Hi,
Need some help. My mums VW Tiguan she was driving along today and the car came up with a RED warning saying STOP CAR IMMEDIATELY! BATTERY NOT CHARGING.
I have run a scan and it has come up with several fault codes, relating to the generator.
I Have also checked the voltage at the battery 12.5V with engine off, 11.7V with engine running, so it is not charging.
Any help much appreciated.
Friday,14,October,2022,20:35:06:41168
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVGZZZ5NZHW403044 License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F A5
VIN: WVGZZZ5NZHW403044 Mileage: 90540km-56258miles
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 JC HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3023
Revision: B4H24--- CVN: DBFBCE1D4C6C0C4B
Coding: 0119001203271D082000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 74B1DFB81E3122ABDB7-8020
VINID: 9E65EAAAA15EA989C400300410DA7B269F
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [044] - -
[Diagnostic interface for data busRead out DTC]
Mileage: 90535 km
Date: 2022.10.13
Time: 15:35:30
Engine RPM: 1028.50 /min
Normed load value: 10.6 %
Coolant temperature: 87 °C
Intake air temperature: 68 °C
Voltage terminal 30: 11.880 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 1
Acceleration: 0.000 m/s²
9582 - NOx Sensor 1 Bank 1
P2200 00 [096] - Electrical Malfunction
28991 - No Communications with NOX Sensor 1
U029D 00 [032] - -
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 60277000000516
Coding: 0AEE929A34200B6F4777070462C74950492CD0E2E046927D30605078C02A4200002F641A1B13111435351919323200
VCID: 76B5E5B0084D30BBE53-8022
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 M HW: 5NA 907 044 M
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00387115
Coding: 0012010420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 49CF5E4C29330F43581-801C
Humidity sensor: exterior:
Rear A/C control head:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Fault Frequency: 216
Reset counter: 65
Mileage: 89118 km
Date: 2022.09.11
Time: 14:39:34
Outside temperature: 22.5 °C
Voltage terminal 30: 13.2 V
System run time-Engine running time: 186 s
System run time-Terminal 15 on: 188 s
Air quality status: Malfunction
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Reset counter: 101
Mileage: 89855 km
Date: 2022.09.23
Time: 10:15:19
Voltage terminal 30: 13.1 V
Inside temperature: 24.2 °C
Outside temperature: 14.5 °C
Fresh air/recirculating air/back pressure door specified value: 636
Actual value for fresh air/recirculation air flow flap: 822
Actual value for fresh air/recirculation air flow flap: 94.5 %
Part No SW: 5Q0 937 084 CE HW: 5Q0 937 084 CE
Component: BCM MQBAB M H34 0236
Serial number: 02001703200110
ROD: EV_BCMBOSCH_017.rod
VCID: 7DA7FA9C2D7B63E3A49-8028
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 161214 033 0372
Serial number: 00000001612120463584
Component: RLHS 042 0105
Serial number: S7Y17M02D07H02M24S24
Coding: 00A8DD
Serial number: 000000000ZY170042NPK
Serial number: 00000000000068320510
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 001201177478011
Coding: 0071451001
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 372B28B44FC789B33E5-8062
10494464 - Function Limitation due to Environmental Factors
B2022 00 [008] - -
[Geber für Einparkhilfe - Schmutz bzw. Eisbildung]
Reset counter: 97
Mileage: 90425 km
Date: 2022.10.11
Time: 16:34:16
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0233
Coding: 2A0060C150FF8728749C8145004087
VCID: 3E253D9060FDB8FBFD3-806A
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2HXP3N
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 1079B3280AE97E8B5FF-8044
Left seat belt tensioner:
Serial number: 5NC857705C0025R00385
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NC857706C0025R01070
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35700000000AB99D412V
Subsystem 4 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35800000000B6854012A
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3510001B3247FF95C1DL
Subsystem 6 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3520001B3247FF96A33D
Subsystem 7 - Part No SW: ----------- HW: 480 400 202 17
Serial number: 3550001A5244A734D7DA
Subsystem 8 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001AB244A735F48A
Subsystem 9 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001AB244A735831$
Subsystem 10 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001AB244A734A42Y
Subsystem 11 - Part No SW: ----------- HW: 480 000 102 17
Serial number: I0M0000000023DA4112X
Subsystem 12 - Part No SW: ----------- HW: 480 000 102 17
Serial number: I0N00000000E85A4A028
Part No SW: 5Q0 953 569 A HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: -------- Serial number: 20210623400073
Coding: 0C00
Shop #: WSC 25168 004 1048576
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C21379876E1AAEBD37-8068
Part No SW: 5NA 920 951 A HW: 5NA 920 951 A
Component: KOMBI 309 8311
Coding: 27A400006380060001886B031401000000000000
VCID: 3FDB409467F7B1F3F65-806A
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005888040
Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
GVL: 01D43C0000000000408C80000000480000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B10D4B7974173665-807A
Generator:
Subsystem 2 - Part No SW: 5TA 959 442 A HW: 5TA 959 442 A Labels: 3C8-959-537.CLB
Serial number: 0371704185000444AO2B
Coding: 280000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9059452904
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
Reset counter: 83
Mileage: 90168 km
Date: 2022.10.04
Time: 10:42:33
Terminal 30 power supply: 13.1 V
Terminal 15: On
8526353 - Generator
P1B00 00 [009] - Mechanical Malfunction
Reset counter: 65
Mileage: 90535 km
Date: 2022.10.13
Time: 15:34:30
Terminal 30 power supply: 11.6 V
Terminal 15: On
8526354 - Generator
P1B01 00 [008] - Electrical Malfunction
Reset counter: 105
Mileage: 90536 km
Date: 2022.10.13
Time: 15:39:47
Terminal 15: On
Serial number: HA1-00010.01.17
Coding: 0101
VCID: 4ACD61402C35045B51B-801E
Component: TSG FS 020 0041
Serial number: 211016EJL21975
Coding: 00310220D001048000001000
VCID: 43D34C640B1FD51392D-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013227000
Coding: 0D0000
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D7527C052BEB23BC9-8010
Component: TSG BFS 020 0041
Serial number: 060117EA518352
Coding: 00310020DE01048000001000
VCID: 42DD49601405DC1B99B-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013045639
Coding: 050000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02730601FF00000051110101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 313F16ACA1A35783701-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL072UT
Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 06021712K10174
Coding: 0003070600000401000213448050A90084000E000020
VCID: 3B23348473EFADD3DAD-806E
End----(Elapsed Time: 01:32, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
