Hex-Net update on VCDS Config V2.262
Bentley
South Wales, UK
C?ID=263294
Hi, I'm updating my lead and it seems to be doing things, but the applying data bar has stalled.
The transferring XX % and remaining XX are both changing.
I can't see any cancel button and I'm hesitating on just closing the program or unplugging the lead in case it is half updated and bricks the lead.
Any suggestions?
Thanks in advance, Paul.
Shaun
Can you post a screenshot? Do you have an antivirus program that tries to scan USB devices, or other software like that which might cause USB interruptions? Is this plugged into a USB hub or directly to PC?
Shaun
This should only take like two-three minutes max, I would try a different USB port or PC if you can.
Bentley
South Wales, UK
C?ID=263294
