How to get the Data set to update
jhuber
C?ID=346551
Hello!
My HEX-NET versions are:
CB: V0.4623
FW: 0.257
CFB: 0.10
BL: 0.28
DS: 30000060
According to the first post in the Current Versions thread , the dataset should be 60000055. How do I get the dataset to update? In VCDS Mobile (Web interface), when I check for updates, it says that the HEX-NET is up to date. The PC version says the same thing.
Thanks!
Zenerdiode
Newcastle, England
C?ID=24330
You ignore the first digit, that’s for internal use. You’re at DS 60 (higher than 55 on Current Versions) so I suspect the Current Versions thread needs to be updated.
You’re all good :thumbs:
jhuber
C?ID=346551
Thank you all!!
alexnoe
Taufkirchen, Germany
C?ID=418771
Is it normal that I have data set version 62?
Shaun
You have 62 because you were testing updates from the alpha channel which has later versions than release.
alexnoe
C?ID=418771
Here, you explain that this is a problem in connection with ASAM update. Well, could this be the same issue?
Shaun
Probably, are you trying to get rods right now? I could put your interface back on the alpha channel.
alexnoe
C?ID=418771
I wasn't specificially trying now, I just happened to make the connection when reading through current threads, but yes, please put me on the alpha channel again, then I'll retry, probably tomorrow or the day after.
Shaun
Done
alexnoe
C?ID=418771
It worked. After an auto scan, it downloaded about 1,3 MB of data. Before reputting me on the alpha channel, this download was repeated over and over. This time, the second auto scan worked without telling me that another download was necessary.
When accessing the engine control unit, it downloaded more data, but after that, I was able to access even advanced measurement values.
Basicly, this implies that once someone was on the alpha channel, leaving the alpha channel doesn't really work well :/
You might have a point there, at least until Release or Beta has caught up to whatever version was on Alpha when the interface was put on Alpha...?
