need coding for this vehicle - ill post vin tomorrow
heres full scan swapped over ecu & key kit - vin below may be wrong ill double check tomorrow
Tuesday,27,September,2022,10:44:27:01218
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: VSSZZZ6JZBR035472 License Plate: SA60 ZHW
Mileage: 166590km-103514mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZBR035472 Mileage: 166590km-103514miles
4B-Multifunc. Module -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFHD) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CR HW: 03L 906 018 A
Component: R4 2,0L EDC H21 6750
Revision: 43H21--- Serial number: CVN: 2FE011DC
Coding: 00190012042500080000
ASAM Dataset: EV_ECM20TDI01103L906018CR 003003
ROD: EV_ECM20TDI01103L906018A_003.rod
VCID: 7CA1FDAAC66B2BCBBBB-8028
VINID: 9A38EAAAA19AA928800C510708C6EA8BD6
4891 - EGR Valve (N18)
P0403 00 [036] - Malfunction
Mileage: 166597 km
Date: 2022.09.14
Time: 21:20:53
Engine RPM: 859.50 /min
Normed load value: 42.4 %
Coolant temperature: 14 °C
Intake air temperature: 13 °C
Voltage terminal 30: 13.280 V
Air mass: actual value (mg/stroke): 273.4 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 88.99 %
EGR valve: offset closed: 6.77 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 7
High press EGR actuator: actual unconditioned volt val: 1126.8 mV
4892 - EGR Valve (N18)
P0403 00 [172] - Malfunction
Mileage: 166597 km
Date: 2022.09.14
Time: 02:52:13
Engine RPM: 780.50 /min
Normed load value: 34.5 %
Coolant temperature: 22 °C
Intake air temperature: 16 °C
Voltage terminal 30: 13.760 V
Air mass: actual value (mg/stroke): 382.2 mg/stroke
EGR Solen.val.: actual value: 74.83 %
High press EGR actuator: actual unconditioned volt val: 1552.0 mV
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Shop #: WSC 04941 000 00000
VCID: 06559F428867611BDDF-8052
Fault Frequency: 10
Reset counter: 189
Mileage: 166597 km
Date: 2017.02.04
Time: 21:32:55
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x1013
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Status: 01100101
Fault Frequency: 10
Reset counter: 189
Mileage: 166597 km
Date: 2017.02.04
Time: 21:32:55
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x1051
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Frequency: 6
Reset counter: 189
Mileage: 166597 km
Date: 2017.02.17
Time: 01:02:08
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x10E1
Hex Value: 0x2089
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Reset counter: 229
Mileage: 164783 km
Date: 2017.07.16
Time: 00:03:55
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x10FD
Hex Value: 0x2598
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
Fault Frequency: 6
Reset counter: 229
Mileage: 166597 km
Date: 2017.02.17
Time: 01:10:42
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x10E7
Hex Value: 0x2597
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7D00
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6J0 820 043 B HW: 6J0 820 043 B
Component: Climatronic H07 0505
Revision: S0000000
VCID: 2313E6D61BD5B433DA1-8076
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 189
Mileage: 166597 km
Date: 2017.02.04
Time: 02:52:27
Fault Status: 00101001
Fault Frequency: 48
Reset counter: 229
Mileage: 166597 km
Date: 2017.02.17
Time: 01:02:24
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 187100950
Coding: 248829E888612500922000007E0B1CC80080400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 40D9495AEA838F2BA73-8014
Subsystem 1 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3130
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3130
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10AirbagA03 H08 0020
Revision: -------- Serial number: 003GZ00026FY
Coding: 003033
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4CC16D6AD64B5B4B4BB-8018
Serial number: 3495RRB40636SD5ODGF4
Serial number: 3505RRB404V6R0C299CM
Part No SW: 6J0 920 902 C HW: 6J0 920 902 C
Component: KOMBI H05 0404
Coding: 410A00
VCID: 290FF4FE79796E6390D-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 422100
VCID: 70B9D99A9AA35FAB173-8024
03590 - Control Module for Multifunction Module
Reset counter: 189
Mileage: 166597 km
Date: 2017.02.04
Time: 02:52:31
Component: IMMO H05 0404
VCID: 6A8DCBF2BCFFA57B597-803E
Part No SW: 6J0 035 342 C HW: 6J0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668164690
Coding: 020000
VCID: 2411E5CA1EDBB30BA3B-8070
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10121
Shop #: WSC 06403
VCID: 2E0507E24957095B45F-807A
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
Address 4B: Multifunc. Module
Address 56: Radio (J503) Labels: None
Part No SW: 6J2 035 153 C HW: 6J2 035 153 C
Component: Radio H05 0107
Revision: R0000000 Serial number: SEZAZ2K9504784
Coding: 0001040002
VCID: 2615FFC268E7411BBDF-8072
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668223967
Coding: 0200000001010110
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323D139254AF2DBB217-8066
End----(Elapsed Time: 01:57, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
