My Q5 threw up an amber engine light on the dash, mpg has been maybe 5mpg lower than normal, and the start-stop occasionally won't work.
VCDS says there is a problem with "temp sensor 3". Any ideas how, without pulling the car apart, I can identify what temp sensor 3 is?
Thursday,20,October,2022,15:43:42:03339
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 22.9.0.0 (arm64) HEX-V2 CB: 0.4623.4
VIN: WAUZZZ8R1GA044269 License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
AC
VIN: WAUZZZ8R1GA044269 Mileage: 129070km-80200miles
Address 01: Engine (J623-CTBA) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 997 401 E HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0002
Revision: 58H14--- CVN: BE7D205AC19C777138D3FF82
Coding: 2A254012052703030000
Shop #: WSC 02422 002 1048576
ASAM Dataset: EV_ECM30TDI0118K5997401E 001002
ROD: EV_ECM30TDI0118K5997401D.rod
VCID: 3B2336F433E57063F21-806F
VINID: 9D196AAAA2220574401040862432A7E560
21501 - Engine Coolant Temperature Sensor 3
P01E3 00 [038] - Electrical Malfunction
Mileage: 129056 km
Date: 2022.10.20
Time: 14:09:01
Engine RPM: 685.00 /min
Normed load value: 27.8 %
Coolant temperature: 59 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.420 V
Coolant temperature at radiator outlet: actual value: 25.6 °C
Heat delivery temperature in cooling system: 43.3 °C
Outside temperature: 17.5 °C
Fuel consumption: 0.77 l/h
Fuel temperature: 22.5 °C
Engine oil temperature: 57.5 °C
Part No SW: 8R2 927 156 P HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0009
Revision: --H03--- CVN: 0000313E
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 4ACD63306C3FD9EB797-801F
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BA HW: 8R0 907 379 BA
Component: ESP8 quattro H09 0020
Coding: 2F5DCC01
VCID: 005981181A03D3BBE73-8055
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Coding: 01B54040000000000000
VCID: 7F5B02E467FDAC439E9-802B
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0815000092832021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000132151001
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01060820152414
Coding: 3625028000
VCID: 78A9E9F842D39B7BDF3-802D
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001144385101
Coding: 260000108034AFE01581408300001D0D4F9D470827090201000008004400030100000024000000
Shop #: WSC 06335 123 12345
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150716 H12 0050
Serial number: 90243015150615181953
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20502958
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000002807151240
Serial number: 07798FB7000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H49 0610
Serial number: 003JPDD0GXMF
Coding: 30473531313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C9593872332BFB6F3-801D
Serial number: 6334MSME530930744
Serial number: 6344MSME530A6F79T
Serial number: 6352QSME57582464I
Serial number: 6362QSME79582D40Q
Serial number: 63732SME74522472W
Serial number: 63832SME74521950X
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OH6000TC
Coding: 000037
VCID: 48C9593872B32BFB6F3-801D
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 P HW: 8R0 920 981 P
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03828558G
Coding: 33A6220003012600010000
VCID: 47CB5A047FAD2483669-8013
Part No SW: 8R0 907 468 T HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0070
Revision: 1Y090032 Serial number: 3241Y1570705FA
Coding: 80CF07FF00
VCID: 50F971588AE3E33B373-8005
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 0476607403
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 14023001732011200181
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0511
Revision: Serial number: 0000160604337
Coding: 011D02215C01440004
VCID: 4FFB722497DDFCC32E9-801B
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0022058887
Coding: 100000000001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D7500C45213693945-8011
Revision: 00002001 Serial number: 0376479057
Coding: 013B0622A0B930808720053680040047
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0511
Revision: Serial number: 0000161068092
Coding: 011D02215E01440004
VCID: 4EC56F2090D7F5CB25F-801B
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000576556
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D33F03CDF496BE97-806F
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109H20F8059905
Coding: 010103020100000001
VCID: 2B0306B4C305E0E3621-807F
Part No SW: 8R2 035 670 K HW: 8R2 035 670 J
Component: H-BNT-EU H50 0941
Revision: -------- Serial number: 517GX0F7504312
Coding: 160101060005E1ED05808B5E00000403040000000000000000
VCID: 3C2135E8366B775BFBB-8069
Subsystem 1 - Part No: 8R0 060 884 CR
Component: EUR 2015 2102
Component: DU7 High H42 0104
Serial number: A130HU0F3431853
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000002332423
Component: CD-Database 6208
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000160498807
Coding: 010C02204001240004
VCID: 46D5570078A73D8B9DF-8013
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D2738EC2D717E53CC5-8069
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000160501554
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 151870281
ROD: EV_RDCMA00100.rod
VCID: 2F3B12A4F79D9CC34E9-807B
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.3V)-----------
