- Jul 8, 2022
- 3
- 0
- Fall River, MA, USA
- C?ID=513496
I'm very new to all of this! But the coding is starting to make sense
I'm installing Euro R tails in my FL 7.5 wagon. I did no pin swapping, because guides I had seen (only for Mk7>Mk7.5) looked like the pins were already in the right place for a FL. Out of the box, after I trimmed the barrier to allow the tail lights to plug in... the tail section worked as designed, the brake light worked like NAR (flash with turn), and the orange turn signals worked like the side markers (on with tail lights). So, I had hoped all I'd have to do is code the brakes and turn signals. Removing the turn from the brake was easy... change "blink hellphase" and "blink dunkelphase" to "not active" on leuchte 20 and 21 (brake lights).
Making the orange signals work was much harder... anything I did, I could not get the ambers to work by activating leuchte 18 and 19. They only worked when I changed anything on leutche 27. And they only ever activated together... so I'm thinking that leutche 27 (pin T73c/6 on the CCM) is one wire output, that is split to both sides. (interestingly when I did activate leutche 18 and 19, they blinked the brake lights... but the brakes were "master" meaning they stopped blinking when putting the brakes on).
The easiest fix would probably to be to swap the pins so the side markers (leutche 27) power the tails, together, and then recode the current tail (leutche 23 and 24) to be turn signals instead.
But, since I'm going to run a new wire for the rear fog, I am probably going to run a new wire for one side turn signal, and figure out what pin they actually are on the CCM so that everything is set up the way it "should" be. I'm new to all of this, and info is spread far and wide, and I can't really find any coding that changes what I've discovered.
But they're in! I left them coded like NAR where the brake is also turn, for now until I can figure this out.
Wednesday,05,October,2022,18:44:25:04833
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: 3VWH17AU6JM755384 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 47 4B
52 5F 75 A5 CA D6 D7
VIN: 3VWH17AU6JM755384 Mileage: 117295km-72883miles
29-Left Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13--- CVN: B1D4D877
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00225
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS020_VW37.rod
VCID: 46D558766826C32B9DF-8012
VINID: 0E69D804746519A7471450C810103D49E4
15074 - Cylinder Disabling
P130A 00 [096] - -
20662 - Oxygen (Lambda) Sensor B1 S1
P0131 00 [096] - Signal too Low
Mileage: 116424 km
Date: 2022.09.24
Time: 21:12:43
Engine RPM: 1294.00 /min
Normed load value: 6.7 %
Coolant temperature: 65 °C
Intake air temperature: 54 °C
Voltage terminal 30: 13.945 V
Unlearning counter according OBD: 18
Engine: operating status: IS
ECU_STATE: SYN_ENG_IGK_ON
T_ES: 0 min
T_AST_SAE: 4 s
TTIP_MES_LS_UP[1]: 646.6875 °C
TEG_DYN_LS_UP[1]: 247.4125 °C
Lambda probes actual: bank1: 0.6826
17178 - Databus
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 115825 km
Date: 2022.09.16
Time: 19:25:43
Engine RPM: 5677.00 /min
Normed load value: 40.4 %
Vehicle speed: 117 km/h
Coolant temperature: 88 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.964 V
Unlearning counter according OBD: 21
Engine: operating status: PL
N_TOOTH: 5694 /min
T_AST_SAE: 69 s
Engine oil temperature: 95.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 13040.0 kPa
FUP_EFP_MES: 11000.8 hPa
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 115825 km
Date: 2022.09.16
Time: 19:25:43
N_TOOTH: 5694 /min
T_AST_SAE: 69 s
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Readiness: 0000 0001
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01706131385 CVN: 00008634
Coding: 0018
Shop #: WSC 01357 011 12345
ROD: EV_TCMDQ250021.rod
VCID: 59EF830AC9985CD3C0D-800C
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 52057000000119
Coding: 43FA6AA134250971807A030880C729C2562C9001C001943C36435050E029430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
VCID: 77ABE5B25F4C6AA3D69-8022
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0445350506
Coding: 032C0C
VCID: 3C213A9E26EA89FBFBB-8068
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0202002420011800010400401211142A
VCID: 48C9564E6232D55B6F3-801C
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C86418071700LT
Shop #: WSC 00066 790 00248
ROD: EV_BCMBOSCH_018.rod
VCID: 0B43A94233C47E43821-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170621 043 0551
Serial number: 97022066170706232328
Coding: 0F4DFD
Component: RLHS 042 0105
Serial number: S8Y17M07D03H15M10S47
Coding: 06A8DD
Humidity sensor: interior:
10 Faults Found:
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Reset counter: 244
Mileage: 117110 km
Date: 2022.10.03
Time: 17:53:53
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: operated
Low beam: Not operated
last_wakeup: Pin A32 Heckdeckel Softtouch TasterPin
Voltage: 11.7 V
Outside temperature: 11.5 °C
12554 - Bulb for Left Back-up Light
B12CB 15 [008] - Open or Short to Plus
Reset counter: 238
Mileage: 117110 km
Date: 2022.10.03
Time: 17:52:36
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Reset counter: 244
Mileage: 117110 km
Date: 2022.10.03
Time: 17:51:38
Terminal 15 status: OFF
CAN-Bus_aktiv: OFF
OFF: operated
Position lamps: Not operated
Voltage: 12.3 V
Outside temperature: 12.0 °C
12810 - Bulb for Right Back-up Light
B12CC 15 [008] - Open or Short to Plus
Reset counter: 238
Mileage: 117110 km
Date: 2022.10.03
Time: 17:52:16
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
8967 - Bulb for Right Fog Lamp
B1220 11 [008] - Short to Ground
13578 - Bulb for Left Tail Light 2
B12C0 15 [008] - Open or Short to Plus
Reset counter: 238
Mileage: 117110 km
Date: 2022.10.03
Time: 17:52:36
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
13834 - Bulb for Right Tail Light 2
B12C1 15 [008] - Open or Short to Plus
Reset counter: 238
Mileage: 117110 km
Date: 2022.10.03
Time: 17:52:16
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
21258 - Bulb(s) for Front Side Marker
B145A 15 [008] - Open or Short to Plus
Reset counter: 238
Mileage: 117110 km
Date: 2022.10.03
Time: 17:53:53
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.7 V
197384 - Lock Module for Central Locking; Rear Right
B12DC 29 [008] - Signal Implausible
B1263 01 [009] - Electrical Failure
Fault Frequency: 27
Reset counter: 201
Mileage: 108602 km
Date: 2022.07.10
Time: 16:40:46
CAN-Bus_aktiv: On
OFF: operated
last_wakeup: Pin C14 Kessy Weckleitung
Voltage: 12.2 V
Outside temperature: 28.5 °C
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617168
Coding: 0271163811
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F97E2E9A621D9B373-8004
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 351D67C1C1FFCF28949C810520401600000000000000000000
Shop #: WSC 00066 790 00072
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E25309630F69BEBD5F-806A
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR08J2HI
VCID: 47CB55726F2CDA23669-8012
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007F6AB9
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 506 17
Serial number: 35700000000CFB3C152X
Subsystem 3 - Part No SW: ----------- HW: 480 002 506 17
Serial number: 3580000000081C3C152H
Subsystem 4 - Part No SW: ----------- HW: 480 402 706 17
Serial number: 3510001A9264428454E$
Subsystem 5 - Part No SW: ----------- HW: 480 402 706 17
Serial number: 3520001C525E6143C23.
Subsystem 6 - Part No SW: ----------- HW: 480 400 207 17
Serial number: 3550002A924F3823432.
Subsystem 7 - Part No SW: ----------- HW: 480 400 207 17
Component: FrontSensor_P 001 6149
Serial number: 3560002A924F3823334$
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 15071704221395
Coding: 0C10
VCID: 094F934A39B86C53B0D-805C
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BA5101DED84CF0502887F031001000080000000
VCID: 270BF5F2CF6C3A23869-8072
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 14081700840926
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
Shop #: WSC 00066 790 07025
GVL: 01D63C0000000600408C80008000C80010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 333311A20BB446832A1-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 28170002078110071439
Coding: 35FFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H55 0041
Serial number: 0331835
Serial number: HA1-00023.05.17
Coding: 3801
VCID: 4ACD6C467C3E274B797-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
0033 - Supply voltage
[Supply voltage - lower limit exceeded]
Reset counter: 241
Mileage: 117197 km
Date: 2022.10.04
Time: 17:48:00
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000169236007
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 343112BE0EBA41BB33B-8060
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038723401421
Coding: 003A13200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000007048454
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 9302
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FFB7D52875C02632E9-801A
21760 - Databus
[HCA_01 Botschaft - CAN-Timeout]
Reset counter: 182
Mileage: 115263 km
Date: 2022.09.08
Time: 11:01:22
Motor status: 02
System status: Driving mode
Supply voltage: 13.75 V
Temperature: 48.0 °C
KFC: 55
KFA: 00 00
Freeze frame conditions: 20
uioUdNotFilt_xdu16: 13.77 V
uAdSensI_SwitchedKl30_xdu16: 13.76 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD00FLW4
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E0500D6E0966B6B45F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 05081700840400
Coding: 000000050100211200113F47030000000000000000000000000000000000
VCID: 72BDD4A6342E0F8BE17-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038723300421
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000007025900
Coding: 091000
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Fault Frequency: 46
Reset counter: 228
Mileage: 108602 km
Date: 2022.07.10
Time: 14:52:28
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0842
Coding: 027312020000000051220002001808001F0108F401200500C6
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2076160
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
B11CF 53 [009] - Deactivated
Reset counter: 14
Mileage: 108567 km
Date: 2022.07.08
Time: 21:19:31
Voltage terminal 30: 14.0 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 98 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43D341625B14F603BA1-8016
9458451 - Cellular Antenna
B1053 13 [008] - Open Circuit
[GSM antenna open load]
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 26061712P21113
Coding: 000307020002020100221344C156890094000E200120
Shop #: WSC 26159 002 104857
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00800073720C
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3D27379A3DF080F3CC5-8068
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F238A29D8BCD3E0D-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
