2014 Audi TT Mk3 - No Alarm Sound
CHADTT
Stoke-on-Trent, UK
C?ID=45372
Hi everyone, :-)
Car is an 8S FV 2014 2.0 Quattro S-line Coupe.
Problem is with the alarm sounder not working.
I can set the alarm, open the door with the third key and trigger the alarm (indicators flashing etc) but no sound from the sounder.
I replaced the original sounder (5Q0 951 605) with a new genuine Audi 5Q0 951 605A, but this made no difference and my VCDS scan was exactly the same.
Tried clearing them, cycling ignition on/off, but they return straight away.
Ran output test on the sounder, which says it is running ok, but no sound is heard.
The wiring looks fine, and the connector is not corroded etc.
Car battery is healthy (Stop start works fine also).
I'm not too sure but maybe the sounder requires coding into the 09-Central Electrics Subsystem.
Would there possibly be some adaptions required?
Can post full scan if required.
Any help would be very much appreciated.
Part No SW: 5Q0 937 084 BR HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0136
Serial number: 01011424701439
Coding: 07055D46C20106FD03044004B31807A80080000000000000000000000000
Shop #: WSC 06385 790 00016
ROD: EV_BCMBOSCH_013.rod
VCID: 09122ECFA844DFC514-805C
Subsystem 1 - Part No SW: 8S2 955 119 A HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 140510 032 0371
Serial number: 00000001405080700121
Coding: 1BC7F7
Component: G397_RLFS H06 0002
Serial number: 23161452
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 12 09 2014 00000787
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141900BJZ
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [009] - -
Reset counter: 128
Mileage: 97919 km
Date: 2022.09.21
Time: 19:05:58
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.1 V
Outside temperature: 15.5 °C
267032 - Alarm Horn / Siren for Anti-Theft System
B131D 29 [009] - Signal Implausible
Reset counter: 128
Mileage: 97919 km
Date: 2022.09.21
Time: 19:05:58
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.1 V
Westbury, UK
We need to know how your TT is equipped and configured, so please post an unedited Auto-Scan.
VCDS will have saved it in C:\Ross-Tech\VCDS\Scans
If it were not coded, I don't think there would be faults for it; it would just be ignored.
If it were mine, I would unplug that sounder temporarily and clear fault codes, then check them again to see if/how the faults change.
CHADTT
Stoke-on-Trent, UK
C?ID=45372
The tyre pressure fault was cleared afterwards. No other faults on the system apart from the two alarm records.
Saturday,17,September,2022,08:55:17:32157
VCDS Version: 22.9.0.0 (x64)
VIN: TRUZZZFV9F1002942   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 47 52 55 5F A5
          A9
VIN: TRUZZZFV9F10*****   Mileage: 97801km-60770miles
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Revision: --H13---    CVN: 1648DBCF
   Coding: 0A1D00324406010B3002
   ASAM Dataset: EV_ECM20TFS0208S0906259 001003
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AF04103FDA2C45D0D-802E
   VINID: 92296AAAA5A62560400022440840632F5F
   Part No SW: 0D9 300 012 E    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4504
   Revision: 05853104    Serial number: TFK01408290985 CVN: 000094A3
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 18347B8BE3EE364D9B-804C
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 62384000000119
   Coding: 32AA608D1A9915AB409A0068C2938306444C0658A8020043C16022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 4084F3EBDBFE5E8D03-8014
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 160
                    Mileage: 97800 km
                    Date: 2022.09.16
                    Time: 14:12:01
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0345706070
   Coding: 000F0F1720
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 77F65837CEB0D93572-8022
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0020
   Revision: 20008000    Serial number: 89300000002319
   Coding: 410040000011101100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6CDC775B87F66AED8F-8038
   Humidity sensor: exterior:
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H06 0010
   Serial number: 00000000000000002970
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0010
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0010
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0010
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H06 0010
   Coding: 1BC7F7
   Coding: 00005D
          U10F3 00 [009] - -
                    Reset counter: 102
                    Mileage: 97461 km
                    Date: 2022.05.26
                    Time: 10:19:05
                    CAN-Bus_aktiv: On
                    OFF: operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 14.6 V
                    Outside temperature: 24.0 °C
                    Reset counter: 102
                    Mileage: 97461 km
                    Date: 2022.05.26
                    Time: 10:19:05
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 14.6 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39211424701517
   Coding: 0000040011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3B7E8407B2183D5556-806E
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R002AF0
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   VCID: 4D9ADADF1CAC83E5F8-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 509 14
   Serial number: 35700000000BA1911117
   Subsystem 2 - Part No SW: -----------    HW: 480 001 509 14
   Serial number: 35800000000F45FCF01/
   Subsystem 3 - Part No SW: -----------    HW: 480 012 708 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A0112665C55C0W
   Subsystem 4 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3550002BD156E9E3418I
   Subsystem 5 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3560002AF156E9E4B1DX
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2300002C3175A8E112A
   Subsystem 7 - Part No SW: -----------    HW: 480 002 508 14
   Serial number: I0M00000000555FCBE0L
   Subsystem 8 - Part No SW: -----------    HW: 480 002 808 14
   Serial number: I0N00000000BF34DD01F
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8S0 907 129 AB    HW: 8S0 907 129 AB
   Component: Lenks. Modul  H06 0140
   Revision: --------    Serial number: 91335NIN00190
   Coding: 0818
   ASAM Dataset: EV_SMLSKLOMQB 019002
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H31 0221
   Coding: 24050050698006000120E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76E85533C9BAA03D69-8022
   Part No SW: 8S0 907 468     HW: 8S0 907 468
   Component: GW MQB TT3    012 0184
   Revision: --------    Serial number: 29081410801554
   Coding: 030100042F025A004B0002683C0000000000000000000000000000000001
   GVL: 01D43C1000000600408C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 7DFA4A1FEC8CF36528-8028
   Generator:
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H06 0001
   Serial number: 20140806131741 RD086
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 0158653003
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7742
   Serial number: HA1-00011.08.14
   Coding: 0101
   VCID: 458AE2FFC4DC7BA530-8010
   Serial number: 14000196689010
   Coding: 0900000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E2662FA0D48705BC-8024
   Serial number: 03091401100943
   Coding: 001F46224001040100001402
   VCID: 4280F9E3D5F24C9D15-8016
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5061
   Coding: 9103
   VCID: 377698378E301935B2-8062
   Part No SW: 8S0 035 465     HW: 8S0 035 465
   Component: MIB2_amp_P_TT H06 0170
   Revision: 00000001    Serial number: AUZ8ZAEH7001KU2
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 72E06923A5D2BC1D45-8026
   Serial number: 05091402090886
   VCID: 4182F6EFD0F457850C-8014
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0090
   Coding: 03EE001E2B230200
   Shop #: WSC 61373 001 1048576
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005008
   VCID: 336EAC279A48F5158E-8066
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 020 P    HW: 8S0 035 020
   Component: MU-H-ND-EU    H33 0117
   Serial number: A259H0EB001375
   Coding: 013304010000000011111102000800002F0000E300700000DE
   VCID: 356A923F943CEB25A0-8060
   Subsystem 1 - Part No SW: V03 959 801 ES    HW: -----------
   Component: ECE 2014/2015  --- 0086
   Subsystem 2 - Part No SW: 8S0 919 614 A    HW: 8S0 919 614 A
   Component: ControlUnit_H  H21 0124
   Serial number: C1000022071400010069
   Compact disc data bank:
   Component: Gracenote  --- 1010
   Part No SW: 8S0 980 653     HW: 5Q0 980 653
   Component: MQB_MFK       H06 0002
   Serial number: 10000124881
   Coding: 0100010001010305000501000000010100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 140812201981
CHADTT
Stoke-on-Trent, UK
C?ID=45372
Hi,
I removed the sounder and cleared the codes, cycled the ignition and re-scanned, the same faults appeared.
With the new sounder the faults are the same.
Just wondering if it's actually a wiring problem?
Have you by chance got a copy of the wiring diagram for the alarm system?
Hmm.. Might indeed be a wiring or power problem then.
Wiring diagrams are copyrighted (by VWAG) material and I have to keep my nose clean, sorry. But being in the UK, you should be able to get what you need with a cheap, 1-hour subscription to erWin.
CHADTT
Stoke-on-Trent, UK
C?ID=45372
Fuse F6 in the glovebox is ok.
All fuses in engine bay are ok
Pin 1 of the sounder socket is showing 12v
Pin 2 is grounded. (Across pins 1 and 2 shows 12v).
Can only assume Pin 3 is the communication channel.
Would it be possible to ask if someone can list the settings/codings/adaption values to check that the alarm horn is enabled?
CHADTT
Stoke-on-Trent, UK
C?ID=45372
Hi Uwe
Traced from wiring diagrams that Pin 3 to the alarm is supplied by a 10Amp fuse in the engine bay fusebox.
This fuse was missing, possibly pulled by previous owner as the old alarm horn was not working.
Alarm now works fine.
Thanks to everyone for their help.
