B8 A4 led tail lamp euro coding
rlarsen
Copenhagen, Denmark
C?ID=78998
Your posted old coding was wrong.
I have below attached the old (OEM) and the new coding from Bulb => FL LEDs
   #62
kantusjack
Spain
C?ID=69091
There is something strange ...
I have the same coding you propose in channels 200 (73) and 201 (105) ... it is supposed to be fog lights, but Fog lights do not work in this car ...
   #63
rlarsen
Copenhagen, Denmark
C?ID=78998
I don't know - but are the wiring done the correct way ??
   #64
kantusjack
Spain
C?ID=69091
These are the changes we did
LEFT OUTER
ORIGINAL ----------------------- NEW
Pin 1 GREY/BLUE ----------- PIN 2 LEFT OUTER
Pin 2 BLACK ----------------- PIN 4 LEFT OUTER
Pin 3 BLUE/BLACK ---------- PIN 1 LEFT OUTER & PIN 1 LEFT INNER
Pin 4 BROWN --------------- PIN 5 LEFT OUTER
LEFT INNER
Pin 1 BLACK/GREEN--------- PIN 4 LEFT INNER
Pin 2 BROWN---------------- PIN 5 LEFT INNER
Pin 3 GREY ------------------ PIN 3 LEFT OUTER & PIN 3 LEFT INNER
Pin 4 GREY/YELLOW -------- PIN 2 LEFT INNER
RIGHT OUTER
ORIGINAL ------------------------ NEW
Pin 1 BROWN --------------- PIN 5 LEFT OUTER
Pin 2 GREY/WHITE---------- PIN 1 LEFT OUTER & PIN 1 LEFT INNER
Pin 3 BLACK/WHITE -------- PIN 4 LEFT OUTER
Pin 4 BLACK/GREEN -------- PIN 2 LEFT OUTER
RIGHT INNER
ORIGINAL------------------------- NEW
Pin 1 GREY/WHITE --------- PIN 4 LEFT INNER
Pin 4 GREY/BLUE ----------- PIN 2 LEFT INNER
   #65
Dino20vt
Leicester, UK
Hi, can anyone point me in the direction of the coding for a RoW Facelift B8.5 A4 avant bulb car to Facelift LED please?
Current channel values:
181 65535
182 7
183 65535
184 7
185 65535
186 7
187 65535
188 0
189 65535
190 4
191 16239
192 3
193 6
194 7
195 14849
196 14881
197 14852
198 14884
199 0
200 73
201 105
202 0
203 14849
204 14881
205 13
206 45
207 12
208 44
209 0
210 0
211 51214
212 51215
213 14387
214 3
rlarsen
Copenhagen, Denmark
C?ID=78998
I ask as my current values are different to the left table being a facelift, can I still use the right values?
From your posted coding, the current one are Blub values, so yes you should be able to use the Bulb => FL LED codings.
Below I have added the difference between old OEM LED and FL LED.
Dino20vt
Leicester, UK
Thanks rlarsen, gave it a go tonight and mostly successful :thumbs:
Only small issue is I get bulb warning for both fog lights, channels 200 and 201 have the correct values of 73 and 105 but channels 182, 184, 186 and 190 would not accept the new values, not sure if it’s connected to the problem though,
Thanks again
rlarsen
Copenhagen, Denmark
C?ID=78998
Thanks again
You don't have to change Channel 182, 184, 186 and 190 - so leave them be your current value. - they are not part of the coding directly.
About the bulb out on the fog lights - try change Channel 181 and/or 191 to 65391 - otherwise have a look at the table below, and change the part of the value so it works.
   #71
Dino20vt
Leicester, UK
I’m probably missing something here but seeing as the fl LED lights are all LED bar the revering lights, shouldn’t the ch181 table be mostly 0’s?
   #72
rlarsen
Copenhagen, Denmark
C?ID=78998
Sure - but I don't think all of the lights are LEDs - aren't the fog and reverse still bulbs ??
But if 0 works - then it works :)
   #73
Dino20vt
Leicester, UK
Reverse lights definitely incandescent as replaceable, unsure of the rest, others quite possibly, even if unaccessible👍🏻
   #74
AndyHops
Denver, CO, USA
C?ID=335767
Fixed links to pictures from request on PM....
Hey! Do you happen to have the coding table for a pre-FL B8 Avant that is going from NA bulbs to OEM Euro LEDs? Thank you so much! This entire thread has been hugely informative.
   #75
nofx1981
Canada
C?ID=132572
Did you ever figure yours out? I could use this info.
   #76
Boki Ar
Arandjelovac, Serbia
C?ID=57300
  • Voinalovych Mykola​
  • Today at 9:55 AM
  • Report
Audi a4 b8 Led usa 2016. Good people, please help me find the original code for American LED headlights. 180-241.
   #78
MOBILE
Twin Cities, MN, USA
C?ID=412308
I think a MY2012 is not the Facelift in US right ?? - in the rest of the world the MY2012 is the first Facelift year.
But if I'm right then you should be able to use the Coding below - use the RoW one (the left side):
Login code to unit 46 is: 16017
Please check that your current coding is the same as the right side of the table - otherwise I (or we) need to calculate the new coding for you.
Does anyone have the chart for this? The original attached pictures are no longer available! I have a US model B8 MY2011 Sedan. I have factory LED tails, and would like to recode them so the blinker is all by itself like the ROW Euro code. This thread has literally every other combo listed. Halogen to led, facelifts, avants, etc. But the original US LED to Euro LED would be awesome! I watched Davids Youtube video of when it was first done. But I cannot find the coding info anywhere... Thanks!!
   #79
avantbunnie
SF, CA, USA
C?ID=606530
Try this one:
Channel – New Value
195 – 5251
196 – 5283
197 – 5124
198 – 5156
203 – 73
204 – 105
205 – 13
206 – 45
207 – 12
208 – 44
209 – 0
210 – 0
Save a copy of your adaptations too, and don't change ch.199 - 202!!! Only change ch.195-198, then 203-210. Let me know how it goes.
   #80
avantbunnie
SF, CA, USA
C?ID=606530
But please post your current adaptations here, I want to see what we are working with. Thanks.
