Skoda Octavia iV RS Trailer retrofit
golfi_vend
Tartu, Estonia
C?ID=195131
Trying to do retrofit on this particular car. Codings/ADP done so far:
Car in question:
Engine 01:
Byte5 Bit 4 - Trailer Installed
ACC 13:
Control_module_for_towing_sensor --> Installed
BCM 09:
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,adapted from,not installed ,to,installed
Trailer 69:
0200000202001200 to 0100000202001200 Byte 0 From NAR(02) to EU(01)
This got all the fault messages gone, but for now swiveling still doesn't work.
I'm guessing this module also needs parameters?
NEtech
Denmark
C?ID=56995
What type towbar is it?
Where is it sourced from (i guess no activation card)?
[01], you probably mean Byte 5 Bit 4
[10] Byte 3 Bit 0
[13] Byte 1 Bit 7
[19] Byte 15 Bit 6, Byte 19 Bit 4
[6C] Byte 2 Bit 0
[6D] Byte 1 Bit 7
Yes think so too, what does [1A] show?
golfi_vend
Tartu, Estonia
C?ID=195131
It is original Skoda Towbar with swiveling(Not fully electric) I guess but without act card.
Dealer itself made the offer, but in ETKA VIN filter doesn't rule it out, but has a warning not for "iV RS".
It Does have SVM code TOWAB next to it, but it isn't valid in ODIS.
I can check and record 1A, but I didn't see anything that refers to dataset.
kreativ
Hidden
C?ID=108852
It needs to be unlocked using ODIS online and running SVM procedure. You can't just upload dataset to 5H2 module, it wont work.
golfi_vend
Tartu, Estonia
C?ID=195131
Yeah but not possible with Odis, because it being iV RS so officially not supported.
Which kind of unlocking are we talking about here also? SFD?
kreativ
Hidden
C?ID=108852
You can try make SWK from other Octavia VIN.
It will parameterize and unlock the button for swivel.
golfi_vend
Tartu, Estonia
C?ID=195131
[10] Byte 3 Bit 0
[13] Byte 1 Bit 7
[6C] Byte 2 Bit 0
[6D] Byte 1 Bit 7
Trailer now functioning.
I had to do different coding on 10 and 19 though. It is swiveling, not fixed/mechanically removable.
Also needed dataset. As this is being "gen2" dataset seems like it doesn't show up on 1A.
I've uploaded fresh ascan+adp to scan folder:
                Address 69: Trailer
Control Module Part Number: 5H2 907 383
  Component and/or Version: Anhaenger     H09 0040
           Software Coding: 0100000202001200
            Work Shop Code:
                      VCID: 6D8CA2FC2D1E68D3304-8038
Advanced Identification/FAZIT
     Serial number: 000000000005908
     Identification: HLH-W42
     Date: 21.01.22
     Manufacturer number: P009
     Test stand number: 3996
Flash Status
     Programming Attempts(application): 0/0
     Flash Date: 00.00.00
Misc.
     Hardware number: 5H2 907 383
     Workshop System Name: J345
     Equipment/PR Code: 000000000000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset: EV_TrailFunctGener3Hella
     ASAM Dataset Revision: 001009
VCDS Info:
       Labels: 5H0-907-383.clb
       ROD: EV_TrailFunctGener3Hella_VW27.rod
kreativ
Hidden
C?ID=108852
Good to know it worked.
What did you recode in 19? And what is 1A that you are talking about?
golfi_vend
Tartu, Estonia
C?ID=195131
Under "exp coding" there is option to select swiveling not fixed. Byte is same as NeTech suggested.
1A - Advanced ID
kreativ
Hidden
C?ID=108852
So you did not upload dataset to 69?
Only coding and the swivel now works
