2016 Audi RS3 - misfire and possible boost leak
jono
Canberra, Australia
C?ID=410415
Hi
While cruising at 90km/h I had the CEL and shudder, which I suspected to be a misfire. Cylinder 4 was the main suspect but multiple misfiring detected. Coil pack on cylinder four was cooked and plugs fouled. Replaced coil pack but issue still remains. Car is running a stage 2 Revo tune.
Auto scan
Saturday,08,October,2022,14:08:38:17021
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WUAZZZ8V4GA905396   License Plate: RS3
Mileage: 61919km-38474mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
          5F 6C A5 BB BC
VIN: WUAZZZ8V4GA905396   Mileage: 61919km-38474miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0006
   Revision: NKH52---    CVN: 122A4F12
   Coding: 12250032256601033620
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM25TFS0118V0907404 001007
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76B5E33938431A6BCDF-8022
   VINID: 9E546AAAA2261174490050C918F3CDF200
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:28:18
                    Engine RPM: 736.00 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.640 V
                    Engine status: COENG_RUNNING
10594 - Cylinder 4
          P0304 00 [096] - Misfire Detected
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:28:18
10595 - Cylinder 5
          P0305 00 [096] - Misfire Detected
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:30:31
                    Engine RPM: 740.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 64 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 14.760 V
10205 - Cylinder Disabling
          P130A 00 [032] - -
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:31:01
                    Engine RPM: 766.50 /min
                    Coolant temperature: 66 °C
Readiness: 0010 0001
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5203
   Revision: 00H10V01    CVN: 863BB2CD
   VCID: 290FF845B97D059390D-807C
   Part No SW: 8V0 907 379     HW: 8V0 907 379
   Component: ESC           H42 0020
   Revision: 00000000    Serial number: 63365000000313
   Coding: 999CF08DBA9915AE4094096D4397B20644990F5DA80290C24D6022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 015F80E5618D2DD3E8D-8054
   Revision: 00021000    Serial number: 0389112382
   Coding: 030C0C
   VCID: 3A2D37094CDBBE0BE97-806E
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000821482
   Coding: 03100015110000001000000000001400
   VCID: 33331A2D6BB14F432A1-8066
   Humidity sensor: exterior:
   Serial number: E0284A08000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061600700460
   Coding: 07151D46C24106FD03844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F98C559BD6593B0D-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151121  043 0580
   Serial number:         151129053001
   Coding: 0A47F7
   Serial number: 61160877
   Coding: 00006C
   Serial number: 12 10 2015  00000676
   Serial number: 000000000ZY153211X2D
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034346272
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000PPQX100000
   Coding: 901E00
   Revision: --------    Serial number: 39391534605460
   Coding: 0070150011
   VCID: 43D34AED3B11FFC3BA1-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 02121503071983
   Coding: 003E1701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 48C95DC10237DC9B6F3-801C
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       020116014
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R1BY5ZB
   Coding: 98CCC000008000005C54000000C800000065
   VCID: 4BC362CD13413783421-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 201 16
   Serial number: 35767000000ABA98081%
   Subsystem 2 - Part No SW: -----------    HW: 480 001 201 16
   Serial number: 358670000000BA98081X
   Subsystem 3 - Part No SW: -----------    HW: 480 401 712 15
   Serial number: 3516502BF1E3EAA1715S
   Subsystem 4 - Part No SW: -----------    HW: 480 401 712 15
   Serial number: 3526502B31E3EAA3810F
   Subsystem 5 - Part No SW: -----------    HW: 480 400 712 15
   Serial number: 3556502B31E3EA95F1B.
   Part No SW: 8V0 953 521 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 21121508490514
   Coding: EC18
   ASAM Dataset: EV_SMLSKLOMQB 020001
   Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
   Component: KOMBI         H02 6423
   Coding: 278D081A7F8800080184EA001000000000000000
   VCID: 45D754F53525C1F3945-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004336939
   Coding: 030100043F0860005B000278B80B00000001010000000000000000000000
   GVL: 01D43C000000060040CC90000002CC0000000000000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79AFE805095D7513A0D-802C
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 23 12 2015  A0075865
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 3556198603
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00004.11.15
   Coding: 0601
   Revision: 00000000    Serial number: 15000269328005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343119316EBF487B33B-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H06 0080
   Serial number: 0386817770
   Coding: 030312
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 38292D0172D7AC1B1F3-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H06 0080
   Serial number: 0388494335
   Coding: 030312
   Serial number: 141015BJD09519
   Coding: 005D1A205C01040000001003
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9103
   VCID: 392F280549DDB513E0D-806C
   Serial number: 221015BJM03165
   Coding: 005D12205E01040000001003
   VCID: 42DD4FE9240BF6CBB17-8016
   Component: AFS-ECU       H01 0110
   Coding: 01A600002B200200
   VCID: 3FDB461D57F99B23DE9-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 022 D    HW: 8V0 035 022
   Component: MU-H-ND-RW    H45 0402
   Serial number: A628A0G7508399
   Coding: 017303080000000021511102000A00002F000326010001005E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 2E050B59809362AB45F-807A
   Subsystem 1 - Part No SW: V03 959 800 TF    HW: -----------
   Component: ROW 2016  --- 0055
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY204N6R
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: ALJAL117111500030167
   Compact disc data bank:
   Component: Gracenote  --- 4006
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 303915219AA7745B573-8064
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000476351
   Coding: 0100010000010303000500010100010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C21311146EF803BFBB-8068
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 251115BKP0584B
   Coding: 004D12204001040000001002
   Serial number: 251115BKP05925
End----(Elapsed Time: 01:58, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Address 01: DTCs cleared
I also logged the following fault codes which I cleared but they haven't returned, even after a short drive.
01 Engine
        System description: 2.5l R5/4V TF
        Software number: 8V0907404
        Software version: 0006
        Hardware number: 07K907309C
        Hardware version: H52
        Faults:
                P229400 - Fuel Pressure Regulator "B" Control Circuit/Open
                Intermittent
                    Priority - 2
                Malfunction frequency counter - 1
                Unlearning counter - 255
                km-Mileage - 61917 km
                Engine speed - 0.00 1/min
                Normed load value - 0.0 %
                Vehicle speed - 0 km/h
                Coolant temperature - -40 °C
                Intake air temperature - 59 °C
                Ambient air pressure - 980 mbar
                Voltage terminal 30 - 12.100 V
                Dynamic environmental data - 20962811A4199A11CE1964128AAC11C9009E11D71F40
                date - 2022-10-07 16:35:35
                P164E00 - Oil pressure regulation valve
            Electrical error
                Intermittent
                    Priority - 2
                Dynamic environmental data - 209628107A0111BD0D6013380512160F541514041770000001B410100000
                U11F300 - Charge air pressure sensor
            No communication
                Intermittent
                    Priority - 2
                Dynamic environmental data - 209628107A0111BD0D6013380512160B161514041770000001B410100000
                P012100 - Throttle/Pedal Pos.Sensor A Circ.
            Range/Performance
                static
                    Priority - 2
                Dynamic environmental data - 209628107A0111BD0D6013380512160AC81514041770000001B410100000
                P019000 - Fuel Rail Pressure Sensor "A" Circuit
                Intermittent
                    Priority - 2
                P022300 - Throttle/Pedal Position Sensor/Switch B          High Input
                static
                    Priority - 2
                P201400 - Intake Manifold Runner Position Sensor/Switch Circuit
                Intermittent
                    Priority - 2
                Dynamic environmental data - 209628107A0111BD0D6013380512160EE01514041770000001B410100000
                P030400 - Cyl.4
            Misfire Detected
                static
                    Priority - 2
                km-Mileage - 61916 km
                Engine speed - 763.50 1/min
                Normed load value - 18.4 %
                Coolant temperature - 97 °C
                Intake air temperature - 52 °C
                Voltage terminal 30 - 14.520 V
                Dynamic environmental data - 209628107A0311BD0E091338051216046C1514041770000001A8101001F1
                date - 2022-10-07 15:44:09
                P030000 - Random/Multiple Cylinder
            Misfire Detected
                static
                    Priority - 2
                P030500 - Cyl.5
            Misfire Detected
                Intermittent
                    Priority - 2
                Engine speed - 1318.00 1/min
                Normed load value - 20.0 %
                Coolant temperature - 81 °C
                Intake air temperature - 57 °C
                Voltage terminal 30 - 14.560 V
                Dynamic environmental data - 20964F107A0311BD0D3113380612160636151404177000000614101003DB
                date - 2022-10-07 16:25:59
                P130A00 - Hide cylinder
                Intermittent
                    Priority - 2
                Malfunction frequency counter - 3
                Engine speed - 773.50 1/min
                Normed load value - 16.9 %
                Coolant temperature - 86 °C
                Voltage terminal 30 - 14.500 V
                Dynamic environmental data - 209628107A0311BD0D4C13380512160407151404177000000614101001E1
                date - 2022-10-07 15:44:34
                P023800 - Turbocharger Boost Sensor (A) Circ.
            High Input
                Intermittent
                    Priority - 2
                Dynamic environmental data - 209628107A0111BD0D6013380512160FAE1514041770000001B410100000
I'm suspecting a boost leak or issue with the turbo due to the pressure faults, which has then caused the misfire issues, but would appreciate any advice.
0120raptor
North West UK
C?ID=210440
Why does the coolant temp go from minus 40* up to plus 97* ?
TFSI
Maryland, USA
C?ID=66650
Hi
Auto scan
          5F 6C A5 BB BC
          P0300 00 [096] - -
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:28:18
10594 - Cylinder 4
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:28:18
10595 - Cylinder 5
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:30:31
          P130A 00 [032] - -
                    Mileage: 61917 km
                    Date: 2022.10.08
                    Time: 11:31:01
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 901E00
   Coding: 0070150011
   Coding: EC18
   Generator:
   Coding: 0601
   Coding: 030312
   Coding: 030312
   Coding: 9103
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
01 Engine
        Faults:
                Intermittent
                    Priority - 2
            Electrical error
                Intermittent
                    Priority - 2
            No communication
                Intermittent
                    Priority - 2
            Range/Performance
                static
                    Priority - 2
                Intermittent
                    Priority - 2
                static
                    Priority - 2
                Intermittent
                    Priority - 2
                P030400 - Cyl.4
            Misfire Detected
                static
                    Priority - 2
            Misfire Detected
                static
                    Priority - 2
                P030500 - Cyl.5
            Misfire Detected
                Intermittent
                    Priority - 2
                Intermittent
                    Priority - 2
            High Input
                Intermittent
                    Priority - 2
Hi Jono-
Did you replace the cyl. 4 spark plug as well or just the coil? Do you have supply to the coil as well as the activation signal present on the coil circuit? I do not think boost pressure is the issue affecting just one cylinder.
  • Agree
Reactions: JMR
Rich
L.I., New York
C?ID=159735
I had a 2009 A5 3.2 Audi and after a misfire is used my Ross Tech and set the live feature for all 6 cylinder misfires, both instant and average (excuse me if my terminology is off, this was a long time ago). I then went to the parkway and gunned it from a stop. One cylinder had a serious misfire and two others seemed to be on the way out. I changed all 6 coil packs and no more misfires. Car had about 80,000 miles at the time.
JMR
Romania
C?ID=432218
what about the spark plug ???
jono
Canberra, Australia
C?ID=410415
Looks like it was a failed injector has resulted in the piston being burnt out. Bore looks ok but my mechanic will have it apart in the next couple of weeks to the see extent of the damage.
jono
Canberra, Australia
C?ID=410415
It's been a journey, and it is still continuing, but here is the latest:
- New engine fitted (approximately 26,000kms) with a HPFP and stock turbo that has been ported (around 28 per cent larger inducer and 30 per larger exhaust compared to stock)
- Recorded some misfires at idle but that went away and it has been fine to drive around on low-to-mid boost
- When hitting full boost (second gear WOT) it misfired, CEL comes one, almost like it is hitting a rev limiter at 5,000 rpm
- Logged data today to see what was happening and got worried by the results (see below) and also recorded 115 misfires in four seconds across cylinders 1, 2 and 3 (with only one misfire being logged in cylinder 5).
The formatting is a bit off but hitting -12.8 degree ignition timing retardation was a huge red flag. I've been speaking to my mechanic and the tuning shop that did the original stage 2 tune (Revo) but would this be something a custom tune could sort out or are there physical issues with the engine that I should be concerned about?
Time   Injection    Ignition timing    Fuel pressure    Long-term Lambda Turbo inlet pressure
        Time        retard angle    (actual and        fuel      actual
                                    specified)        trime      value
     ms     °     °     °     °     °             MPa     MPa         %                  hPa
0.37    0.838    0    0    0    0    0    6.181    6.3055    -1.08    0.978    424.69
0.81    0.851    0    0    0    0    0    6.498    6.625    -1.08    0.9805    453.05
1.24    0.977    0    0    0    0    0    7.0305    6.894    -1.08    0.9939    504.77
1.73    0.985    0    0    0    0    0    7.3115    7.2355    -1.08    0.9897    562.81
2.23    1.074    0    0    0    0    0    7.3235    7.2855    -1.08    0.9844    590.08
2.81    0.948    0    0    0    0    0    7.2705    7.292    -1.08    0.9832    544.69
3.29    0.839    0    0    0    0    0    7.1205    7.1185    -1.08    0.9902    448.59
3.85    0.768    0    0    0    0    0    6.482    6.322    -1.08    0.9739    401.02
4.36    0.83    0    0    0    0    0    5.8815    5.833    -1.08    0.9971    411.48
4.83    0.882    0    0    0    0    0    5.7825    5.955    -1.08    0.9761    425.23
5.28    0.815    0    0    0    0    0    6.5395    6.743    -1.08    0.9834    463.36
5.78    0.819    0    0    0    0    0    7.046    6.835    -1.08    0.9888    461.56
6.23    0.816    0    0    0    0    0    6.7575    6.8325    -1.08    0.9976    456.64
6.68    0.935    0    0    0    0    0    6.826    6.776    -1.08    0.9905    518.44
7.08    0.872    0    0    0    0    0    7.119    7.172    -1.08    0.9934    515.31
7.48    0.953    0    0    0    0    0    7.296    7.215    -1.08    1.002    537.97
7.91    0.967    0    0    0    0    0    7.3435    7.255    -1.08    0.9893    566.88
8.33    0.951    0    0    0    0    0    7.304    7.277    -1.08    0.9939    558.98
8.75    1.003    0    0    0    0    0    7.333    7.2855    -1.08    0.9905    577.42
9.17    1.116    0    0    0    0    0    7.3235    7.305    -1.08    0.9849    618.13
9.57    0.971    0    0    0    0    0    7.522    7.3305    -1.08    0.9817    572.27
10.07    0.811    0    0    0    0    0    7.2505    7.288    -1.08    0.9834    471.56
10.57    0.807    0    0    0    0    0    6.6795    6.6045    -1.08    0.9744    429.22
11    0.845    0    0    0    0    0    6.46    6.4775    -1.08    0.9727    458.75
11.43    0.774    0    0    0    0    0    6.791    6.762    -1.08    1.0022    436.88
11.84    0.844    0    0    0    0    0    6.443    6.3115    -1.08    0.9912    440.55
12.26    0.811    0    0    0    0    0    6.547    6.688    -1.08    0.9922    453.59
12.79    0.829    0    0    0    0    0    6.7455    6.704    -1.08    0.991    456.17
13.34    0.842    0    0    0    0    0    6.9225    6.9835    -1.08    0.9856    488.05
13.84    1.091    0    0    0    0    0    7.171    7.173    -1.08    0.9973    532.58
14.3    2.622    0    0    0    0    0    7.3525    8.1145    -1.08    0.9805    1140.94
14.7    4.302    0    0    0    -2.3    0    10.0105    10.049    -1.08    0.9919    1829.69
15.1    8.226    -6.8    -4.5    -4.5    -2.3    -6.8    12.029    11.5145    -1.08    0.949    2906.17
15.6    10.466    -6.8    -6.8    -6.8    -4.5    -9    9.5195    11.9145    0    0.8513    3582.5
16.11    10.454    -6.8    -12    -6.8    -6    -10.5    7.746    11.9925    0    0.8101    3582.97
16.54    12.588    -6.8    -12.8    -4.5    -2.3    -6.8    11.0875    11.9195    0    0.8062    4105.94
17.06    16.195    -4.5    -6.8    -9    -9    -6.8    7.4825    11.911    0    0.8909    4131.88
17.57    14.657    -9    -6.8    -12.8    -12.8    -10.5    6.2405    11.9785    0    0.9106    4132.89
18.01    0.651    -12.8    -12    -12    -12    -12    3.1155    3.0015    -1.08    0.8125    313.83
18.44    0.737    0    0    0    0    0    3.2895    3.3125    -1.08    13.6721    308.28
18.94    0.734    0    0    0    0    0    3.4355    3.462    -1.08    15.9998    319.84
19.37    0.718    0    0    0    0    0    3.5475    3.5595    -1.08    15.9998    318.75
19.81    0.731    0    0    0    0    0    3.628    3.6295    -1.08    15.9998    318.28
20.25    0.71    0    0    0    0    0    3.6955    3.6995    -1.08    15.9998    318.83
20.67    0.699    0    0    0    0    0    3.7565    3.7625    -1.08    15.9998    315.94
21.07    0.713    0    0    0    0    0    3.8    3.811    -1.08    15.9998    314.14
21.51    0.675    0    0    0    0    0    3.845    3.8525    -1.08    15.9998    309.69
21.95    0.667    0    0    0    0    0    3.889    3.8905    -1.08    15.9998    307.34
22.49    0.68    0    0    0    0    0    3.9255    3.9305    -1.08    1.6589    289.14
23    0.67    0    0    0    0    0    3.9685    4.004    -1.08    0.9741    301.17
23.54    0.701    0    0    0    0    0    4.1025    3.977    -1.08    0.9854    300.78
24.08    0.935    0    0    0    0    0    3.8875    4.0975    -1.08    0.9893    371.8
24.51    0.901    0    0    0    0    0    5.8495    6.238    -1.08    0.9846    484.77
24.96    0.92    0    0    0    0    0    7.2445    7.076    -1.08    1.0085    512.34
25.45    1.021    0    0    0    0    0    7.304    7.2355    -1.08    0.9858    563.67
25.99    0.98    0    0    0    0    0    7.2245    7.275    -1.08    0.98    545.39
iichel
Netherlands, eastern part
C?ID=284912
shortly before the timing advance, actual fuel pressure is not keeping with specified. perhaps an issue?
jono
Canberra, Australia
C?ID=410415
Is the timing advancing? I recall seeing a post from @Uwe which said a figure with a - is advance and + is retard but wasn't sure given the measuring value is retard angle.
Yes, I noticed the rail pressure dropping off so will look into that. I also logged a P010800 manifold abs.pressure or bar.pressure which I will investigate.
jono
Canberra, Australia
C?ID=410415
Update - the car ended up misfiring on cylinder 1 at idle quite badly so I got it towed home worried that what blew it up last time was going to happen. Compression was 150psi across all cylinders but the spark plug from cylinder 1 was fouled.
Once I get to the bottom of the fuel supply issue I will look at the tune.
Larry Manton
C?ID=112505
Are you sure about cause and effect? Perhaps it's adjusting fuel pressure because of misfires?
Notice here, 4132HPA that converts to 60psi of boost, off the charts. Don't know what happened here but cam timing retarded and such, sounds like the ECU was in panic mode, and would be curious to know what that was. I have mentioned a term mega knock which is posted by mini coopers, is this one and the same.
I suppose what if Boost sensor is faulty (not actually 60 psi) and ECU is trying to correct for that when in fact nothing is wrong, just throwing that out there, but ECU was not happy here.
I don't see that as an overfuel from an injector, possible????
jono
Canberra, Australia
C?ID=410415
Thanks @Larry Manton, that’s really useful.
Overfuelling could be a possibility. I checked for engine DTCs again this morning and it had logged a P025C Fuel Pump Module Control Low and a P2294 Fuel Pressure Regulator 2 Control Circuit Open
I put a new spark plug in cylinder 1 this morning and it turned over and idled fine and only misfired once I gave it a slight rev. The new spark plug was wet and smelt of fuel.
jono
Canberra, Australia
C?ID=410415
Update
I suspected the injector on cylinder 1 to be the issue so swapped it with the cylinder 3 and misfires started on cylinder 3. I put an injector in from my old engine and, once I swapped the plugs around, the misfires went away. Have driven a total of 30 minutes (only 50 per cent throttle and minimal boost) and have recorded only a handful of misfires that go away without the CEL illuminating. I will get a new set of plugs as they fouled when swapping them to cylinder 1, probably upgraded coil packs and it's booked in for a custom tune on the 28th of April.
