Golf mk7 lane assist
Kr0z1
Vilnius, Lithuania
C?ID=439084
Hello, recently i retrofitted A5 front assist camera to golf mk7, and tried to code lane assist, but no luck. In instrument cluster ant 5F lane assist options now available, but can't activate. There is autoscan and couple photos.
Monday,03,October,2022,16:33:21:09716
VCDS Version: 22.9.0.0 (x64)  HEX-NET2 CB: 0.4623.4
VIN: 3VW447AU8HM074417   License Plate: LUK750
Mileage: 23392km-14535mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 29 2B 32 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: 3VW447AU8HM074417   Mileage: 23392km-14535miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 95999324
   Coding: 091D00124464002F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 3720417C0FCFDBF3169-8062
   VINID: 0E69C41074652187401C41011C38EF7357
15450 - Blocking Valve for Coolant (N82)
          P1889 00 [047] - Open or Short to Ground
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:36:20
                    Engine RPM: 0.00 /min
                    Coolant temperature: 18 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.003 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 99 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 12690.0 kPa
15451 - Thermostat for Transmission
          P19A1 00 [047] - Short to GND
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:36:20
                    Voltage terminal 30: 13.984 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 99 kPa
17790 - Coolant Pump Control Circuit
          P2600 00 [047] - Open
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 17:58:23
                    Coolant temperature: 17 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.945 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 99 kPa
                    FUP_H_SAE: 12550.0 kPa
Readiness: 1110 0101
   Part No SW: 0D9 300 020 N    HW: 02E 927 770 AS
   Component: DQ250-6V MQB  H54 5004
   Revision: 06454104    Serial number: TFK01703221916 CVN: 0000FCBF
   ROD: EV_TCMDQ250021.rod
   VCID: 20128A20BA41BC4BC73-8074
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 51397000000142
   Coding: 01FA6BA154270970807B020140CA6880D62A900140021636164350D1C089430000000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   VCID: 79A48744795B0D83A0D-802C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0440105794
   Coding: 032C0C
   Shop #: WSC 01383 790 50316
   VCID: 3B285D4C33E7FF93F21-806E
   Part No SW: 5GM 907 044 E    HW: 5GM 907 044 E
   Revision: 00001K04
   Coding: 00020014200100000004000012111402
   VCID: 46DE3CB87825B27B9DF-8012
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86421041700SX
   Shop #: WSC 00066 790 00201
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0740F1BC3FAF6B73A69-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170425  043 0551
   Serial number: 97022066170505190617
   Component: RLHS  042 0105
   Serial number: S9Y17M04D03H13M39S11
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691607431102170246
   Coding: 181803
   Humidity sensor: interior:
18186 - Bulb for Rear Left Side Marker Lamp
          B12BC 15 [009] - Open or Short to Plus
                    Reset counter: 209
                    Mileage: 21766 km
                    Date: 2022.08.25
                    Time: 20:17:34
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 26.5 °C
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 25
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 16:05:19
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Voltage: 12.4 V
                    Outside temperature: 16.0 °C
722437 - Control Module for Power Sunroof
          B13C6 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 209
                    Mileage: 21766 km
                    Date: 2022.08.25
                    Time: 20:17:34
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 233
                    Mileage: 23262 km
                    Date: 2022.09.14
                    Time: 19:45:26
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 15.5 °C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 350000C141FFC428949C810520301600000000000000000000
   VCID: 3C2A5E5036E9F8ABFBB-8068
   Serial number: 11031741350325
   ROD: EV_DRCONTITEMIC_001_VW48.rod
   VCID: 3822424002D1D48B1F3-806C
   Serial number: 003GCR08AB56
   VCID: 47C031BC7F2FAB73669-8012
   Serial number: IBH000000000007AEUT7
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 704 17
   Serial number: 35700000000A248C332G
   Subsystem 3 - Part No SW: -----------    HW: 480 002 504 17
   Serial number: 358000000000DC60432D
   Subsystem 4 - Part No SW: -----------    HW: 480 402 704 17
   Serial number: 35100019B24E98317585
   Subsystem 5 - Part No SW: -----------    HW: 480 402 704 17
   Serial number: 35200019B24E98319601
   Subsystem 6 - Part No SW: -----------    HW: 480 401 102 13
   Serial number: 3550002C50F76B219120
   Subsystem 7 - Part No SW: -----------    HW: 480 402 502 13
   Serial number: 3560002A10F8ABF4317F
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 09051708490866
   Coding: 0410
   Part No SW: 5G1 920 791 B    HW: 5G1 920 795 B
   Component: KOMBI         403 4191
   Coding: 0BAD111AFD88000A02886A035000000000000000
   VCID: 2B086D0CC3876F13621-807E
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 240
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:27:30
   Component: GW MQB High   518 5286
   Serial number: 24061700840508
   Coding: 0101000870085900FB00023B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   GVL: 01523C500000060040CC80008000CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F30791CF79F13334E9-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170000163890027042
   Coding: 35FFFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Revision: 00000000    Serial number: 17000106337002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343A76701EB930EB33B-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00016.01.17
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0439060202
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Serial number: 0440324884
   Coding: 010111
   Serial number: 130617A0080BJ8
   Coding: 003E13200000020000000000
   VCID: 43D825AC4B178753BA1-8016
   Serial number: 00000000000006689056
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C4ACE9026C9082B8BB-8058
   Revision: 00000001    Serial number: VWZ8Z1HBA03JLMU
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D8CA3143D13A1233C5-8038
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   002 0285
   Serial number: 05051710800242
   Coding: 000000050100164A04203F40020000000000000000000000000000000000
   VCID: 72B6B068242D7EDBE17-8026
   Serial number: 140617A00800P7
   VCID: 42D620A8540D8E5BB17-8016
   Serial number: 00000000000006507896
   Coding: 091000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0755
   Coding: 027300020000000051110002001808009F0203F401200105C6
   Shop #: WSC 00066 790 00156
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 32367068E4AD3EDB217-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H51 8130
   Serial number: VWZ6ZJV0721976
          B201A 00 [009] - -
                    Reset counter: 240
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:33:15
                    Voltage terminal 30: 14.0 V
                    Status_Software_Version_Management-module_name: C
          B11CF 53 [009] - Deactivated
                    Reset counter: 240
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:33:18
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 141 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 240
                    Mileage: 23392 km
                    Date: 2022.09.29
                    Time: 18:33:19
                    BAP-BAP_Function_ID: 02
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H04 0272
   Serial number: 14101511P10218
   Coding: 0003070000000402002013548146890088000E200000
   Component: SAS-GEN 2     H06 0014
   Serial number: 170413203906
   VCID: 6B88AD0C0307AF13221-803E
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 3924474439DBCD83E0D-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:51, VBatt start/end: 14.3V/14.6V)-----------
Cuzoe
C?ID=279487
The fault in 17 is for a missing LDW message. I believe LDW is lane departure warning. Did you code module 44? Check long coding, byte 3. Someone will have to check me but I think bit 0. Use the helper.
You also have a fault in 09 for left rear side marker. Assuming that is the turn signal, does anybody know if lane assist will work if one of those bulbs is out? I know ACC won't work if a brake light is out. It would make sense if this is similar although I've never read about it.
Kr0z1
Vilnius, Lithuania
C?ID=439084
Okey, in couple days i will check coding in module 44 and will fix rear side marker coding, because this golf was imported from USA to Europe and the one who did rear lights missed side marker coding.
Kr0z1
Vilnius, Lithuania
C?ID=439084
So the problem was solved. The problem was with A5 module, changed to other part, and line assist now is working. (now I don't have access to this vehicle for exact part number, but when I get, I will post part number which is now installed)
