DPF Regen Issues (Corrected Scan Format)
Steviejay
C?ID=236567
Hello everyone,
I wonder if there is anybody out there, who could help me with a particularly strange issue with the DPF regen.
The car has been in the garage twice & had one forced regen (static) with new DPF sensor & one forced regen driven.
Both solved the problem for a short time.
The first regen solved the problem for around 800 miles, the second regen only lasted for 115 miles, before the engine light came back on. No amount of driving (hard) has changed the situation.
One other strange fault is the rear RHS door fault.
Any suggests gratefully received.
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 5F 62 72 AC
          47
VIN: WAUZZZ4GXHN019529   Mileage: 89321km-55501miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FR    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1648
   Revision: 85H23---    CVN: 56EF1694C19C7771D45710C1
   Coding: 0A194012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FR 002006
   ROD: EV_ECM20TDI01104L906021FR_002.rod
   VCID: 7AFBC6F2FD078A5D0D-802E
   VINID: 9D196AAAA117A1878004914224779CB759
19226 - Particulate Trap Bank 1
          P2002 00 [237] - Efficiency Below Threshold
                    Mileage: 89162 km
                    Date: 2022.11.04
                    Time: 07:51:50
                    Engine RPM: 1873.00 /min
                    Normed load value: 56.9 %
                    Vehicle speed: 111 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 73 °C
                    Voltage terminal 30: 14.620 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.027
                    Differential pressure ratio: low-pressure EGR: 32.0 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 47.5 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 44.7 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 66.46 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 51.87 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 46.0 hPa
Readiness: 1 1 0 0 0
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A09E41600579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 4189711ED05119850C-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0824
   Coding: 03B8704E000000000000
   VCID: 7CF7C0EAFF33B46D1F-8028
   Serial number: 3216000120557008
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 22061600041350
   Coding: 34210978210000
   VCID: 63C59B966A8D6B953E-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001400722101
   Coding: 2600001400349F600481408300001D0C0F9D820827090201000008206100140200400024030000
   VCID: 74E7E8CAD763FC2D57-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 160512  H38 0080
   Serial number:         160520112441
   Coding: 0045F7
   Serial number: 61966919
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 21 06 2016  00000631
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 97C8453800PAG0MUFU03
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100AAVA4
   Coding: 30333130313630323639554A305234473053
   VCID: 3B7503F6B2BD735556-806E
   Serial number: 3575HRB406144QFUBHR5
   Serial number: 3585HRB405F44DAGFH9G
   Serial number: 3515JRB400Q571N6O9PT
   Serial number: 3525JRB400Q571N6II4C
   Serial number: 3554VRB40185752EH8K5
   Serial number: 3564VRB4012573KSC9DJ
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560PFO000UC
   Coding: 000014
   VCID: 3B7503F6BABD735556-806E
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 10 05 2016  D0027554
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 30450307    Serial number: 658220616592029
   Coding: 33A40D000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 326B2ED265F7B21D85-8066
   Part No SW: 4G5 907 468 G    HW: 4G5 907 468 C
   Revision: --------    Serial number: 00000002293653
   Coding: C0CD074418
   GVL: BD81C840D860600300000000
   VCID: 397919FEB881414544-806C
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 8129490504
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 16041500000000000816
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 24061600041544
   Coding: 22
   VCID: 3D710DEEACA97D6568-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720S0N1C
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33652BD69AEDBB158E-8066
   Component: TSG FA        H03 0511
   Coding: 011C16014001620002080002
   VCID: 479D6F06F67527B5C2-8012
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000011895
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7B06F2BD874A5D4D-806E
   Revision: 00002001    Serial number: 0409517435
   Coding: 011B062280B900408320088400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00022582390
   Component: TSG BF        H03 0511
   VCID: 46836202F17F3EBD39-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001896559
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 316921DE60F18905FC-8064
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 C    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H62 0170
   Coding: 0101000001415B47082B060301010000000000
   VCID: 2345DB96220D2B957E-8076
   Subsystem 1 - Part No: 8X0 919 884 J
   Component: P32-50-15.03  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464E%0G2763095
   Subsystem 3 - Part No SW: 4G2 919 710 E    HW: 4G2 919 710 E
   Serial number: 90349PFH000K9
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 4999693EE061D1C5D4-801C
Address 72: Door, Rear Right (J389)       Labels: 4H0-959-795.clb
   Component: TSG HR        H03 TSG HR        H03 05110511
No Faults Found
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 161460882
   ROD: EV_RDCMA00100.rod
   VCID: 2F6D27A676C59FF5EA-807A
End-------------------------(Elapsed Time: 04:58)--------------------------
GolfswagenVolk
Belgium
C?ID=401717
If everything electrically (incl. speaker) works on the rear door i don't see any problem there.
About the DPF: can you check the ash mass? or maybe the DPF is toast and needs replacing
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
From the past experience if it's the engine code with Adblue from 2014 then you issue may be related with Low Pressure EGR.
This is failing and not closing properly and during regeneration exhaust reading over the pressure sensors are not correct.
If don't have adblue try to monitor the DPF Pressures and temperatures during regenerations process and post it here.
