2013 A4 AC failure, both the cabin and outside air flaps are closed, Codes 00457, 00716, 01274, 01229 Flap Motors are new
nasonb8A4
Hubbardston, MA, USA
C?ID=262081
Turn on AC on auto, goes into recirc mode and cabin air flap does not open so no air circulation
Both the cabin and outside air flaps are closed, Codes 00457, 00716, 01274, 01229 Flap Motors are new
When problem began the inside flap would modulate and open and then close
When I remove the cabin flap motor and prop the flap open Ac works fine
nasonb8A4
C?ID=262081
Here is the Auto Scan for the HVAC and Cent Elec, I am a newbie so was not sure how to attach the whole scan file
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01231020121883
   Coding: 6480208000
   Shop #: WSC 02391 823 56573
   VCID: 397970DCB0F1AF47C8-806C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 42
                    Reset counter: 227
                    Mileage: 254109 km
                    Date: 2022.03.18
                    Time: 11:59:44
00716 - Air recirculation Flap Positioning Motor (V113)
                    Reset counter: 227
                    Mileage: 213619 km
                    Date: 2020.06.19
                    Time: 16:04:36
                    Voltage: 13.00 V
                    Temperature: 42.0°C
                    Temperature: 34.0°C
                    Count: 10414
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001001
                    Reset counter: 242
                    Mileage: 257204 km
                    Date: 2022.05.10
                    Time: 16:34:55
                    Voltage: 13.20 V
                    Temperature: 34.0°C
                    Temperature: 29.0°C
                    Count: 25000
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00001011
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000501434901
   Coding: 26000091863CAFC00000480300003D0D0F1C520822090221000008004000030100000000000000
   VCID: 76E3BBE0C16F003FE5-8022
   Component: WWS 231012  H07 0080
   Serial number: SWF12100236512
   Coding: 00FD11
   Serial number: 20671333
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000510121577
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3GXV02
   Serial number: 0B484456000000000001
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 146
                    Reset counter: 227
                    Mileage: 254109 km
                    Date: 2022.03.18
                    Time: 11:59:00
We don't attach them. They're just text. Copy & Paste the whole thing into a post, preferably between CODE tags, as explained here:
