Hi trying to post an auto scan
Two S4's
California, USA
C?ID=525814
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 42 46 52 53 55 56 5F 62
          6C 72
VIN: WAUBGAFL1BA109766   Mileage: 224390km-139429miles
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H07 0003
   Revision: --H07---    CVN: BC966676
   Coding: 0104000A240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323D176144A9622B09B-8066
   VINID: 9D19525D159C0524410091C61807D5CEF5
6485 - Oxygen (Lambda) Sensor B1 S2
          P0139 00 [096] - Response too Slow
                    Mileage: 223684 km
                    Date: 2022.07.16
                    Time: 06:23:29
                    Engine RPM: 1349.00 /min
                    Vehicle speed: 36 km/h
                    Coolant temperature: 73 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.898 V
                    Unlearning counter according OBD: 24
                    Engine speed: actual: 1344 /min
                    MAF_ENVD: 70.81176 mg/stroke
                    Coolant temperature (unfiltered): 73.5 °C
                    Engine: operating status: PUC
                    T_AST_ENVD: 308.40 s
                    STATE_LS_ENVD[1]: 4
6486 - Oxygen (Lambda) Sensor B2 S2
          P0159 00 [096] - Response too Slow
                    Mileage: 223684 km
                    Date: 2022.07.16
                    Time: 06:23:06
                    Engine RPM: 1192.00 /min
                    Vehicle speed: 45 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 25 °C
                    Engine speed: actual: 1184 /min
                    Coolant temperature (unfiltered): 71.3 °C
                    T_AST_ENVD: 282.70 s
                    STATE_LS_ENVD[2]: 4
   Part No SW: 8K1 927 156 K    HW: 0B5 927 156 F
   Component: 0B5 30TFSINAR H05 0008
   Revision: --H05---    Serial number: 0000000415 CVN: 0000F19E
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 3D27345D8DF7AD53E49-8068
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 290D1A
   VCID: 025D87A1B40912ABD9B-8056
02214 - Tire Pressure Warning
                    Reset counter: 86
                    Mileage: 222991 km
                    Date: 2022.06.27
                    Time: 07:45:04
                    Hex Value: 0x7500
                    Hex Value: 0x4006
                    Hex Value: 0x1F37
                    Hex Value: 0x19A3
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 114
                    Mileage: 224277 km
                    Date: 2022.08.09
                    Time: 16:48:55
                    Hex Value: 0x00C0
                    Hex Value: 0x0722
                    Hex Value: 0x0232
                    Hex Value: 0x0993
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H05 0435
   Coding: 090100
   VCID: 76B5EB71E8C13E0BE53-8022
   Subsystem 1 - Part No SW: 8T0 959 754 AD    HW: 8T0 959 754 AD
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0810000123572015
   Serial number: 2310000100559002
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 97
                    Reset counter: 50
                    Mileage: 211971 km
                    Date: 2021.11.02
                    Time: 08:25:55
   Revision: C1000000    Serial number: 01221220100794
   Coding: 66102000
   VCID: 00598DA9BA0500BBCFF-8054
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000908484
   Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
   VCID: 3C213959966DA45BD37-8068
   Component: WWS 130111  H06 0070
   Serial number: SWF11010137020
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11227863
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001712100948
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
7 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
03188 - Bulb for Side Marker Light; Front Left
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:00
                    Reset counter: 100
                    Mileage: 223389 km
                    Date: 2022.07.11
                    Time: 21:16:00
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0080
   Revision: 11001001    Serial number: 36891101704469
   Coding: 20010D
   VCID: 4ACD6F81CCB90AEB51B-801E
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0N2CUY
   Coding: 303837354230303030304A55304C384B3053
   VCID: 45D75CBDE527E593BC9-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R10000021GW
   Serial number: 6334MSME5B25774ES
   Serial number: 6344MSME5B34685DT
   Serial number: 6352QSME3E7D2632R
   Serial number: 6362QSME327D4E08T
   Serial number: 63732SME56013754U
   Serial number: 63832SME5601055AW
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KA30016F
   Coding: 000036
   VCID: 3E2533518071B64BFD3-806A
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 Q    HW: 8K0 920 981 Q
   Component: KOMBIINSTR.   H09 0258
   Revision: 00000000    Serial number: EJG12KC1C
   Coding: 8B1709008300D705020000
   VCID: 41DF48ADF18FC9B3801-8014
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10C1503A7
   Coding: 00C303
   VCID: 035382A5AB131BA3D2D-8056
   Component: J367-BDM  H07 0170
   Serial number: 11001CB7060111
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H10 0025
   Serial number: 001001110001047
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
   VCID: 2E050311509146CB6D3-807A
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C03204000410001
   VCID: 53F372E51BF34B2322D-8006
   Revision: 00002001    Serial number: 0141390004
   Coding: 0106023A00FA440480B0013200000000
   Component: GTO BF  H01 0050
   Serial number: 00000000000000345420
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H07 0041
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52FD77E124E9422B29B-8006
   Revision: 00000003    Serial number: 00000000831065
   VCID: 34311179BE3D6C1B1B7-8060
                    Fault Status: 00101011
                    Reset counter: 114
                    Mileage: 224277 km
                    Date: 2022.08.09
                    Time: 16:46:46
                    Voltage: 12.40 V
                    Count: 38
                    Hex Value: 0x0163
                    Hex Value: 0x0008
                    Hex Value: 0x1010
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 392F204D955F9173C81-806C
                    Fault Status: 00101010
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:14
                    Reset counter: 115
                    Mileage: 224286 km
                    Date: 2022.08.11
                    Time: 16:55:15
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471AY0B7551458
   Coding: 020007020100000001
   VCID: 5DE794DD6D378D53849-8008
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 490AQ0B7600319
   Coding: 010200000206A1EF05000B0E000000030000
   VCID: 38292549A255887B37F-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466AZ0B0290777
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000719862
   Component: CD-Database  1886
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C03204000210001
   VCID: 56F58BF108015E0BC53-8002
   Revision: --H04---    Serial number: 525PA8-J0Y911X
   Coding: 1000006
   VCID: 38292549AE55887B37F-806C
02203 - Audio / Video Input 1
                    Fault Frequency: 82
                    Reset counter: 81
                    Mileage: 215004 km
                    Date: 2022.01.16
                    Time: 12:55:47
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 27
                    Reset counter: 121
                    Mileage: 221474 km
                    Date: 2022.06.01
                    Time: 12:58:58
                        Reverse OFF
                    Count: 3
02283 - Video Connection to Output [End Unit]
                    Reset counter: 118
                    Mileage: 224290 km
                    Date: 2022.08.12
                    Time: 07:42:26
                        Reverse OFF
                    Count: 3
   Component: TSG HR        H06 1401
End----------(Elapsed Time: 01:54, VBatt start/end: 12.4V/12.4V)-----------
Two S4's
California, USA
C?ID=525814
sorry for the dumb post , but i was trying to see that i can do it .
so do i physically have to highlight the scan every time or is there an easier way?
thanks for your patience
Westbury, UK
See the </> icon in the forum editor bar? Click on that and it will open a new window, paste the Auto-Scan into there and when you close the window it will insert the code tags for you.
Two S4's
California, USA
C?ID=525814
Monday,15,August,2022,18:55:09:24635
Dealer/Shop Name: Leonard Two S4's
VIN: WAUBGAFL4BA134614   License Plate: 6SMP256
Mileage: 133360km-82866mi   Repair Order:
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 42 46 47 52 53 55 56 5F
          62 6C 72
VIN: WAUBGAFL4BA134614   Mileage: 133360km-82866miles
   VINID: 9D19525D159C1124410C418110A0491FBB
                    Mileage: 133098 km
                    Date: 2022.08.09
                    Time: 21:10:54
                    Engine RPM: 1169.00 /min
                    Vehicle speed: 59 km/h
                    Coolant temperature: 96 �C
                    Intake air temperature: 51 �C
                    Voltage terminal 30: 13.405 V
                    Unlearning counter according OBD: 30
                    Engine speed: actual: 1152 /min
                    MAF_ENVD: 65.36470 mg/stroke
                    Coolant temperature (unfiltered): 96.8 �C
                    STATE_LS_ENVD[2]: 4
   Component: 0B5 30TFSINAR H10 0010
   Revision: --H10---    Serial number: 0000000715 CVN: 00006FC5
   Coding: 290D1A
   Shop #: WSC 06324 000 00000
                    Reset counter: 190
                    Mileage: 132056 km
                    Date: 2022.07.27
                    Time: 16:14:10
                    Hex Value: 0x3500
                    Hex Value: 0x4006
                    Hex Value: 0x1F37
                    Hex Value: 0x1FAD
                    Hex Value: 0x00FF
   Coding: 090100
   Serial number: 0511000001723003
   Serial number: 2311000024997016
   Revision: C1000000    Serial number: 01280220110072
   Coding: 66102000
   Revision: 10030001    Serial number: 00000000967992
   Component: WWS 240211  H07 0070
   Serial number: SWF11020245873
   Coding: 00FD11
   Serial number: 11299555
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000504110725
   Revision: 11001001    Serial number: 36891105940828
   Coding: 20010D
   Serial number: 003GLD0N8NV9
   Serial number: 5810000R10000026DA
   Serial number: 6334MSME5C645A18O
   Serial number: 6344MSME5C60304DH
   Serial number: 6352QSME77031A60B
   Serial number: 6362QSME280220462
   Serial number: 63732SME1F072D644
   Serial number: 63832SME317F2920$
   Revision: --------    Serial number: 90372KBM0002U
   Coding: 000036
   Component: KOMBIINSTR.   H10 0258
   Revision: 00000000    Serial number: EJG354P2C
   Revision: EC000056    Serial number: 5600E1121401BC
   Coding: 00C303
   Serial number: 1100AFE6150211
00576 - Terminal 15
                    Reset counter: 210
                    Mileage: 132934 km
                    Date: 2022.08.05
                    Time: 17:24:58
                    Bin. Bits:    10000
                    Voltage: 12.40 V
                    Count: 7
   Serial number: 002402110001106
   Revision: 00002001    Serial number: 0143992679
   Component: GTO BF  H01 0070
   Serial number: 00000000000000366841
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 227
                    Mileage: 133337 km
                    Date: 2022.08.15
                    Time: 10:36:42
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804003808101
   VCID: 7AADFF41DCD95A6B81B-802E
   Revision: 00000003    Serial number: 10000000736327
   Coding: 0000004
   Revision: AB001007    Serial number: 471C$0B7562657
   Coding: 020007010000000001
   Revision: --------    Serial number: 490BV0B7607541
   Serial number: 9466BM0B0531306
   Serial number: 00000000760010
   Component: TSG HL        H06 1501
   Revision: --H05---    Serial number: 525PA8-J0Z91MS
   Coding: 1000006
   Component: TSG HR        H06 1501
End----------(Elapsed Time: 01:59, VBatt start/end: 12.2V/12.0V)-----------
Westbury, UK
Any reason(s) you wanted to post an Auto-Scan?
I can see several DTCs from July & August, all flagged as intermittent - so worth clearing them and seeing if any come back.
Two S4's
California, USA
C?ID=525814
i was getting ready to post a question about dsg adaptation , which i did in general vw/audi
since the scan i posted first, ive been working on all dtc's . i believe i only have a rear camera , which is the wire loom being bent and losing power.
also the second scan is my wifes car.
my question in the other thread is about
erase start stop- error out of range
main pressure valve - abort safety reasons
here is a scan from this morning. (i replaced the key battery and cleared that dtc afterwards)
Saturday,24,September,2022,08:28:47:24635
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WAUBGAFL1BA109766   License Plate: 8YQM909
Mileage: 228030km-141691mi   Repair Order: 92422
          6C 72
VIN: WAUBGAFL1BA109766   Mileage: 228030km-141691miles
   VCID: 323D176144A9622B217-8066
   VCID: 3D27345D8DF7AD53CC5-8068
   Coding: 290D1A
   VCID: 025D87A1B40912ABF17-8056
   Coding: 090100
   VCID: 76B5EB71E8C13E0BCDF-8022
00955 - Key 1
                    Reset counter: 206
                    Mileage: 226165 km
                    Date: 2022.09.07
                    Time: 11:49:23
   Coding: 66102000
   VCID: 00598DA9BA0500BBE73-8054
   Coding: 260010910634AF212700080300003D0D0F9CD24802010161000000
   VCID: 3C213959966DA45BFBB-8068
   Coding: 00FD11
   Coding: 025028
   Coding: 20010D
   VCID: 4ACD6F81CCB90AEB797-801E
   VCID: 45D75CBDE527E593945-8010
   Coding: 000036
   VCID: 3E2533518071B64BD5F-806A
   Coding: 8B1F09008300D705020000
   VCID: 41DF48ADF18FC9B3A8D-8014
   Coding: 00C303
   VCID: 035382A5AB131BA3FA1-8056
   VCID: 2E050311509146CB45F-807A
   VCID: 53F372E51BF34B230A1-8006
   Coding: 0106063A00FA44048030013200000000
   VCID: 52FD77E124E9422B017-8006
   VCID: 34311179BE3D6C1B33B-8060
   Coding: 0000004
   VCID: 392F204D955F9173E0D-806C
   VCID: 5DE794DD6D378D53AC5-8008
   VCID: 38292549A255887B1F3-806C
   VCID: 56F58BF108015E0BEDF-8002
   Coding: 1000006
   VCID: 38292549AE55887B1F3-806C
                    Fault Frequency: 171
                    Reset counter: 214
                    Mileage: 226158 km
                    Date: 2022.09.07
                    Time: 11:39:28
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 9
                    Reset counter: 214
                    Mileage: 226916 km
                    Date: 2022.09.15
                    Time: 14:08:02
                        Reverse OFF
                    Count: 3
End----------(Elapsed Time: 01:55, VBatt start/end: 13.1V/13.1V)-----------
Address 05: DTCs cleared
Thread closed. Please carry on here:
