I have a 2012 Audi b8 A4 with the led tail lights i know davidb8 was able to code it so that the turn signals are separate from the brake lamps. Anyone know how to code it to be amber instead of red and not blink with the brake light.
It's no secret how the LEDs are Coded - David just kept it for himself.
Which model do you have - Sedan or Avant ??
About the amber instead of red - well - that will be a problem - unless you want to change both tail lights to the Euro model, because the LEDs are red on the US model.
And I will suggest that this thread is moved into the Tweaks forum, so that it's only valid VCDS users who can see the coding.
Ok i have the Sedan. And yeah he was charging people to get it coded to work. I figured you need to change the tail lamps but i did it on a mkv jetta i coded it to have amber turn signals instead of red for the hella oem leds. I'm fine for now to just have the brake light separate from the turn signal if that is possible.
Yeah it isn't a facelift. Where do i go to check if my coding matches? In the U.S.A 2013 was the facelift year.
[46 - Comfort System]
[Security Access - 16] -> Enter login-code: 16017
[Adaptation - 10]
Channel 195 to 208
Hey guy's thanks a lot for your help the coding was correct and now it works properly.
Does anybody know what the coding is for the non-LED tail lights? or if it's even possible on our north american spec cars? Much appreciated
Which coding do you want ?? NA model with the RoW coding - or the NA coding as it is OEM ??
If you take the codings from the RoW section below - Channel 197 and 198 - you should have the RoW's way of using the signal lights.
I don't know if it can be done on your model - the face lift model of 4F (C6) - I've seen codings for the current model the 4G (C7) - and they look similar to the A4/A5/Q5 (B8).Hello, are there similar codes that can be used on a 2010 A6 Avant? I am looking to code mine tail lights so the turn signals are separate from the brake lights.
Dan
