T5.1 security access code
Colob
Norway
Anyone got the security access code for 09-Central Electronics?
Want to change brightness on park light
AINils
Germany (AIB)
C?ID=56975
There's no need of security access for coding. But Auto-Scan would help in your case to see if we can find a solution for your problem
Colob
Norway
Friday,23,September,2022,15:33:53:56548
VCDS Version: 22.9.0.0 (x64)  HEX-NET CB: 0.4623.4
Dealer/Shop Name: Elitebil AS
VIN: WV1ZZZ7HZEH026634   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 18 19 22 25 37 55 56 61 69 6C 6E 0B
VIN: WV1ZZZ7HZEH026634   Mileage: 173840km-108019miles
04-Steering Angle -- Status: Sporadic communication error 1000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GR    HW: 03L 907 309 L
   Component: R4 2,0L EDC   X38 5591
   Revision: 22X38---    Serial number: 00000000000000 CVN: BF1B07D4
   Coding: 0119401A233601080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GR 003003
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 014AA08D90D5EE854C-8054
   VINID: 9E606AAAA1D8A9560008618310B635FA8D
12306 - Particulate Trap Bank 1
          P2002 00 [237] - Efficiency Below Threshold
                    Mileage: 173358 km
                    Date: 2022.09.13
                    Time: 19:42:41
                    Engine RPM: 2145.00 /min
                    Normed load value: 69.0 %
                    Vehicle speed: 118 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 14.520 V
                    Exhaust gas jet volume in particle filter: 507.2 m³/h
                    Particle filter: difference pressure: -2 hPa
                    Particle filter: soot mass measured: 0.00 g
                    Particle filter: soot mass calculated: 6.28 g
                    Particle filter: differential pressure: dynamic offset: 4 hPa
                    Exhaust gas temperature sensor 3: 438.6 °C
                    Exhaust gas temperature sensor 4: 392.6 °C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [109] - Electrical Fault
                    Mileage: 173412 km
                    Date: 2022.09.14
                    Time: 06:30:14
                    Engine RPM: 1017.00 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 13 °C
                    Intake air temperature: 12 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 11.120 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 1700 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 8
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 7
                    Outside temperature: 10.0 °C
10088 - Neutral Gear Sensor
          P15A1 00 [040] - Implausible Signal
                    Fault Frequency: 35
                    Mileage: 173284 km
                    Date: 2022.09.13
                    Time: 16:41:06
                    Engine RPM: 1765.50 /min
                    Normed load value: 84.3 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.620 V
                    Neutral position sensor: current transmission angle: 20.00 °
                    Neutral position sensor: adapted transmission angle: 0.00 °
                    Adaptation status of neutral position sensor-Bits 0-7: 36
                    Transmission neutral position sensor voltage: 1650 mV
                    Neutral position sensor: upper adaptation value: 3130 mV
                    Neutral position sensor: lower adaptation value: 0 mV
4729 - Steering Effort Control Module
          U0130 00 [032] - No Communications
                    Mileage: 173724 km
                    Date: 2022.09.20
                    Time: 20:00:07
                    Engine RPM: 858.50 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 17 °C
                    Unlearning counter according OBD: 36
                    Cruise Control System (CCS): status-Bits 0-7: 15
                    selected gear-Bits 0-7: 0
12641 - Particulate Trap Bank 1
                    Mileage: 173471 km
                    Date: 2022.09.17
                    Time: 12:50:43
                    Engine RPM: 1450.00 /min
                    Normed load value: 73.7 %
                    Vehicle speed: 80 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.720 V
                    Exhaust gas jet volume in particle filter: 186.3 m³/h
                    Particle filter: difference pressure: -1 hPa
                    Particle filter: soot mass calculated: 12.00 g
                    Particle filter: differential pressure: dynamic offset: 5 hPa
                    Exhaust gas temperature sensor 3: 374.1 °C
                    Exhaust gas temperature sensor 4: 316.9 °C
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 708724AD99A60E9B24A89974696290
   Shop #: WSC 02736 790 49152
   VCID: 3A381761B5837D5D4D-806E
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:08
                    Count: 32832
                    Count: 4097
                    Count: 8214
                    Count: 510
   Part No SW: 7E5 907 047 BF    HW: 7E5 907 047 BF
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000003
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 74A4F959DF67CB2D57-8020
9479698 - Control Circuit for Front Left Seat Heater
          B10A6 12 [008] - Short to Plus
                    Reset counter: 57
                    Mileage: 173668 km
                    Date: 2022.09.20
                    Time: 06:31:20
9479699 - Control Circuit for Front Left Seat Heater
          B10A6 13 [009] - Open Circuit
                    Reset counter: 17
                    Mileage: 173187 km
                    Date: 2022.09.10
                    Time: 13:55:11
9672979 - Heated Seat; Front Right
          B1399 13 [008] - Open Circuit
                    Reset counter: 53
                    Mileage: 173178 km
                    Date: 2022.09.09
                    Time: 21:38:28
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 220130307
   Coding: E0A0393A0A21201300200F71376B8DD40290672F7E055841320000030000
   Shop #: WSC 02736 790 12345
   VCID: 2D122C3D74CDDAE5D8-8078
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Coding: 400000
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Coding: 400000
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:20:22
                    Fault Status: 00101010
                    Reset counter: 61
                    Mileage: 173824 km
                    Date: 2017.02.12
                    Time: 16:09:25
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00JUYGB
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3522045D949D9225A0-8060
   Part No SW: 7E0 920 870 J    HW: 7E0 920 870 J
   Component: KOMBI         H04 0710
   Coding: 160E01
   VCID: 302C35496BFFB70DF3-8064
Address 18: Aux. Heat        Labels: 7E0-819-008.clb
   Part No: 7E0 819 008 F
   Component: J737__Standheizung  0605
   Revision: 00086000    Serial number: 09024901A00000
   Coding: 0021322
   Shop #: WSC 21053 210 01865
   VCID: 2C1421398FD7D3EDCF-8078
01408 - Under-Voltage Shut-Off (fixed Value)
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:16:26
                        Start
                    Temperature: 40.0°C
                    Voltage: 10.00 V
                    Temperature: 4.0°C
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 042200
   VCID: 70ACF549A37FF70DB3-8024
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:09
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000015
   Shop #: WSC 02736 790 00000
   VCID: 373E0E5546916035B2-8062
                    Reset counter: 138
                    Mileage: 173163 km
                    Date: 2017.01.30
                    Time: 17:03:30
   Component: IMMO          H04 0710
   VCID: 6A98E7218DA30DDDFD-803E
   Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
   Component: RNS315-EU   H70 0407
   Serial number: VWZAZ2N0396896
   Coding: 000002010200140000039002
   ROD: EV_RNS315EUV2UDS.rod
   Component: EUR_W_V4  0050
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2022.09.21
                    Time: 16:04:46
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 0288000001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77BECE55CE11A03572-8022
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Frequency: 89
                    Reset counter: 21
                    Mileage: 173163 km
                    Date: 2022.09.09
                    Time: 16:02:04
          U1400 00 [008] - -
          [Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2022.09.21
                    Time: 16:04:42
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2022.09.20
                    Time: 20:00:07
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 330B1A73
   Shop #: WSC 02737 790 00000
   VCID: 6B96E2258A5914D586-803E
   Subsystem 1 - Part No SW: 7E0 915 181 B    HW: 7E0 915 181 B
   Component: J367-BDM  H08 0181
   Serial number: 50172K58062221649409
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000193917647
   Coding: 410D000101000000
   VCID: 312A304D68F5BE05FC-8064
02564 - Trailer; Left Tail Lamps (M60)
                    Fault Status: 11101010
                    Reset counter: 12
                    Mileage: 173579 km
                    Date: 2017.02.07
                    Time: 18:55:13
02565 - Trailer; Right Turn Signals (M63)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Reset counter: 52
                    Mileage: 173579 km
                    Date: 2017.02.07
                    Time: 19:11:10
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H12000    Serial number: 525PA8-J360013
   Coding: 0000016
   Shop #: WSC 02969 612 182243
   VCID: 6582941DACBD22A5D0-8030
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 1
                    Mileage: 173163 km
                    Date: 2017.01.30
                    Time: 16:02:05
                        Reverse OFF
                    Count: 3
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:09
                        Reverse OFF
                    Count: 3
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:04:44
                        Reverse OFF
                    Count: 3
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 297197
   Coding: 000203
   VCID: 3522045D9C9D9225A0-8060
End----(Elapsed Time: 01:43, VBatt start/end: 11.5V/11.6V. VIgn 11.5V)-----
Colob
Norway
                    Mileage: 173358 km
                    Date: 2022.09.13
                    Time: 19:42:41
                    Mileage: 173412 km
                    Date: 2022.09.14
                    Time: 06:30:14
                    Fault Frequency: 35
                    Mileage: 173284 km
                    Date: 2022.09.13
                    Time: 16:41:06
                    Mileage: 173724 km
                    Date: 2022.09.20
                    Time: 20:00:07
                    Mileage: 173471 km
                    Date: 2022.09.17
                    Time: 12:50:43
   Revision: 00H43001
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:08
                    Count: 32832
                    Count: 4097
                    Count: 8214
                    Count: 510
   Revision: 00001012
   Coding: 0000000003
                    Reset counter: 57
                    Mileage: 173668 km
                    Date: 2022.09.20
                    Time: 06:31:20
                    Reset counter: 17
                    Mileage: 173187 km
                    Date: 2022.09.10
                    Time: 13:55:11
                    Reset counter: 53
                    Mileage: 173178 km
                    Date: 2022.09.09
                    Time: 21:38:28
   Coding: 400000
   Coding: 400000
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:20:22
                    Reset counter: 61
                    Mileage: 173824 km
                    Date: 2017.02.12
                    Time: 16:09:25
   Coding: 160E01
   Coding: 0021322
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:16:26
                        Start
                    Temperature: 40.0°C
                    Voltage: 10.00 V
                    Temperature: 4.0°C
   Revision: B9074001
   Coding: 042200
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:09
   Coding: 0000015
                    Reset counter: 138
                    Mileage: 173163 km
                    Date: 2017.01.30
                    Time: 17:03:30
          U1400 00 [008] - -
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2022.09.21
                    Time: 16:04:46
                    Fault Frequency: 89
                    Reset counter: 21
                    Mileage: 173163 km
                    Date: 2022.09.09
                    Time: 16:02:04
          U1400 00 [008] - -
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2022.09.21
                    Time: 16:04:42
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2022.09.20
                    Time: 20:00:07
   Coding: 330B1A73
                    Reset counter: 12
                    Mileage: 173579 km
                    Date: 2017.02.07
                    Time: 18:55:13
                    Reset counter: 52
                    Mileage: 173579 km
                    Date: 2017.02.07
                    Time: 19:11:10
   Coding: 0000016
                    Reset counter: 1
                    Mileage: 173163 km
                    Date: 2017.01.30
                    Time: 16:02:05
                        Reverse OFF
                    Count: 3
                    Reset counter: 56
                    Mileage: 173724 km
                    Date: 2017.02.10
                    Time: 20:00:09
                        Reverse OFF
                    Count: 3
                    Reset counter: 57
                    Mileage: 173776 km
                    Date: 2017.02.11
                    Time: 16:04:44
                        Reverse OFF
                    Count: 3
   Coding: 000203
AINils
Germany (AIB)
C?ID=56975
Not possible to modify brightness
AINils
Germany (AIB)
C?ID=56975
How should I explain? This only can be done by ECU developer, Volkswagen or producer of your 3rd party lights
Colob
Norway
Thats why i need the security access code
Westbury, UK
Since it needs the firmware hacking any organisation that needs you to supply the SA code is unlikely to know what they are doing well enough to be trusted IMHO.
  • Agree
