C8 RS6: Suspension service mode reset?
C8RS6
Georgia, USA
C?ID=70901
I lowered my C8 RS6 using VAG COM. Because the various instructions I found online didn't match up to what I saw, I clicked around and tried different things. The lowering seems to have worked fine.
I now get a persistent "Air suspension in service mode! Vehicle can be moved but handling may be impaired" message. Can anyone tell me how to reset this? Unfortunately, I didn't save the factory coding, so I may need that for a C8 RS6 as well if anyone has it. Thanks!
C8RS6
Georgia, USA
C?ID=70901
Sure, thank you for your help:
Monday,03,October,2022,11:10:10:39590
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WUA1CBF23MN908793   License Plate:
Chassis Type: F2-AU58 (4KL)
Scan: 01 02 03 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 65
          6D 74 75 81 82 A5 A9 BB BC C4 CA CB CC CF D6 D7 DB DC DD DE
VIN: WUA1CBF23MN908793   Mileage: 32945km-20471miles
74-Chassis Control -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
Address 01: Engine (J623-DJPB)       Labels: None
   Part No SW: 4K0 907 557 F    HW: 0P2 907 309 A
   Component: V8 4.0l TFSI  H31 0001
   Revision: 72H31000    CVN: 07FA06A2
   Coding: 122A0012256E010E342C6000000400000000000000000000
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_ECM40TFS0114K0907557F 001001
   ROD: EV_ECM40TFS0114K0907557F.rod
   VCID: 36352F1488CED7DB0DF-8062
   VINID: 9E54414D25820DD7890081C90CE62D453F
   Part No SW: 4K0 927 158 F    HW: 0D6 927 156 H
   Component: 0D6 40FSINAR  H06 0002
   Revision: --H06---    CVN: EDBAE14200007164
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 3537281895C8DCC3045-8060
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 B
   Component: V552 ATFP  H02 0830
   Serial number: 2102201543
   Part No SW: 4M8 907 379 E    HW: 4M8 907 379 E
   Component: ESP9 Premium  H06 0040
   CVN: 6BA4B405
   Coding: 34AA6A9731A20B9E13A54C9A588091E2F43A892C568CD0C8321A89472F5C91
   ROD: EV_ESP9BOSCHCMP_AU58.rod
   VCID: 41DF4CC8D1006063A8D-8014
125440 - Function Restriction
          C10C2 F2 [032] - due to Excessive Brake Temperture
          [Brakes_overheated_during_active_braking_by_BMR_or_ACB.]
0298 - Control Module for Suspension
          U122B 00 [032] - Implausible Message
          [Signal_FDR_Sollgiermom_Vorsteuerung_TV_Error(1023)_or_Invalid(1021.1022)_or_PDU_FDR_05_not_received_correctly(combination_of_Timeout:_CS:_AC]
0297 - Databus
          [Signal_FDR_Sollgiermom_Vorsteuerung_TV_-Error(1023)]
13773569 - Control Module for Suspension
          [Signal_FDR_TV_SollRadDiff_Moment_error_(4095)_or_PDU_FDR_02_not_received_correctly_(combination_of_Timeout:_CS:_AC)]
12853509 - Databus
          [Signal_FDR_TV_SollRadDiff_Moment_error_(4095)]
452352 - Databus
          [Signal_RCTA_Status_error_(3)]
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Coding: 07000363C0291CDD070E57889CEF9C28130B37510406009701050A001B33160108690A028010000000000303004308180802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7AADFB24FC56F3BBA97-802E
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000002102180403988
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 41064630X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 16S15.02.2100692420
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00Y202
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR119122023310570
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 BE    HW: 4K0 947 135 BE
   Component: Dachmodul  H42 0416
   Serial number: A00341824
   Coding: 0D0101
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA146905000098119599
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BM02753890
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BM02753915
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BM04233560
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BM02753920
   Part No SW: 4K0 907 561 K    HW: 4K0 907 561
   Component: LRR4R         H12 0500
   Coding: D7659F5478082C00010360E00000003E4A1146484401409E15
   ASAM Dataset: EV_ACCBOSCHAU65X 002031
   ROD: EV_ACCBOSCHAU65X_AU58.rod
2359 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_SENSOR_DISTURBED]
                    Reset counter: 206
                    Mileage: 32754 km
                    Date: 2022.10.02
                    Time: 08:50:20
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 14.1 V
                    Vehicle speed: 5.30 m/s
                    Longitudinal acceleration: -0.81 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: -13.300 °
                    Yaw_rate-Data: -0.776 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.129 °
                    Misalignment angle: horiz: fast algorithm: -0.269 °
                    Congestion pilot: status: OFF
                    Outside temperature: 15.00 °C
                    Sensor blindness: radar: no blindness detected
   Part No SW: 4N0 959 655 AC    HW: 4N0 959 655 AC
   Component: AirbagVW31    H05 2844
   Serial number: 0031JM00D49S
   Coding: BFFCFCC000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 7DA7F038ED78C4838C5-8028
   Left seat belt tensioner:
   Serial number: 00AI2021069696600000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2021068749600000
   Coding: 04F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D21000F978I0X
   Coding: 303233
   Subsystem 4 - Part No SW: -----------    HW: 480 000 303 21
   Serial number: 35700000000A6A71905K
   Subsystem 5 - Part No SW: -----------    HW: 480 000 303 21
   Serial number: 3580000000042DC0715H
   Subsystem 6 - Part No SW: -----------    HW: 480 031 003 21
   Serial number: 351002C18ADACCB07E4$
   Subsystem 7 - Part No SW: -----------    HW: 480 031 003 21
   Serial number: 352002C18614D0F07801
   Subsystem 8 - Part No SW: -----------    HW: 480 031 003 21
   Serial number: 355002C1862A95D13ACL
   Subsystem 9 - Part No SW: -----------    HW: 480 031 003 21
   Serial number: 356002C18629D4A0EBBV
   Part No SW: 4N0 907 129 KF    HW: 4N0 907 129 KF
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 7F5B0A30E774D6939E9-802A
Address 17: Instruments (J285)       Labels: None-SRI2
   Part No SW: 4K0 920 890 E    HW: 4K0 920 890 E
   Component: FBenUSA------ H24 0056
   Coding: 0B6F49F17EA8CF05029067649800431008002000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 3039190C6AAAF9EB573-8064
   Part No SW: 4KL 907 468 C    HW: 4K1 907 468 C
   Component: Gateway       H07 0602
   Serial number: F0265944544911
   Coding: 02030001000406405496000000590132FC9A00C8980000000900008E00000000
   GVL: F1597C580800000002DC88008100C800110C0070010000000000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003220
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 50F9798C0A6A99EB373-8004
   Subsystem 1 - Part No SW: 4K0 951 523 K    HW: 4K0 951 523 K
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863130021022601DE
   Subsystem 3 - Part No SW: 4KE 419 508 B    HW: 4KE 419 508 B
   Component: J1158 KLR  H03 0007
   Serial number: 21025001803S0007H034
262671 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BC_MFA]
                    Reset counter: 210
                    Mileage: 32914 km
                    Date: 2022.10.03
                    Time: 07:49:52
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Fault Frequency: 19
                    Reset counter: 209
                    Mileage: 32599 km
                    Date: 2022.09.27
                    Time: 21:57:26
                    EM_vehicle_state: 00 00
                    Total static current-current total quiescent current: 88 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
16711990 - Ethernet Databus Branch 1
          U122C 00 [008] - No Communication
          [Ethernet_databus_no_communication_port_1]
                    Fault Frequency: 14
                    Reset counter: 203
                    Mileage: 27565 km
                    Date: 2022.08.15
                    Time: 14:49:07
                    Ethernet counter checksum error: branch 1: 0
                    Ethernet counter connection interruptions: branch 1: 1
   Part No SW: 4N0 907 144 D    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0803
   Serial number: 30303030303030
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2F3B1A707794E6134E9-807A
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 A    HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0070
   Revision: 5WK12701    Serial number: 605109301200507
   Coding: 0300
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: 3A2D3B24BCD633BBE97-806E
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000434598171
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   VCID: 7BA3FE20F36CCAB3B21-802E
   Part No SW: 4N0 907 566 AL    HW: 4N0 907 566 A
   Component: MRR_HR H24 0587
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 005989CC9A8AA96BE73-8054
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS003 0430
   Serial number: YE007UBG05632
   Coding: 001DCB0152001280A009A032
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 46D55FD4F82E475B9DF-8012
   Coding: E1002101010001
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D130464A6CBFB217-8066
   Part No SW: 4N0 907 064 EP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0224
   Coding: 013400004FB100C0650FA0046C05880203004000810426502F0400000F04823F001E0681011F35
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   VCID: 015F8CC89180A063E8D-8054
   ID - sensor:
   Serial number: 000000000ZY210201EDT
   Serial number: 00000000000034374945
   left tail lamp 1:
   Subsystem 4 - Part No SW: 4K0 945 217 A    HW: 4K0 945 217 A
   Component: SHL_li1  006 0002
   Serial number: 00000000000003269377
   Subsystem 5 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38517022
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4K5 945 093 E    HW: 4K5 945 093 E
   Component: SHL_li2  004 0002
   Serial number: 00000000000003526771
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4K0 945 218 A    HW: 4K0 945 218 A
   Component: SHL_re1  006 0002
   Serial number: 00000000000003640895
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4K5 945 094 E    HW: 4K5 945 094 E
   Component: SHL_re2  004 0002
   Serial number: 00000000000003579900
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS003 0430
   Serial number: YE007UB212183
   Coding: 001DCB015E001280A009A030
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 45D758D8C5284C43945-8010
   Part No SW: 4M2 035 092 A    HW: 4M2 035 092
   Component: MU-TP-NS-US   042 3385
   Serial number: GRO-63306.03.21
   Coding: 15820010804100000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU58.rod
   VCID: 270BF2505F64BE53869-8072
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4K0 919 605 J    HW: 4K0 919 605 F
   Component: DU AU58x Top   H31 0055
   Serial number: INX00103012100220812
   Subsystem 2 - Part No: V03 959 808 M
   Component: MIB3_NA_2022.  0796
   Compact disc data bank:
   Component: Gracenote2     3004
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4K0 919 603 J    HW: 4K0 919 603 F
   Component: DU AU58x Bot   H31 0054
   Serial number: INX00104012100241010
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007521000032177042
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU   H11 0100
   Serial number: HHA-07314.03.2134860
7219 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Frequency: 8
                    Reset counter: 194
                    Mileage: 30389 km
                    Date: 2022.08.29
                    Time: 15:57:54
                    BAP: 10
                    Voltage terminal 30: 15.2 V
Address 61: Battery Regul. (J1120)       Labels: 4M0-915-105.clb
   Part No SW: 4N0 915 105 D    HW: 4N0 915 105 D
   Component: BMS_48V_LiIon H09 0206
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 2B030E60438C9A33621-807E
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0010
   Serial number: 30000000089242
   ROD: EV_RDKHUFAU736_AU58.rod
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 1270
   VCID: 3431151C9EB2C5CB33B-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4K0 907 777 CA    HW: 4K0 907 777 C
   Component: Fahrwerk-SG   H53 2135
   Serial number: 2602210941
   Coding: 746C5040DA44
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 78A9E12CC25AE1ABDF3-802C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132278306
   Coding: 303030
3342339 - Function block
          B2003 00 [008] - -
          [Function_block_normal_level_narrow_control_tolerance]
                    Reset counter: 209
                    Mileage: 32914 km
                    Date: 2022.10.02
                    Time: 22:04:50
                    Internal DTC: 102
196609 - Basic Setting of Deflected Position not Performed
          C10C5 00 [137] - -
                    Reset counter: 169
                    Mileage: 32914 km
                    Date: 2022.10.02
                    Time: 22:03:35
                    Internal DTC: 837
   Part No SW: 4KE 035 283 A    HW: 4KE 035 283 B
   Component: CB_H_NAR      041 0236
   Serial number: A971C0MS157931
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU58.rod
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K1 713 041 J    HW: 4K1 713 041 H
   Component: GSM-LL H15 0051
   Serial number: 21.062 40688
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2A0D0B644C76833B997-807E
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4K1 919 617 C    HW: 4K1 919 617 C
   Component: HeadupDisplay H12 5951
   Coding: 4700E2
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_AU58.rod
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 G    HW: 4K4 907 117
   Component: zFAS Var C    H09 0366
   Coding: 020188000000000000FBD60000F4D50E139F7200000000D8000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000098D00080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003_AU58.rod
   VCID: 333316009BBCC2F32A1-8066
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 4K0 907 159 E    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 210216200817
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS005 0430
   Serial number: YE007UBG19543
   Coding: 000DC90100001280E008A020
   VCID: 48C951ECF23A512B6F3-801C
   Component: TSG HBFS005 0430
   Serial number: YE007UBG18415
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC21084001209
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75B7E818D5489CC3C45-8020
   Coding: 268040058203
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_
   Coding: 42244200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 392F2428B9D038A3E0D-806C
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N0 903 028 R    HW: 4N0 903 028 R
   Component: BSG-HP1-65    H19 0527
   Serial number: 25062200030054
   Coding: 30000400000000
   Shop #: WSC 14095 006 1048576
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H24 0587
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
   Part No SW: 4K0 941 592 AC    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFDC08A120B0E318D-8024
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 AL    HW: 4N0 907 669 A
   Component: MRR_VR H24 0587
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 045185DC8E92B54BC3B-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H24 0587
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Coding: 229000058204
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_009_AU58.rod
   VCID: 76B5EF14C84E97DBCDF-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 2019E94C3A4A496BC73-8074
End----------(Elapsed Time: 02:31, VBatt start/end: 12.3V/12.3V)-----------
Ziddywerks
Northern NJ USA
C?ID=208579
If you did a full reset on the air suspension instead of a relearn for height to lower it you may be SOL. As you will need to raise the car to lift all 4 wheels off the ground to set some of those basic settings. Let's hope you only did the basic change.
C8RS6
Georgia, USA
C?ID=70901
@EuroX, thank you. I have a lift. What would I do?
Ziddywerks
Northern NJ USA
C?ID=208579
I would run basic setting to relearn the system. Should be a number of test plans in VCDS to do so. I'm sure there will be dampner basic settings and so on. I don't have VCDS in front of me but the test plans should be in there IIRC.
C8RS6
Georgia, USA
C?ID=70901
The only test I'm able to run was "system function test". All the other ones say error request out of range
oripaamoni
San Diego, CA, USA
C?ID=555497
I am sure you got this figured out by now but I think the final step is to go to "Basic settings" and select - "IDE09283-MAS00675 - Switch to normal level control function." then "Go" to bring you out of the service mode.
