- Jul 7, 2022
- 3
- 0
- San Leandro, CA, USA
- C?ID=520682
I have had my VCDS for a few months now and I am learning a lot! One question I have is why in OBD2 are modes 5 and 6 unavailable? I know the mode 6 data is in there because I can see it with my other scan tool, a Blue Driver. Any ideas?
Saturday,15,October,2022,14:12:24:23389
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: WVWFV71K28W252233 License Plate:
Mileage: 143400km-89104mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65 77
VIN: WVWFV71K28W252233 Mileage: 143400km-89104miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H13N58PC
Coding: 0403010A1C070160
Shop #: WSC 01279 785 00200
VCID: 36352BF1C442C86B0DF-8062
VINID: 9E69D698705B0889C21420830CD597509F
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 143407 km
Time: 15:58:18
RPM: 772 /min
Load: 22.3 %
Temperature: 82.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Readiness: 0110 0101
Part No SW: 02E 300 050 J HW: 02E 927 770 AD
Component: GSG DSG 082 1409
Revision: 05108020 Serial number: 00001008182108
Shop #: WSC 04940 001 00001
VCID: 196FC04D559C071300D-804C
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B3D2E597B09D43EA1-8026
Part No SW: 1K0 820 047 HR HW: 1K0 820 047 HR
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7BA3FAC5BFE0D503B21-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008017839
Coding: 178D0F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 71BFD8EDEDACAF5318D-8024
Component: Wischer 300108 021 0501
Coding: 00038805
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0255340
Coding: 0000000
VCID: 333312E5D730DD432A1-8066
Reset counter: 215
Mileage: 142267 km
Time: 01:22:22
01304 - Radio
Reset counter: 20
Mileage: 143390 km
Time: 11:41:16
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0AGNXT
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C81C999CA8E42BB2BB-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME367553729
Subsystem 3 - Serial number: 6342MSME367503556
Subsystem 4 - Serial number: 6352QSME50064C45D
Subsystem 5 - Serial number: 6362QSME507214478
Subsystem 6 - Serial number: 63727SME13352667-
Subsystem 7 - Serial number: 63827SME13306F3B3
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0012122
VCID: 78A9E5C98ED6FE1BDF3-802C
Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0H13N58PC
Coding: 0007203
Shop #: WSC 00000 067 57207
VCID: 323D17E1282AD44B217-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 020208F2001104
Coding: ED811F070017020000
Shop #: WSC 26084 444 57895
VCID: 30391DE92626E65B573-8064
01304 - Radio
Reset counter: 7
Mileage: 143023 km
Time: 14:21:56
Reset counter: 7
Mileage: 143023 km
Time: 14:21:56
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2MZL03
VCID: 7DA7F4DDA1F4DB338C5-8028
Component: IMMO VDD 1216
Shop #: WSC 61266 000 1048576
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 382925C9CE563E1B1F3-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 35372CFDD944C373045-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
VCID: 04518139C21EAAFBC3B-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392F20CDF55C2713E0D-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D1F992BE9A7BF3B-8020
Address 56: Radio
Component: RDK 0450
Coding: 0100101
Address 77: Telephone
End----------(Elapsed Time: 01:20, VBatt start/end: 12.0V/12.0V)-----------
