Hi, gents. First post here. (I submitted my genuine VCDS serial, but seems it hasn't taken yet.) Attempted to dyno a 2022 GTI DSG on a 2WD dyno. Was able to successfully enter dyno mode using the cabin sequence (ign on, hazards, gas pedal 5 times), but trans refuses to shift above second gear. Tried to activate dynomometer mode in the ECU, TCU, and ABS (may also need to be activated in the instrument cluster), but all requested security access. Any input as to how long it may take to get this access, assuming its possible? Thanks!
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 32 3C 42 44 52 5F 6C
75 A5 A9 D6 D7 C002 C003
VIN: WVWG87CDXNW151267 Mileage: 16935km-10522miles
Address 01: Engine (J623-DRNA) Labels: None
Part No SW: 8Y0 906 264 A HW: 06K 907 425 N
Component: R4 2.0l TFSI H08 0001
CVN: 2EA54D43
Coding: 092500122464010F30000000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0208Y0906264A 001003
ROD: EV_ECM20TFS0208Y0906264A_VW38.rod
VCID: BD326A752C10A265E8-80E8
VINID: 9E69D72074D4A1E9C11410861CACDE58B3
Readiness: 1110 1101
Part No SW: 0GC 906 557 AT HW: 0GC 300 020 Q
Component: GSG DQ381 H06 4260
CVN: C0DE839C
ASAM Dataset: EV_TCMDQ381062 001001
ROD: EV_TCMDQ381062.rod
VCID: 8F6EE0BD563C60F54A-80DA
Subsystem 1 - Part No SW: 5WA 713 033 BB HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20211011000069542739
Subsystem 2 - Part No SW: 5H0 713 059 R HW: 5H0 713 059 R
Component: ZSB_SB_Mono H01 0014
Serial number: 92478UKA00689
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810500003544805
Part No SW: 5WA 614 517 BL HW: 5WA 614 517 N
Component: ESC H13 0133
Serial number: 62411000001053 CVN: 7ED01246
Coding: 36FC6C9056256A6D9379600606CA60064A5258555A88030820B4B831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 9366ECCD7A1484156E-80C6 SFD
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 H HW: 5WA 959 436 H
Component: Kessy IOBOX 100 0725
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004.rod
VCID: D9FADEE5D8787E45E4-808C
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 P HW: 5WA 907 007 P
Component: AC Automat H30 3440
Coding: 002000010211000000100010111110010000011000000000000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001100
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: D4E42FD1BF9A432D37-8080
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002061221225322514
Part No SW: 5WA 937 086 AE HW: 5WA 937 086 L
Component: BCM37w_M028 0175
Serial number: BXJ53F101221940
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 9464EFD17F1A832D77-80C0 SFD
Subsystem 1 - Part No SW: 5H1 955 119 A HW: 5H1 955 119 A
Component: FWISCHER_MYJT 003 0051
Serial number: 907453F0402118505228
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SAY22M01D04H15M24S02
Subsystem 3 - Part No SW: 5H0 941 193 AP HW: 5H0 941 193 AP
Component: LiSi H06 0008
Serial number: 92471UKN000E5
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471UKH0007Z
Subsystem 5 - Part No SW: 5H0 959 569 C HW: 5H0 959 569 C
Component: DACHKONSOLE 101 0104
Serial number: 000000092661ULN02170
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000006122104221448
15400960 - Secure Onboard Communication
U14FD 00 [040] - Time Server not Available
[Sichere on-board Kommunikation: Zeitserver nicht verfügbar]
Reset counter: 22
Mileage: 15727 km
Date: 2022.09.28
Time: 00:20:44
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.6 V
Outside temperature: 9.0 °C
Light switch position: automatic
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 294 C HW: 5WA 919 294
Component: PDC 08 Kanal H04 0577
Serial number: 000006122194560
Coding: 0040014011
ASAM Dataset: EV_EPHBO18VW3800000 002029
ROD: EV_EPHBO18VW3800000_VW38.rod
VCID: D2E829C9858E4D1D25-8086
15 Faults Found:
1080304 - Parking Sensor(s); Rear
B107B F0 [032] - Function Limitation due to External Factors
1111826 - Front Left Parking Aid Sensor
B10F7 12 [032] - Short to Plus
1111828 - Front Left Parking Aid Sensor
B10F7 14 [032] - Open or Short to Ground
1112082 - Front Left Center Parking Aid Sensor
B10F8 12 [032] - Short to Plus
1112084 - Front Left Center Parking Aid Sensor
B10F8 14 [032] - Open or Short to Ground
1112338 - Front Right Center Parking Aid Sensor
B10F9 12 [032] - Short to Plus
1112340 - Front Right Center Parking Aid Sensor
B10F9 14 [032] - Open or Short to Ground
1112594 - Front Right Parking Aid Sensor
B10FA 12 [032] - Short to Plus
1112596 - Front Right Parking Aid Sensor
B10FA 14 [032] - Open or Short to Ground
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [032] - Open Circuit
1113328 - Parking Sensor(s); Front
B10FC F0 [032] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
13637426 - Databus
U1123 00 [040] - Received Error Message
Reset counter: 37
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
13647889 - Databus
[Bremsensteuergerät - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
Reset counter: 37
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:44
13688835 - Databus
U1123 00 [044] - Received Error Message
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 39
Mileage: 16935 km
Date: 2022.10.07
Time: 14:20:54
13959168 - Parking Sensor(s); Rear
[Geber für Einparkhilfe - Schmutz bzw. Eisbildung hinten]
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Coding: 0D22009E507680451247400000004004AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: CDD23AB59CB012E578-8098
17 Faults Found:
1538 - Sensor for Automatic Distance Control
C110B F0 [032] - Limited Visibility
[FAULT_SENSOR_BLINDNESS]
1561 - Databus
[FAULT_BV_AVAILABILITY_ERROR]
204873 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [032] - -
[FAULT_MISALIGNMENT_VERTICAL_STEP_DETECTE]
204874 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [032] - -
[FAULT_MISALIGNMENT_HORIZONTAL_STEP_DETECTED]
209054 - Databus
[FAULT_BV_BLINDNESS_ERROR]
Reset counter: 29
Mileage: 16408 km
Date: 2022.10.04
Time: 00:17:02
209153 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:50
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
0577 - Databus
[FAULT_VZM_SYSTEM_STATUS_ERROR]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:43
0616 - Databus
U1122 00 [040] - Implausible Message
[FAULT_QBIT_TRANSVERSE_ACCELERATION_INVALID]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
0723 - Databus
[FAULT_BV_RELEVANT_ERROR]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:50
0790 - Databus
U1122 00 [044] - Implausible Message
[FAULT_RB_PER_HV_OOS_SERVICE]
Fault Frequency: 14
Mileage: 16933 km
Date: 2022.10.07
Time: 13:17:32
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [032] - -
[FAULT_MISALIGNMENT_VERTICAL]
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Fault Frequency: 11
Mileage: 16933 km
Date: 2022.10.07
Time: 13:17:37
0822 - Databus
[FAULT_QBIT_LONGITUDINAL_ACCELERATION_INVALID]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
0828 - Databus
[FAULT_QBIT_YAW_RATE_INVALID]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:42
0859 - Databus
U1122 00 [032] - Implausible Message
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_INIT]
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 M HW: 5WA 959 655 M
Component: AirbagVW40 007 0636
Serial number: 000000003C0J3R7
Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: E18AF605F028A685AC-80B4 SFD
Component: ------------- H16 0022
Serial number: IBH00000000000H5U0S/
Subsystem 2 - Part No SW: ----------- HW: 480 400 812 21
Serial number: 3510001B706EE1438473
Subsystem 3 - Part No SW: ----------- HW: 480 400 812 21
Serial number: 35200019F06B45B4E4AI
Subsystem 4 - Part No SW: ----------- HW: 480 002 611 21
Serial number: 35700000000B07DC5C5.
Subsystem 5 - Part No SW: ----------- HW: 480 002 611 21
Serial number: 35800000000346257C5H
Subsystem 6 - Part No SW: ----------- HW: 480 400 112 21
Component: FrontSensor_D 003 614A
Serial number: 35500019EC6AD97123DR
Subsystem 7 - Part No SW: ----------- HW: 480 400 112 21
Component: FrontSensor_P 003 614A
Serial number: 35600019AC6AD975036J
Address 17: Instruments (J285) Labels: None-SRI2
Part No SW: 5H0 920 340 B HW: 5H0 920 340 B
Component: KOMBI 220 5350
Coding: 08BC0442638CCF050280220B2000000820300400
ASAM Dataset: EV_DashBoardVDDMQB37W 003033
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: A10AB605B0A8E685EC-80F4 SFD
13639427 - Databus
[ECU for engine control modul error value recieved]
Reset counter: 26
Mileage: 15345 km
Date: 2022.09.24
Time: 19:34:26
16711686 - Secure Onboard Communication
U14FE 00 [008] - Signature Verification Failed
[SOK_signature_verification_failed]
Mileage: 14 km
Date: 2022.04.09
Time: 11:45:31
16711695 - Low Coolant Level
B1B07 00 [008] - -
[warning_insufficient_coolant]
Mileage: 8950 km
Date: 2022.07.05
Time: 20:35:19
Part No SW: 5WA 907 530 Q HW: 5WA 907 530 G
Component: GW2020 High 756 7099
Revision: -------- Serial number: 771049050021357
Coding: 0000808D0F00000000000000010303327302600902000301030100000001010000000000000000000000000000000000
GVL: 3D400000020840CC80008002C800004004004000004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 005011
ROD: EV_GatewMQB2020_004_VW38.rod
VCID: D6E0D5D9A966513DC9-8082 SFD
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 7877278905
Subsystem 3 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218113002100930
Subsystem 4 - Part No SW: 5H0 959 542 J HW: 5H0 959 542 J
Component: KLR_JSS_1Zone 076 0022
Serial number: 3133020AB21322165002
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 K HW: 3Q0 909 059 D
Component: EBKV H09 0307
Serial number: BPA085101121013
Coding: 5003C5009F00007BEFBDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016.rod
VCID: D8FCDBE1A372674DDB-808C SFD
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000317583007
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: B2284949E54E6D1D05-80E6
Address 32: Differential Locks (-----) Labels:* None
Part No SW: 5WA 907 554 B HW: 5WA 525 130
Component: Quersperre H65 8640
Serial number: HH3-00023.10.21
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 005001
ROD: EV_LockElectHA1VW37X_VW38.rod
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 E
Component: HRE_Master H25 0284
Serial number: 00000589915963
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr.rod
VCID: BC346771370AAB6DDF-80E8
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 E
Component: HRE_Slave H25 0284
Serial number: 00000589704476
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
2240559 - Databus
[databus error value received - ESP_10 - ESP_HL_Fahrtrichtung]
Mileage: 16933 km
Date: 2022.10.07
Time: 13:17:36
2240560 - Databus
[databus error value received - ESP_10 - ESP_HR_Fahrtrichtung]
Mileage: 16933 km
Date: 2022.10.07
Time: 13:17:36
2244610 - Local Data Bus 2
U10C7 00 [032] - No Communications
[no communication - LIN]
2240563 - Databus
[databus error value received - ESC_50 - ESP_QBit_Gierrate]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:15:22
2236437 - Databus
[databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:48
2252891 - Databus
[databus error value received - VMM_02 - VZM_Systemstatus]
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:44
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007ULE1170B
Coding: 003B03208000040000000000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: CAD831A96DDE05DD5D-809E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000055957663
Coding: 111000
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 00592547
Coding: 0000000000000001000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
VCID: CED03DB991B629FD01-809A
1350 - Databus
[DTC_ESP_QUERBESCHLEUNIGUNG_QBIT]
1356 - Databus
[DTC_ESP_GIERRATE_QBIT]
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007ULE2649D
Coding: 003B03208C00040000800000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: C9DA0EA568D80EC554-809C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000055822461
Coding: 091000
Part No SW: 5H0 035 871 HW: 5H0 035 871
Component: MU-E--US 099 1766
Serial number: CVRV59N0AEB0000
Coding: 23800000000200000000000000000000000000000000000000
ASAM Dataset: EV_MUEIMQB37w 001003
ROD: EV_MUEIMQB37w_VW38.rod
VCID: E582E215E400CAA550-80B0 SFD
6923 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 39
Mileage: 16822 km
Date: 2022.10.07
Time: 00:44:13
Voltage terminal 30: 13.4 V
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 D HW: 5WA 980 556 B
Component: RV eCompact H26 0344
Serial number: FCLK20231221000
Coding: 02030004E42800
ASAM Dataset: EV_CamSysRVCCompaFicos 010024
ROD: EV_CamSysRVCCompaFicos_010.rod
Part No SW: 5WA 035 285 A HW: 5WA 035 285 A
Component: OCU3HMQB37W H12 0015
Serial number: 0000000110VIWPA
Coding: 02380020906828208005460070102607
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002.rod
VCID: C5C2029544C0EAA5B0-8090 SFD
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 C HW: 5WA 980 653
Component: MQB MFK 3.0 H09 3302
Serial number: E82645704213480
Coding: 00000A88006C4040109F40001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: CFEE20BD96BC20F50A-809A
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 0
Mileage: 16935 km
Date: 2022.10.07
Time: 14:11:46
1124417 - Development code 1
B2F01 00 [009] - -
[Wrong_formating_rem_data]
Fault Priority: 9
Reset counter: 0
Mileage: 18 km
Date: 2022.04.11
Time: 15:15:26
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 5H0 907 159 HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 211202291082
VCID: EC94973107EAFBED0F-80B8
Part No SW: 992 941 591 DE HW: 992 941 591 D
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: EA9891290D1EE5DD7D-80BE
Component: LED1R H08 9202
End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.3V)-----------
