Resolved Seat ibiza 2.0 fr 2010 - ABS lost coding (ESP8.2i)
Resolved
wallyscarclinic
wales
C?ID=445482
need coding for this vehicle - ill post vin tomorrow
heres full scan swapped over ecu & key kit - vin below may be wrong ill double check tomorrow
Tuesday,27,September,2022,10:44:27:01218
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: VSSZZZ6JZBR035472   License Plate: SA60 ZHW
Mileage: 166590km-103514mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZBR035472   Mileage: 166590km-103514miles
4B-Multifunc. Module -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFHD)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CR    HW: 03L 906 018 A
   Component: R4 2,0L EDC   H21 6750
   Revision: 43H21---    Serial number:                CVN: 2FE011DC
   Coding: 00190012042500080000
   ASAM Dataset: EV_ECM20TDI01103L906018CR 003003
   ROD: EV_ECM20TDI01103L906018A_003.rod
   VCID: 7CA1FDAAC66B2BCBBBB-8028
   VINID: 9A38EAAAA19AA928800C510708C6EA8BD6
4891 - EGR Valve (N18)
          P0403 00 [036] - Malfunction
                    Mileage: 166597 km
                    Date: 2022.09.14
                    Time: 21:20:53
                    Engine RPM: 859.50 /min
                    Normed load value: 42.4 %
                    Coolant temperature: 14 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 13.280 V
                    Air mass: actual value (mg/stroke): 273.4 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 88.99 %
                    EGR valve: offset closed: 6.77 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    High press EGR actuator: actual unconditioned volt val: 1126.8 mV
4892 - EGR Valve (N18)
          P0403 00 [172] - Malfunction
                    Mileage: 166597 km
                    Date: 2022.09.14
                    Time: 02:52:13
                    Engine RPM: 780.50 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 22 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.760 V
                    Air mass: actual value (mg/stroke): 382.2 mg/stroke
                    EGR Solen.val.: actual value: 74.83 %
                    High press EGR actuator: actual unconditioned volt val: 1552.0 mV
Readiness: 1 1 0 0 1
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 04941 000 00000
   VCID: 06559F428867611BDDF-8052
                    Reset counter: 189
                    Mileage: 166597 km
                    Date: 2017.02.04
                    Time: 21:32:55
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x1013
                    Hex Value: 0x149D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Reset counter: 189
                    Mileage: 166597 km
                    Date: 2017.02.04
                    Time: 21:32:55
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x1051
                    Hex Value: 0x1B9D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 189
                    Mileage: 166597 km
                    Date: 2017.02.17
                    Time: 01:02:08
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x10E1
                    Hex Value: 0x2089
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Reset counter: 229
                    Mileage: 164783 km
                    Date: 2017.07.16
                    Time: 00:03:55
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x10FD
                    Hex Value: 0x2598
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
03306 - Coding Not Valid
                    Reset counter: 229
                    Mileage: 166597 km
                    Date: 2017.02.17
                    Time: 01:10:42
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x10E7
                    Hex Value: 0x2597
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7D00
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 B    HW: 6J0 820 043 B
   Component: Climatronic   H07 0505
   Revision: S0000000
   VCID: 2313E6D61BD5B433DA1-8076
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 189
                    Mileage: 166597 km
                    Date: 2017.02.04
                    Time: 02:52:27
                    Fault Status: 00101001
                    Fault Frequency: 48
                    Reset counter: 229
                    Mileage: 166597 km
                    Date: 2017.02.17
                    Time: 01:02:24
   Part No SW: 6R0 937 087 F    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0221
   Revision: BF046001    Serial number: 0345 187100950
   Coding: 248829E888612500922000007E0B1CC80080400F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 40D9495AEA838F2BA73-8014
   Subsystem 1 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3130
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3130
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Component: LIN BACKUP HO  H11 9004
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10AirbagA03 H08 0020
   Revision: --------    Serial number: 003GZ00026FY
   Coding: 003033
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4CC16D6AD64B5B4B4BB-8018
   Serial number: 3495RRB40636SD5ODGF4
   Serial number: 3505RRB404V6R0C299CM
   Part No SW: 6J0 920 902 C    HW: 6J0 920 902 C
   Component: KOMBI         H05 0404
   Coding: 410A00
   VCID: 290FF4FE79796E6390D-807C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 422100
   VCID: 70B9D99A9AA35FAB173-8024
03590 - Control Module for Multifunction Module
                    Reset counter: 189
                    Mileage: 166597 km
                    Date: 2017.02.04
                    Time: 02:52:31
   Component: IMMO          H05 0404
   VCID: 6A8DCBF2BCFFA57B597-803E
   Part No SW: 6J0 035 342 C    HW: 6J0 035 342 C
   Revision: A1001003    Serial number: 7668164690
   Coding: 020000
   VCID: 2411E5CA1EDBB30BA3B-8070
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10121
   Shop #: WSC 06403
   VCID: 2E0507E24957095B45F-807A
00816 - Power Steering Sensor (G250)
            30-00 - Open or Short to Plus
Address 4B: Multifunc. Module
Address 56: Radio (J503)       Labels: None
   Part No SW: 6J2 035 153 C    HW: 6J2 035 153 C
   Component: Radio         H05 0107
   Revision: R0000000    Serial number: SEZAZ2K9504784
   Coding: 0001040002
   VCID: 2615FFC268E7411BBDF-8072
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668223967
   Coding: 0200000001010110
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 323D139254AF2DBB217-8066
End----(Elapsed Time: 01:57, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
I don't suppose you scanned it before you "swapped over ecu & key kit"? Check your Scans sub-folder.
wallyscarclinic
wales
C?ID=445482
i didnt do a full scan before changing over -
s p autos
C?ID=496129
if you still have old pump plug it back in and read all fault cods and save it this will have all the coding you can just swap over the coding and work shop code
wallyscarclinic
wales
C?ID=445482
vin - VSSZZZ6JZBR025010
wallyscarclinic
wales
C?ID=445482
s p autos
C?ID=496129
you will most likely need to do some basic settings as well is the pump old or new
wallyscarclinic
wales
C?ID=445482
the pump havent been changed and was working fine before, while everything been swapped over - coding was lost for the abs
s p autos
C?ID=496129
wallyscarclinic
wales
C?ID=445482
someone has been messing around with its coding then is your new unit old or brand new
old unit its only lost it since everything been swapped around - strange as i havent had this problem before
s p autos
C?ID=496129
you will need the coding wizards on hear then hopefully they can help you
wallyscarclinic
wales
C?ID=445482
ok hopefully they will see my post :-)
iichel
Netherlands, eastern part
C?ID=284912
wallyscarclinic
wales
C?ID=445482
Thanks guys im away from tomorrow i will try when im backing fingers crossed it be ok 😂
etz2k
C?ID=69430
130248DB837000B7C82912E9C1D300821700
The only difference is in the second to last byte, I gave the XDS diff for free :-)
The autoscans of german Ibiza 2.0TDI that i found show XDS activated, but UK models not, the other bits are all the same or i'm wrong?
  • Informative
