2015 VW Sharan Reductant Tank Heating
Souriau
Newry, NI
C?ID=86928
Can anyone point me in the right direction regarding the reductant tank heater.
Pre-scan before clearing the codes.
Thursday,22,September,2022,13:11:14:46973
VCDS Version: 22.9.0.0  HEX-NET CB: 0.4623.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ7NZFV031335   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56 61
          62 72 77
VIN: WVWZZZ7NZFV031335   Mileage: 122730km-76260miles
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H28 9956
   Revision: 44H28---    Serial number:                CVN: 9BEE0BB638D3FF82
   Coding: 0019001A042501080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003010
   ROD: EV_ECM20TDI01103L906018H_VW36.rod
   VCID: F7BEA2814E7AB935F2-80A2
   VINID: 9E69EAAAA1DEA969800C10C31497A9246F
9655 - Control Circuit for Reductant Tank Heating
          P202A 00 [237] - Open Circuit
                    Fault Frequency: 27
                    Mileage: 110619 km
                    Date: 2021.12.07
                    Time: 19:30:38
                    Engine RPM: 2862.00 /min
                    Normed load value: 51.4 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 9 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.820 V
                    Outside temperature: 7.0 °C
                    Pressure sensor for reducing agent: measured pressure: 4999 hPa
                    Sensor for reducing agent fill level: fill level: 79.94 %
                    Sensor for reducing agent tank temperature: temperature: 5.3 °C
                    Reducing agent pump: activation: 13.18 %
9656 - Control Circuit for Reductant Tank Heating
          P202B 00 [232] - Short to GND
                    Fault Frequency: 12
                    Mileage: 109834 km
                    Date: 2021.11.17
                    Time: 09:52:56
                    Engine RPM: 777.00 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.960 V
                    Outside temperature: 13.0 °C
                    Pressure sensor for reducing agent: measured pressure: 5 hPa
                    Sensor for reducing agent fill level: fill level: 79.88 %
                    Sensor for reducing agent tank temperature: temperature: 8.3 °C
                    Reducing agent pump: activation: 87.99 %
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
Readiness: 1 2 0 0 0
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 S    HW: 7N0 614 109 S
   Component: J104   C3 450M VD3F 0040
   Revision: --H07---    Serial number: 00000008668045
   Coding: 0019991
   Shop #: WSC 00020 790 00000
   VCID: BD3270A9E4C65365E8-80E8
02214 - Tire Pressure Warning
                    Reset counter: 85
                    Mileage: 120638 km
                    Date: 2016.12.22
                    Time: 17:09:33
                    Speed: 62.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 7N0 907 044 Q    HW: 7N0 907 044 Q
   Component: Clima-Sharan  H02 0506
   Revision: 00001K02
   Coding: 021000C449
   VCID: BE3077A521C0487DF1-80EA
   Part No SW: 5K0 937 084 K    HW: 5K0 937 084 K
   Component: BCM PQ35 B    122 0174
   Revision: BA122001
   Coding: 40180A3F8125F1C0408800C01400006443D11308426D29226480872000C1
   VCID: BA387BB535E8645DCD-80EE
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    141209  033 0044
   Serial number:         141216191928
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S5Y15M01D17H07M12S00
   Coding: 0228BB
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28231436460152
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: B93A64B938EE6F45C4-80EC
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H13 0014
   Serial number: 003LGP12WFSE
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: BFCE0AA126CA4175FA-80EA
   Serial number: 3493ETS608627B91A9D0
   Serial number: 3503ETS6021B3C01ADDP
   Serial number: 3513ETS606826B91ADD$
   Serial number: 3523ETS603178C01ADDT
   Serial number: 35540TS60A420D41A9DH
   Part No SW: 5K0 953 521 DF    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 LENKS.MODUL   016 01620162
   Revision: FF010042    Serial number: 20150112300311
   Coding: 1082240000
   ROD: N/A
   VCID: F3A696915A02D515CE-80A6
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6
   Coding: E20000
   Part No SW: 7N0 920 970 L    HW: 7N0 920 970 L
   Component: KOMBI         H04 0905
   Coding: 440F01
   VCID: BC347DAD37DC5A6DDF-80E8
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: B83C61BDCBE4764D3B-80EC
00664 - Fuel gauge
                    Fault Status: 01100010
                    Fault Frequency: 31
                    Reset counter: 227
                    Mileage: 109989 km
                    Date: 2016.04.14
                    Time: 08:32:03
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 170115F1000993
   Coding: 468003
   VCID: FF4E4AA16E4A8175BA-80AA
   Component: IMMO          H04 0905
   VCID: EA988BF50DC814DD7D-80BE
Address 2E: Media Player 3
   Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000129977013
   Coding: 011006208001411011
   VCID: C5C218494C161BA5B0-8090
02111 - Motor for Window Regulator
                    Fault Status: 01100101
                    Fault Frequency: 65
                    Reset counter: 53
                    Mileage: 109839 km
                    Date: 2016.04.09
                    Time: 10:11:53
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H21000
   VCID: C2C803559D382C9D95-8096
   Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000131695837
   Coding: 011004208001411011
   VCID: C4C4054D472C22ADA7-8090
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000460494
   Coding: 0024167
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  007 0119
   Revision: 01000001    Serial number: VWZ1Z2R0994603
   Coding: 0100040004000D
   VCID: B52268891CF68B2520-80E0
   Component: Batt.regelung H58 1653
   Coding: 030F7859
   VCID: F1AA9C99281EE7053C-80A4
   Component: J367-BDM  H07 0180
   Serial number: 42016C04501491320499
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
   Component: TSG HL        H04 0553
   Revision:             Serial number: 0000132468615
   Coding: 010004200001411001
   VCID: C7DE1241761A09B542-8092
   Component: TSG HR        H04 0553
   Revision:             Serial number: 0000132468577
   Part No SW: 5N0 035 729 D    HW: 5N0 035 729 D
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670056165
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: B12A5C99E09EA7057C-80E4
End----(Elapsed Time: 02:19, VBatt start/end: 14.5V/11.8V. VIgn 11.8V)-----
post-scan after clearing the codes.
Thursday,22,September,2022,13:30:43:46973
          62 72 77
   VCID: F7BEA2814E7AB935F2-FFFE
          P202A 00 [039] - Open Circuit
                    Mileage: 122739 km
                    Date: 2022.09.22
                    Time: 13:27:55
                    Engine RPM: 780.50 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.520 V
                    Outside temperature: 15.5 °C
                    Pressure sensor for reducing agent: measured pressure: 5000 hPa
                    Sensor for reducing agent fill level: fill level: 79.93 %
                    Sensor for reducing agent tank temperature: temperature: 15.2 °C
                    Reducing agent pump: activation: 13.28 %
Readiness: N/A
   Coding: 0019991
   Revision: 00001K02
   Coding: 021000C449
   Revision: BA122001
   Coding: 004DBD
   Coding: 0228BB
   Coding: 108001
   Coding: 00304D
   Component: LENKS.MODUL   016 0162
   Coding: 1082240000
   ROD: EV_SMLSNGVOLWS.rod
   Component: E221__MFL-TK6  H07 0023
   Serial number: 70000000000000841255
   Coding: E20000
   Coding: 440F01
   Coding: 0000041
   Coding: 468003
   Revision: 00H21000
   Coding: 0024167
   Coding: 030F7859
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:55, VBatt start/end: 14.4V/14.5V)-----------
