Rear Wiew Camera Fault 2014 El- Golf
christofferbeck87
Norway
C?ID=411717
Hello folks!
I have a electric golf 2014 mod, for some moths ago the rear view camera and the opening handle to the luggage compartment quit working. At the same time.
Had the car to the workshop and they said that the module was defective.
I bought a new "used" one, that was working before it was removed from the donor car. but installed in mine, not working.
Got codes that says no signal from the rear view camera, so maybe broken coax? but that don't explain why the handle/micro switch dosent work?
Only way to open trunk is with the remote.
Is there any coding or something I need to do after installing the new part?
Provide a full autoscan :
Friday,23,September,2022,19:14:40:44206
VIN: WVWZZZAUZEW900294   License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
          8C A5 BD C6
VIN: WVWZZZAUZEW900294   Mileage: 77528km-48173miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 A    HW: 0EA 907 309 A
   Component: E-Vehicle     H21 8343
   Revision: WMH21---    CVN: A20C7889
   Coding: 000D0012006404003000
   Shop #: WSC 00773 218 00000
   ASAM Dataset: EV_VCU00XXX0110EA906016A 002015
   ROD: EV_VCU00XXX0110EA906016A_002.rod
   VCID: 2D070A602D9BF483549-8078
   VINID: 9E69EAAAA465A959C900008910A9948B27
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 N    HW: 5Q0 907 379 H
   Component: ESC           H31 0807
   Revision: 00000000    Serial number: 60474000000172 CVN: B0B3C704
   Coding: 01FA40A12C20316C0379060941C7298002348CC0608294B3F881507AC242
   Shop #: WSC 54057 001 1048576
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001.rod
   VCID: 47CB58C8AF273ED34E5-8012
   Revision: 00021000    Serial number: 0331367279
   Coding: 030C0C
   VCID: 3A2D313CECD5533BC1B-806E
   Part No SW: 5GE 907 044 K    HW: 5GE 907 044 K
   Component: Climatronic   H01 Y055
   Revision: 00001K07
   Coding: 00022200200100010105000200101000
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 44D14FC49E1115CBAB7-8010
   Subsystem 3 - Part No SW: 12E 963 231 C    HW: 12E 963 231 C
   Component: J848 HV-PTC  H09 0203
   Serial number:  T133523003804000027
   Air quality sensor:
   A/C compressor sub:
H04
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011409502405
   Coding: 00051B66C34102F34BE44000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BA3F438A36FAA339AD-802E
   Component: WWS    140404  042 0551
   Serial number:         140407105525
   Component: RLFS  024 0042
   Serial number: Y14M04D09H09M00S01S6
   Coding: 00A8DD
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431407800523
   Coding: 2031161011
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 42DD49DC84051BFB99B-8016
   Part No SW: 5Q0 907 572 C    HW: 5Q0 907 572 C
   Component: ACC Bosch MQB H04 0210
   Serial number: 10021477030758
   Coding: 001C2700FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 372B2808DFC74E533E5-8062
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    009 0870
   Serial number: 003MFR000LFH
   Coding: 98CCC000002000005C0000CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002132
   VCID: 50F973945A69F96B1FF-8004
   Left seat belt tensioner:
   Serial number: 34169667B09041440402
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668B10041470439
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 904 14
   Serial number: 357000000006D1BC9F0$
   Subsystem 4 - Part No SW: -----------    HW: 480 000 904 14
   Serial number: 35800000000191BC9F0V
   Subsystem 5 - Part No SW: -----------    HW: 480 403 103 14
   Serial number: 351000299142B1B4B1F4
   Subsystem 6 - Part No SW: -----------    HW: 480 402 703 14
   Serial number: 3520002C1153FB90B12/
   Subsystem 7 - Part No SW: -----------    HW: 480 402 503 14
   Serial number: 3550002B7153FB93836B
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10041404220455
   Coding: 0C10
   Part No SW: 5GE 920 870     HW: 5GE 920 870
   Component: KOMBI         306 2300
   Coding: 072418186F94000800886803160000
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 A    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3166
   Revision: --------    Serial number: 05111310800388
   Coding: 0201001746381000EF001210081E00000001000100030000000000000000
   GVL: 01543C0000000608508C9000A000481800000000000000000000000000000000
   ASAM Dataset: EV_GatewEVConti 010015
   ROD: EV_GatewEVConti_010.rod
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H15 0038
   Serial number: 29140000512260084135
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5GE 915 181     HW: 5GE 915 181
   Component: J367-BDMHella  H03 8050
   Serial number: 2490422103
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059
   Component: EBKV          H11 0160
   Serial number:   085430010016
   Coding: 01720100321900030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_002.rod
   VCID: 4CC167E4B641DD8B637-8018
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057
   Component: VX70BrakeAssi  H03 0140
   Serial number: 05802861050314032018
239616 - Implausible Data Received from Engine Control Module
          U0401 00 [047] - -
          [iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
                    Mileage: 77528 km
                    Date: 2022.09.23
                    Time: 19:06:03
   Revision: 00000000    Serial number: 14000089455004
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F04CEB1A54B1B7-8060
   Serial number: 09041406070008
   Coding: 003F1320D000048000001000
   VCID: 40D943D48A0909EB8FF-8014
   Serial number: 00000000000002357540
   Component: EPS_MQB_ZFLS  123 1043
   Coding: D302
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF46D0810300E3801-8014
   Part No SW: 5QE 907 080 G    HW: 5QE 907 080 B
   Component: VW370E2615020 H04 2480
   Revision: 00H04000    CVN: C8865FB5
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080G 001022
   ROD: EV_DMCM09550115QE907080C.rod
   VCID: 4ACD61FCBC35C3BB51B-801E
   Serial number: 08041406070521
   Coding: 003F1120DE00048000001000
   VCID: 3FDB4028F7F77613F65-806A
   Serial number: 00000000000002328134
   Coding: 190000
   Coding: 051A000001010000
   VCID: 75B7E200854BFC43EC9-8020
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 044 B    HW: 5G0 035 044
   Component: MU-H-TN-EU    H40 0358
   Serial number: A461C0E7516098
   Coding: 02737001FF00000011110001000800101F0105D4010001009F
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E65DDAC503D1F1BDD3-804A
   Component: ABT_High  H51 0022
   Serial number: VWZ8Z9PJ600U1Y
   Subsystem 2 - Part No SW: V03 959 800 GP    HW: -----------
   Component: ECE 2014  --- 0078
   Compact disc data bank:
   Component: Gracenote  --- 1008
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 133
                    Mileage: 77528 km
                    Date: 2022.09.23
                    Time: 19:06:25
                    Voltage terminal 30: 14.0 V
   Part No SW: 5QE 035 284     HW: 5QE 035 284
   Component: OCULowMQBEU   007 0535
   Coding: 0273700110829A01007800000000
   Shop #: WSC 01459 666 28888
   ROD: EV_OCULowMQB.rod
   VCID: 015F86D0C183C0E3C01-8054
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0731
   Serial number: VWADEDB007     CVN: F113BE7D
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52FD799C54658B7B29B-8006
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0052
   Serial number: 10000061845
   Coding: 0101010001020303000500000100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B233438E3EF6A33DAD-806E
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V1.clb
   Part No SW: 5QE 915 022 C    HW: 12E 915 022 C
   Component: LMSG          H06 1062
   Serial number: 00820040650115
   Coding: CA0903
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB_001.rod
Address C6: Batt. Chrg. (JAX4)       Labels: 5QE-915-681.clb
   Part No SW: 12E 915 682 G    HW: 12E 915 682 G
   Component: OBC KOSTAL    H41 0142
   Revision: --------    Serial number: 2302140BL0003C
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3707 002001
   ROD: EV_OBCSinglPhaseKLOVW3707_002.rod
   VCID: 2E050D6C209D8F9B6D3-807A
End----------(Elapsed Time: 02:03, VBatt start/end: 14.9V/14.9V)-----------
I would not go buying parts without fully investigating the situation with the aid of a wiring diagram and multimeter first.
christofferbeck87
Norway
C?ID=411717
True, just me hoping for a quick fix.
So you think maybe some short somewhere in the wiring? Shouldn't that bring a code short to ground / short to + ?
Actually, I was thinking more along the lines of a broken wire, or perhaps a blown or missing fuse.
christofferbeck87
Norway
C?ID=411717
I thought that was the same as a short?
But thanks, I will try to get a WD and start looking with a voltmeter :-)
Westbury, UK
Not the same.
A short is a wire connecting to somewhere it shouldn't, such as another wire or the chassis.
A broken wire is an open circuit so the wire doesn't connect to where it should.
A blown or missing fuse means no power is being supplied to the circuit(s).
christofferbeck87
Norway
C?ID=411717
Okei, thanks.
But shouldn't that trow a code, if there was a open circuit?
Only code is no signal from the camera, but seems like there's no power
Westbury, UK
Okei, thanks.
The diagnostic firmware can usually detect both open and closed circuits.
If it seems like there's no power then it's time to check the fuses and wiring using a multimeter and a wiring diagram (BTW see how wiring diagram is bold blue, that means it's a link giving details how to get a wiring diagram).
