- Mar 20, 2014
- 21
- 5
- C?ID=94920
Car came to me from another workshop. Their customer came to go home after work and the car refused to start. As there were no warning lights or gauge activity they sent the instrument cluster away for test and repair. Refitted repaired cluster still no activity. Engine cranks but no start.
I have checked all fuses and relays nothing was found wrong. Checked CAN circuit 67 Ohms a little high maybe. No CAN activity when checked with scope CAN H reading 2.5v CAN L 2.4v but flatlined.
Getting worried I'm off down a rabbit hole and thought I would just put it out here and see if any of you guys have seen similar behavior and can suggest where to test next.
Thursday,03,November,2022,09:02:55:49214
VCDS Version: 22.9.0.0 (x64)
VIN: WAUZZZ8PXAB005910 License Plate: RV59VKX
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
17-Instruments -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LS HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3610
Revision: 13H01--- Serial number: AUX7Z0I6FNV01A
Coding: 0000072
Shop #: WSC 00046 412 00000
VCID: 0102791A58C934854C-8054
VINID: 9D196AAAA220A11480005241006CB6CAC3
U0155 - 000 -
Fault Frequency: 47
Temperature: 16.2°C
Voltage: 11.70 V
Bin. Bits: 00000000
Torque: 126.0 Nm
Temperature: 24.3°C
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0°C
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - MIL ON
Fault Status: 11100000
Voltage: 10.56 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 790.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 1362401A094A0022C833020C904100823800
VCID: 7EF802E6E9374B7D31-802A
Reset counter: 191
Count: 2
Count: 4096
Count: 8194
Count: 41984
Fault Status: 00101100
Reset counter: 191
Count: 2
Count: 4096
Count: 105
Count: 41984
Count: 2048
Reset counter: 191
Count: 3
Count: 4096
Count: 8208
Count: 41984
03391 - Coding Not Possible
Reset counter: 191
Count: 3
Count: 4096
Count: 8254
Count: 40448
Reset counter: 191
Count: 3
Count: 4096
Count: 8211
Count: 40448
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0140
Revision: 000579 Serial number: 8P0820043BK
VCID: 76E81AC60107033D69-8022
Fault Status: 00101010
Reset counter: 231
Temperature: -50.0°C
Fault Status: 01101000
Reset counter: 191
Fault Status: 00101001
Reset counter: 231
Voltage: 11.50 V
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 104 0575
Revision: 00104 AH
Coding: 0E000A2CB005F0C0207041E00000015C431A29AA104DC129E40008800040
Shop #: WSC 00752 210 91076
VCID: 3260E6D66DEF5F1D85-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
17 Faults Found:
Reset counter: 191
Voltage: 11.65 V
Term 50 Off
Fault Frequency: 14
Reset counter: 231
Voltage: 11.70 V
Term 50 Off
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 231
Term 15 Off
Voltage: 12.15 V
Term 50 Off
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Reset counter: 231
Voltage: 11.55 V
Term 50 Off
Reset counter: 231
Voltage: 11.55 V
Term 50 Off
Reset counter: 231
Voltage: 11.60 V
Term 50 Off
Reset counter: 231
Voltage: 11.60 V
Term 50 Off
Reset counter: 231
Voltage: 11.60 V
Term 50 Off
Reset counter: 231
Voltage: 11.15 V
Term 50 Off
Reset counter: 231
Voltage: 11.50 V
Term 50 Off
01516 - Terminal 30; Left
Reset counter: 231
Term 15 Off
Voltage: 12.15 V
Term 50 Off
02391 - Terminal 30 Reference
Reset counter: 231
Term 15 Off
Voltage: 12.15 V
Term 50 Off
Reset counter: 231
Term 15 Off
Voltage: 12.15 V
Term 50 Off
Reset counter: 231
Term 15 Off
Voltage: 12.15 V
Term 50 Off
Reset counter: 231
Term 15 Off
Voltage: 12.10 V
Term 50 Off
Reset counter: 231
Term 15 Off
Voltage: 12.00 V
Term 50 Off
01800 - Light Switch (E1)
Reset counter: 231
Term 15 Off
Voltage: 12.00 V
Term 50 Off
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0140
Revision: -------- Serial number: 003FB00224UO
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FA68F22161D12F58A-801A
Serial number: 3572DRB4000094C5323O
Serial number: 3582DRB4000094D4CA1/
Serial number: 35128RB400004EE7329S
Serial number: 35228RB400004EE8912S
Serial number: 35547RB400004E3901DO
Serial number: 35647RB400004E389A9
12670208 - No Communication with Instrument Cluster
U0155 00 [009] - -
Reset counter: 191
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0002012
VCID: 4688AA063167D3BD39-8012
Component: E0221 H02 0030
01304 - Radio
Address 17: Instruments
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 0222
Revision: H16 Serial number: 4040K0961682BC
Coding: E9807F06100202002103
VCID: 66C84A8651A7F3BDD9-8032
Reset counter: 191
Reset counter: 191
01304 - Radio
Reset counter: 191
Address 25: Immobilizer
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0000692
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 233 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F66EFA2BEDD72F5EA-807A
Reset counter: 191
Voltage: 11.75 V
DD
Temperature: 15.0°C
000 - - - MIL ON
Battery Volts: 11.5 V
PD
Temperature: 14.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158949270891
VCID: 3668DAC64187433DA9-8062
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0000692
VCID: 4796A702366DCAB5C2-8012
Address 56: Radio
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 4280B6161D4FEF9D15-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 438EB3120255E6951E-8016
End-------------------------(Elapsed Time: 02:06)--------------------------
