09 Jetta ABS Coding Needed (MK60EC1)
protekorl
C?ID=310356
Customer replace ABS module but don't have any auto scan saved for the new module. How I can find coding info for new used module
protekorl
C?ID=310356
this is with old module:
Friday,23,September,2022,11:42:52:57792
VCDS Version: 22.9.0.0 (x64)  HEX-NET CB: 0.4623.4
VIN: 3VWJZ71K89M083753   License Plate:
Mileage: 132660km-82431mi   Repair Order: 09 jetta omar 2
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJZ71K89M083753   Mileage: 132660km-82431miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 N    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0HN2440K1
   Coding: 0000071
   Shop #: WSC 05073 444 100136
   VCID: 393AC8BF70B8524544-806C
   VINID: 0E69DAA8705B2097402031C50C6A1E5E19
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 27.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.319 V
Readiness: 0010 0101
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B400D492A00FD881202E9921C00413000
   Shop #: WSC 48590 001 1048576
   VCID: 76A00383C126FD3D69-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 186
                    Mileage: 132663 km
                    Count: 4608
                    Count: 125
                    Count: 48400
                    Count: 60382
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78BC0DBB0B328B4D7B-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001123482
   Coding: 14058E234004150007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 000 00000
   VCID: 3228FF93ADCEA11D85-8066
   Component: Wischer 051108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.75 V
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.55 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.80 V
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.80 V
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07KX5L
   Coding: 0013889
   VCID: 6C9421EB4F6A37ED8F-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME406037551
   Subsystem 3 - Serial number: 6342MSME4060746FE
   Subsystem 4 - Serial number: 6351HSME185B2D53F
   Subsystem 5 - Serial number: 6361HSME184A53065
   Subsystem 6 - Serial number: 63727SME186C51283
   Subsystem 7 - Serial number: 63827SME186C06712
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0000021
   VCID: 03466A5742F4D8955E-8056
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0HN2440K1
   Coding: 0023203
   VCID: 3C34D1AB7F8A676D5F-8068
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 070908F2002397
   Coding: E9807F070002021002
   VCID: 3522C48F5CA0B625A0-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000251889021
   Coding: 0001205
   VCID: 6FAE36E77E7CCCF5AA-803A
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 228
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A18E7F3851EE9DD3D-807E
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 31.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 0444694B47FADFAD67-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08080607131502
   Coding: 0001204
   VCID: 70AC359B6342D30DB3-8024
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       018 0021
   Revision: 00018000    Serial number: VWZ4Z7H6389655
   Coding: 0040401
   VCID: 200C05DBF322238D63-8074
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003624214
   Coding: 0001168
   VCID: 76A003830126FD3D69-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003586744
   Coding: 0001168
   VCID: 77BE0E87062C843572-8022
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
protekorl
C?ID=310356
this is with the new one:
Friday,23,September,2022,11:32:13:57792
   Coding: 0000071
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 27.0°C
                    Temperature: 28.0°C
                    Voltage: 12.319 V
   Revision: 00H31001
   VCID: 7DB21CAFE410AE6528-8028
10 Faults Found:
                    Reset counter: 204
                    Mileage: 25635 km
                    Date: 2006.14.27
                    Time: 12:31:59
                    Count: 16384
                    Count: 32782
                    Count: 8226
                    Count: 42752
                    Count: 59904
                    Count: 2039
                    Count: 1024
                    Reset counter: 204
                    Count: 16386
                    Count: 12
                    Count: 256
                    Count: 8211
                    Count: 41728
                    Count: 58112
                    Count: 63223
                    Reset counter: 204
                    Count: 16386
                    Count: 12
                    Count: 256
                    Count: 8233
                    Count: 41728
                    Count: 58112
                    Count: 63223
                    Reset counter: 189
                    Mileage: 132669 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 107
                    Count: 42752
                    Count: 256
                    Fault Status: 00101110
                    Reset counter: 190
                    Mileage: 132669 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 104
                    Count: 41472
                    Fault Status: 00100101
                    Reset counter: 189
                    Mileage: 66314 km
                    Date: 2001.00.02
                    Time: 16:36:09
                    Count: 1544
                    Count: 8242
                    Count: 52224
                    Count: 212
                    Count: 288
                    Count: 8705
                    Count: 188
                    Count: 52225
                    Reset counter: 189
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 48896
                    Fault Status: 01100101
                    Reset counter: 189
                    Mileage: 2687233 km
                    Date: 2047.04.00
                    Time: 16:04:28
                    Count: 256
                    Count: 50109
                    Count: 256
                    Count: 279
                    Count: 195
                    Count: 256
                    Count: 27069
                    Count: 256
                    Reset counter: 189
                    Mileage: 132669 km
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 42752
                    Count: 256
                    Reset counter: 189
                    Mileage: 132669 km
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 42752
                    Count: 256
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.75 V
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.55 V
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.80 V
                    Reset counter: 190
                    Mileage: 132663 km
                    Voltage: 13.80 V
   Coding: 0013889
   Coding: 0000021
00576 - Terminal 15
   Coding: 0023203
   Coding: 0001205
                    Reset counter: 228
   Revision: 00H15000
            000 - - - MIL ON
                        PD
                    Temperature: 31.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0001204
   Coding: 0040401
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
protekorl
C?ID=310356
Please post an Auto-Scan, we need to see full details of the Jetta (especially the ABS module to confirm if it is a compatible replacement) and coding is often vehicle and configuration dependent.
hello I post already the auto scans let me know if you need anything else. thanks
JMR
Romania
C?ID=432218
There is not a matter of coding but the abs unit seems to be sick
  • Agree
Agreed, that does not look like a happy module that just needs coding.
However:
Old:
New:
Try:
113B400D492A00FD881202E9921C0041300000
Jef
HQ
Where did this replacement ABS module come from? From a quick and lazy search, that looks to be ABS module from 2012 and up cars.... now installed in a 2009.
Partslink24 shows this car should have ABS module 1K0 907 375 AH.
protekorl
C?ID=310356
I will check with the customer thanks for the info.
