Audi A6 S Line - Throttle Valve and Particle Filter
Ben Pine
C?ID=403180
Hi All,
Could someone please help me with an issue i have with my Audi.
The engine check light came on last week along with a picture of a coil, today I have a particle filter refer to owners manual error
I've run an autoscan and its showing that the throttle valve is faulty ( am guessing it needs stripping and cleaning) but there is nothing for the particle fillter. Ive reset all codes and only the particle filter remains, does any ideas on what could be the issue??
The measurement figures for the particle filter:
IDE00430-ENG188621 Particle filter: field regeneration request status-Bits 0-7 10
IDE00431-ENG188621 Particle filter: field regeneration lock status-Bits 0-7 0
IDE00432 Particle filter: time since last regeneration 92696 s
IDE00433 Particle filter: oil ash volume 0.13 l
IDE00434 Particle filter: soot mass calculated 28.39 g
IDE00435 Particle filter: soot mass measured 4.51 g
IDE00436 Particle filter: kilometers since last regeneration 1315739 m
IDE01407 Particle filter: fuel consumption since last regeneration 79.67 l
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value 27 hPa
IDE07745 Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 26 hPa
IDE07748 Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 4 hPa
ENG108162 Particle_filter_service_regeneration_duration_with_headup 0.00 s
All help appreciated. Ben
Autoscan code below:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 47 52 53 55
          5F 62 6D 72 AC
VIN: WAUZZZ4G2GN055827   Mileage: 182762km-113563miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---    CVN: 00F3A24DC19C777138D3FF82
   Coding: 12254012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFE8C0895F4FA3A0D-802C
   VINID: 9D196AAAA1170977801452021C68419C76
          U1113 00 [032] - -
                    Mileage: 182348 km
                    Date: 2022.10.25
                    Time: 07:18:43
                    Engine RPM: 899.00 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 9.820 V
                    Unlearning counter according OBD: 30
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 15
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [032] - -
                    Mileage: 182348 km
                    Date: 2022.10.25
                    Time: 07:18:43
9124 - Throttle Actuator Control System
          P2111 00 [172] - Stuck Open
                    Fault Frequency: 26
                    Mileage: 182348 km
                    Date: 2022.10.25
                    Time: 07:19:53
                    Engine RPM: 994.00 /min
                    Normed load value: 34.9 %
                    Vehicle speed: 11 km/h
                    Coolant temperature: 22 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.700 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 581.7 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: 86.67 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 20.35 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -6.65 %
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 55
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 7
                    Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 3470.0 mV
Readiness: 1 1 0 0 1
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H03 0002
   Revision: --H03---    Serial number: 0000000057 CVN: B3F32B1E
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 290FF880397F3F2390D-807C
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117041150160000827
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4020A10FD763A8D-8014
36352 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
          [HydraulicSupplyUndervoltage]
                    Mileage: 182348 km
                    Date: 2022.10.25
                    Time: 07:18:41
                    VzRef: 00
                    Bit Info 1: C0
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 72
                    Unlearning counter according OBD: 25
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B9704E000000000000
   VCID: 7BA3F2C883E37DB3B21-802E
   Serial number: 3215000117598011
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 14071500040722
   Coding: 34220978210000
   VCID: 6393AAA81BD3A5739A1-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001117237701
   Coding: 0105001440349FE041014083000018000F9DC7082F08020100000894E100140200400024030000
   VCID: 71BFD0E0D1AF07E318D-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150626  H37 0080
   Serial number:         150701035637
   Coding: 0045F7
   Serial number: 24092399
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 12 07 2015  00000289
   Serial number: E3C8C5B7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1005PTCE
   Coding: 30333130313630323639554A305234473053
   VCID: 3B2332C8C3E3BDB3F21-806E
   Serial number: 3575HRB405P3H46A3P7C
   Serial number: 3585HRB405H3H46CC1QB
   Serial number: 3515JRB401I53400M9AI
   Serial number: 3525JRB401I534009GKN
   Serial number: 3554VRB40653GAJID8N$
   Serial number: 3564VRB40533GSECD0IV
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OG40000A
   Coding: 000035
   VCID: 3B2332C8C363BDB3F21-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 19 06 2015  D0055417
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 29450306    Serial number: 658130715592033
   Coding: 33A712000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 323D1FEC14A97CFB217-8066
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001924747
   Coding: C0CD074418
   GVL: FD81C940FC61600300000000
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 38292DC4F2D596AB1F3-806C
   Serial number: 7606347103
   Voltage stabilizer:
   Serial number: 150512000000000001CF
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 14
                    Reset counter: 129
                    Mileage: 182387 km
                    Date: 2022.10.25
                    Time: 10:05:43
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 12 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 129
                    Mileage: 182348 km
                    Date: 2022.10.25
                    Time: 07:17:26
                    Voltage terminal 30: 11.0 V
                    Voltage terminal 15: 11.0 V
                    Control Module temperature: 16 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 678BBEB8EF6BC953469-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 11071500040089
   Coding: 22
   VCID: 3D273CD0DDF7B383CC5-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720JNZC6
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331AE8EBB375F32A1-8066
   Component: TSG FA        H03 0507
   Coding: 011C16015C01620002080002
   VCID: 47CB5E388FABE953669-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0026987174
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F28C0C9DF8FA3E0D-806C
   Revision: 00002001    Serial number: 0373922814
   Coding: 013B0622A0B93080C320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Revision: CJ007001    Serial number: 00000000177406
   Coding: 030000
   VCID: 1D67DC507DB7D383EC5-8048
   Component: TSG BF        H03 0507
   Coding: 011C16015E01620002080002
   VCID: 46D5533C88A1F05B9DF-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001535140
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070C900D9723037C5-8078
   Coding: 04FE02102A600200
   VCID: 343119F4EEBD72CB33B-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 A    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H61 0139
   Coding: 0101010101415B47082B060301020100000000
   VCID: 211FE0A041CFF763C8D-8074
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464F/0F2718255
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349OG90000W
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49CF580099BF1F2370D-801C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 190501059
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 363523FCF8C160DB0DF-8062
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151730179
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B1698079B51134E9-807A
End----------(Elapsed Time: 01:55, VBatt start/end: 14.3V/14.4V)-----------
JMR
Romania
C?ID=432218
This here is a problem . You need to fix your throttle actuator so then will be able to do a regen
Ben Pine
C?ID=403180
Ok, so the actuator is stopping a regen and the reason I have the message is due to the throttle actuator as well?
