VW T5.1 CAAB Transporter Starting Problems
Iann41
C?ID=518535
It's taking ages to start the transporter van I have. As if it was starved of diesel. At first, I thought it was the fuel pump relays, but I bought a couple and swapped these about with no improvement. I noticed that the tank lift pump didn't seem to turn on when the ignition was turned on. I understand that it runs for several seconds. Also, the auxiliary fuel pump doesn't seem to work. I have checked both pumps and both work when 12v is fed to them. This also ruled out the wiring loom. I have also tested the amount of fuel each pump moves, and this seems normal. Also, cracked open an injector just to see if fuel is reaching these and all seems fine. I have bought a ross tech vcds to test and check live reading concerning the fuel system but from what I can see, it's all ok. Originally, I had several fault codes but when cleared, the vcds said that everything was ok with no faults. I am leaning to it being either the fuel stop valve (think this is what it's called) or the ECU. More ECU as the problems with the fuel pumps is a mystery. Any advice welcome. I'm running out of ideas. Thanks.
Post a FULL vehicle scan and include the VIN, don’t include the UK reg.
Iann41
C?ID=518535
First scan
Thursday,22,September,2022,17:14:07:17157
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WV1ZZZ7HZCH012351   License Plate:
Mileage: 75190km-46720mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZCH012351   Mileage: 75190km-46720miles
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CD    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H42 9118
   Revision: 26H42---    Serial number: 00000000000000 CVN: 56607A21
   Coding: 01114010230400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906022CD 002013
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 698FB353B9FDD21350D-803C
   VINID: 9E606AAAA1D8A936000420C504B4635B63
4978 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [036] - Electrical Malfunction
                    Mileage: 75197 km
                    Engine RPM: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.080 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 0 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 80
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 1
                    Glow cycles below temperature threshold-Bits 0-7: 9
                    Glow cycles below temperature threshold-Bits 0-7: 154
                    Outside temperature: 20.0 °C
5196 - Relay for Fuel Pump 2 (J49)
          P2632 00 [036] - Open Circuit
                    Fault Frequency: 15
                    Mileage: 75197 km
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.420 V
                    Engine status: COENG_STANDBY
                    Fuel temperature: 19.0 °C
                    Mean injection quantity: 0.00 mg/stroke
                    Fuel Metering Valve: 26.48 %
                    Fuel Pressure Regulator Valve: 9.81 %
                    Fuel high-pressure: actual value: 5000 hPa
                    Control Module temperature: -2.0 °C
5200 - Fuel Pump Relay Control Circuit
          P0627 00 [036] - Open Circuit
                    Fault Frequency: 13
                    Mileage: 75197 km
                    Coolant temperature: 16 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 10.100 V
                    Engine status: COENG_READY
                    Fuel temperature: 15.3 °C
                    Fuel Metering Valve: 33.86 %
                    Fuel Pressure Regulator Valve: 12.12 %
                    Fuel high-pressure: actual value: 6200 hPa
4661 - Relay for Aux Coolant Pump (J496)
          P1927 00 [036] - Open Circuit
                    Fault Frequency: 16
                    Mileage: 75197 km
                    Date: 2022.09.22
                    Time: 00:09:20
                    Voltage terminal 30: 12.360 V
                    Engine status: COENG_FINISH
                    Limitation: accelerator pedal: 92.5 Nm
                    Exhaust gas temperature sensor 1: 51.4 °C
                    Control Module temperature: 27.6 °C
4713 - No Communication with ABS Brake Control Module
          U0121 00 [036] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Mileage: 75197 km
                    Date: 2022.09.22
                    Time: 00:16:15
                    Intake air temperature: 18 °C
                    selected gear-Bits 0-7: 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 708724AD89A50E9724A59176A95F10
   Shop #: WSC 02736 790 49152
   VCID: 372B252BBF49B4E3169-8062
                    Reset counter: 95
                    Mileage: 73797 km
                    Date: 2014.08.15
                    Time: 15:12:17
                    Count: 16512
                    Count: 2305
                    Count: 128
                    Count: 764
                    Reset counter: 82
                    Mileage: 75197 km
                    Date: 2017.02.12
                    Time: 00:05:12
                    Count: 16384
                    Count: 1
                    Count: 8194
                    Count: 512
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0251
   Revision: BM047001    Serial number: 0428 169110644
   Coding: A0A0303A0E212031002008102C2B8C500000430F60060000300000000000
   Shop #: WSC 02734 790 00000
   VCID: 38292617B257BB9B1F3-806C
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
11 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
                    Fault Status: 00101011
                    Reset counter: 122
03435 - Terminal 30 for Interior Light and Parking Light
                    Reset counter: 115
03301 - Response Closing Status of Drivers Door
                    Reset counter: 93
                    Mileage: 73797 km
                    Date: 2015.09.05
                    Time: 03:38:58
03302 - Response Closing Status of Passenger's Door
                    Fault Frequency: 19
                    Reset counter: 94
                    Mileage: 73796 km
                    Date: 2014.07.16
                    Time: 10:33:52
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 136
                    Reset counter: 104
                    Mileage: 67821 km
                    Date: 2018.06.16
                    Time: 07:56:22
03442 - Return Message Closing Status of Rear Lid
                    Reset counter: 89
                    Mileage: 73797 km
                    Date: 2015.08.15
                    Time: 00:36:36
                    Reset counter: 122
                    Reset counter: 94
                    Reset counter: 122
                    Reset counter: 94
                    Date: 2014.07.16
                    Time: 10:33:50
00538 - Reference Voltage
                    Reset counter: 122
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL0063U93
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35372F23A5C546F3045-8060
12656896 - Databus
          [Bremse8 Time Out Error]
                    Reset counter: 122
                    Mileage: 75197 km
                    Date: 2022.09.22
                    Time: 00:16:15
   Part No SW: 7E0 920 960 E    HW: 7E0 920 960 E
   Component: KOMBI         H03 0305
   Coding: 460200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2B03095B73810003621-807E
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 122
                    Mileage: 75197 km
                    Date: 2022.09.22
                    Time: 16:33:11
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 92
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0251
   Revision: BM047001
   Coding: 042300
   VCID: 70B9DE379AA723DB173-8024
                    Reset counter: 94
                    Mileage: 73797 km
                    Date: 2016.03.23
                    Time: 02:13:56
                    Reset counter: 122
                    Mileage: 75197 km
                    Date: 2017.02.12
                    Time: 00:05:13
                    Reset counter: 122
                    Mileage: 75197 km
                    Date: 2017.02.12
                    Time: 00:16:17
   Component: IMMO          H03 0305
   VCID: 6A8DCC5FBCFBD90B597-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 73796 km
                    Date: 2020.03.24
                    Time: 09:05:25
   Part No SW: 7E0 035 156 A    HW: 7E0 035 156 A
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1K0731775
   Coding: 0000020001
   VCID: 211FEB7301CDDA53C8D-8074
                    Fault Status: 00110010
                    Reset counter: 89
                    Mileage: 73797 km
                    Date: 2014.08.15
                    Time: 15:12:33
00856 - Radio Antenna
                    Fault Status: 00110111
                    Fault Frequency: 22
                    Reset counter: 114
                    Date: 2064.00.00
                    Time: 00:00:02
                    Fault Status: 01111011
                    Fault Frequency: 73
                    Reset counter: 82
                    Mileage: 67800 km
                    Date: 2018.06.15
                    Time: 10:14:36
                    Reset counter: 89
                    Mileage: 73796 km
                    Date: 2014.08.14
                    Time: 21:15:58
End----------(Elapsed Time: 01:21, VBatt start/end: 12.1V/12.1V)-----------
Iann41
C?ID=518535
scan after codes have been cleared
Friday,23,September,2022,12:50:01:17157
   Revision: 00H43001
   Coding: 460200
   Revision: BM047001
   Coding: 042300
   Coding: 0000020001
                    Reset counter: 82
                    Mileage: 75197 km
                    Date: 2017.02.13
                    Time: 03:26:55
End----------(Elapsed Time: 01:07, VBatt start/end: 12.7V/12.6V)-----------
Iann41
C?ID=518535
sorry about the long script, but i couldn't do the code thingy in the video and this was the only way to post the fault codes.
iichel
Eindhoven, NB, NL
C?ID=284912
that's fine. does it start now?
Some nice chap will come along and wrap it for you later. Now you need to run it for a few days with the fault reoccuring and then do a reread. One of the original codes suggested a poor battery.
Iann41
C?ID=518535
Thank you to whoever 'wrapped' the fault codes above. Battery is new but it did need a little charging as it's getting drained with the long cranking to get the van started. I'll post in a few days' time if any fault codes appear. The van still takes ages to start but when it does it drives ok with no issues.
Iann41
C?ID=518535
The van is now sorted, I think. It turned out to be sticky injectors when cold. I had two options, new injectors or injector cleaner. Injector cleaner sorted the problem. I think this was due to the van being stood a few years because of the covid con and the biodiesel in the fuel going off. Thanks for any help and good luck with your problems.
JMR
Romania
C?ID=432218
preach it ! :D
:thumbs:
