2014 Polo Airbag coding
Revivals
England
C?ID=513296
Hi there, Just brought this system as have an airbag fault on a 2014 polo with internal module error.
I've got a new air bag module but I cant find how to do put in the index code? I've got the code off the box.
I'm clearly doing something wrong so any help would be greatly received.
Thanks in advance
Mark
Please see scan below
Thursday,22,September,2022,15:23:13:39412
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWZZZ6RZFY075072   License Plate: AJ14MLK
Mileage: 56446km-35073mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY075072   Mileage: 56446km-35073miles
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057     HW: 04C 907 309 J
   Component: R3 1.0l MPI   H22 7749
   Revision: 31H22000    CVN: 0A1335A8
   Coding: 01110072022401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057 001011
   ROD: EV_ECM10MPI011_VW26.rod
   VCID: 629DA4EFC4C62E5B917-8036
   VINID: 9E69EAAAA1A2A96A401C5007088725CC00
4710 - No Communications with Airbag Control Module
          U0151 00 [032] - -
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 00:00:05
                    Engine RPM: 0.00 /min
                    Coolant temperature: 59 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.850 V
                    selected gear-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08505609140522
   Coding: 23DD2485492A33C5091410700053C42492CC90080005C7090C00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 6C81CAD73602682B2BB-8038
1094 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [ComScl_Airbag_02_Timeout]
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:47:59
0922 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [ComScl_mAirbag_1_Timeout]
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:47:58
1171 - Multiple collision brake
          B13BC F2 [008] - No function
1148 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [008] - -
          [Scl_KBI_Standzeit_02_Invalid]
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 00:00:10
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0103
   Serial number:  1405271B-0887
   Coding: 200000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D67D713BD3851A3EC5-8048
329475 - Motor for Fresh Air / Recirculated Air Flap
          B108B 13 [012] - Open Circuit
                    Reset counter: 200
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:52:47
                    Voltage terminal 30: 14.8 V
459009 - Databus
          U1121 00 [013] - Missing Message
                    Fault Frequency: 8
                    Reset counter: 161
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:47:58
          B10CD 00 [012] - -
          [Funktionseinschränkung durch Energiemangement]
                    Reset counter: 201
                    Mileage: 56444 km
                    Date: 2022.08.22
                    Time: 00:41:07
                    Voltage terminal 30: 11.5 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                    CAN input signal(s) status-Back-up lamp: OFF
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0046
   Serial number: 007278021065
   Coding: 03000850425300530BA44080B10F07C800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: 2E0500DFC09EDA3B45F-807A
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 801 BB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU029041441193530
   Coding: 1400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 802 AT  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU030041441200736
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1402119W4
   Serial number: 00000000000059223681
   Subsystem 5 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU021051441417811
   Coding: 1400A0
   Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU019051441390224
   Coding: 0400A0
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 160
                    Mileage: 56444 km
                    Date: 2022.08.16
                    Time: 20:16:20
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 0
                    Voltage: 12.5 V
                    Outside temperature: 22.0 °C
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 201
                    Terminal 15 status: On
                    OFF: operated
                    Voltage: 11.0 V
                    Outside temperature: 20.0 °C
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 94231414801972
   Coding: 0031051001
   VCID: 3D2737931DF831A3CC5-8068
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag??? 001 0330
   Revision: --------    Serial number: 003LM008MW5R
   Coding: 000000000000000000000000000000000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313F1BA3D1A0C5C358D-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C91387693E13R
   Subsystem 2 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00C91387692D12P
   Subsystem 3 - Part No SW: -----------    HW: 442 153 005 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A009D15397A4C12G
   Subsystem 4 - Part No SW: -----------    HW: 442 153 005 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A715397A2D18H
8 Faults Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [129] - Open or Short to Ground
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [129] - Open or Short to Ground
9466644 - Crash Signal
          B1073 14 [129] - Open or Short to Ground
10490624 - No End-of-Line Programming
          B2013 00 [137] - -
          [ECU not EOL programmed]
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [129] - Open or Short to Plus
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [129] - Open or Short to Plus
13697024 - Component Protection
          U1100 00 [129] - No Basic Setting
          [ATP Not Configured Or Invalid Initial State/ Adjustment]
15361024 - Component Protection
          U1101 00 [129] - Active
          [ATP DiagServiceOrEepFailure]
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0260
   Coding: 272409002180260001082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009036
   VCID: 221DE4EF84466E5BD17-8076
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 201
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0046
   Revision: --------    Serial number: 007278021065
   Coding: 030100046F0A640071000000000000010001000000000000000000000000
   GVL: 01443C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 6597BFF3D5E85963745-8030
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1461402482400275AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61142F50172821253266
65793 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
          [Eindrahtfehler CAN-Antrieb]
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:52:46
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
131605 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Reset counter: 160
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:48:00
                    Terminal 30 power supply: 11.1 V
                    Terminal 15: On
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 56444 km
                    Date: 2022.08.18
                    Time: 22:22:57
                    Terminal 15: OFF
          U1101 00 [009] - Active
                    Reset counter: 161
                    Mileage: 56444 km
                    Date: 2022.08.16
                    Time: 00:56:51
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CE640651
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 333311AB2BBCF7D32A1-8066
   Part No SW: 3Q0 035 842     HW: 3Q0 035 842
   Component: MU-S-D-ER     H04 0105
   Serial number: VWZAZ2P4521398
   Coding: 02620000BE00000011111201000808001F0100860120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6A8DCCCF3CF6761B597-803E
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H41 1015
   Serial number: VWZ8Z9PH000969
          B201A 00 [009] - -
                    Reset counter: 160
                    Mileage: 56444 km
                    Date: 2022.08.16
                    Time: 00:20:51
                    Voltage terminal 30: 14.4 V
          B2000 87 [008] - Missing Message
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.17
                    Time: 18:28:29
                    Voltage terminal 30: 14.6 V
                    System_Software_Error-SW_Status_Consistency: 02 01 00
                    System_Software_Error-SW_Status_Device: B
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [008] - Open Circuit
                    Reset counter: 201
                    Mileage: 56444 km
                    Date: 2022.08.22
                    Time: 00:41:04
                    Voltage terminal 30: 11.4 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: electrically OK
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 201
                    Mileage: 56444 km
                    Date: 2022.08.22
                    Time: 00:41:04
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: electrically OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: electrically OK
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [008] - Open Circuit
                    Reset counter: 201
                    Mileage: 56444 km
                    Date: 2022.08.22
                    Time: 00:41:04
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: electrically OK
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: electrically OK
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 201
                    Mileage: 56446 km
                    Date: 2022.09.16
                    Time: 02:48:03
                    Voltage terminal 30: 11.0 V
                    Network diagnosis-Status: not enabled
End----(Elapsed Time: 00:52, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
"No End-of-Line Programming" means it hasn't been parameterized. Take car to dealer or independent with ODIS and GeKo/Fazit access; this needs to be done online to the servers on VW's mothership.
Revivals
England
C?ID=513296
Hi Uwe
Thanks for the reply, I will get it booked in at a main dealers then.
Thanks again for the help
Mark
