hello everyone,
I have a Passat B6 from 2006 and the client tried to retrofit new instrument cluster from a CC 2012.
The car has now the ABS and ESP light on and parking brake as well without coding.
The client used the adaptor for cluster and the connections seems ok but after i code the ABS everything it's ok , but after 5-15 ignitions cycle ABS coding it's lost again.
Can somebody have a look over the scan and give me some options if ABS it's compatible with this Cluster or i need to upgrade?
Thanks in advance!
Thanks in advance!
Friday,28,October,2022,16:11:34:32554
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4622.4
Workshop Code: 022 21992 002029
VIN: WVWZZZ3CZ7P062620 License Plate:
Mileage: 30km-18mi Repair Order:
Chassis Type: 3C-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ7P062620 Mileage: 30km-18miles
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Part No SW: 06F 906 056 GN HW: 06F 906 056 EK
Component: MED9.5.10 G00 0184
Revision: 69H03--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 7BB6020A3A9A4A5516-802E
VINID: 9E69EAAAA0D3A8780018218200293AC5F6
P1653 - 001 -
Fault Status: 01100001
Fault Frequency: 10
Mileage: 33 km
Date: 2017.03.20
Time: 14:58:59
Load: 0.0 %
Temperature: 18.0°C
P1653 - 004 -
Fault Frequency: 8
Mileage: 33 km
Date: 2017.03.20
Time: 15:05:28
RPM: 840 /min
Load: 60.8 %
Speed: 1.0 km/h
Temperature: 19.0°C
Readiness: 1110 0101
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667939172
Coding: 0010000
Shop #: WSC 21992 022 02029
VCID: 2F2EE65ABE6266F5EA-807A
7 Faults Found:
02840 - Wake-Up Line from Central Convenience Module
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Mileage: 34 km
Date: 2017.03.20
Time: 16:05:08
Address 08: Auto HVAC Labels: 3C0-907-044.clb
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 679E4E7A5612FEB5E2-8032
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004409379
Coding: 00848F0700041A00000A00000F000000000959435C0000
VCID: 2E10FB5EB9686FFDE1-807A
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
Fault Frequency: 8
Reset counter: 227
Mileage: 33 km
Voltage: 12.30 V
Fault Frequency: 7
Reset counter: 227
Mileage: 33 km
Voltage: 12.30 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 030 2522
Revision: 10030000 Serial number: 003B1PJRLGKE
Coding: 0012339
VCID: 302CE526A35C790DF3-8064
Subsystem 1 - Serial number: 6332MSME12406F7F
Subsystem 2 - Serial number: 6342MSME127A7A31
Subsystem 3 - Serial number: 6351HTS6K5Q65JI2
Subsystem 4 - Serial number: 6361HTS6K5QM9QP2
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507AE
Coding: 0000111
Shop #: WSC 05311 000 00000
VCID: 3424E9365744452D97-8060
Component: E0221 002 0010
Part No SW: 3C8 920 870 K HW: 3C8 920 870 K
Component: KOMBI H03 0305
Coding: 161E00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod (VIN: N/A)
VCID: 3326EA2A9A4A42158E-8066
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 11071101290175
Coding: 351002
VCID: 383CDD068B2CA14DBB-806C
Reset counter: 227
Mileage: 34 km
Date: 2017.03.20
Time: 15:58:13
Reset counter: 227
Mileage: 34 km
Date: 2017.03.20
Time: 15:58:13
01304 - Radio
Reset counter: 11
Mileage: 34 km
Date: 2017.03.20
Time: 16:02:03
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 227
Mileage: 34 km
Date: 2017.03.20
Time: 15:58:17
Part No SW: 3C0 959 433 M HW: 3C0 959 433 M
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Subsystem 1 - Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 227
Mileage: 33 km
Date: 2017.03.20
Time: 15:05:48
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12007001 Serial number: 00000577168916
Coding: 0000180
VCID: 3B36C20A7A1A8A5556-806E
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.133 H07 1806
Component: KSG PQ46 ELV 042 0472
Coding: 62FD00020186407E38009415200A4B0B607C00
Reset counter: 12
Mileage: 34 km
Date: 2017.03.20
Time: 16:09:17
Reset counter: 12
Mileage: 34 km
Date: 2017.03.20
Time: 16:09:17
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12007001 Serial number: 00000077868916
Coding: 0000180
VCID: 3C34C1167F148D6D5F-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
VCID: 210A1062F8B6C0856C-8074
000 - - - MIL ON
Fault Status: 11100000
Fault Frequency: 33
Reset counter: 253
Mileage: 16 km
Date: 2017.03.16
Time: 17:41:02
Voltage: 12.42 V
Count: 171
01316 - ABS Control Module
Fault Status: 11101101
Reset counter: 227
Mileage: 16 km
Date: 2017.03.16
Time: 17:17:36
Voltage: 13.87 V
Count: 236
Address 56: Radio
Address 62: Door, Rear Left Labels: None
Part No: No response
Component: Error LIN Slave 0
VCID: 2C14F1568F741DEDCF-8078
Address 69: Trailer
Address 72: Door, Rear Right Labels: None
End----------(Elapsed Time: 01:15, VBatt start/end: 12.2V/12.2V)-----------
