hello everyone,
I just retrofitted a rear display unit on a Seat Leon 2021 with display and temperature only.
I replace all the mechanical part and air flow unit but i can't code it correctly to make the temperature adjustable from rear screen.
In the current scenario the rear display it's showing the temperature but i can not setup it from +/- button and it's not appearing on 5F unit.
If i'm using sync option from the screen the temperature it's modified on rear console as well and sync with the one in front.
I code it in climatronic unit and also add it on adaptation channel.
Any ideea if i need to code it somewhere else except climatronic module and what should be the correct coding?
Tuesday,01,November,2022,18:50:34:32554
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4622.4
Workshop Code: 022 21992 002029
VIN: VSSZZZKLZMR001521 License Plate:
Mileage: 23105km-14356mi Repair Order:
Chassis Type: KL-SE38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5 BB
BC D6 D7 811E 811F 8120 8121
VIN: VSSZZZKLZMR001521 Mileage: 23105km-14356miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
811E-Burglary Protection FL -- Status: Malfunction 0010
Address 01: Engine (J623-DPBA) Labels: Redir Fail!
Part No SW: 05E 906 012 HW: 05E 907 309 D
Component: R4 1.5l TFS H20 9971
Revision: 8AH20000 CVN: 58BB66CA
Coding: 011900322364150870080000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906012 002009
ROD: EV_ECM15TFS01105E906012.rod
VCID: 5CF461965754AD6D7F-8008
VINID: 9A38EAAAA6DCA9D880001142044F6629D4
34193 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
Engine RPM: 0.00 /min
Coolant temperature: 56 °C
Intake air temperature: 35 °C
Voltage terminal 30: 11.080 V
Drive train coordinator irreversible switch off conditions: 0
Drive train coordinator reversible switch off conditions: 2172682240
Drivetrain coordinator: brake fault status: 517
Readiness: 1110 0001
Part No SW: 5WA 614 517 BC HW: 5WA 614 517 N
Component: ESC H13 0125
Serial number: 61900000001144 CVN: A476CAB0
Coding: 34042C982220446D527C50020AC461862DB458F042D067C0009CA231018FF100001C38
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013051
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 0A5857CEAD4063DD1D-805E SFD
8563 - Control Module for Steering Assist
U10BB 00 [047] - Implausible Signal
[CCan_EPS_BLW_QBit]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:03
C1146 02 [047] - Signal Failure
[RKA+: missing input signal(s)]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:12
0294 - Steering Angle Sensor
B1168 F2 [039] - Not Initialized
[Swa_init_fail]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
4499 - System Voltage
P0562 00 [032] - Too Low
[Vpre_low_uv]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:15
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003.rod
VCID: 54E489B63F84652DB7-8000
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 727 N HW: 5WA 907 727 N
Component: Climatronic H02 0340
Coding: 000000010011020010100110101001010000012000200000100000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005067
ROD: EV_ACClimaBHBVW38X_SK38.rod
VCID: 5BF6628A525AAA5576-800E
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Interior temperature sensor:
Subsystem 2 - Part No SW: 5WA 907 527 HW: 5WA 907 527
Component: E857 H01 0103
Serial number: 00001290520210728501
328453 - Motor for Rear Temperature Flap
B108E 54 [047] - Missing Calibration / Basic Setting
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
Voltage terminal 30: 10.80 V
Inside temperature: 20.20 °C
Outside temperature: 21.00 °C
Rear temperature flap: actual value: 81
Rear temperature flap: actual value: 0.5 %
Rear temperature flap: specified value: 255
329988 - Motor for Defroster Flap
B1090 71 [047] - Actuator Stuck
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
Defrost door - Specified value: 74
Defroster flap: actual value: 0.0 %
Defroster flap: actual value: 27
329989 - Motor for Defroster Flap
B1090 54 [047] - Missing Calibration / Basic Setting
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
Part No SW: 5WA 937 086 P HW: 5WA 937 086 H
Component: BCM 37W BOSCH 016 0137
Serial number: BXJ53F070720940
ASAM Dataset: EV_BCM37w 005001
ROD: EV_BCM37w_005_AU38.rod
VCID: 5EF06B9E4148BF7D11-800A SFD
Subsystem 1 - Part No SW: 5FB 955 113 HW: 5FB 955 113
Component: FWISCHER_MYJT 067 0052
Serial number: 907353F0402002000711
Serial number: 24410808X81A955555A0
Subsystem 3 - Part No SW: 5H0 941 193 AG HW: 5H0 941 193 AG
Component: LiSi H04 0513
Serial number: TW571414072000010718
Subsystem 4 - Part No SW: 5H0 959 561 H HW: 5H0 959 561 H
Component: DACHKONSOLE 006 0006
Serial number: 92661TFA00356-------
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 GA HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000015072004220345
left tail lamp 1:
left tail lamp 2:
Right rear tail lamp 1:
7 Faults Found:
1074714 - Databus
U1123 00 [046] - Received Error Message
[LLP_L_Low Datenbus empfangener Fehlerwert]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:07
Terminal 15 status: On
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 11.0 V
Outside temperature: 21.0 °C
Light switch position: automatic
B1263 01 [047] - Electrical Failure
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
Engine run: OFF
Voltage: 10.7 V
566550 - Databus
U1123 00 [047] - Received Error Message
[Leistungsmodul für LED-Scheinwerfer links - falscher Datensatz]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:08
Engine run: OFF
Voltage: 11.0 V
566806 - Databus
[Leistungsmodul für LED-Scheinwerfer rechts - falscher Datensatz]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:08
Engine run: OFF
Voltage: 11.0 V
65536 - Headlight
C107E 54 [047] - Missing Calibration / Basic Setting
[Scheinwerfer keine Grundeinstellung]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:03
Engine run: OFF
Voltage: 11.0 V
72192 - Level Control System Position Sensor; Rear Left
C1036 F1 [047] - Sensor Swap Detected
[Drehwinkelsensor hinten links: Sensortausch erkannt]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:03
Engine run: OFF
Voltage: 11.0 V
786697 - Motor for Rear Window Wiper
B1223 14 [046] - Open or Short to Ground
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
Engine run: OFF
Voltage: 11.0 V
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 HW: 5WA 919 298
Component: PLA 12K Kanal H04 0026
Serial number: 000004072094630
Coding: 8200022001
ASAM Dataset: EV_EPHBO2CVW3800000 002027
ROD: EV_EPHBO2CVW3800000_VW38.rod
VCID: 13664AAAFA0AA215EE-8046
13637426 - Databus
U1123 00 [039] - Received Error Message
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
13647889 - Databus
[Bremsensteuergerät - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:19
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 A HW: 5WA 907 572
Component: ACC Bosch MQB H10 0246
Coding: 02030075100740451247400000000005484020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
ROD: EV_FRONTRADARBOSCHVW380_003.rod
VCID: 4CD491D6E7B43DEDEF-8018
12 Faults Found:
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [046] - -
[FAULT_VBAT_BUSMON_LOW]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:16
1561 - Databus
[FAULT_BV_AVAILABILITY_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
2055 - Databus
U1122 00 [175] - Implausible Message
[FAULT_ALP_STEERING_WHEEL_INIT]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
209153 - Databus
U1123 00 [175] - Received Error Message
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
0577 - Databus
[FAULT_VZM_SYSTEM_STATUS_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
0616 - Databus
U1122 00 [046] - Implausible Message
[FAULT_QBIT_TRANSVERSE_ACCELERATION_INVALID]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
0723 - Databus
[FAULT_BV_RELEVANT_ERROR]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
0822 - Databus
[FAULT_QBIT_LONGITUDINAL_ACCELERATION_INVALID]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
0828 - Databus
[FAULT_QBIT_YAW_RATE_INVALID]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
0859 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_INIT]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:20
Address 15: Airbags (J234) Labels: 1EA-959-655.clb
Part No SW: 1EA 959 655 BJ HW: 1EA 959 655 BJ
Component: VW40Airbag 009 0037
Serial number: U190SuE0395
Coding: 88CC008000C0C000000000000000000051540000205400004000F68000130065
Shop #: WSC 00049 770 00229
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_001_VWE3.rod
Subsystem 1 - Part No SW: ----------- HW: 440 001 002 20
Component: FrontSensor_P 00A 010A
Serial number: 356CJ202BFE08342000K
Subsystem 2 - Part No SW: ----------- HW: 440 000 402 20
Component: SideSensor_Df 00A 0887
Serial number: 357CJ00000093534334.
Subsystem 3 - Part No SW: ----------- HW: 440 000 402 20
Component: SideSensor_Pf 00A 0887
Serial number: 358CJ0000007C4343341
Subsystem 4 - Part No SW: ----------- HW: 440 002 201 20
Component: SideSensor_Dr 00A 0149
Serial number: 351CJC332C33C646400O
Subsystem 5 - Part No SW: ----------- HW: 440 002 101 20
Component: SideSensor_Pr 00A 0149
Serial number: 352CJA73251D04F5800S
Subsystem 6 - Part No SW: ----------- HW: 440 001 002 20
Component: FrontSensor_D 00A 010A
Serial number: 355CJ202BFE08341B00T
9 Faults Found:
9446675 - Redundant signal path for airbag shut-off; passenger side
B1025 13 [137] - Open Circuit
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
9445395 - Key switch for deactivation of passenger-side airbag
B1020 13 [137] - Open Circuit
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
1075464 - Databus
[NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:04
1075461 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
1075462 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
1075463 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
1075465 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
Address 17: Instruments (J285) Labels: None-SRI2
Part No SW: 5FA 920 790 A HW: 5FA 920 790 A
Component: KOMBI 206 3440
Coding: 04A400006B940008018062032000080800300800
ASAM Dataset: EV_DashBoardVDDMQB37W 003032
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 383CDD06832CA14DBB-806C SFD
16777018 - Control unit for information electronics 1
U1054 00 [009] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:21
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:21
16777022 - Control unit for information electronics 1
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:21
Part No SW: 5WA 907 530 E HW: 5WA 907 530 C
Component: GW2020 High 752 7075
Revision: -------- Serial number: 150160900287143
Coding: 0000808D0F00000000000000012301105101610902000100030100000001010000000000000000000000000000000000
GVL: 3D0000000208408C800080024800004004004000004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 004003
ROD: EV_GatewMQB2020_004_VW38.rod
VCID: 4AD897CEEDC023DDDD-801E SFD
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 9163424005
Subsystem 3 - Part No SW: 5FA 919 719 G HW: 5FA 919 719 G
Component: E221__MFL-PR6 H02 0020
Serial number: PR6-0440059171200648
2494569 - Ethernet Module for Back-Up Cam
U1643 00 [047] - No Communication
[Rearview_camera_system_control_module_no_communication_vlan]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
8397571 - LV Energy Management
B1802 F1 [046] - Warning Triggered
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:02
74
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0111
Serial number: BPA085140620013
Coding: 1002C140730000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 013023
ROD: EV_BrakeBoostG2BoschVW37W_013.rod
VCID: 54E489B63F84652DB7-8000 SFD
106752 - Brake Control Module
U12DC 00 [034] - Received Malfunction Message
[Scl_ESC_51_ESC_Bremsdruck_02_Error]
172048 - Function Restricted due to Insufficient Voltage
U1400 00 [046] - -
[RBNET_Undervoltage_Replacement]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:16
172400 - System Voltage
P0562 00 [034] - Too Low
[PSCUnderVoltageLevel1]
172416 - System Voltage
P0562 00 [046] - Too Low
[PSCUnderVoltageLevel2]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:16
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H08 0040
Serial number: 20000075799005
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 3228EF2E65504B1D85-8066
Part No SW: 5Q4 959 593 H HW: 5Q4 959 593 H
Component: TSG FS 010 0691
Serial number: 0000413780048
Coding: 00311120D000020000001000
Shop #: WSC 21992 022 02029
Subsystem 1 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000041554334
Coding: 210000
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
1114117 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Reset counter: 160
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
Part No SW: 5WA 907 144 H HW: 5WA 907 144 C
Component: BASGEN1MQB37 101 1030
Serial number: 00174476
Coding: 0000000000000000000102010100010000000101010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
ROD: EV_SteerAssisBASGEN1MQB37_006_VW41.rod
VCID: 4ED09BDE11A80FFD81-801A
5423 - Steering Angle Sensor
B1168 F2 [167] - Not Initialized
[DTC_RACKPOS_NOINIT]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
MonitorId: 00 00
HybridDriveReady: 00000000
IgnitionEnabled: 00000001
Communication control: 00000000
Diagnostic session: 00000001
ComM_ModeType: 00000000
NM_Signal_Fahrbereit: 00000000
NM Signal V gr 7: 00000000
System status: 3
ECU Status: 4
HWLib Status: 1
Support power reduction: 0.0 %
Voltage terminal 30: 11.109 V
Temperature circuit board: 34 °C
Output stage temperature: 26 °C
Rackposition: 0.00 mm
Rackspeed: 0.00 mm/s
pinion angle dependent amplitude factor: 0 °
Steering wheel angle: 0 °/s
SupplierFreezeFrameData: 01 00 00 00 02 01 00 00 4A 48 08 00 01 00 00 00 01 00 00 00
Part No SW: 5Q4 959 592 H HW: 5Q4 959 592 H
Component: TSG BFS 010 0691
Serial number: 0000413731547
VCID: 49DAA8C2E8C628C5D4-801C
Subsystem 1 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000041665041
Coding: 390000
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:05
1114131 - Window Regulator; Front Passenger Side
B1320 54 [009] - Missing Calibration / Basic Setting
Reset counter: 120
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:01
1114133 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Reset counter: 160
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:17
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5FA 035 862 B HW: 5FA 035 862 B
Component: MU-O-ND-EU H56 1672
Serial number: WG8LGM010720000
Coding: 43800000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_SK38.rod
VCID: 3620D33E8938573DA9-8062 SFD
Subsystem 1 - Part No SW: 5FA 919 605 HW: 5FA 919 605
Component: ABT_W_10 H37 3074
Serial number: VDD02416072099710172
Subsystem 2 - Part No SW: V03 959 806 MG HW: -----------
Component: EU 2019/30 --- 202
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 A HW: 5WA 980 556 A
Component: RV eCompact H20 0193
Serial number: FCL-K2018.06.20
Coding: 04032200843000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_009.rod
VCID: 4FEE86DA16A206F58A-801A
13705496 - Databus
U1121 00 [047] - Missing Message
[Oldbit-monitoring Gateway_73.Getriebe_11_alt]
Fault Frequency: 33
Mileage: 88576 km
Date: 2056.03.00
Time: 00:08:00
13705507 - Databus
[Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
Fault Frequency: 33
Mileage: 88576 km
Date: 2056.03.00
Time: 00:08:00
13706006 - Databus
[Errorvalue-monitoring VMM_02.VZM_Systemstatus]
Fault Frequency: 33
Mileage: 88576 km
Date: 2056.03.00
Time: 00:08:00
Part No SW: 5WA 035 284 A HW: 5WA 035 284 A
Component: OCU3HMQB37W H12 0067
Serial number: 0000000006VITD3
Coding: 043800009068A8209005460061402607
ASAM Dataset: EV_OCU3HMQB37W 001039
ROD: EV_OCU3HMQB37W_001_SE38.rod
VCID: 44C4B9F6CFE4F5AD27-8010 SFD
12866049 - Databus
[Airbag: Error value received]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:03
Voltage terminal 30: 11.0 V
13631561 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal Electronic Failure
[Control unit defective Analog circuitry]
Mileage: 23105 km
Date: 2021.12.17
Time: 00:06:35
Voltage terminal 30: 12.7 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H05 3129
Serial number: E26735112201980
Coding: 000308882148C040509E08801020002001018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_AU38.rod
VCID: 4DD29CD21CAE34E5F8-8018
1126400 - Internal Fault
B200F F4 [008] - Unknown Error Elaboration
[Failure_fusion_internal_error]
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:26
1124198 - Development code 1
B2F01 00 [008] - -
[VZF_Init]
Fault Priority: 9
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:21
1124406 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function_degradation_supply_voltage_too_low]
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:16
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 65824472641EECA5D0-8030
131081 - Headlamp Type
C119F 00 [175] - Implausible
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
Component: LED1R H08 9202
131079 - invalid data record
B2005 00 [175] - -
[Invalid Dataset]
Reset counter: 0
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0632
ASAM Dataset: EV_RSADVL37w 002012
ROD: EV_RSADVL37w_002.rod
VCID: 47DEAEFAFED2DEB5C2-8012
1081345 - VKMS
B18B0 F0 [009] - Missing Adaptation
[VKMS_new_download_container_required_due_to_vehicle_change]
Mileage: 23105 km
Date: 2022.01.28
Time: 00:22:00
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
Component: Kessy RSAD 070 0634
ASAM Dataset: EV_RSADVR37w 002012
ROD: EV_RSADHL37w_002.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002012
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002012
End----------(Elapsed Time: 01:32, VBatt start/end: 10.6V/13.6V)-----------
