09MK6
Hello everyone,
lost my abs module a while back and finally got around to replacing it unfortunately could not get communication with the old one to get the code for it.
Sunday,25,September,2022,16:30:33:55947
VCDS Version: 22.9.0.0 (x64)
VIN: 3VWRZ71K19M015295 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K19M015295 Mileage: 119160km-74042miles
62-Door, Rear Left -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 M HW: 07K 906 055 M
Component: 2,5l R5/4V G 9203
Revision: G6H01--- Serial number: VWX7Z0H62480DL
Coding: 0000075
Shop #: WSC 22207 444 11729
VCID: 387F78494B89004DBB-806C
VINID: 0E69E2A8705B04974004508914C34BE8BE
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 119169 km
Time: 22:41:25
RPM: 703 /min
Load: 31.4 %
Temperature: 71.0°C
Temperature: 40.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.081 V
Readiness: 0010 0101
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: 7DF1A95D242BE56528-8028
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 12699 003 1048576
VCID: 76E3B671C11DB63D69-8022
Fault Status: 01100101
Reset counter: 26
Mileage: 119169 km
Count: 7
Count: 12800
Count: 279
Count: 50176
Reset counter: 26
Mileage: 119169 km
Count: 7
Count: 12800
Count: 295
Count: 50176
Reset counter: 26
Mileage: 119169 km
Count: 7
Count: 12800
Count: 270
Count: 50176
Reset counter: 26
Mileage: 119169 km
Count: 7
Count: 12800
Count: 195
Count: 49920
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CF7A4593F31EC6D1F-8028
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000001002956
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 6FED83157E4787F5AA-803A
Component: Wischer 150708 021 0501
Coding: 00038805
Shop #: WSC 00066
Fault Status: 01101100
Reset counter: 30
Mileage: 119169 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
Fault Frequency: 12
Reset counter: 30
Mileage: 119169 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0361534
Coding: 0000100
VCID: 33654F6552EFE3158E-8066
Reset counter: 26
Mileage: 119169 km
Time: 22:41:31
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05Y173
Coding: 0013889
VCID: 6CD794194F517CED8F-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME106D62425
Subsystem 3 - Serial number: 6342MSME290503742
Subsystem 4 - Serial number: 6351HSME16264612
Subsystem 5 - Serial number: 6361HSME1627030A/
Subsystem 6 - Serial number: 63727SME15570F733
Subsystem 7 - Serial number: 63827SME15586D78E
004 - No Signal/Communication - Intermittent - MIL ON
01588 - Igniter for Head-Airbag; Drivers Side (N251)
00590 - Igniter 2 for Passenger Airbag (N132)
00589 - Airbag Igniter 1; Passenger Side (N131)
01217 - Side Airbag Igniter; Driver Side (N199)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 0305DFA542CF93955E-8056
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H62480DL
Coding: 0023203
Shop #: WSC 26085 444 54622
VCID: 3C7764597FB12C6D5F-8068
Reset counter: 66
Mileage: 119169 km
Time: 22:41:20
00771 - Fuel Level Sensor (G)
Fault Status: 00100011
Reset counter: 69
Mileage: 119169 km
Time: 22:23:21
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 87071 km
Time: 00:00:39
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 250508F1002233
Coding: ED807F060003021002
Shop #: WSC 00066 123 12345
VCID: 3561717D5C9BFD25A0-8060
Fault Status: 00110100
Reset counter: 66
Mileage: 119169 km
Time: 22:41:21
Reset counter: 25
Mileage: 119169 km
Time: 22:41:21
Fault Frequency: 11
Mileage: 119169 km
Time: 15:25:24
Component: IMMO 3HL 1222
Shop #: WSC 26085 444 999999
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36637671419DF63DA9-8062
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B52018525A2DD3D-807E
Reset counter: 76
Mileage: 119169 km
Time: 22:42:57
Voltage: 13.38 V
DU
Temperature: 45.0°C
RPM: 694 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186083E2904058FB0880F0488DCA0
VCID: 0407DCB947C194AD67-8050
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000799088707
Coding: 0001204
VCID: 70EF80696379980DB3-8024
Fault Status: 00100101
Reset counter: 66
Mileage: 119169 km
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2215587
Coding: 0010401
VCID: 2959AD0D8023A9C534-807C
Address 62: Door, Rear Left
Component: RDK 0450
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 66
Mileage: 119169 km
Time: 22:43:33
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003277505
Coding: 0001168
VCID: 77FDBB750617CF3572-8022
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 30
Mileage: 119169 km
End-------------------------(Elapsed Time: 01:59)--------------------------
