Passat 3C 2006 retrofit instrument cluster Passat CC 2011
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
hello everyone,
I have a Passat B6 from 2006 and the client tried to retrofit new instrument cluster from a CC 2012.
The car has now the ABS and ESP light on and parking brake as well without coding.
The client used the adaptor for cluster and the connections seems ok but after i code the ABS everything it's ok , but after 5-15 ignitions cycle ABS coding it's lost again.
Can somebody have a look over the scan and give me some options if ABS it's compatible with this Cluster or i need to upgrade?
Thanks in advance!
Friday,28,October,2022,16:11:34:32554
VCDS Version: 22.9.0.0 (x64)  HEX-NET CB: 0.4622.4
Workshop Code: 022 21992 002029
VIN: WVWZZZ3CZ7P062620   License Plate:
Mileage: 30km-18mi   Repair Order:
Chassis Type: 3C-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ7P062620   Mileage: 30km-18miles
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
   Part No SW: 06F 906 056 GN    HW: 06F 906 056 EK
   Component: MED9.5.10       G00 0184
   Revision: 69H03---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 7BB6020A3A9A4A5516-802E
   VINID: 9E69EAAAA0D3A8780018218200293AC5F6
               P1653 - 001 -
                    Fault Status: 01100001
                    Mileage: 33 km
                    Date: 2017.03.20
                    Time: 14:58:59
                    Temperature: 18.0°C
               P1653 - 004 -
                    Fault Frequency: 8
                    Mileage: 33 km
                    Date: 2017.03.20
                    Time: 15:05:28
                    RPM: 840 /min
                    Load: 60.8 %
                    Speed: 1.0 km/h
                    Temperature: 19.0°C
Readiness: 1110 0101
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667939172
   Coding: 0010000
   Shop #: WSC 21992 022 02029
   VCID: 2F2EE65ABE6266F5EA-807A
7 Faults Found:
02840 - Wake-Up Line from Central Convenience Module
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:05:08
Address 08: Auto HVAC        Labels: 3C0-907-044.clb
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 679E4E7A5612FEB5E2-8032
   Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004409379
   Coding: 00848F0700041A00000A00000F000000000959435C0000
   VCID: 2E10FB5EB9686FFDE1-807A
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 00028
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 33 km
                    Voltage: 12.30 V
                    Reset counter: 227
                    Mileage: 33 km
                    Voltage: 12.30 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 03 AIRBAG VW8   030 2522
   Revision: 10030000    Serial number: 003B1PJRLGKE
   Coding: 0012339
   VCID: 302CE526A35C790DF3-8064
   Subsystem 1 - Serial number: 6332MSME12406F7F
   Subsystem 2 - Serial number: 6342MSME127A7A31
   Subsystem 3 - Serial number: 6351HTS6K5Q65JI2
   Subsystem 4 - Serial number: 6361HTS6K5QM9QP2
01587 - Igniter 2 for Airbag; Drivers Side (N250)
   Part No SW: 3C0 953 549 K    HW: 3C0 953 549 K
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C9953507AE
   Coding: 0000111
   Shop #: WSC 05311 000 00000
   VCID: 3424E9365744452D97-8060
   Part No SW: 3C8 920 870 K    HW: 3C8 920 870 K
   Component: KOMBI         H03 0305
   Coding: 161E00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod (VIN: N/A)
   VCID: 3326EA2A9A4A42158E-8066
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 11071101290175
   Coding: 351002
   VCID: 383CDD068B2CA14DBB-806C
                    Reset counter: 227
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 15:58:13
                    Reset counter: 227
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 15:58:13
01304 - Radio
                    Reset counter: 11
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:02:03
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 227
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 15:58:17
   Part No SW: 3C0 959 433 M    HW: 3C0 959 433 M
   Component:    IMMO         042 0383
   Subsystem 1 - Part No: 3C0 905 861 F
   Component:    ELV          026 0380
   3C0905861F     ELV          026 0380
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 227
                    Mileage: 33 km
                    Date: 2017.03.20
                    Time: 15:05:48
   Component: J386  TUER-SG FT    1123
   Revision: 12007001    Serial number: 00000577168916
   Coding: 0000180
   VCID: 3B36C20A7A1A8A5556-806E
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.133 H07 1806
   Component:    KSG PQ46 ELV 042 0472
   Coding: 62FD00020186407E38009415200A4B0B607C00
                    Reset counter: 12
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:09:17
                    Reset counter: 12
                    Mileage: 34 km
                    Date: 2017.03.20
                    Time: 16:09:17
   Component: J387  TUER-SG BT    1123
   Revision: 12007001    Serial number: 00000077868916
   Coding: 0000180
   VCID: 3C34C1167F148D6D5F-8068
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0010000
   VCID: 210A1062F8B6C0856C-8074
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 33
                    Reset counter: 253
                    Mileage: 16 km
                    Date: 2017.03.16
                    Time: 17:41:02
                    Voltage: 12.42 V
                    Count: 171
                    Fault Status: 11101101
                    Reset counter: 227
                    Mileage: 16 km
                    Date: 2017.03.16
                    Time: 17:17:36
                    Voltage: 13.87 V
                    Count: 236
Address 56: Radio
Address 62: Door, Rear Left        Labels: None
   Part No: No response
   Component: Error LIN Slave 0
   VCID: 2C14F1568F741DEDCF-8078
Address 69: Trailer
Address 72: Door, Rear Right        Labels: None
End----------(Elapsed Time: 01:15, VBatt start/end: 12.2V/12.2V)-----------
JMR
Romania
C?ID=432218
please post an autoscan with the coded abs and no faults in the abs module.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
I did that several times .
After coding and calibration after 5-10 ignition cycle coding it’s lost again .
Westbury, UK
Do the VINs in the relevant Advanced IDs match - can't remember the exact modules but something like 01, 03, 17, 25? Someone will be along to make sure I've got the correct list :D
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
here it's the scan after coding.
It's working for just 2-3 ignition cycle then again no coding.
Saturday,29,October,2022,16:26:37:32554
Mileage: 50km-31mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
VIN: WVWZZZ3CZ7P062620   Mileage: 50km-31miles
   Coding: 0000072
               P1653 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 40 km
                    Date: 2017.03.21
                    Time: 15:52:02
                    Temperature: 32.0°C
               P1653 - 004 -  - Intermittent
                    Mileage: 40 km
                    Date: 2017.03.21
                    Time: 15:52:02
                    Temperature: 32.0°C
Readiness: 0110 0100
   Coding: 0009614
   Coding: 00063445
   Shop #: WSC 00028
                    Reset counter: 144
                    Mileage: 51 km
                    Voltage: 14.05 V
                    Reset counter: 144
                    Mileage: 51 km
                    Voltage: 14.05 V
   Coding: 0012339
   Coding: 0000111
   Coding: 161E00
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P09209042D
   Coding: F9807F46000202001002
   VCID: 2A18F74E858003DD3D-807E
                    Reset counter: 144
                    Mileage: 51 km
                    Date: 2017.03.21
                    Time: 16:24:18
                    Reset counter: 144
                    Mileage: 51 km
                    Date: 2017.03.21
                    Time: 16:24:18
   Coding: 0000052
   Coding: 60E1020E4686403E38001515200A4B8D005C00
   Subsystem 3 - Component:      IRUE No Answer
                    Reset counter: 144
                    Mileage: 52 km
                    Date: 2017.03.21
                    Time: 16:25:11
   Coding: 0000052
Address 56: Radio
Address 69: Trailer
End----------(Elapsed Time: 02:14, VBatt start/end: 13.9V/13.9V)-----------
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
no idea from no-one?
dieseltje
Groningen, The Netherlands
C?ID=148044
With old cluster all functions are direct OK or did you swap also gateway? I see you have B7 gateway with B6 CCM. B6 Gateway with index E should be sufficient.
siLc
Tallinn, Estonia
C?ID=330192
In the first scans there is indeed a B7 gateway but in the last one B6 index L.
This B6 EPB software is very old, that probably can be updated to index G (SW 0005) and see if anything changes?
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
Thanks for your answer!
I install already a new gateway from a B6 index L but same issue.
I read eeprom memory of the cluster and edit the eeprom by selecting ABS Type to 3C0 but still same issue.
After several ignition on/off coding disappear.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
I install new gateway now with L to match the CCM.
I edited eeprom of cluster and selected ABS type on 3C0 but same issue.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
latest scan with the car after ABS coding:
   Coding: 0000072
                    Mileage: 40 km
                    Date: 2017.03.21
                    Time: 15:52:02
                    Temperature: 32.0°C
                    Mileage: 40 km
                    Date: 2017.03.21
                    Time: 15:52:02
                    Temperature: 32.0°C
   Coding: 0009614
   Coding: 00063445
   Shop #: WSC 00028
                    Reset counter: 144
                    Mileage: 51 km
                    Voltage: 14.05 V
                    Reset counter: 144
                    Mileage: 51 km
                    Voltage: 14.05 V
   Coding: 0012339
   Coding: 0000111
   Coding: 161E00
                    Reset counter: 144
                    Mileage: 51 km
                    Date: 2017.03.21
                    Time: 16:24:18
                    Reset counter: 144
                    Mileage: 51 km
                    Date: 2017.03.21
                    Time: 16:24:18
   Coding: 0000052
                    Reset counter: 144
                    Mileage: 52 km
                    Date: 2017.03.21
                    Time: 16:25:11
   Coding: 0000052
Address 56: Radio
Address 69: Trailer
siLc
Tallinn, Estonia
C?ID=330192
Also what's the deal with rear door modules being offline? VIN says this B6 is a MY2007, so it should have the rear door modules controlled by the front modules via LIN wire (instead of being dedicated CAN modules). So the rear modules shouldn't be missed by many modules.
Since this is a very specific problem, my thinking is getting the other things in order in this car may help.
dieseltje
C?ID=148044
and other part of my question. If you throw back the old cluster. are the errors then gone?
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
You are right....read door controled modules are via LIN connected to front doors.
They are working properly so i didn't spend time on that.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
With old 2006 cluster everything working as expected without any issues.
I'm thinking to update the parking brake control module, because since i remember when you remove that one physically you will lost abs coding.
Another possibility will be to downgrade the software o the cluster to B, SW 110 but i don't know if i will mess up the cluster.
sers77
Norway
C?ID=26140
Have you been driving it between ign.cycles?
I can send you a new cluster EEPROM file if you like (I have all)?
CF.T
Portugal
C?ID=386461
The client used the adaptor for cluster and the connections seems ok (...)
I think you should make sure the adapter is actually good, these are very problematic sometimes, and I've seen very strange problems solved by removing the adapter and doing things properly and connect wires directly. If with the original works, and the new cluster is problematic, I think there's a very good chance that's your problem. Occam's razor and all that.
Edit: I used one for a while and didn't have any problem with it, but others were not so lucky
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
yes , between ignition cycles works ok without any issue.
I will try today an update over Parking Brake module.
Do you know if the cluster can be downgraded to B series?
