Hi, I'm trying to activate developer mode on my Golf GTE MIB2 HI Harmon Infotainment unit so that I can clear out a number of Invalid Data Error faults (via the Green Engineering Menu). This is a JDM vehicle and the errors were introduced when the firmware was replaced with a local version.
I have successfully changed to developer mode in the past on my other Golf R using S12345 to access engineering mode, but this one doesn't accept this code I think because VCDS is not finding a label file. The part number of the MIB 2 unit is 3G-035-050M which is the japan market equivalent of a 3G-050-020 or similar.
I have tried to redirect by creating a 3G-5F.lbl file with "REDIRECT,3V0-035-MIB-HGH2.CLB,3G0-???-???", but VCDS is still not picking it up.
Can anyone offer some advice as to how I can get this to be recognised?
Thanks for any help.
Auto-scan below:
Auto-scan below:
Thursday,13,October,2022,18:56:27:39451
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86(VMWare)
VCDS Version 22.9.0.0 HEX-V2 CB: 0.4623.4
VIN: WVWZZZAUZGW801XXX License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 23 2B 42 44 51 52 55 57
5F 75 8C A5 A9 C6
VIN: WVWZZZAUZGW801813 Mileage: 15565km-9671miles
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AD HW: 04E 907 309 F
Component: R4 1.4l TSI h H21 1716
Revision: X3H21--- CVN: C137768B
Coding: 011D0012636405083000
ASAM Dataset: EV_ECM14TFS01104E906023AD 006004
ROD: EV_ECM14TFS01104E906023AB_006.rod
VCID: 629D565364C610AB917-8037
VINID: 9E69EAAAA465A979C80012010C1E4AD7DA
Readiness: 1110 0001
Part No SW: 0DD 300 045 L HW: 0DD 927 770 B
Component: GSG DQ400E H31 1109
Revision: 00031033 Serial number: TFK01504280134 CVN: 53B38510
ROD: EV_TCMDQ400021.rod
VCID: 3039EC1B7AAAF23B573-8065
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 61465000000170 CVN: 6959CE81
Coding: 01FA80A13820316D037F060181C62980011C8CC0608194F3F8A150B8C202
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 05576DCF95A88793D45-8051
Revision: 00021000 Serial number: 0371163721
Coding: 030C0C
VCID: 3A2DCE33ACD6386BE97-806F
Part No SW: 5GE 907 044 AC HW: 5GE 907 044 AC
Component: Climatronic H02 1104
Revision: 00001K07
Coding: 00121004100100000105000011101402
ASAM Dataset: EV_ACClimaBHBVW37X 005134
VCID: 7DA7052FFD78CF538C5-8029
Subsystem 3 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: T151683003807000039
Air quality sensor:
A/C compressor sub:
H02
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0173
Serial number: 01061515700558
Coding: 03011A42435102F369EC5000000403281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5BFF27F774DD439E9-802B
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150529 042 0551
Serial number: 150605162050
Component: RLHS 037 0059
Serial number: S2Y15M06D18H16M23S17
Coding: 31E8DD
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 E HW: 5Q0 907 572 E
Component: ACC Bosch MQB H05 0312
Serial number: 16051503210327
Coding: 021C1700FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 392FD13FA9D03373E0D-806D
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 29051541350190
ROD: EV_DRCONTITEMIC_001_VW48.rod
VCID: 372BD7079FC42503169-8063
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR00WHSF
Coding: 98FCC0C0002000005C5400CF00C800000065
VCID: 50F98C9B1A6A923B373-8005
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B14061570050
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B15061570297
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 306 15
Serial number: 35700000000A0DDCF41/
Subsystem 4 - Part No SW: ----------- HW: 480 001 506 15
Serial number: 3580000000065558E31K
Subsystem 5 - Part No SW: ----------- HW: 480 400 806 15
Serial number: 35100029F1B5A882D17F
Subsystem 6 - Part No SW: ----------- HW: 480 400 806 15
Serial number: 3520002C91A91E02F3FH
Subsystem 7 - Part No SW: ----------- HW: 480 400 806 15
Serial number: 3550002C51B0CB35032.
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 02061504220916
Coding: 0C10
VCID: 094F61FFB9B0E3F3B0D-805D
Part No SW: 5G1 920 654 A HW: 5G1 920 654 A
Component: KOMBI 322 6420
Coding: 272D1B187FC0000E02806A131600010000000000
VCID: 2809047B427ABAFB8F3-807D
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 D HW: 5QE 907 530 A
Component: GW MQB EV 312 3225
Revision: -------- Serial number: 31051510803278
Coding: 0201001726F16400FB00527CDC1F00000001050100010000000300000000
GVL: 01503C1000000608508C90008000CC1800000000000000000000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 47CBA7C7EF245583669-8013
Subsystem 1 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001197710035236
Coding: 2DFFFF
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 7802376903
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010022
Coding: 02720100331A00020002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
VCID: 4FFB8FE707548DC32E9-801B
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861020615050205
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000152439001
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E00B8EB2CE1B33B-8061
Component: TSG FS 020 0041
Serial number: 180515BEH1413A
Coding: 003F1720D001048000001000
VCID: 43D3B3D7DB1C79A3BA1-8017
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006455212
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: D102
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H06 4492
Revision: 00H06000 CVN: 3A7DD219
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
Component: TSG BFS 020 0041
Serial number: 280515BER17267
Coding: 003F1120DE01048000801000
VCID: 42DDB6D3C40670ABB17-8017
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006470742
Coding: 150000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0296020001010000
VCID: 75B71D0FC5489713C45-8021
Address 57: TV Tuner (R78) Labels:* None
Part No SW: 8V0 919 129 B HW: 8V0 919 129 B
Component: JP-DTV H11 1360
Coding: 02041C0000000100000000
ASAM Dataset: EV_TVMELC 001033
ROD: EV_TVMELC_VW37.rod
VCID: 3FDBBF27B7F41D43DE9-806B
Part No SW: 3G0 035 050 M HW: 3G0 035 050
Component: MU-H-N-JP 040 1187
Serial number: K5F AW7H8035LW
Coding: 02730008FF0000005111000100113A001F0209F601200100F6
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_MUHig4CGen2AW7 001081
ROD: EV_MUHig4CGen2AW7_VW37.rod
VCID: 2411104B3E525E9BA3B-8071
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0032
Serial number: VWZ8Z9RU3025P7
Subsystem 2 - Part No SW: V03 959 806 ND HW: -----------
Component: ROW 2021 --- 0090
Compact disc data bank:
Component: Gracenote2--- --- 2007
17 Faults Found:
1585 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
Voltage terminal 30: 13.4 V
1586 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1587 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for language]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1588 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1589 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1590 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1592 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1595 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1652 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for eco HMI]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1655 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1656 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1657 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1603 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1690 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for in-car communication]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1597 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for language]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
1598 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for visible MMI system languages]
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:52
B201A 00 [009] - -
Reset counter: 187
Mileage: 15565 km
Date: 2022.10.13
Time: 18:48:57
Status_Software_Version_Management-module_name: MDUV101/ABT
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Coding: 0273900410829A0100F800000000
Shop #: WSC 19388 002 1048576
ROD: EV_OCULowMQB.rod
VCID: 44D1B0CBDE127E9B83B-8011
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0652
Serial number: T3030088 CVN: 71245BB1BE0FD826B72DDBABB72DDBABB72DDBABB72DDBABB72DDBABB72DDBAB
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006036
ROD: EV_BECM06020115C6915182_AU37.rod
VCID: 3333E3178BBCC9232A1-8067
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0472
Serial number: V013C1542730655
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0472
Serial number: V013C1542730819
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0472
Serial number: V013C1542730878
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0472
Serial number: V013C1542730996
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0472
Serial number: V013C1542730876
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0472
Serial number: V013C1542731152
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0472
Serial number: V013C1542630936
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0472
Serial number: V013C1542731151
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 00000354837
Coding: 0100000000020308000500000101010100
ROD: EV_MFKBoschAU370.rod
VCID: 3C21C82BA6E2065BFBB-8069
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0017
Serial number: 150604200136
VCID: 2E05F263609EE4CB45F-807B
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AA HW: 5QE 915 682 AA
Component: OBC KOSTAL H61 3017
Revision: -------- Serial number: 2905150ET000IC
Coding: 105168022000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0C4158EBB6C2F6DB8BB-8059
End----------(Elapsed Time: 02:09, VBatt start/end: 13.2V/13.3V)-----------
