front Right Treble Speaker
          B1064 F0 [008] - Cross-Coupled
          [Verbindungen zu Lautsprechern Kanal 7: elektrischer Fehler im Stromkreis]
                    Reset counter: 88
                    Mileage: 40229 km
                    Date: 2022.06.23
                    Time: 09:44:14
                    Voltage terminal 30: 12.1 V
0585 - Front Left Treble Speaker
          B1061 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 12: Unterbrechung (AC-Diagnose)]
                    Reset counter: 88
                    Mileage: 40229 km
                    Date: 2022.06.23
                    Time: 09:44:14
   Component: FCM MQB Low   002 0345
   Serial number: 09061910524172
   Coding: 000000050900165206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35372BC535CBF3832C9-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SDR01781
   Coding: 001F1320DC00040000000000
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031198255
   Coding: 091000
   Part No SW: 5NA 035 026 E    HW: 5NA 035 026
   Component: MU-H-NS-US    H55 1418
   Serial number: A851L0KB000501
   Coding: 027310020000000021220002001808001F0507F401200405DE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   VCID: 392F27F519D317E3C81-806C
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0573408
   Subsystem 2 - Part No SW: V03 959 806 NG    HW: -----------
   Component: NAR 2021  --- 0081
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H11 0610
   Serial number: 05021915K12530
   Coding: 0003070000000201002223548156890084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D94A117A09462B8FF-8014
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190419202209
   VCID: 2F3B19ADD797C953665-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:01, VBatt start/end: 12.1V/12.1V)-----------
Curious: There are no ACC faults showing in your scan...?
MK7.5
C?ID=402753
It’s an old scan, but all coding is the same. Just the fault stored saying that the sensor needs to be realigned
golfi_vend
Tartu, Estonia
C?ID=195131
Disconnect module, code out from modules that give fault and replce steering wheel buttons.
MK7.5
C?ID=402753
Definitely don’t see any need to replace steering wheel. The only additional button that ACC adds is the distance button. I don’t mind a fault code being stored, I just want to know if it’s possible to code regular cruise, and if so, how?
downtime
Finland
C?ID=280813
Also I wonder if the ”older” MQB cars stlll need separate FeC for CCS. Earlier it was so. Newer MQBs have both ACC and regular cruise and you can just code the CCS to be active in ACC module.
Try to find some hobbyist in your area who knows how to clear the misalignment error. Most likely there’s nothing wrong with the alignment unless you’ve moved it. The 3QF radar seems to be really picky and go nuts with automatic calibration if there’s heavy slushy snow or rain.
golfi_vend
Tartu, Estonia
C?ID=195131
If I remember correctly alignment angle can be changed in development session using SA 20103.
downtime
Finland
C?ID=280813
Yes, you’re correct. It can be done. Just need to be able to change the session from diagnostic to development.
There’s 4 angles. Horizontal correction angle static, vertical correction angle static and same two with dynamic at the end instead of static.
Now if you clear the dynamic values and go to basic settings and execute reset personalization settings. It will clear the misalignment error and restart the dynamic calibration.
DO NOT change the static values.
DerHase
C?ID=502924
What are you vertical and horizontal readings in live data?
Put the car on level ground and pull your grille emblem to see the radar module directly. Check to make sure you can't rattle the sensor around like crazy. Most have a tiny bit of play but in my experience aftermarket grilles have poor fitment/retainment, or if the sensor was pried out before they tend to wear out the little nubs and the groove it slides and clicks into.
IF you have a digital angle finder, IIRC there is something like a 4 or 4.5 deg vertical tolerance for the emblem mounted radar units. Going strictly off memory it needs to be -0.5 deg downwards up to +4.0 deg upwards as measured externally. Pending what your live data readings show, and a physical inspection find that may mean you could just be on the verge of in/out of spec... and something as simple as loosening the upper grille and pushing forward or backward to affect the radar vertical angle a tiny bit may be all that's needed.
I have the targets and calibrate these systems after collision repairs... I don't know anything about the basic settings dynamic reset referenced above by @downtime , we do the static calibration since it's easier to verify/diagnose in a controlled environment rather than drive for 20 min and then find out something is messed up.
AINils
Germany (AIB)
C?ID=56975
                    Mileage: 38874 km
                    Date: 2022.05.24
                    Time: 09:12:57
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 622 s
                    MAP_MES_SAE: 26 kPa
          U0416 00 [032] - -
   No subsystems:
   Coding: 132C0C0723
   Revision: 00001K08
   Air quality sensor:
   Coding: 0008DD
   Coding: 0471155811
   Coding: 303344
          U1110 00 [008] - -
                    Reset counter: 87
                    Mileage: 38866 km
                    Date: 2022.05.24
                    Time: 09:02:11
   Generator:
   Coding: 2DFFFF
   Coding: 0001
                    Reset counter: 87
                    Mileage: 42918 km
                    Date: 2022.08.11
                    Time: 12:51:19
                    Reset counter: 84
                    Mileage: 42852 km
                    Date: 2022.08.10
                    Time: 20:09:29
   Coding: 02011103
   Coding: 020111
   Coding: 111000
   Coding: 911F0000
                    Reset counter: 88
                    Mileage: 42045 km
                    Date: 2022.07.28
                    Time: 12:52:10
                    Reset counter: 88
                    Mileage: 42045 km
                    Date: 2022.07.28
                    Time: 12:52:10
                    Reset counter: 88
                    Mileage: 40229 km
                    Date: 2022.06.23
                    Time: 09:44:14
                    Reset counter: 88
                    Mileage: 40229 km
                    Date: 2022.06.23
                    Time: 09:44:14
   Coding: 091000
Give me your Anydesk ID an will calibrate for free in 2minutes.
But process of @downtime is fine
downtime
Finland
C?ID=280813
Yes it is. Done it many times. These newer radars rely on dynamic calibration very heavily anyway.
MK7.5
C?ID=402753
How do I change to a development session?
downtime
Finland
C?ID=280813
Try S12345 as security code. Works for some modules.
MK7.5
C?ID=402753
I think that’s it’s just done for. Now I have a 2nd fault stored:
                Address 13: Auto Dist. Reg       Labels: 5Q0-907-572-V2.clb
Control Module Part Number: 5Q0 907 572 P    HW: 3QF 907 572 A
  Component and/or Version: ACC BOSCH MQB H11 0682
           Software Coding: 330047C159FFC728949C810580401600000000000000000004
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ACCBOSCHVW416 002008 (VW37)
                      VCID: 44D146016E115A0B8FA-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 52
                    Mileage: 52105 km
                    Date: 2022.11.15
                    Time: 07:43:18
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 11.9 V
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 52
                    Mileage: 52105 km
                    Date: 2022.11.15
                    Time: 07:43:18
And these are the values:
downtime
Finland
C?ID=280813
and you took the car for a drive after clearing the dynamic values?
MK7.5
C?ID=402753
Maybe I didn’t complete all steps. I’m not sure how to change to a diagnostic sessions and can’t find any information on how to do so. That security access code didn’t work, the only one I was able to get to work was 20103. The only thing I’ve done so far is reset the personalization settings with that security code.
DerHase
C?ID=502924
Can you post the entire live data from module 13?
I just went over a bunch of scans from cars I've calibrated and none of the MK7.5 cars have any kind of dynamic calibration. Some other models give you the option of dynamic or static calibration. Looking at live data it's the vertical deadjustment value that has probably deviated out of spec.
Is there any history of any kind of collision with the vehicle? Has the front bumper or grille ever been removed?
Realistically you need to have it calibrated, end of story. Any kind of fiddling with numbers remotely has potentially dangerous consequences.
I see this all the time where shops throw stuff together and think "oh there's no light it's fine" and return to the customer. This happened once and the car slammed the brakes on from 75mph to a dead stop going into a tunnel with nothing else around.
You should check and see if any collision shops in your area have in-house calibrations or a sublet vendor (such as myself) who goes to the body shops and calibrates this stuff.
downtime
Finland
C?ID=280813
^ I have real experience from these radars and the radar in question has dynamic cal.
It is mrrevo1.4 radar. The older radars do not have dynamic cal but these evo radars do.
But you’re right and like I wrote earlier, if the radar has not been moved it is most likely a glitch and can be done the way I wrote.
If it has moved then professional static calibration is definitely needed.
Radar is safety equipment and wrong angle can give some weird effects.
However, there are parameters in the radar that filter out extreme reflections so even if the radar is way off, it will not cause any dangering issues.
The situation you described could happen also with calibrated radar. It’s called phantom braking and unfortunately happens sometimes in borderline situations where the radar gets a reflection that seems valid even it’s not.
MK7.5
C?ID=402753
The front bumper was hit in June 2021, which left minor cosmetic damage, but the ACC was not effected by that. The damage was never repaired, so the front bumper has never been removed.
After the minor incident, the ACC continued to work up until it randomly stopped working while I was using it on the highway back in September this year. I don’t think the two are related since they’re so far apart.
