'14 JSW BCM Swap Problems
eurospekgarage
Houston, TX, USA
C?ID=314389
Hi everyone,
I've been a long-time lurker and received so much help over the years. It's my turn to ask for some help.
I replaced my bumper with a GTI-style bumper that came with fog lights. I also bought a BCM from a 2012 GTI and installed it into the car to enable the fogs (my original did not have provisions for fog lights). The original BCM to the car is a 5K0 937 084 L unit. While the new one is a 1K0 937 087 L unit. As advised, I copied over the long coding from the old one and coded it into the new unit. The front lights work as they're supposed to (turn signal, high, low, fogs all work fine). But for some reason the reverse lights now act as the DRL in the rear when the light switch in the 0 position. The cluster shows errors for brake lights, reverse lights, and license plate lights (even though brake lights and license plates work as designed). My biggest pain point is that the key remote stopped working (the car does not have KESSY). When I first plugged in the module, bit 18 showed VW EOS NAR version. So I followed the steps to change it to 00, and then to Jetta Sportwagen ROW thinking that it would solve my issues. But the errors still remain.
I hope I explained the issue correctly. Please advise on what I should do. I have attached the scan below:
Wednesday,19,October,2022,19:03:09:12942
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: 3VWPL7AJ9EM601169   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 2E 42 44 46 52 56 62 72
          77
VIN: 3VWPL7AJ9EM601169   Mileage: 132030km-82039miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H16---    Serial number:
   Coding: 0050078
   Shop #: WSC 74291 008 00000
   VCID: 303A186A36207B6B573-8064
   VINID: 0E69E070745A2557460010462482F0B2C6
Readiness: 0 0 0 X X
   Part No SW: 02E 300 015     HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3521
   Revision: 05551213    Serial number: 00001208131527
   Shop #: WSC 05311 000 00000
   VCID: 50FA78EA56E01B6B373-8004
   Revision: 00H31001
   Coding: 114B600C492200FB880C06EA92220042B70000
   Shop #: WSC 00066 000 00000
   VCID: 7DA4F15EBDF246038C5-8028
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   042 0102
   Revision: 00001001
   Coding: 0010001012
   Shop #: WSC 09003 957 00200
   ROD: EV_ACClimaBHBVW411_VW36.rod
   VCID: 186AC0CAB210832B3F3-804C
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2022.10.19
                    Time: 18:50:45
9496613 - Sunlight Photo Sensor
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2022.10.19
                    Time: 18:50:45
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2022.10.19
                    Time: 18:50:45
   Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
   Component: BCM PQ35  H   104 0615
   Revision: 00104 AF
   Coding: AF380E3A882F3EC400080040710089C0496C0886535D0520648420200040
   VCID: 3A2E3A42EC5CB13BE97-806E
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 29061  26  0512
   Coding: 009795
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2017.03.11
                    Time: 18:59:39
                    Voltage: 13.95 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2017.03.11
                    Time: 19:00:07
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2017.03.11
                    Time: 19:00:07
                    Voltage: 13.90 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R024L73
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C223C5AE6E88F0BFBB-8068
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00008DFZ00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME190A1479ZZZY
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME600A1479ZZZV
   Serial number: 3511HSME715B592FZZZ-
   Serial number: 3521HSME5C4B592FZZZ2
   Serial number: 35527SME4C63532FZZZQ
   Serial number: 35627SME15365C2FZZZQ
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MEB00088
   Coding: 189A140000
   Shop #: WSC 00066 000 00185
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B6EE729844155BCDF-8022
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0099245
   Coding: 830000
   Part No SW: 5K0 920 973 G    HW: 5K0 920 973 G
   Coding: 270F01
   Shop #: WSC 00066 000 00118
   VCID: 3534297EC5C25E43045-8060
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 01071303000399
   Coding: 352002
   Shop #: WSC 00066 123 12345
   VCID: 79ACE54EA9DA7A23A0D-802C
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RNMPK07
   Coding: 0000002
   VCID: 7EA6F652BCF45D1B95F-802A
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4DC4619E41D236835C5-8018
   VCID: 6A8ECA02DCFCC1BB597-803E
Address 2E: Media Player 3
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0007003560
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE09FC603A6A833D21-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1509
   Serial number: 00000007951207
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 37282376D34EAC53169-8062
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0007033323
   Coding: 0004B4
   VCID: 5CE29CDA06A8AF0BDBB-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1509
   Serial number: 00000007819183
   Coding: 000490
Address 56: Radio (J503)       Labels: None
   Part No SW: -----------    HW: -----------
   Component: Radio         --- 5814
   Coding: 16000440040000
   VCID: 6FB8DB16E79E24930E9-803A
00856 - Radio Antenna
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2017.03.11
                    Time: 18:50:44
                    Reset counter: 208
                    Mileage: 132036 km
                    Date: 2017.03.11
                    Time: 18:58:14
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664875704
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E06061220946D9B45F-807A
End----------(Elapsed Time: 01:11, VBatt start/end: 14.0V/14.0V)-----------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
How suggested to put old coding to replacement BCM specially one with diffrent part number.
Those BCM are know if you mess with Byte 18 you can damage BCM,
Do you have long coding from replacement BCM, if you do post it here so someone can look at it and see it is 1K0 BCM comparable for your JSW.
eurospekgarage
Houston, TX, USA
C?ID=314389
Thanks for your response.
The original new to me 1K0 BCM coding is :
6D180A1A80272AC40088008570000D0440050086434D8D60648020200040
The factory 5K0 that came with the car had:
AF380E3A882F3EC400080040710008C0494C5586535D0500E48420200040
They both use the same label file, so the coding should be pretty much the same for both -- except for the mess that is Byte 18. Whether the lighting configurations that this byte points at in these two modules are the same is anyone's guess.
2kaa52
Ceska Republica, Praha
C?ID=319193
Have to Copy the lamp config from old bcm to the new bcm. But that isnt possible with vcds.
If you need more help-PM me
