AGM Battery Coding for a VW Sharan 7N
mkgb
Hi,
I wonder if anyone can clarify the correct coding for an AGM battery in a VW Sharan 7N.
Mine has the 7N0907534 Battery regulator and the Coding with the current old EFB battery is 330F7859.
From what I understand Byte 2 bits 7-4 are where the battery technology is defined (in my case this is 78) I have also seen online other ECUs with 18 and occasionally 08. I can't find anywhere however where the correct bit settings for an AGM battery are defined.
Any help would be appreciated. I have access to a Ross-Tech interface through work but without above information I'm not sure I can code it correctly.
mkgb
Hi Uwe,
I won't be able to get the ross-tech on the vehicle until I get back to the office next week, but here is a log form the tool I have at home:
VIN: WVWZZZ7NZFV0XXXXX
Engine
Part #: 03L906018HH
Component: R4 2,0L EDC
Software version: 9956
ASAM/ODX identifier: EV_ECM20TDI01103L906018HH
Coding: 0019001A043501080000 (hex)
[No fault codes]
ABS
Part #: 7N0614109S
Component: J104 C3 450M V
Software version: [none]
ASAM/ODX identifier: [none]
Coding: 19991 (decimal)
[Purchase "Pro" to see fault codes]
Parking brake
Part #: 3AA907801J
Component: J540 EPB4 VW-63
Coding: 24167 (decimal)
Steering angle
[ECU not present]
Power steering
Part #: 7N0909144R
Component: EPS_ZFLS Kl. 272
Coding: [none]
[No fault codes]
Airbags
Part #: 7N0959655C
Component: VW10Airbag00M
Software version: 0014
ASAM/ODX identifier: EV_AirbaVW10TS6VW428
Coding: 00304D (hex)
[No fault codes]
Tire pressure monitor
[ECU not present]
Parking/steering assist
Part #: 7N0919475A
Component: PARKHILFE 8K
Software version: 0012
ASAM/ODX identifier: EV_EPHVA18VW4280000
Coding: 118001 (hex)
[No fault codes]
Instrument cluster
Part #: 7N0920970L
Component: KOMBI
Software version: 0905
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 440F01 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Central electronics
Part #: 5K0937084K
Component: BCM PQ35 B
Software version: 0174
Coding: 40180A3F8125F1C0408800C01400006443D11308426D29226480872000C1 (hex)
[No fault codes]
Body/convenience system
[ECU not present]
Driver's door
Part #: 7N0959793F
Component: TSG FA
Software version: 0553
Coding: 011006208001411011 (hex)
[No fault codes]
Front passenger's door
Part #: 7N0959792F
Component: TSG BF
Coding: 011004208001411011 (hex)
[No fault codes]
Rear left door
Part #: 7N0959794G
Component: TSG HL
Coding: 010004200001411001 (hex)
[No fault codes]
Rear right door
Part #: 7N0959794G
Component: TSG HR
[No fault codes]
Steering wheel
Part #: 5K0953521DF
Component: LENKS.MODUL
Software version: 0162
ASAM/ODX identifier: EV_SMLSNGVOLWSXS
Coding: 1082240000 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7N0907044Q
Component: Clima-Sharan
Software version: 0506
ASAM/ODX identifier: EV_ClimatronicSharan
Coding: 021000C449 (hex)
[No fault codes]
Trailer
Part #: 7N0907383
Component: Anhaenger
Software version: 0120
Coding: 410C040001000000 (hex)
[No fault codes]
Radio
Part #: 5M0035186L
Component: Radio RCD310
Software version: 0119
Coding: 0100040004000D (hex)
[No fault codes]
Telephone
Part #: 5N0035729D
Component: TELEFON
Software version: 0593
ASAM/ODX identifier: EV_UHVUMI
Coding: 0A01000080010101 (hex)
[No fault codes]
Auxiliary heater
Part #: 7N0963271G
Component: Zuheizer
Coding: 41 (decimal)
[No fault codes]
CAN network gateway
Part #: 7N0907530AQ
Component: J533 Gateway
Software version: 1653
Coding: 468003 (hex)
[No fault codes]
Media player
[ECU not present]
Battery regulator
Part #: 7N0907534
Component: Batt.regelung
Coding: 330F7859 (hex)
[No fault codes]
  • Haha
Reactions: JMR
