VW 2012 Transporter engine CAAC loosing power above 2k rpm
ghosthd80
Kent, UK
C?ID=178130
hi All
my name is Sly I never actually post anything in here but time has come
I`m struggling with above vehicle for probably more than 2 months and following Peter from Ross-Tech advise would like ask for help here
just to let you all know I would like to offer reward of £50 (bank transfer or PayPal ) to the person who will help me solve this nightmare
VW Transporter 2L TDI engine code CAAC
van is loosing power above 2k rpm after power drops down it starts powering again
no fault codes at all
new turbo charger fitted, new EGR fitted , DPF was removed by previous owner
vacuum and pipes also checked
all readings via VCDS correct nothing unusual at all
if anyone have any ideas please help all welcome
please find scan below and some pictures with graph
https://ibb.co/BZbSh7S
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZCH042255   Mileage: 217130km-134918miles
01-Engine -- Status: Sporadic communication error 1000
18-Aux. Heat -- Status: Malfunction 1010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9970
   Revision: 26H43---    Serial number: 00000000000000 CVN: D8995D5B
   Coding: 0119401A230400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6DD1187BBCDBDAE598-8038
   VINID: 9E60AAAAA1D8A93600102085140D7360E2
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 208724AD09A8049724A49076AA6310
   Shop #: WSC 02756 790 49152
   VCID: 377DFA138607A035B2-8062
                    Fault Status: 00101100
                    Reset counter: 35
                    Count: 16512
                    Count: 257
                    Count: 80
                    Count: 762
                    Reset counter: 35
                    Count: 16512
                    Count: 257
                    Count: 64
                    Count: 762
                    Reset counter: 37
                    Mileage: 217037 km
                    Date: 2017.03.15
                    Time: 05:39:50
                    Count: 16512
                    Count: 2305
                    Count: 128
                    Count: 762
                    Reset counter: 44
                    Mileage: 217111 km
                    Date: 2017.03.20
                    Time: 01:50:47
                    Count: 16512
                    Count: 1
                    Count: 8194
                    Count: 762
                    Fault Status: 00100011
                    Reset counter: 247
                    Mileage: 216961 km
                    Date: 2017.03.06
                    Time: 00:09:37
                    Count: 16384
                    Count: 1
                    Count: 83
                    Count: 512
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   Shop #: WSC 02756 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FED0273B6D728F5AA-803A
          U1111 00 [008] - -
                    Reset counter: 44
                    Mileage: 217111 km
                    Date: 2022.10.28
                    Time: 02:00:20
          B10AB F0 [009] - Too Low
                    Reset counter: 4
                    Mileage: 217111 km
                    Date: 2022.10.28
                    Time: 02:00:22
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0251
   Revision: BO047001    Serial number: 0429 242110850
   Coding: A0B0793A0E612413922048102C2B8DD40000410F60040000300000000000
   Shop #: WSC 02756 790 00000
   VCID: 3979FC2BB013B64544-806C
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 3 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 7E1 951 171
13 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
                    Fault Status: 00101011
                    Reset counter: 31
01758 - Bulbs for Brake Lamps
                    Fault Frequency: 34
                    Reset counter: 35
                    Mileage: 217037 km
                    Date: 2017.03.07
                    Time: 09:26:07
03431 - Activation of Left Parking Light
                    Reset counter: 35
03432 - Activation of Right Parking Light
                    Fault Frequency: 13
                    Reset counter: 35
03435 - Terminal 30 for Interior Light and Parking Light
                    Fault Frequency: 22
                    Reset counter: 31
00329 - Control Circuit for Unlocking Rear Lid
                    Reset counter: 35
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 23
                    Reset counter: 43
                    Mileage: 216955 km
                    Date: 2017.03.04
                    Time: 06:29:24
                    Reset counter: 31
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 35
                    Mileage: 217037 km
                    Date: 2017.03.07
                    Time: 07:53:38
                    Reset counter: 35
                    Mileage: 217037 km
                    Date: 2017.03.15
                    Time: 05:40:10
                    Reset counter: 31
                    Reset counter: 35
                    Mileage: 217037 km
                    Date: 2017.03.15
                    Time: 00:08:17
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 43
                    Mileage: 217075 km
                    Date: 2017.03.20
                    Time: 02:42:35
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47401119501541
   Coding: 108001
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 3467CD1F9F714B2D97-8060
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL007GJPM
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3561F01B940B5225A0-8060
   Part No SW: 7E0 920 970 E    HW: 7E0 920 970 E
   Component: KOMBI         H04 0305
   Coding: 460C00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2C57D57F474113EDCF-8078
Address 18: Aux. Heat        Labels: 7E0-815-071.clb
   Part No: 7E0 815 071 C
   Component: J737__Standheizung  0605
   Revision: 00087000    Serial number: 09024900A00000
   Coding: 0000031
   VCID: 2541205BECAB22A510-8070
01413 - Dosing/Metering Pump (V54)
            007 - Short to Ground
                    Fault Status: 01100111
                    Mileage: 216985 km
                    Date: 2017.03.06
                    Time: 02:02:56
                        Start
                    Temperature: 28.0°C
                    Voltage: 10.68 V
                    Temperature: 15.5°C
01582 - Signal for Coolant Temperature
                    Mileage: 217111 km
                    Date: 2017.03.20
                    Time: 01:50:48
                    Temperature: 76.0°C
                    Voltage: 11.90 V
                    Temperature: 21.5°C
01126 - Engine Speed Signal
                    Mileage: 217111 km
                    Date: 2017.03.20
                    Time: 01:50:48
                    Temperature: 76.0°C
                    Voltage: 11.90 V
                    Temperature: 21.5°C
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0251
   Revision: BO047001
   Coding: 042300
   VCID: 70EF010FA3E9370DB3-8024
                    Reset counter: 44
                    Mileage: 217111 km
                    Date: 2017.03.20
                    Time: 01:50:48
01304 - Radio
                    Reset counter: 37
                    Mileage: 217037 km
                    Date: 2017.03.15
                    Time: 00:02:02
                    Reset counter: 28
   Component: IMMO          H04 0305
   VCID: 6ADB13678D35CDDDFD-803E
Address 56: Radio
End-------------------------(Elapsed Time: 03:10)--------------------------
JMR
Romania
C?ID=432218
you have errors complaining about ECU losing comms and it seems to me that your engine ECU drops comms from your scan ...is this scan fresh after you ve tired to clear all errors ? Or are those errors persistent and will come on again after clearing them ? There could be a loss of power from battery or your ecu loses it s power sometimes. Does the dash lights all up when power gone? Or it shows only the abs and airbag ?
JMR
Romania
C?ID=432218
no rewards for opinions/help/suggestions necessary here , unless we do work on the car
ghosthd80
Kent, UK
C?ID=178130
Hi JMR
thanks for reply to my post
there was only one communication error and never come back
ECU don`t loose the power
ECU still calling for power
there is no lights on dashboard at all not even when power drops down
power dropping down then coming back up to around 2k rpm (its not fix RPM )
I change fuel filter after that power comeback for 5 min after that loosing power all the time
then I tested flow on pump 1.2l per min after that power comeback for another 10-15 min and back to square one
that`s interesting why there is no fault code on ECU
thanks
Westbury, UK
THere are many intermittent no communication faults on many modules, have you checked basics like security of battery terminals and ground strap, security of wiring to fuse block, etc?
ghosthd80
Kent, UK
C?ID=178130
I checked wiring battery terminals as well
and actually I add ground points to eliminate that problem
JMR
Romania
C?ID=432218
Is it possible that your alternator doesn t charge right all the time ? Can you rig a multimeter and take a ride monitoring the alternator voltage output ? Or you can do it with the vcds..
ghosthd80
Kent, UK
C?ID=178130
All check alternator holding steady 13.8v
S4Phil
Scotland, UK
C?ID=124175
Although this thread is from 2022, we had a VW Transporter with the CAAA 2.0 TDI Engine with an almost identical fault as the OP's description and I thought I'd update the thread for any future searchers.
I messaged Sly (Thanks Sly!) the original poster and asked for his help, he advised the issue for them had ended up being the fuel return pipe set, part number 03L 130 235 AJ.
Our issue was also with the fuel return pipes (leak off pipe set), but the garage the vehicle came from had previously broken the black one way valve on the fuel return pipes & replaced it with a straight screen wash fitting. This part had been hidden by the factory heat protective sleeving on the return pipes.
This fault was a tough one due to all data logging on VCDS (fuel pressures, charge system, timing etc) coming back as perfect. Not only this but the van would only fault at a higher throttle input, it otherwise idled and took small amounts of throttle with no issues. After speaking with Sly and removing the leak off pipes from the vehicle, the foreign part was pretty obvious. The VW workshop manual states this valve being missing or faulty can be 'detrimental' to injector operation.
Hope this helps someone in the future!
thebrick
Norway
THANK YOU SIR!!!!
This helped me, thanks alot!
I created an account here just to let you know that your post helped me solve this exact same problem, again thank you!
S4Phil
Scotland, UK
C?ID=124175
THANK YOU SIR!!!!
That's great, hopefully I saved you weeks of headaches like we had!
Phil
