Resolved Data bus error Stg.A5 after Lane Assist retrofit
Resolved
flowistade
Hamburg, Germany
C?ID=313259
hey (:
I replaced the windscreen on my Passat Bj.08.2015 to retrofit the Lane Assist as well as DLA/FLA and VZE, so far everything has worked well.
I installed the kufatec cable set according to the instructions provided, I got the front camera with the part number 3Q0 980 654H from Aliexpress and I think it was new, but I did not use the cable set supplied from Aliexpress because the complete cable and pins are on it to the canbus 2 for the acc sensor are missing.
I flashed the data set from the Passat to the camera with VCP and everything went great.
However, now I have the problem that an error in the stg A5 cannot be deleted, the error with the calibration is normal because the camera has not yet been calibrated, but the error local data bus missing message (timeout RDR1_Header)
Can't be erased and keeps coming back. The error with the calibration is normal, I think because the camera has not yet been calibrated,
I've attached a VCDS autoscan.
Can this be due to incorrect coding or a lack of customization?
Would be cool if there is a solution for that.
Have a nice weekend and best regards
Freitag,23,September,2022,18:57:48:51172
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 11 x64
VCDS Version: MFT 22.3.1.7  HEX-V2 CB: 0.4615.4
Datenstand: 20220523 DS338.0
www.VCDS-Shop.de
Fahrzeug-Ident.-Nr.: WVWZZZ3CZGE046595   KFZ-Kennzeichen: FX239
Kilometerstand: 149045km   Reparaturauftrag:
Fahrzeugtyp: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 42 44 47
          52 55 5F 6C 6D A5 BB BC
Fahrzeug-Ident.-Nr.: WVWZZZ3CZGE046595   Kilometerstand: 149045km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
14-Raddämpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: Fehler 0010
BB-Türelektronik hinten links -- Status: i.O. 0000
BC-Türelektronik hinten rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CUAA)       Labeldatei:. DRV\03N-906-026-CUA.clb
   Teilenummer SW: 03N 906 026 E    HW: 03N 907 309
   Bauteil: R4 2.0l BTD   H23 2114
   Revision: A1H23---    CVN: 4C1431C438D3FF82
   Codierung: 0125001A036605083000
   Betriebsnr.: WSC 45195 182 00000
   ASAM Datensatz: EV_ECM20BTD01103N906026E 001004
   ROD: EV_ECM20BTD01103N906026E.rod
   VCID: 2D06F8629D9D402354A-8078
   VINID: 9E69EAAAA0D3A97540106149146A2A89B7
Kein(e) Fehlercode(s) gefunden.
Readiness: 1110 1011
Adresse 02: Getriebe (J743)       Labeldatei: DRV\0BH-927-711.clb
   Teilenummer SW: 0DL 300 012 F    HW: 0BH 927 711 F
   Bauteil: GSG DQ500     H10 5301
   Revision: 00H10V01    CVN: 9F13DE08
   Codierung: 0014
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_TCMDQ500021 001001
   VCID: 2C00F566A687492B434-8078
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\5Q0-907-379-IPB-V1.clb
   Teilenummer SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Bauteil: ESC           H42 0723
   Revision: 00000000    Seriennummer: 61965000001033
   Codierung: 0FEC6B8F54240B72077C070941C869F0D62AD0E0E08296F5186250F8C209
   Betriebsnr.: WSC 00015 115 08193
   ASAM Datensatz: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7AAC033E1C53279B818-802E
Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5Q0-959-435.clb
   Teilenummer SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Bauteil: VWKESSYMQB    026 0709
   Revision: 00026000    Seriennummer: 0374935086
   Codierung: 000F0F0703
   Betriebsnr.: WSC 05311 115 00303
   ASAM Datensatz: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 392EDC3259D5EC83C82-806C
   Steuergerät für Heckklappenöffnung:
Adresse 08: Klima-/Heizungsel. (E87)       Labeldatei:| DRV\5G0-907-044.clb
   Teilenummer SW: 5NA 907 044 AK    HW: 5NA 907 044 AK
   Bauteil: AC Automat    H50 1301
   Revision: 20K03000    Seriennummer: 00000A00110880
   Codierung: 1202010420410101111550400010192A
   Betriebsnr.: WSC 01357 011 00200
   ASAM Datensatz: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW48.rod
   VCID: 084869F652BF450B87C-805C
   Sensor für Luftgüte:
   Geber für Luftfeuchtigkeit: außen:
   Subsystem 2 - Teilenummer SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Bauteil: AQ_Hum_Sensor  H01 0006
   Seriennummer: 7F29476800PAG0MUFU03
   Klimabedienteil hinten:
   Subsystem 3 - Teilenummer SW: 5HG 907 049 A    HW: 5HG 907 049 A
   Bauteil: E265KlimaHeck  H01 0103
   Seriennummer: 2200000412
Adresse 09: Zentralelektrik (J519)       Labeldatei:| 5Q0-937-08X-HV1.clb
   Teilenummer SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Bauteil: BCM PQ37BOSCH 028 0162
   Revision: --------    Seriennummer: 86581707150274
   Codierung: 00011D46C2C102FF57C44014001C57281C80000000000000000000000000
   ASAM Datensatz: EV_BodyContrModul1UDSBosc 015002
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03527EDA6B996653D2E-8056
   Steuergerät für Wischermotor:
   Subsystem 1 - Teilenummer SW: 3G1 955 119 A    HW: 3G1 955 119   Labeldatei: DRV\5QX-955-119-V1.CLB
   Bauteil: WWS    150701  042 0607
   Seriennummer:         150704163524
   Codierung: 0E4DDD
   Sensor für Regen- und Lichterkennung:
   Subsystem 2 - Teilenummer SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labeldatei: DRV\5Q0-955-547.CLB
   Bauteil: RLHS  037 0059
   Seriennummer: S3Y15M07D28H16M30S54
   Codierung: 90A8DD
   Lichtschalter:
   Subsystem 3 - Teilenummer SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Bauteil: E1 - LDS MQB  H01 0032
   Seriennummer: 21 05 2015  00000550
   Geber für Luftfeuchtigkeit: innen:
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\5Q0-919-294.clb
   Teilenummer SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Bauteil: PARKHILFE 8K  H03 0056
   Revision: --------    Seriennummer: 39331520101576
   Codierung: 0071153811
   Betriebsnr.: WSC 05311 115 00063
   ASAM Datensatz: EV_EPHVA18AU3700000 002026
   VCID: 44D0BDC62E17A16BAB4-8010
Adresse 13: Distanzregelung (J428)       Labeldatei:| 3Q0-907-572.clb
   Teilenummer SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Bauteil: ACC BOSCH MQB H04 0192
   Codierung: 3200678259FFC428949C804D
   ASAM Datensatz: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430ED067EB711EB1B4-8060
Adresse 14: Raddämpfung (J250)       Labeldatei: 5Q0-907-376.clb
   Teilenummer SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Bauteil: DAEMPFUNGS-SG H16 0120
   Seriennummer: 14071541350193
   ASAM Datensatz: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372ADA0A6FC1FAF33E6-8062
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5Q0-959-655.clb
   Teilenummer SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Bauteil: Airbag VW20   013 0195
   Revision: --------    Seriennummer: 003STPEGC1JI
   Codierung: 98FCC0C0008000005C5400CC000800000065
   Betriebsnr.: WSC 05314 000 00001
   ASAM Datensatz: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF22A077102B3B66-802A
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: -----------    HW: 454 001 507 15
   Bauteil: SideSensor_Df  008 0887
   Seriennummer: 3576U000000CB2ACF51X
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: -----------    HW: 454 001 407 15
   Bauteil: SideSensor_Pf  008 0887
   Seriennummer: 3586U000000F08504514
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 454 801 507 15
   Bauteil: SideSensor_Dr  301 0148
   Seriennummer: 3516R5CADA007000000D
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 454 801 207 15
   Bauteil: SideSensor_Pr  301 0148
   Seriennummer: 3526R7E7D6E07000000P
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Fahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 454 800 207 15
   Bauteil: FrontSensor_D  304 0149
   Seriennummer: 3556VA4DB6607000000L
   Codierung: 2D2D2D
Adresse 16: Lenkradelektronik (J524)       Labeldatei:| DRV\5Q0-953-549.clb
   Teilenummer SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Bauteil: Lenks.Modul   075 0175
   Revision: FF032032    Seriennummer: 20150724501066
   Codierung: 0410
   Betriebsnr.: WSC 00015 115 00001
   ASAM Datensatz: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D26C8224DFDD0A3E4A-8068
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
   Teilenummer SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Bauteil: KOMBI         409 1340
   Codierung: 03A50818FF80000800887F031000000000000000
   ASAM Datensatz: EV_DashBoardVDDMQBAB 009048
   VCID: 270A0A4ABF616A73AE6-8072
Adresse 18: Standheizung (J364)       Labeldatei:| DRV\5Q0-963-272.clb
   Teilenummer SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Bauteil: STH-MQB       007 0072
   Codierung: 9309
   ASAM Datensatz: EV_AuxilParkiHeateWOS 002018
   VCID: 3828D93662DFF58B37C-806C
   Funkfernbedienung Standheizung:
   Subsystem 1 - Teilenummer SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Bauteil: R149 T91-LIN  003 0301
   Seriennummer: 00000000000001177052
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\5Q0-907-530-V1.clb
   Teilenummer SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Bauteil: GW MQB High   212 2227
   Revision: --------    Seriennummer: 08071510804294
   Codierung: 0B0300045F017300FB00025A9C0F00010001070000000000000000000000
   Betriebsnr.: WSC 131071 102 209715
   GVL: 01D43C0008000600409C90000006CC0000000000000000000000000000000000
   ASAM Datensatz: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 75B61002354D48E3ECA-8020
   Generator:
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-DC1  H10 0040
   Seriennummer: 29150001490330065296
   Codierung: 2DFFFF
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Bauteil: J367-BDMHella  H04 8050
   Seriennummer: 0923337103
   Wechselrichter für Netzsteckdose:
   Subsystem 4 - Teilenummer SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Bauteil: WECHSELRICHTE  H56 0033
   Seriennummer: 0128108
   Analoguhr:
   Subsystem 5 - Teilenummer SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Bauteil: Analoguhr  209 2002
Adresse 22: Allrad (J492)       Labeldatei:* DRV\0CQ-907-554.clb
   Teilenummer SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Bauteil: Haldex4Motion H52 7082
   Seriennummer: HA1-00019.06.15
   Codierung: 0301
   ASAM Datensatz: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D4A7CE182B937BB50-8012
Adresse 2B: Lenksäulenverrieg. (J764)       Labeldatei:* DRV\5Q0-905-861.clb
   Teilenummer SW: 3Q0 905 861     HW: 3Q0 905 861
   Bauteil: ELV-MQBB      H05 0031
   Seriennummer: 15000066751010
   Codierung: 0800000000000000
   ASAM Datensatz: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE2412412564C3302-8024
Adresse 36: Sitzverst. Fahr. (J810)       Labeldatei:* Keine
   Teilenummer SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Bauteil: Sitzmemory    H04 0016
   Seriennummer: Y0006OGI15034
   Codierung: 0010000200000500818280808080000000008181000000F400
   ASAM Datensatz: EV_SeatMemorDriveSide 002019
   VCID: 3A2CC33E5CD3E79BC18-806E
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
   Teilenummer SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Bauteil: TSG FS        020 0041
   Seriennummer: 070715BG709352
   Codierung: 001F0B20D200020000001000
   ASAM Datensatz: EV_DCUDriveSideEWMAXKLO 006003
   VCID: 43D2BEDA2B19A65392E-8016
1 Fehler gefunden:
65649 - Lampe für Ambientebeleuchtung
          B1325 13 [008] - Unterbrechung
          Sporadisch - bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 144
                    Kilometerstand: 149045 km
                    Datum: 2022.09.23
                    Zeit: 18:55:51
Adresse 44: Lenkhilfe (J500)       Labeldatei:| DRV\5Q0-909-143.clb
   Teilenummer SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Bauteil: MQB_PP_APA    204 2033
   Revision: 00000000    Seriennummer: 0000318139
   Codierung: 01000011005001
   Betriebsnr.: WSC 00015 115 00303
   ASAM Datensatz: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
   VCID: 3B22C63A53E9DE93DAE-806E
Adresse 47: Soundsystem (J525)       Labeldatei:| DRV\3Q0-035-466.clb
   Teilenummer SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
   Bauteil: MIB2_amp_P_VW H45 0190
   Revision: 00000001    Seriennummer: VWZ8Z1FAT0077B6
   Codierung: 1284020001AA0A2AAA0000000000
   ASAM Datensatz: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 2F3AE26A97913233666-807A
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
   Teilenummer SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Bauteil: TSG BFS       020 0041
   Seriennummer: 090715BG817685
   Codierung: 001F0120DE00020200001000
   ASAM Datensatz: EV_DCUPasseSideEWMAXKLO 006003
   VCID: 42DCBBDE3403AF5B998-8016
1 Fehler gefunden:
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 144
                    Datum: 2022.09.23
                    Zeit: 18:55:51
Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:| DRV\7P6-907-357.clb
   Teilenummer SW: 7P6 907 357 C    HW: 7P6 907 357 B
   Bauteil: AFS-ECU       H01 0110
   Revision: --------    Seriennummer: --------------
   Codierung: 03A202000F210200
   Betriebsnr.: WSC 05311 000 08193
   ASAM Datensatz: EV_HeadlRegulAFSMQBMLB 001001
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDAB22A47F1C2B3F66-806A
   Leistungsmodul 1 für LED-Scheinwerfer links:
   Subsystem 1 - Teilenummer SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labeldatei: 3D0-941-329.CLB
   Bauteil: LED LeiMo li.  H09 0003
   Codierung: E02400
   Leistungsmodul 1 für LED-Scheinwerfer rechts:
   Subsystem 2 - Teilenummer SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labeldatei: 3D0-941-329.CLB
   Bauteil: LED LeiMo re.  H09 0003
   Codierung: E02400
   Leistungsmodul für Scheinwerfer links:
   Subsystem 3 - Teilenummer SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labeldatei: 3D0-941-329.CLB
   Bauteil: LeiMo links  H02 0003
   Codierung: E02400
   Leistungsmodul für Scheinwerfer rechts:
   Subsystem 4 - Teilenummer SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labeldatei: 3D0-941-329.CLB
   Bauteil: LeiMo rechts  H02 0003
   Codierung: E02400
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-HGH2.clb
   Teilenummer SW: 3G0 035 020 H    HW: 3G0 035 020
   Bauteil: MU-H-ND-EU    H42 1367
   Seriennummer: A598G0F7511239
   Codierung: 028402010000000051111102008808031F0006E401200000DF
   Betriebsnr.: WSC 12345 123 12345
   ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
   VCID: 1C6025A6F627B9AB334-8048
   Anzeige- und Bedienungseinheit 1 für Informationselektronik:
   Subsystem 1 - Teilenummer SW: 5G6 919 606     HW: 5G6 919 606
   Bauteil: ABT_High-2  H50 9130
   Seriennummer: VWZ6ZJT2600850
   Datenträger:
   Subsystem 2 - Teilenummer SW: V03 959 809 PA    HW: -----------
   Bauteil: ECE 2022  --- 0195
   Seriennummer: --------------------
1 Fehler gefunden:
1555 - Softwareversionsmanagement prüfen
          B201A 00 [009] - -
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 104
                    Datum: 2022.09.23
                    Zeit: 18:10:26
                    Spannung Klemme 30: 12.3 V
                    Status_Software_Version_Management-module_name: MVW_MIB2/VW_MIB2
Adresse 6C: Rückfahrkamera (J772)       Labeldatei:| DRV\5Q0-980-556.clb
   Teilenummer SW: 5Q0 980 556     HW: 5Q0 980 556
   Bauteil: RVC Compact   H07 0100
   Codierung: 0184020162002017000040
   ASAM Datensatz: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW41.rod
   VCID: 77AA1A0A2F413AF3FE6-8022
Adresse 6D: Heckklappe (J605)       Labeldatei:| DRV\5Q0-959-107.clb
   Teilenummer SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Bauteil: HDSG-Modul    H12 0250
   Revision: --------    Seriennummer: 30109229400000
   Codierung: 0200
   ASAM Datensatz: EV_DeckLidCONTIAU736 001011
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 3C20C52656E7D9ABD34-8068
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H08 0272
   Seriennummer: 07031812P22120
   Codierung: 0002070600000401002213448150A90094000E000020
   Betriebsnr.: WSC 00020 999 12345
   ASAM Datensatz: EV_MFKBoschMQBB 001001
2 Fehlercodes gefunden:
0660 - Grundeinstellung nicht durchgeführt
          B2010 00 [009] - -
          [Initial_calibration_missing]
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 104
                    Datum: 2022.09.23
                    Zeit: 18:54:15
                    Steuergerätetemperatur: 45 °C
                    Außentemperatur: 17.0 °C
                    Fahrzeuggeschwindigkeit: 0.00 km/h
                    Systemlaufzeit: 3757.7 s
                    Spannung Klemme 15: 13.9 V
                    mid: 00 1E
                    Status der Kamera: Kalibrierung
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Lokaler Datenbus
          U1169 00 [009] - fehlende Botschaft
          [Timeout_RDR1_Header]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 104
                    Datum: 2022.09.23
                    Zeit: 18:54:15
                    Systemlaufzeit: 3758.2 s
                    mid: 01 43
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
Adresse BB: Türelektronik hinten links (J388)       Labeldatei:* Keine
   Teilenummer SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Bauteil: TSG HFS       020 0041
   Seriennummer: 020715BG108369
   Codierung: 000E01200100020000001000
   Betriebsnr.: WSC 35044 001 1048576
   ASAM Datensatz: EV_DCURearDriveMAXKLO 006003
   VCID: 45D6A0C2252D9863BCA-8010
1 Fehler gefunden:
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 144
                    Datum: 2022.09.23
                    Zeit: 18:55:52
Adresse BC: Türelektronik hinten rechts (J389)       Labeldatei:* Keine
   Bauteil: TSG HBFS      020 0041
   Seriennummer: 010715BG108365
   ASAM Datensatz: EV_DCURearPasseMAXKLO 006003
1 Fehler gefunden:
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 144
                    Datum: 2022.09.23
                    Zeit: 18:55:52
Ende--------(Dauer: 02:31, Batt.-Spannung Start/Ende: 14.1V/14.2V)---------
kamold
Australia
C?ID=241363
Check bit 6 in byte 3 of your radar:
flowistade
Hamburg, Germany
C?ID=313259
Thank you again Guys lane assist is now working perfecly !!! :)
Sonntag,25,September,2022,15:12:15:51172
www.VCDS-Shop.de
Gateway-Verbauliste:  5Q0 907 530 AF
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Fahrzeug-Ident.-Nr.: WVWZZZ3CZGE046595   Kilometerstand: 149082km
   Codierung: 0014
   Codierung: 0E4DDD
   Codierung: 90A8DD
   Lichtschalter:
   Codierung: 320067C259FFC428949C804D
   Codierung: 2D2D2D
   Codierung: 2D2D2D
   Codierung: 2D2D2D
   Codierung: 2D2D2D
   Codierung: 2D2D2D
   Codierung: 0410
   Codierung: 9309
   Generator:
   Codierung: 2DFFFF
   Analoguhr:
   Codierung: 0301
   Codierung: E02400
   Codierung: E02400
   Codierung: E02400
   Codierung: E02400
   Datenträger:
1 Fehler gefunden:
          B201A 00 [009] - -
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 106
                    Kilometerstand: 149082 km
                    Datum: 2022.09.25
                    Zeit: 15:11:49
                    Status_Software_Version_Management-module_name: MDUV624/Main
   Codierung: 0200
Ende--------(Dauer: 02:16, Batt.-Spannung Start/Ende: 12.1V/12.1V)---------
