Friday,21,October,2022,12:36:19:64412
VCDS Version: 22.9.0.0 (x64) HEX-NET2 CB: 0.4623.4
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 72
VIN: VSSZZZ1PZCR003390 Mileage: 82890km-51505miles
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 997 558 G HW: 03L 906 023 KL
Component: R4 1.6l TDI H43 9981
Revision: --H43--- Serial number: CVN: 54CF6572
Coding: 00114036032501080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM16TDI02103L997558G 003003
ROD: GV_ECM16TDI021VW32X.rod
VCID: 41D42F6AB10673C3A8D-8014
VINID: 9A38EAAAA060A938800030C900953B650C
10158 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [037] - Electrical Fault
Mileage: 82893 km
Date: 2022.10.21
Time: 01:38:23
Engine RPM: 0.00 /min
Coolant temperature: 15 °C
Intake air temperature: 16 °C
Voltage terminal 30: 12.085 V
Glow status-STATE_GLOW: 48
Fuel temperature-TFU: 15 °C
Sensor for engine block temperature: raw value-Coolant temperature: 15 °C
10160 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [037] - Electrical Fault
Mileage: 82893 km
Date: 2022.10.21
Time: 01:38:23
10119 - High Pressure Fuel Rail
P00C6 00 [036] - Minimum Pressure Not Reached
Mileage: 82893 km
Date: 2022.10.21
Time: 02:33:21
Engine RPM: 264.75 /min
Normed load value: 12.9 %
Intake air temperature: 17 °C
Voltage terminal 30: 9.148 V
Fuel high-pressure: actual value-FUP_FIL: 0.000 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 20 l
Time since engine start: 0 s
Fuel Metering Valve-VCV: 27.184 %
Fuel Pressure Regulator Valve-PCV: 52.139 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 29821.777 kPa
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B2012092200FDC80E04ED90190091350800
Shop #: WSC 04941 000 00000
VCID: 7BA89D8293EAD913B21-802E
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 0
Mileage: 82893 km
Date: 2017.03.13
Time: 01:18:45
Count: 3
Count: 2
Count: 20992
Count: 397
Count: 43520
Count: 65280
Part No SW: 5P0 907 044 R HW: 5P0 907 044 R
Component: Climatronic H18 0804
Revision: 00001001
Coding: 0000000003
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3FD02992C7F20533DE9-806A
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 4E180A3E8025B0C04288008095008104425100A8427D81605C80C7000041
VCID: 3B285D82D36A1913F21-806E
Subsystem 1 - Part No: 1P0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 27051 26 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89331113601715
VCID: 3A265886DC50201BE97-806E
Mileage: 82893 km
Date: 2017.03.13
Time: 02:33:29
Temperature: 16.0°C
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__A0E VW10 HI 1918
Revision: 22014000 Serial number: 003K0P9TL9XK
Coding: 0012357
VCID: 4CCA0E5E8AC4AEAB4BB-8018
Subsystem 1 - Serial number: 6332MTS624731181
Subsystem 2 - Serial number: 6342MTS642391181
Subsystem 3 - Serial number: 6351HTS69GQOT9KR
Subsystem 4 - Serial number: 6361HTS6DFH44AKJ
Fault Status: 11100001
Mileage: 82893 km
Date: 2017.03.13
Time: 01:18:54
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110528101613
Coding: 1082140002
ROD: EV_SMLSNGVOLWS.rod
VCID: 79A4878A9956EB03A0D-802C
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 0
Mileage: 82893 km
Date: 2022.10.21
Time: 02:33:09
Part No SW: 1P0 920 953 D HW: 1P0 920 953 D
Component: KOMBI H04 0607
Coding: 410B01
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 31347FAA01A6E34358D-8064
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 140511F2001982
Coding: 350203
VCID: 372041B2EF423D73169-8062
Component: IMMO H04 0607
VCID: 6A86A8C6ECF0509B597-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660067386
VCID: 290497CA29F69B8390D-807C
Part No SW: 5P0 035 191 D HW: 5P0 035 191 D
Component: RNS315 H05 0010
Serial number: SEZAZ2L9128830
Coding: 040004010402000000000000
ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
ROD: EV_RNS315SeatEUV1UDS.rod
VCID: 2C0A6EDE26848EAB6BB-8078
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0508
Revision: 12110009 Serial number: 0002518442
Coding: 0212B0
VCID: 6D8CA3DADD1E47A33C5-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 E HW: 3C0 959 794 E Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1501
Serial number: 00000005779202
Coding: 000290
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 0
Mileage: 82893 km
Date: 2022.10.21
Time: 01:19:06
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 65 3201
Revision: 00H20000
VCID: 343A76BEF234D66B33B-8060
000 - - - MIL ON
Fault Status: 11100000
Mileage: 82893 km
Date: 2017.03.13
Time: 01:19:10
Battery Volts: 12.2 V
DD
Temperature: 20.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0508
Revision: 14110009 Serial number: 0002471283
Coding: 0212B0
VCID: 6E8EA4D6D018BCBB05F-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 E HW: 3C0 959 795 E Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1501
Serial number: 00000005777392
Coding: 000290
Reset counter: 0
Mileage: 82893 km
Date: 2022.10.21
Time: 01:19:14
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 030B185A
VCID: 71B4BFAAC1A6A34318D-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900567661
End----------(Elapsed Time: 01:31, VBatt start/end: 12.3V/13.1V)-----------
