2004 A4 1.8T won't start
Wiesbaden
C?ID=166980
Big surprise when I wanted to pull out of the garage last night. Car would not start. 3 beeps and the Brake light flashing.
I had come home from work 2 hrs earlier and all was fine. I plugged in VCDS. See below.
Overnight I unplugged the battery - maybe it would reset something. It did! New message it cluster: "PRESS CLUTCH PEDAL TO START ENGINE" - mind this is a CVT...:confused:
Any help appreciated. Thank you!
Wednesday,08,July,2015,19:06:35:44380
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUJC68E34A093706   License Plate: 475 2070
Mileage: 208630km-129636mi   Repair Order:
          67 69 75 76 77
VIN: WAUJC68E34A093706   Mileage: 208630km-129636miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016581
   Shop #: WSC 63351 000 00000
   VCID: 79F9522333740EE9291-513E
18034 - Powertrain Data Bus
            P1626 - 004 - Missing Message from TCU
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04279
   Shop #: WSC 06435
   VCID: 65C10E53FFCC9A09FD9-513E
            P1626 - 35-00 - Missing Message from TCU
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 35-00 -
   Part No: 8E0 820 043 AB
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 02120
   VCID: 61C91A43EBE4F629011-513E
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 00003
   Shop #: WSC 63351
   VCID: 35619E130FEC2A898D9-4B06
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        3001
   Coding: 0010607
   VCID: 377D941B45E0D8999F5-513E
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01041
   Shop #: WSC 63351
   VCID: 3E73813F3ADAE9D15C3-4B06
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 02200
   Shop #: WSC 02120
   VCID: 326BA50FFE823DB1A8B-5122
   WAUJC68E34A093706     AUZ6Z0C0232086
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1411
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72EB650F3E027DB168B-4B06
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
Address 56: Radio        Labels: None
   Part No: 8E0 035 186 K
   Component: concert II  NP2    0007
   Coding: 01001
   Shop #: WSC 02120
   VCID: 2F6DAC7BEDB01059C75-4E7C
End-------------------------(Elapsed Time: 05:53)--------------------------
TCM seems to be MIA. Check fuses first.
Wiesbaden
C?ID=166980
Interesting comment about the TCM fuse. Is it located in the fuse box driver side left? I will check them all and reseat them.
I had the TCM rebuilt 2 years ago (BBA Reman). Was good for 20K miles so far.
Jef
HQ
Transmission specifications G0Z Variable gearing ratio
Hmmm.... so the running joke to know what kind of transmission is in a car like yours... 01V or 01J? Well, is the transmission broke? Yes, then it is a 01J. The "CVT" trans has one minor issue... they fail.... often.
OOMY guess says you are in the market for 8E0-910-155-F
Wiesbaden
C?ID=166980
Ok - it's running again - I was ready to junk it.
Thanks Uwe for the fuse suggestion - that was it!
I did not think it would be so easy to immobilize an Audi: Just pull fuse 31!
Thanks for suggestions from other participants as well.
I know the CVT can have issues. But also I found that if you get your TCM rebuild and keep changing the tranni fluid every 40K miles you can get a lot of miles from it. Of course I am not running that car hard.
NostraJackAss
!ALWAYS! Check Fuses First!
