PLEASE HELP! VW Touran 07mod does not start!
mskree
Norway
C?ID=521941
My touran suddenly wouldnt start, plugged in vcds and it came up about 500 fault codes. I do not know where to start searching.
Saturday,05,November,2022,16:35:10:56245
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVGZZZ1TZ8W063410   License Plate:
Mileage: 239790km-148998mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
VIN: WVGZZZ1TZ8W063410   Mileage: 239790km-148998miles
15-Airbags -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 RN    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1397
   Revision: --H07---    Serial number: VWX7Z0G83NB14H
   Coding: 0000072
   Shop #: WSC 01286 386 08256
   VCID: 7CA1F9B52AE6DCBBBBB-8028
   VINID: 9E65EAAAA064A889C0183101003647E7C1
013112 - Control Circuit for Glow Plug Controller 1
               P3338 - 000 - Electrical Malfunction
                    Mileage: 239793 km
                    Time: 00:12:19
                    Voltage: 12.54 V
                    Bin. Bits: 00101100
                    Temperature: 6.3°C
                    Bin. Bits: 01010000
005441 - Fuel Pump Relay (J17)
               P1541 - 000 - Open Circuit
                    Mileage: 239793 km
                    Time: 00:12:20
                    Voltage: 12.54 V
                    Bin. Bits: 00101100
                    Bin. Bits:        0
                    (no units): 0.0
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
                    Mileage: 239793 km
                    Time: 00:12:25
                    Voltage: 12.54 V
                    Bin. Bits: 00101100
                    Temperature: 6.3°C
                    (no units): 16.0
Readiness: 1 1 0 0 1
   Revision: 00H11001
   Coding: 0021190
   Shop #: WSC 01324 785 00200
   VCID: 73B3D28907B893C3EA1-8026
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79AFE0A125D4E993A0D-802C
            009 - Open or Short to Ground
   Revision: 00H54000    Serial number: 00000007553187
   Coding: 098B8F2100040F0047120C000000000000087F075C000100000000000000
   VCID: 71BFD8817DA4A1D318D-8024
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060102 021  0501
   Coding: 00038805
   Shop #: WSC 01324
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 197
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.85 V
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.05 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.85 V
                    Fault Status: 00100001
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 15.65 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.85 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.90 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 15.55 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 D    HW: 1T0 909 605 D
   Component: 04 AIRBAG VW8   021 0100
   Revision: 02021000    Serial number: 003B9D05YN4G
   Coding: 0012340
   VCID: 36352B9D544AC6EB0DF-8062
   Subsystem 1 - Serial number: 6332QSME375338015
   Subsystem 2 - Serial number: 6342QSME35462663B
   Subsystem 3 - Serial number: 6352QSME334F4265J
   Subsystem 4 - Serial number: 6362QSME326C7A4F.
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Component: J0527           636 0070
   Coding: 0002022
   VCID: 75B7EC9109CC8DF3C45-8020
   Part No SW: 1T0 920 874 A    HW: 1T0 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NB14H
   Coding: 0005101
   Shop #: WSC 80093 222 69422
   VCID: 343111954236D4FB33B-8060
   Part No: 1K0 815 071 T
   Component: Zuheizer        050 2504
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000011
   Shop #: WSC 80093 222 71269
                    Reset counter: 197
                    Mileage: 239793 km
                    Reset counter: 237
                    Mileage: 239793 km
                    Reset counter: 237
                    Mileage: 239793 km
                    Reset counter: 237
                    Mileage: 239793 km
                    Reset counter: 237
                    Mileage: 239793 km
   Revision:   H07 01    Serial number: 050907F2001223
   Coding: E9807F46000A028002
   VCID: 30391D85B62EE8DB573-8064
                    Fault Status: 00110100
                    Reset counter: 237
                    Mileage: 239793 km
                    Time: 00:04:03
   Component: IMMO            VDD 1216
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1201
   Coding: 0000181
   VCID: 382925A55E5E309B1F3-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.071 H08 1901
   VCID: 35372C91494CCDF3045-8060
   Coding: 809002085103087F2D06840560084F03E0FC00
   VCID: 035382495718A343FA1-8056
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000180
   VCID: 392F20A165542993E0D-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
   Component: Radio BVX       035 0047
   Revision: 00035000    Serial number: VWZ1Z2G6259204
   Coding: 0040400
   VCID: 6889B5E54E7E601B4F3-803C
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1202
   Coding: 0000144
   Shop #: WSC 01324 785 1012552
   VCID: 372B269953403FE3169-8062
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H15 0070
   Revision: 3A002001    Serial number: 00000106472953
   Coding: 0100000200000000
   VCID: 2E0503FDA01AFE2B45F-807A
                    Reset counter: 237
                    Mileage: 239793 km
                    Reset counter: 237
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.2V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Well, does it crank but not start?
Mileage: 239793 km
Time: 00:12:20
If the engine can't get fuel, then it obviously won't start ;) Check relay 449 on the relay panel under the left side of the dashboard, near the light switch.
JMR
Romania
C?ID=432218
fuse for pump relay , fascia 1 , at the knees panel, location F12 , 10 A ( red) middle row , 4th from left to right , also fuse F43 , 15 A ( lower row , bigger fuses ) 2nd from left to right
JMR
Romania
C?ID=432218
also , is your car cranking ? I see no rpm while that fuel pump relay got the error ...
I had a Skoda Superb a while back , customer called me because the car wouldn't start , NO CRANK , same fuel relay error. After laboring for about 1 hour around that car, customer " remembered" that earlier that day his starter missed cranking for a beat or two then it started. Luckily for him , the car was near a mechanic shop and we had a mechanic forcing the starter to turn ( a bypass between ign start wire and main battery wire at starter..and after few forced cranks ( with the ignition on ) the car came back to life and all errors disappeared. I can swear that it was the WEIRDEST diagnostic/car starting session EVER !!! I frigging checked and rechecked wires and fuses and relays for nearly one hour...
siLc
Tallinn, Estonia
C?ID=330192
F12 is for the fuel pump control unit J538, which the 1.9/2.0 TDI doesn't have (but the petrols do) - the fuel tank pump is only operated via the relay J17. F43 is correct supply voltage fuse for the switched side of the J17 but I figured since the ECU complained about the J17 relay having an open circuit, the open circuit is on the relay's switching side - that's detectable by the ECU, because the ECU is what supplies the voltage for it.
Reactions: JMR
JMR
Romania
C?ID=432218
Never hurts to check the fuses , the database shows f12 optional ... You can also take the relay out an verify voltages and ground. Also the relay could be stuck open..or dead. I d beat that relay few times with the plastic end of a screwdriver or change it with a similar one
mskree
Norway
C?ID=521941
Checked and works perfectly
mskree
Norway
C?ID=521941
Yes the car is cranking
mskree
Norway
C?ID=521941
After i changed the high pressure sencor on ac i did a new scan and this is what came up.
Monday,07,November,2022,19:13:40:56245
   Coding: 0000072
                    Mileage: 239793 km
                    Time: 01:43:37
                    Voltage: 12.31 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 01010000
                    Mileage: 239793 km
                    Time: 01:43:37
                    Voltage: 12.31 V
                    Bin. Bits: 00101100
                    Bin. Bits:        0
                    (no units): 0.0
   Revision: 00H11001
   Coding: 0021190
   Coding: 00038805
   Shop #: WSC 01324
                    Reset counter: 197
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
00906 - Horn (H1)
                    Reset counter: 237
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
                    Reset counter: 197
                    Mileage: 239793 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.55 V
   Coding: 0012340
   Coding: 0002022
   Coding: 0005101
   Coding: 0000011
   Coding: 0000181
   Coding: 0000180
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:21, VBatt start/end: 12.1V/12.1V)-----------
JMR
Romania
C?ID=432218
Have you identified the fuel pump relay so far ?
mskree
Norway
C?ID=521941
So far I have checked and tested all fuses and relays. I also replaced the fuelpump relay and Glow Plug Control Module. I've inquired around a bit and come to the conclusion that there must be a wire break somewhere. Anyone know where i can find div wiring diagrams from glow plug control module to ecu etc? Or know where I can start troubleshooting?
