Anything else to blame for sporadic oil pressure red light than bad/ clogged balance shaft? I opened the oil pan found some remaining sealant and little plastic. Is it a sign of bad balance shafts?
I did timing chain and cylinder head rebuilt work but never opened and inspect the balance shafts.
Could it be the balance shaft tensioner I did not replace? The oil warning sensor is clean and no oil in the connector. mann oil filter and 5w30 full synthetic oil in there.
It usually happens after the car driven for long with AC specially and when you slow down and stop then try to accelerate again.
One more thing, the top of the engine feels super super hot, but there is no overheating and coolant level is at right level. No engine light on nor error code when scanning with ross tech cable
The car is a 2012 vw eos cbfa engine
